Edorn
CPT.Pirk
#108151
Hááát... Most nem tudom kipróbálni, de visszagörgetve, talán az alábbi rész lehetett. De ez csak egy erős talán... Amint tudom, újra kipróbálom és akkor megnézem azt is, hogy dmesg mit dob ki rá.
Illetve 1920 x 1080 felbontás.[ 0.612257] pci 0000:28:00.0: vgaarb: setting as boot VGA device[ 0.612257] pci 0000:28:00.0: vgaarb: bridge control possible[ 0.612257] pci 0000:28:00.0: vgaarb: VGA device added: decodes=io+mem,owns=none,locks=none[ 0.612257] vgaarb: loaded[ 0.612257] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0[ 0.612257] hpet0: 3 comparators, 32-bit 14.318180 MHz counter[ 0.614135] clocksource: Switched to clocksource tsc-early[ 0.614896] VFS: Disk quotas dquot_6.6.0[ 0.614904] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)[ 0.615080] AppArmor: AppArmor Filesystem Enabled[ 0.615124] pnp: PnP ACPI init[ 0.615244] system 00:00: [mem 0xf0000000-0xf7ffffff] has been reserved[ 0.615376] system 00:01: [mem 0xfd200000-0xfd2fffff] has been reserved[ 0.615702] system 00:03: [io 0x0a00-0x0a0f] has been reserved[ 0.615704] system 00:03: [io 0x0a10-0x0a1f] has been reserved[ 0.615706] system 00:03: [io 0x0a20-0x0a2f] has been reserved[ 0.615707] system 00:03: [io 0x0a30-0x0a3f] has been reserved[ 0.616064] pnp 00:04: [dma 0 disabled][ 0.616465] pnp 00:05: [dma 0 disabled][ 0.616746] system 00:06: [io 0x04d0-0x04d1] has been reserved[ 0.616748] system 00:06: [io 0x040b] has been reserved[ 0.616750] system 00:06: [io 0x04d6] has been reserved[ 0.616751] system 00:06: [io 0x0c00-0x0c01] has been reserved[ 0.616753] system 00:06: [io 0x0c14] has been reserved[ 0.616754] system 00:06: [io 0x0c50-0x0c51] has been reserved[ 0.616756] system 00:06: [io 0x0c52] has been reserved[ 0.616757] system 00:06: [io 0x0c6c] has been reserved[ 0.616759] system 00:06: [io 0x0c6f] has been reserved[ 0.616760] system 00:06: [io 0x0cd8-0x0cdf] has been reserved[ 0.616762] system 00:06: [io 0x0800-0x089f] has been reserved[ 0.616763] system 00:06: [io 0x0b00-0x0b0f] has been reserved[ 0.616765] system 00:06: [io 0x0b20-0x0b3f] has been reserved[ 0.616766] system 00:06: [io 0x0900-0x090f] has been reserved[ 0.616768] system 00:06: [io 0x0910-0x091f] has been reserved[ 0.616770] system 00:06: [mem 0xfec00000-0xfec00fff] could not be reserved[ 0.616772] system 00:06: [mem 0xfec01000-0xfec01fff] could not be reserved[ 0.616774] system 00:06: [mem 0xfedc0000-0xfedc0fff] has been reserved[ 0.616776] system 00:06: [mem 0xfee00000-0xfee00fff] has been reserved[ 0.616777] system 00:06: [mem 0xfed80000-0xfed8ffff] could not be reserved[ 0.616779] system 00:06: [mem 0xfec10000-0xfec10fff] has been reserved[ 0.616781] system 00:06: [mem 0xff000000-0xffffffff] has been reserved[ 0.617458] pnp: PnP ACPI: found 7 devices[ 0.623259] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns[ 0.623333] NET: Registered PF_INET protocol family[ 0.623451] IP idents hash table entries: 262144 (order: 9, 2097152 bytes, linear)[ 0.634347] tcp_listen_portaddr_hash hash table entries: 8192 (order: 5, 131072 bytes, linear)[ 0.634366] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)[ 