Támadást találtam a rendszer log-ban:
nov 29 00:21:08 bodyserver sshd[4090]: Disconnected from authenticating user root 180.101.88.224 port 44560 [preauth]
nov 29 00:21:08 bodyserver sshd[4090]: Received disconnect from 180.101.88.224 port 44560:11: [preauth]
nov 29 00:21:08 bodyserver sshd[4090]: Failed password for root from 180.101.88.224 port 44560 ssh2
nov 29 00:21:04 bodyserver sshd[4090]: Failed password for root from 180.101.88.224 port 44560 ssh2
nov 29 00:21:01 bodyserver sshd[4090]: Failed password for root from 180.101.88.224 port 44560 ssh2
nov 29 00:21:00 bodyserver sshd[4090]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=180.101.88.224 user=root
nov 29 00:20:06 bodyserver sshd[4088]: Disconnected from authenticating user root 180.101.88.224 port 16844 [preauth]
nov 29 00:20:06 bodyserver sshd[4088]: Received disconnect from 180.101.88.224 port 16844:11: [preauth]
nov 29 00:20:03 bodyserver sshd[4088]: Failed password for root from 180.101.88.224 port 16844 ssh2
nov 29 00:20:01 bodyserver sshd[4088]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=180.101.88.224 user=rootés ez ismétlődik
Az adguard home is jelzett, de az más volt:
Szóval mindenki ügyeljen a biztonságra, támadnak a kínaiak rendesen
ubyegon2
#91666
Átnéztem mindent amit tudtam. Live rendszeren érdekes módon az fsck azt mondta, h használatban van az nvme pedig se a
dfse amountnem mutatta, h fel lenne csatolva. Mindegy, ssh-n megnéztem a hdsentinel-t, minden ok:body@bodyserver:~$ sudo ./HDSentinelHard Disk Sentinel for LINUX console 0.20.10851 (c) 2023 info@hdsentinel.comStart with -r [reportfile] to save data to report, -h for helpExamining hard disk configuration ...HDD Device 0: /dev/nvme0HDD Model ID : GIGABYTE GP-GSM2NE3128GNTHDD Serial No: SN194108904664HDD Revision : EDFM00.2HDD Size : 122104 MBInterface : NVMeTemperature : 15 °CHighest Temp.: 15 °CHealth : 91 %Performance : 100 %Power on time: 742 days, 9 hoursEst. lifetime: 896 daysTotal written: 2.03 TBThe status of the solid state disk is PERFECT. Problematic or weak sectors were not found.The health is determined by SSD specific S.M.A.R.T. attribute(s): Available Spare (Percent), Percentage UsedNo actions needed.Akkor az nvme-cli-vel megnéztem a partíciók "align-itását". Azok is rendben vannak. És a smart log is:
body@bodyserver:~$ sudo nvme smart-log /dev/nvme0n1Smart Log for NVME device:nvme0n1 namespace-id:ffffffffcritical_warning : 0temperature : 15 C (288 Kelvin)available_spare : 100%available_spare_threshold : 5%percentage_used : 9%endurance group critical warning summary: 0data_units_read : 3.581.288data_units_written : 4.361.099host_read_commands : 26.127.680host_write_commands : 152.044.287controller_busy_time : 13.756power_cycles : 59power_on_hours : 17.817unsafe_shutdowns : 21media_errors : 0num_err_log_entries : 567Warning Temperature Time : 0Critical Composite Temperature Time : 0Thermal Management T1 Trans Count : 0Thermal Management T2 Trans Count : 0Thermal Management T1 Total Time : 0Thermal Management T2 Total Time : 0Szóval csak vakarom a fejem - miközben most tök jól megy a rendszer. De ha itthagyom és napközben be akarok ssh-zni tuti szét lesz hullva
Meg kéne próbáljam frissíteni a fw-t ezzel a gigabyte cuccal? Csak az elég macerás ahogy nézem: kéne egy win-es gép szabad nvme slot-al. Azt nem tom, h hozom össze
#91670Warton:
Én fw frissítéssel nem játszanék wine-al az tuti
Ilyen inkompatibilitást már rég nem tapasztaltam (2008 környékén dobtam otthonról a win-t, akkoriban azért belefutott az ember hasonlókba).