0.634418] TCP established hash table entries: 131072 (order: 8, 1048576 bytes, linear)[ 0.634590] TCP bind hash table entries: 65536 (order: 9, 2097152 bytes, linear)[ 0.634673] TCP: Hash tables configured (established 131072 bind 65536)[ 0.634736] MPTCP token hash table entries: 16384 (order: 6, 393216 bytes, linear)[ 0.634780] UDP hash table entries: 8192 (order: 7, 524288 bytes, linear)[ 0.634834] UDP-Lite hash table entries: 8192 (order: 7, 524288 bytes, linear)[ 0.634892] NET: Registered PF_UNIX/PF_LOCAL protocol family[ 0.634897] NET: Registered PF_XDP protocol family[ 0.634909] pci 0000:20:00.0: PCI bridge to [bus 21][ 0.634922] pci 0000:20:01.0: PCI bridge to [bus 22][ 0.634924] pci 0000:20:01.0: bridge window [io 0xf000-0xffff][ 0.634929] pci 0000:20:01.0: bridge window [mem 0xfce00000-0xfcefffff][ 0.634938] pci 0000:20:04.0: PCI bridge to [bus 25][ 0.634950] pci 0000:03:00.2: PCI bridge to [bus 20-25][ 0.634952] pci 0000:03:00.2: bridge window [io 0xf000-0xffff][ 0.634957] pci 0000:03:00.2: bridge window [mem 0xfce00000-0xfcefffff][ 0.634965] pci 0000:00:01.3: PCI bridge to [bus 03-25][ 0.634967] pci 0000:00:01.3: bridge window [io 0xf000-0xffff][ 0.634971] pci 0000:00:01.3: bridge window [mem 0xfce00000-0xfcffffff][ 0.634977] pci 0000:27:00.0: PCI bridge to [bus 28][ 0.634983] pci 0000:27:00.0: bridge window [io 0xe000-0xefff][ 0.634988] pci 0000:27:00.0: bridge window [mem 0xfcb00000-0xfccfffff][ 0.634991] pci 0000:27:00.0: bridge window [mem 0x7c00000000-0x7e0fffffff 64bit pref][ 0.634997] pci 0000:26:00.0: PCI bridge to [bus 27-28][ 0.634999] pci 0000:26:00.0: bridge window [io 0xe000-0xefff][ 0.635004] pci 0000:26:00.0: bridge window [mem 0xfcb00000-0xfccfffff][ 0.635007] pci 0000:26:00.0: bridge window [mem 0x7c00000000-0x7e0fffffff 64bit pref][ 0.635013] pci 0000:00:03.1: PCI bridge to [bus 26-28][ 0.635015] pci 0000:00:03.1: bridge window [io 0xe000-0xefff][ 0.635018] pci 0000:00:03.1: bridge window [mem 0xfcb00000-0xfcdfffff][ 0.635021] pci 0000:00:03.1: bridge window [mem 0x7c00000000-0x7e0fffffff 64bit pref][ 0.635025] pci 0000:00:07.1: PCI bridge to [bus 29][ 0.635032] pci 0000:00:08.1: PCI bridge to [bus 2a][ 0.635035] pci 0000:00:08.1: bridge window [mem 0xfc800000-0xfcafffff][ 0.635041] pci_bus 0000:00: resource 4 [io 0x0000-0x03af window][ 0.635042] pci_bus 0000:00: resource 5 [io 0x03e0-0x0cf7 window][ 0.635044] pci_bus 0000:00: resource 6 [io 0x03b0-0x03df window][ 0.635045] pci_bus 0000:00: resource 7 [io 0x0d00-0xffff window][ 0.635047] pci_bus 0000:00: resource 8 [mem 0x000a0000-0x000dffff window][ 0.635048] pci_bus 0000:00: resource 9 [mem 0xc0000000-0xfcffffff window][ 0.635050] pci_bus 0000:00: resource 10 [mem 0x440000000-0x7fffffffff window][ 0.635051] pci_bus 0000:03: resource 0 [io 0xf000-0xffff][ 0.635053] pci_bus 0000:03: resource 1 [mem 0xfce00000-0xfcffffff][ 0.635054] pci_bus 0000:20: resource 0 [io 0xf000-0xffff][ 0.635056] pci_bus 0000:20: resource 1 [mem 0xfce00000-0xfcefffff][ 0.635057] pci_bus 0000:22: resource 0 [io 0xf000-0xffff][ 0.635058] pci_bus 0000:22: resource 1 [mem 0xfce00000-0xfcefffff][ 0.635060] pci_bus 0000:26: resource 0 [io 0xe000-0xefff][ 0.635061] pci_bus 0000:26: resource 1 [mem 0xfcb00000-0xfcdfffff][ 0.635063] pci_bus 0000:26: resource 2 [mem 0x7c00000000-0x7e0fffffff 64bit pref][ 0.635064] pci_bus 0000:27: resource 0 [io 0xe000-0xefff][ 0.635066] pci_bus 0000:27: resource 1 [mem 0xfcb00000-0xfccfffff][ 0.635067] pci_bus 0000:27: resource 2 [mem 0x7c00000000-0x7e0fffffff 64bit pref][ 0.635068] pci_bus 0000:28: resource 0 [io 0xe000-0xefff][ 0.635070] pci_bus 0000:28: resource 1 [mem 0xfcb00000-0xfccfffff][ 0.635071] pci_bus 0000:28: resource 2 [mem 0x7c00000000-0x7e0fffffff 64bit pref][ 0.635073] pci_bus 0000:2a: resource 1 [mem 0xfc800000-0xfcafffff][ 0.635307] pci 0000:28:00.1: D0 power state depends on 0000:28:00.0[ 0.635481] PCI: CLS 64 bytes, default 64[ 0.635499] pci 0000:00:00.2: AMD-Vi: IOMMU performance counters supported[ 0.635528] Trying to unpack rootfs image as initramfs...[ 0.635550] pci 0000:00:01.0: Adding to iommu group 0[ 0.635567] pci 0000:00:01.3: Adding to iommu group 1[ 0.635586] pci 0000:00:02.0: Adding to iommu group 2[ 0.635608] pci 0000:00:03.0: Adding to iommu group 3[ 0.635623] pci 0000:00:03.1: Adding to iommu group 4[ 0.635642] pci 0000:00:04.0: Adding to iommu group 5[ 0.635661] pci 0000:00:05.0: Adding to iommu group 6[ 0.635682] pci 0000:00:07.0: Adding to iommu group 7[ 0.635698] pci 0000:00:07.1: Adding to iommu group 8[ 0.635720] pci 0000:00:08.0: Adding to iommu group 9[ 0.635736] pci 0000:00:08.1: Adding to iommu group 10[ 0.635761] pci 0000:00:14.0: Adding to iommu group 11[ 0.635775] pci 0000:00:14.3: Adding to iommu group 11[ 0.635837] pci 0000:00:18.0: Adding to iommu group 12[ 0.635851] pci 0000:00:18.1: Adding to iommu group 12[ 0.635865] pci 0000:00:18.2: Adding to iommu group 12[ 0.635879] pci 0000:00:18.3: Adding to iommu group 12[ 0.635893] pci 0000:00:18.4: Adding to iommu group 12[ 0.635905] pci 0000:00:18.5: Adding to iommu group 12[ 0.635919] pci 0000:00:18.6: Adding to iommu group 12[ 0.635933] pci 0000:00:18.7: Adding to iommu group 12[ 0.635973] pci 0000:03:00.0: Adding to iommu group 13[ 0.635996] pci 0000:03:00.1: Adding to iommu group 13[ 0.636019] pci 0000:03:00.2: Adding to iommu group 13[ 0.636024] pci 0000:20:00.0: Adding to iommu group 13[ 0.636030] pci 0000:20:01.0: Adding to iommu group 13[ 0.636036] pci 0000:20:04.0: Adding to iommu group 13[ 0.636045] pci 0000:22:00.0: Adding to iommu group 13[ 0.636061] pci 0000:26:00.0: Adding to iommu group 14[ 0.636088] pci 0000:27:00.0: Adding to iommu group 15[ 0.636125] pci 0000:28:00.0: Adding to iommu group 16[ 0.636158] pci 0000:28:00.1: Adding to iommu group 17[ 0.636174] pci 0000:29:00.0: Adding to iommu group 18[ 0.636194] pci 0000:2a:00.0: Adding to iommu group 19[ 0.636213] pci 0000:2a:00.1: Adding to iommu group 20[ 0.636233] pci 0000:2a:00.3: Adding to iommu group 21[ 0.636255] pci 0000:2a:00.4: Adding to iommu group 22[ 0.637866] AMD-Vi: Extended features (0x58f77ef22294a5a, 0x0): PPR NX GT IA PC GA_vAPIC[ 0.637873] AMD-Vi: Interrupt remapping enabled -
Edorn
Alábbi problémára esetleg tudtok tippet/megoldást?