ASUS S1090 PRIME J4005I-C
gigabyte gp-gsm2ne3128gntdNo mindegy, van a fiókban másik ssd- legfeljebb újrahúzom a rendszert arra.
De előtte azért ránézek egy live rendszeren (bár nem tudom mit csinálna egy fsck a file rendszerrel mivel ha újra indítom (reset gombbal) a gépet akkor "megjavul" - kb. 1 napra)
Friss szerver telepítésemen (ubi) belefutottam egy
systemd-journaldhibába. Megy a rendszer ~1 napot aztán elhal valamiért (nem tudja írni rootfs-t?)
Bocs, h így post-olom. A hiba alatt ssh-n nem lehet elérni a gépet
Ez egy ASUS S1090 PRIME J4005I-C + Celeron J4005 erőmű, alaplapon nvme ssd + 2 sata ssd. Úgy gondolom, h a rendszer meghajtóval van vmi gondja (az alplapi nvme), de mi?
Keresgéltem a hiba után és azt ajánlották, h frissítsem a ssd fw-t:
Crash systemd-journal Failed to write entry. Ignoring read-only file systemLátott már valaki ilyesmit?
tordaitibi
#86598
termináldiszlexiás - ezen jót derültem
Én meg inkább egérdiszlexiás vagyok - sok mindent gyorsabb parancssorból megcsinálnom mint egerészni
ViZion
#86279
Nálam is hasonló elvárásokkal egy ilyen szerver üzemel 24/7-ben
- ubi 20.04.5 -> már régóta nyaggat, h frissítsem de ssh-n nem merem elindítani - bill + kijelzőt meg nincs kedvem rákötni
- i3 6100
- 8 Gb ram
- 3 ssd tárolásra
- vízzel hűtve egy pici itx házban
A szolgáltatások:
- médiaszerver: plex
- torrent: qbittorrent
- cloud backup: syncthing
- dns szűrés: adguard home
- vpn: tailscale
- monitorozás: glancesA torrent-en letöltött dolgokat a plex automatice beolvassa, beteszi a média könyvtárába. Ha telón lövök egy fotót a syncthing menti (egy külön ssd-re) és a plex is beteszi a fotóim közé. Az adguard-ot gondolom ismered, listákkal lehet szűrni mindent. Tailscale-en keresztül elérem a szervert a telómról, céges gépről, a tab-ról, bárhonnan ahova felteszem a kliensét. A glances meg azért kellett, h az rpi-n futó home assistant tudja olvasni az adatait - tudom nézegetni a HA alatt
Meg eseményeket is lehet(ne) hozzáadni a különböző értékekhez. Jah és router kérdés. Az asus routerekhez jár ddns szolgáltatás és persze padavan is mehet rájuk
Megcsináltam a hétvégén a szerver migrálását. Clonezilla lett belőle - nem vitt rá a lélek újrahúzni az egészet, konfigurációkat átvinni. 64 GB-os meghajtóról 128-asra került - teljesen feleslegesen, az előző is félig volt csak - ez volt kéznél. Klónozás után át kellett még méretezni a partíciót, ip címet átállítani a réginek a címére és megy minden ahogy kell
CPT.Pirk
#85916
Teljesen friss a rendszer, nem annyira régi a vas (i5 3570T) csak egy valamivel újabb 6. gen I3 lesz befogva szervernek - a régi rendszeren 1 db sata port van de 4 meghajtó van ráakasztva (usb-n) ezt szeretném megszüntetni
body@bodyserver:~$ uname -aLinux bodyserver 5.4.0-126-generic #142-Ubuntu SMP Fri Aug 26 12:12:57 UTC 2022 x86_64 x86_64 x86_64 GNU/LinuxElső körben akkor klónozni fogom a meglévő rendszert, és meglátjuk. Természetesen uuid-vel vannak felcsatolva a meghajtók, azokat majd átirkálom első boot előt.