Vettem egy új monitort MSI MAG 244F , amit összekötöttem az RX 6650 XT videokártyámmal. És a probléma, hogy pár másodpercig van kép, aztán elsötétül pár másodpercre, aztán vissza és így tovább. Azt vettem észre, hogy ha megmozdítom az egeret, akkor fixen elsötétül. Elsötétülés és működés ideje random, de kb pár másodperc, de mindig más hosszúságú.
Windows is van a gépen, azzal indítva minden jól működik.
A régi monitorom HDMI->DVI átalakítóval működik, mert a régi monitoromon csak DVI aljzat van. Azzal megy a linux pöcre.
Az új monitor gyári HDMI->HDMI kábellel produkálja a fenti dolgot csak linux alatt. (ugyanaz a HDMI aljzat a videokártyán)
Kellene valamit telepítenem?
Linux: Nobara (42) KDE Plasma Desktop Edition
(majd hosszú távon a terv, hogy DisplayPort kábellel lesz csatlakoztatva, de az még megrendelve sincs...)
Edorn
Csak én vagyok nagyon béna (feltételezem igen), vagy tényleg ennyire nincs megoldva linuxra az automatikus frissítés?
Már meguntam, hogy kb kétnaponta dobja fel a rendszer felugró ablakban, hogy éppen 20-200 db frissítés érkezett: frissítsek. Lefrissítem, de pár nap múlva megint jön az üzenet, hogy újabb 20-200db frissítés érkezett...
Mindenfelé kerestem, hogy hátha be lehet állítani, hogy mondjuk kétehetente, vagy havonta nekem bőven elég, ha ellenőrzi, hogy van-e frissítés. De nem találtam ilyen lehetőséget.
Olyat sem találtam, hogy ne szólogasson, hanem a háttérben szépen frissítse le magának amit kell, max a nagy frissítéseknél szóljon... de semmiképpen se 1-2 naponta zaklasson.
Fedora alapú nobara van telepítve, így a Fedora hivatalos oldalán találtam automatikus frissítésre lehetőséget (dnf-automatic megoldás). Be is állítottam. Újraindítottam a gépet, elkezdtem nézni egy filmet, erre egyszercsak szó nélkül újraindul a gép. Mert kitalálta, hogy akkor ő most lefrissít mindent, ami jó is, csak nem érdekli mit csinálok, újra is indul. Ráadásul a frissítés sem sikerült rendesen: asztalom, tálcám eltűnt (többszöri újraindítás után is). Nagy nehezen előbányásztam (asztal, tálca, menű nélkül vicces volt) a frissítési alkalmazást és kézzel újra lefrissítettem, így már újraindítás után jó volt minden.
Szóval én vagyok csak ilyen szerencsétlen és ez valami kivételes eset volt, vagy ez így működik?
Edorn
Krusader vagy Double Commander beállításban tudnátok segíteni? Mindegy melyikben, csak az egyik megoldódjon:
Krusader:
Hogy tudom beállítani, hogy ki legyen emelve, hogy éppen hol járok? Tudom, alul és felül színnel kiemeli, hogy éppen melyik oldalon vagyok, de ha éppen benne vagyok valamiben és gyorsan akarok valamit átmásolni/törlöni/akármi, nagyon nem az oldal alját fogom nézni.