/dev/disk/by-uuid/f8fd6a4c-efb4-488b-8d29-acafc4502305 / ext4 defaults 0 0/dev/disk/by-uuid/B0AE-BC88 /boot/efi vfat defaults 0 0/swap.img none swap sw 0 0tmpfs /opt/omd/sites/monitoring/tmp tmpfs noauto,user,mode=755,uid=monitoring,gid=monitoring 0 0/dev/disk/by-uuid/1fe71971-a14b-4b32-8c41-e7a9fcb0aed3 /mnt/ssd ext4 defaults 0 2/dev/disk/by-uuid/cc928aee-6229-4bc8-9eac-858162dcd0ec /mnt/store1 ext4 defaults 0 2/dev/disk/by-uuid/68054c62-41a8-4e07-b78e-6612337924e8 /mnt/ssd2 ext4 defaults 0 2/dev/disk/by-uuid/EEB0C948B0C9184B /mnt/usb ext4 0 2 -
growler
#85909
Nem klónozni kellene sztem mivel új (más) hw lesz alatta
Mondjuk egy klónozott meghajtót lehet érdemes lenne rádugni az újgépre - hátha összeszedi magát
#85910CPT.Pirk:
Kicsit olvasgattam közben a témában és úgylátom ez a menete:
1. a két gépen azonos OS (esetemben ubuntu server)
2. a két gépen azonos csomagok, szolgáltatások
3. a forrásgépről átmásolni a beállításokat a célgépre
4. kész is
Meglévő szerverem szeretném migrálni egy új gépre. Van rajta egy jó nagy halom szolgáltatás, nem szeretném újra konfigurálni az egészet. Tudtok mutatni egy guide-ot ami bemutatja a mikéntjét?
#79129
Kipróbáltam nálam, h terheli a procit a qbittorrent:
11 MiB/s a letöltés (nem tudom miért ilyen lassú éppen...)
973 qbittor+ 20 0 1930416 607088 17696 S 22.3 7.6 51:34.37 qbittorrent-nox
model name : Intel(R) Core(TM) i5-3470T CPU @ 2.90GHz
szal ez egy 4/4-es proci és azt eszi meg 20-25%-ra
htop-al nézve 1 szál / mag teker 20-25%-on ha ez érdekes -
tordaitibi
#78778
Azt azért tegyük hozzá, h desktop (otthoni) felhasználásnál ez az arány. Szerver, szuperszámítógép, iot azért más a helyzet
Én 2008-ban mondtam fel (otthon) teljesen a win-nek (akkoriban ubuntu 8.04 még cd-ről települt
), azt meguntam pár kiadás után (az pár év
)és fedorára álltam át - jó sokáig maradt is. Most viszont visszatértem debian alapú rendszerekre (a raspberry miatt is, Mint 20 lett a választott - ezen a rendszeren már semmit nem kell reszelni, out of the box az egész). Van egy szerverem is amin uborka 20 szolgál (nagyon jól dokumentált azért választottam és egy szervernek mindegy is kb. úgyis magadnak telepíted rá a dolgokat pl. ami nálam fut rajta: plex, torrent, adguard, sync home, home assistant) El se tudnám képzelni az életem windows-on
MostaPista
#78765
Mindenre: 2016 februárjától a Fedorának becslések szerint 1,2 millió felhasználója van, köztük Linus Torvalds, a Linux kernel alkotója. - Ö csak tudja
MostaPista
#78753
A fedora kiemelt biztonságú, telepítsd azt. Nem egy kezdő barát de majd megszokjátok egymást
Véreshurka
#78526
Én úgy "tanultam", h /mnt vagy /media alá csatolunk meghajtókat
Jelen esetben egy a helyi hálón lévő smb megosztást:sudo mount -t cifs -o user=pi //192.168.1.215/pi2_share /mnt/pi2_share/Itt ügye pi nevű felhasználó nevében az /mnt/pi2_share mappába. De azt a mappát nem tudom a nevemre venni (és bele írni simán a body nevű felhasználóval):
body@bodyserver:~$ touch /mnt/pi2_share/valami.filetouch: cannot touch '/mnt/pi2_share/valami.file': Permission deniedKipróbáltam, h a /home/body alá csatoltam, úgy is megváltozik a tulajdonosa (root-ra) miután belecsatoltam a megosztást.