(fenti képen, ha nem nézed az oldal alján lévő kék csíkot, meg nem mondod, hogy melyik az aktív oldal és nekem nagyon nem oda fókuszál a tekintetem, ha éppen nagyon benne vagyok valamiben... Hogy lehetne mondjuk kék kerettel kiemelni az aktív sort, vagy valami?)Double Commander:
Itt nagyon szépen látom hol járok, csak itt meg az smb nem működik. Olvastam, hogy gvfs plugin kellene hozzá... de hogy telepítek plugin-t? -
Edorn
Ez így rendben van, hogy ennyi verzió van? A linux telepítése után emlékeim szerint kettő volt a nobara-ból, aztán 1-2 hétre rá egyszercsak feltűnt a 3. Ez itt megáll magától, vagy gyűlni fog míg valahogy én el nem távolítom? No és mi okból? x ideig elérhetőek az előző verziók hiba esetére visszaállási pontként, vagy mi okból? Hirtelen csak ez jutott eszembe, mint ésszerűnek tűnő magyarázat...
Edorn
Távoli asztalhoz milyen megoldást javasolnátok? Linuxról szeretnék elérni Windows 2008 R2 szervert (3389 port).
Próbáltam Remmina-t, de akárhogy állítgatom, nem sikerül kapcsolódni. Még jelszó bekérésig sem jut el...
Edorn
Videó letöltésre mit ajánlanátok, ha:
- legyen egyszerű
- választhassak minőséget és formátumot
- lehető legtöbb helyről tudjon letölteni: youtube, vimeo, esetleg Facebook, xxx, kismillió egyéb/egyedi oldalak.Ha lehet pontos elérést írjatok, mert pl Média Downloader nevezetű alkalmazásból is csak a beépitett csomagkezelőben van vagy 5 változat ugyanolyan néven.
Edorn
Krusader file manager-ben hogy tudom beállítani a Kompare fájlösszehasonlítót?
A Kompare-t Flatpost-al telepítettem. Startmenüből futtatni is tudom. Viszont a Krusader beállításoknál ha jól gondolom a függőségeken belül a "diff utility" mezőben meg kellene adni az elérési útját. Azt hol találom? Hivatalos honlapján nincs, egy Krusader leírásban találtam egyet, de az nem működik (/usr/bin/kompare). Terminálban a "flatpak info org.kde.kompare" telepítési útvonalat nem ír.
Edorn
Edorn
#105219
Végül nem kevés kattintgatás, próbálgatás, kismillió leírás átolvasgatása után meglett:
Fenti hdajackretask futtatása, majd a 0x14 színének átállítás zöldre, jack detection átállítása: No Present-re. 0x1b jack detection átállítása: No Present-re. InstallBootOverride. Majd újraindítás után a megszokott helyen (tálca óra melletti hangerőikon) már ha átváltok fejjhalgatóról vonalkimenetre, akkor végre átvált hangfalra.
Edorn
Esetleg egy dmesg --follow és nézed a kimenetet, miközben húzgálod a csatikat?
Nem mutatta, illetve a kiadott lista sem nyújtott semmi támpontot.
Próbáltam úgy is, hogy a fenti kezelőfelületen minden nem mikrofonnak megjelöltet bepipáltam és átállítottam NotPresent-re. Nem volt eredménye. Majd mindet Present-re. De ennek sem.
Edorn
Ó, néztem én, meg próbálgattam, de hát van egy pár lehetőség (lefelé még lehet tekerni az ablakban, nem ennyi lehetőség van!).
De sem az elnevezések nem stimmelnek, sem a színek, sem a lehetőségek száma. Mi alapján lőjem be, hogy egyáltalán melyik soron kell módosítanom és hogy mit?
Edorn
Remélhetőleg utolsó nyűgöm linuxra való áttérésben.
Mert minden egyéb tökéletesen, sőt jobban működik, mint windows-on.
Ami meglepett, hogy a játékok nem hogy jobban, de hibamentesebben működnek, mint windows-on!Ami még nem működik: a hangfalam.
A fejhallgatóm-mikrofonom a ház csatlakozójába van bedugva, az működik rendesen.
Viszont van az MSI B450 GAMING PLUS alaplapi hangkártya (Realtek® ALC892 - 7.1-Channel High Definition Audio) csatlakozójába dugva egy Edifier hangfal (1jackdugós, nincs kihasználva a 7.1). Az nem működik sehogysem.Linux tálcán az óra mellett a hangerőszabályzónál át tudok váltani fejhallgatóról vonalkimenetre a portoknál, de semmi.
Google keresés alapján erre akadtam több helyen is: [link]
De a kezelőfelületén nem tudok elmenni, hogy mit-hogy kellene átállítani, bár próbálkoztam pár variációval, de nem jártam sikerrel...hdajackretask kezelőfelület:
Edorn
cigam
#105212
Időközben sikerült így működésre bírni:
Flatpost-al telepített Jellyfin Server -> azon belül DLNA bővítmény telepítése.Ezt már látja a médialejátszó. Bár a Jellyfin működése elég nyakatekert, de egyelőre megteszi, legalább működik.
Azért ránézek majd a miniDLNA-ra is, mert sokan ajánlották külföldi fórumokon, csak oda ha jól láttam sok terminálos/konfigfájlos bűvészkedés kell.
Edorn
a gépre is be lehet törni úgy sok esetben
Akkor inkább hagynám az smb1-et.
DLNA valószínű jó lenne, mert az az UPNP-re épül.
Közben találtam egy ilyet, amint tudom kipróbálom:
https://snapcraft.io/install/home-media-server/fedora
De ha van jobb/beváltabb módszer megoldás, akkor kíváncsi vagyok rá! -
Edorn
Az "Official – Nobara’s Custom themed version of KDE" verziót raktam fel.
Közben sikerült utánaolvasnom nem a Commanderre szűkítve és így már találtam infót, és sejtem, hogy mi is lehet ez a GTK/Qt dolog...
Qt6-os változatot felraktam (Double Commander). Valamiért hálózati meghajtó felcsatolás nem megy vele (ami viszont sima Dolphin-al megy). Ezt még ki kell okoskodnom, meg hogy miképpen tudom átállítani a betűtipusát, mert valami borzalmasan undorító...
Edorn
Az mit számít (mondjuk Double Commander kapcsán), hogy GTK2, Qt5 vagy Qt6 verzió?
Próbáltam utánaolvasgatni, de kb mindenhol azt írják, hogy próba aszerencse, ha megy akkor jó, mit érdekel bárkit is, hogy milyen verzió... Illetve valami olyasmit, hogy a GTK2 gyorsabb, de ki akarják vezetni, de attól még lehet működni fog...
Edorn
fekete.puma
#105174
Igen, Nobara lett végül.
Illetve NotepadQQ-t is, remélem hamarosan lesz időm tesztelni.
Már csak valami TotalCommander féleség kellene, amivel ftp-zni is lehet. A fentebb ajánlottakat nem találtam, bár még csak gyors keresésre volt időm, igyekszem este jobban utánajárni. (wine-ozni nem szeretnék, ha egy mód van rá)
Levelezőnek Thunderbird, ami win-en is volt.
Videolejátszásra VLC, ugyancsak win alapján... :-)
Böngésző Chrome, főleg a kismillió könyvjelző, meg egyéb szinkronizálható dolog miatt. -
Edorn
Tudtok esetleg linuxra ajánlani valamit Total Commander helyett? (valamit, ami a leginkább megközelíti a windows-os Total Commander-t)
Illetve windows-os Notepad++ helyett valamit PHP szerkesztésre? (vagy ebből van linuxos változat, csak én nem találom?)
Edorn
cigam
#105053
A windows-os ssd-t egyáltalán nem piszkálnám linux alól, ami meg egy teljesen külön m.2 ssd-n lenne.
Viszont a windows indításkor felcsatol két meghajtót a NAS-ról. Ez akkor gondolom okozhat gondot, mivel azokat a meghajtókat linux alól is el szeretném érni (felcsatolni).Elég csak a windows-nál kikapcsolni a gyors indítást, vagy linux alatt is van neki megfelelője?
Edorn
Sz_Imre
#105026
A GRUB telepítését a linux telepítése során lehet valahol bepipálni? Csak mert nézek videokat, de sehol nem látom ezt a lépést, viszont a telepítés végén automatikusan a GRUB-al indul mindenkinél a rendszer. Vagy automatikusan telepíti, ha látja, hogy másik háttértáron van másik indítható rnedszer?