drwxr-xr-x 2 root root 0 Apr 24 04:06 pi2_share_homeA felállást azért vázolom, hátha rájössz a megoldásra
- helyi háló 3 gép = szerver, pi2, desktop (amiről irkálok) mind3 linux
- a pi2-n lévő smb megosztásba szeretnék írni (root jog nélkül)
- az ubi szerveren ssh-n vagyok belépve
- pi2-n van pi és body nevű felhasználó (mind2 samba user is)Miután felcsatoltam a pi2 megosztását megváltozik a csatolási pont jogosultsága (root-ra).
A pi-ről nézve ez látszik:
pi@raspberrypi2:~ $ ls /home/pi/shared/ -allösszesen 40drwxr-xr-x 2 pi pi 4096 ápr 24 06:06 .drwxr-xr-x 9 pi pi 4096 ápr 23 11:05 ..-rwxrw-rw- 1 pi pi 30166 ápr 22 15:32 check-mk-agent_2.0.0p3-1_all.deb-rwxrw-rw- 1 pi pi 0 ápr 24 06:06 valami.fileA szerverről meg ez:
body@bodyserver:~$ ls /mnt/pi2_share -alltotal 1028drwxr-xr-x 2 root root 0 Apr 24 04:06 .drwxr-xr-x 7 root root 4096 Apr 24 06:19 ..-rwxr-xr-x 1 root root 30166 Apr 22 13:32 check-mk-agent_2.0.0p3-1_all.deb-rwxr-xr-x 1 root root 0 Apr 24 04:06 valami.fileÉrtelemszerűen így nem tudok beleírni mint body
A pi-n lévő smb conf:[pi2_share]path = /home/pi/sharedwriteable=Yescreate mask=0777directory mask=0777public=novalid users = pi bodyValamit nem látok, de mit?
Véreshurka
#78524
cli-ből tudok másolni root-ként - csak miért nem tudom írni a saját /mnt mappám ahogy szeretném? Az /mnt-n belül mindennek tudom váltani a jogait
jah, a kérdésedre a válaszod, az smb felhasználónak is kell jog, h írjon
Megakadtam.
cli-ből felcsatolt smb megostást nem tudom írni. root-ként tudom, ofcourse
és az "érdekes", h nem is tudom átruházni. smb.conf-ban van vmi?
So, a megosztásnak megadott könyvtárat nem tudom módosítani
Szal, csak simán jogosultság probléma? Meg is fejtettem
Véreshurka
#78493
egymás alatt vannak a paraméterek a float ki volt véve (pontosvessző volt előtte)
Véreshurka
#78491
O bakker, tényleg
Pedig már megnéztem a file-t, csak nem elég alaposan
Van nekem egy új ubuntu szerverem, amit nem tudok beállítani openvpn client-nek.
root@bodyserver:/home/body# openvpn bodyserver_client.ovpn
Thu Apr 22 07:16:23 2021 OpenVPN 2.4.7 x86_64-pc-linux-gnu [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [PKCS11] [MH/PKTINFO] [AEAD] built on Sep 5 2019
Thu Apr 22 07:16:23 2021 library versions: OpenSSL 1.1.1f 31 Mar 2020, LZO 2.10
Thu Apr 22 07:16:23 2021 WARNING: No server certificate verification method has been enabled. See http://openvpn.net/howto.html#mitm for more info.