Edorn
No hátha még van aki nem unja a nagyonkezdő kérdéseimet a nagy félig-meddig win-ről linuxra áttérés kapcsán.
Szóval a helyzet: Jelenleg van egy win10-em, amit nagyon nem szeretnék újratelepíteni, max csak frissíteni win11-re. Ez egy 500GB-os sima ssd-n van.
A terv:
- Rendelek egy m.2 SSD-t a linuxnak.
- Mivel sokan nagyon mondják, hogy rengeteg játék jól fut már linuxon, így
a választott linux: Nobara lesz.
- Így ugye meg tudom azt csinálni, hogy az M.2-re telepítem a linuxot a GRUB-al(gondolom ez ide fog kelleni). A windows-hoz meg nem nyúlok, csak mint választási lehetőség fog megjelenni indításkor...
- BIOS-ban az M.2-t adom meg, hogy onnan induljon a rendszer, feljön GRUB, kiválasztom, hogy az M.2-n lévő linux induljon-e, vagy a sima SSD-n lévő windws...Ugye ez így kivitelezhető?
Linuxot az M.2-n EXT4 fájlrendszerrel hozzam létre?ui.: Így ha nem jön be a Nobara, akkor gondolom így nagyon egyszerű újrapakolni valami mással és ne mkockáztatom win-t.
Edorn
fekete.puma
#104981
Gondolom mert a video készítője a legalapabb összetevőkkel telepítette... De installnál lehet választani:
Vagy ettől függetlenül sem ajánlott mindennapi használatra + esteleg játékra?Kifejezetten játékra van esetleg erősen ajánlott megoldás?
Edorn
Edorn
Telepítő választásánál merült fel a kérdés: mi a különbség a x86-64-v2 és x86-64(-v1?) között? Listákat persze találtam, hogy egyik a cpu ezen funkcióit használja, másik meg azokat, de hát ezek ugye nem mondanak sokat... Kell-e ezen agyalnom (AMD Ryzen 5 5600 3.50GHz AM4), vagy ezek ilyen nagyon spéci procikhoz vagy feladatokhoz vannak kitalálva, amik nekem úgyse lehetnek itthon...
Edorn
Warton
#104870
Milyen játék?
Most leginkább Hunt: Showdown, de sok régi játék is előkerül: Thief minden része, Heroes 3, Mordheim, Total War játékok, stb... Némelyik tán linux alatt is elindul...Almalinux-on gondolkodom nagyon, mert több szerveren is használom terminálon... Kérdés mennyire használható/kézreeső/stb napi munkára, miegyébre...
Edorn
Windows 10-ről váltanék Linuxra.
(a Win11 egy hulladék, a win10 1éves hosszabbítás feltételei meg undorítóak)Milyen Linux-ot ajánlotok? ReactOS? Vagy még túl kiforratlan?
Terv: Az asztali gépemre teleítek Win10-et vagy 11-et, mert játékokhoz sajnos kikerülhetetlen. A játékokon kívül viszont minden másra linuxot használnék. (Böngészőn keresztüli munka, LibreOffice [jelenleg is ezt használom], thunderbird, filmnézés, stb...) Egyedi, windows függő alkalmazásom nincs.
Két NAS meghajtó van felcsatolva NTFS: ezt semmiképpen se barmolja szét, de gondolom ettől már egyik linux alatt sem kell tartanom... ugye?!
Régen csináltam már (10+ éve) bootolás során választható több oprendszeres gépet... ha van hozzá jó/ajánlott leírásotok, megköszönnék egy linket.
Szóval milyen Linux-ot ajánlotok?
Edorn
SSH-n másolok ftp-n:
ftp ipcim
prompt
mput *.pdfHogy tudom azt megoldani, hogy ami már megvan a célhelyen, azt ne másolja át?
Illetve a fenti módszerrel való másolás esetén, ha hiba történik, akkor újrapróbálkozik, vagy leáll hibaüzenettel, vagy megy tovább a többi fájlal és nem fogom látni, ha hiba történt másolás során?
Edorn
CentOs 7.x alatt terminál log-ot hogy tudok lekérni a lehető legnagyobb időintervallumra?
Azaz, hogy ssh-n belépve milyen parancsok lettek futtatva (root felhasználó által)...Felfelé cursorral vissza tudnám nézegetni elég sokáig, de gondolom van erre jobb módszer is...
Edorn
A hup-os link lemaradt:
http://hup.hu/cikkek/20140408/roundcube_webmail_1_0_0#comment-1722298 -
Edorn
Hogy tudnám CentOS Linux 7.1.1503 (Core) alatt a roundcube (1.1.3) webes levelezőt úgy beállítani, hogy a levelek listájának betöltődése gyorsabb legyen? (2000 levélnél már érezhetően lassú, keresnél meg végkép)
hup-on több mint egy éve linkeltek valakinek egy leírást az optimalizálásról annyi súgóval, hogy a cacheléssel lesz a probléma:
http://trac.roundcube.net/wiki/Howto_Config/PerformanceDe nem akarok szétbarmolni semmit a próbálkozgatásokkal, hogy mi is kell nekem ebből, ezért kérnék itt segítséget...
Edorn
Van egy php scriptem, ami egy nagyobb fájlt dolgozna fel. Eddig egy régi tárhelyen legalább félig meddig lefutott: a fájl egy részét feldolgozta, majd megállt, mert kifutott az időből.
Most egy új vps szerveren egy ideig tölt az oldal, majd Internal Server Error-ad vissza... A logban ezt találom:
[Sat Jun 13 11:25:10.567481 2015] [fcgid:warn] [pid 2983] (104)Connection reset by peer: [client 145.236.63.12:63585] mod_fcgid: error reading data from FastCGI server
[Sat Jun 13 11:25:10.567514 2015] [core:error] [pid 2983] [client 145.236.63.12:63585] End of script output before headers: index.phpMi lehet a hiba és hogyan orvosolhatom?
CentOS Linux 7.1.1503 (Core) 64 bit
php: 5.4.16-23.el7_0.3
nginx: 1.6.0-1.14082516.centos7/var/log/httpd/suexec_log:
[2015-06-13 11:25:36]: uid: (10002/valami) gid: (1003/1003) cmd: cgi_wrapper -
Edorn
Vps-t szeretnék bérelni több php/mysql honlap számára, viszont linux téren eléggé kezdő vagyok. A jó, hogy nagyon jól előtelepítetten adják át, alig kellett legutóbb is hozzápiszkálni (cégünknek is rendeltünk régebben).
Most magamnak rendelném, és ki szeretném kérni a véleményeteket, hogy szerintetek mivel legyen előtelepítve és miért. Melyikkel lenne a leggyorsabb, vagy éppen legegyszerűbben kezelhető ha felmerül valami probléma vele...
Amik közül lehet választani:
- Debian 7.0
- Ubuntu 12.04
- Ubuntu 14.04 (64bit)
- CentOS 6.0
- CentOS 7.0 (64bit)(1db 1 000 MHZ proci, 1024 MB memória, 50GB tárterület és a legújabb PLESK-el lehet piszkálgatni, no meg ssh-n root-ként)
Milyen program ami... [link]
- Teszt [Linux] A Flatpak
- Árváltozás: Deus Ex Human Revolution Collector's Edition
- Vírusirtó, Antivirus, VPN kulcsok
- BLACK FRIDAY! - Jogtiszta Windows - Office & Vírusirtó licencek- Azonnal - Számlával - Garanciával
- Zalman S3 Black modern, letisztult szèpsèg
- HIBÁTLAN iPhone 15 Pro Max 256GB Natural Titanium -1 ÉV GARANCIA -Kártyafüggetlen, 100% Akkumulátor
- Apple iPhone SE 2020 64GB, Kártyafüggetlen, 1 Év Garanciával
- iPhone 12 mini 64GB Black -1 ÉV GARANCIA - Kártyafüggetlen, MS3457, 94% Akkumulátor
- Samsung Galaxy S23 Ultra Green 120 Hz Dynamic AMOLED 2X, 200 MP kamera, beépített S Pen