Thu Apr 22 07:16:23 2021 TCP/UDP: Preserving recently used remote address: [AF_INET]193.226.212.175:1194
Thu Apr 22 07:16:23 2021 Socket Buffers: R=[212992->212992] S=[212992->212992]
Thu Apr 22 07:16:23 2021 UDPv4 link local: (not bound)
Thu Apr 22 07:16:23 2021 UDPv4 link remote: [AF_INET]193.226.212.175:1194
Thu Apr 22 07:16:23 2021 TCP/UDP: Incoming packet rejected from [AF_INET]192.168.1.1:1194[2], expected peer address: [AF_INET]193.226.212.175:1194 (allow this incoming source address/port by removing --remote or adding --float)
Thu Apr 22 07:16:25 2021 TCP/UDP: Incoming packet rejected from [AF_INET]192.168.1.1:1194[2], expected peer address: [AF_INET]193.226.212.175:1194 (allow this incoming source address/port by removing --remote or adding --float)
Thu Apr 22 07:16:26 2021 TCP/UDP: Incoming packet rejected from [AF_INET]192.168.1.1:1194[2], expected peer address: [AF_INET]193.226.212.175:1194 (allow this incoming source address/port by removing --remote or adding --float)
Thu Apr 22 07:16:29 2021 TCP/UDP: Incoming packet rejected from [AF_INET]192.168.1.1:1194[2], expected peer address: [AF_INET]193.226.212.175:1194 (allow this incoming source address/port by removing --remote or adding --float)
Thu Apr 22 07:16:30 2021 TCP/UDP: Incoming packet rejected from [AF_INET]192.168.1.1:1194[2], expected peer address: [AF_INET]193.226.212.175:1194 (allow this incoming source address/port by removing --remote or adding --float)- A vpn szerver egy ac1200gu
- Az (egyik) kliens lenne az uborka szerver
- Azonos belső hálón vannak (192.168.x)
- Több kliens is csatlakozik a vpn-hez minden gond nélkül (teló, win)Legeneráltam a .ovpn file-t, áttettem az ubi-ra ott futtatnám:
openvpn bodyserver_client.ovpnde a fenti hibát dobja. Mi a gondja? Mit kell beállítsak?
mod.: azt látom, h hozzá kellene adni a --float paramétert, de azt hova? A routeren csak egy gomb van, h mentse le a .ovpn file-t, semmi paraméter...
Rimuru
#75950
No-no. Ez már egy pár hónapos torrent, plex szerver (volt) ami eddig kitűnően tette a dolgát
Csak nemrég kezdtem új "home projectbe": (otthoni felhőtárhelyet készítenék) és próbálgattam a szolgáltatásokat (hol az egyik pi-n, hol a másikon) Az a lomo dolog nem kerek nekem, valszeg az gubancolta össze a dolgokat. Szerencsére az utolsó telepítéskor jegyzeteltem és csak copy / paste volt a reinstall
Mondjuk a torrenteket rakhatom vissza kézzel
body007
#75945
Hát ezt nem értem. Visszatettem a helyére és megint elmentek a jogosultságok:
pi@raspberrypi4:~ $ ls -all
összesen 120
drwxr-xr-x 16 pi pi 4096 nov 20 22:29 .
drwxr-xr-x 4 pi pi 4096 szept 11 20:27 ..
-rw------- 1 pi pi 12667 nov 20 22:36 .bash_history
-rw-r--r-- 1 pi pi 220 aug 20 12:31 .bash_logout
-rw-r--r-- 1 pi pi 3523 aug 20 12:31 .bashrc
drwxr-xr-x 7 pi pi 4096 okt 27 15:06 bpytop
drwx------ 4 pi pi 4096 szept 11 20:42 .cache
drwx------ 7 pi pi 4096 nov 19 12:59 .config
drwxr-x--- 2 pi pi 4096 okt 30 11:44 configs
drwxr-x--- 3 pi pi 4096 nov 19 13:02 etc
-rw-r--r-- 1 pi pi 13857 okt 16 12:25 get-docker.sh
drwx------ 3 pi pi 4096 szept 11 17:51 .gnupg
drwxr-x--- 2 pi pi 4096 nov 19 13:02 home
drwxr-xr-x 19 pi pi 4096 szept 11 20:16 libtorrent
drwx------ 3 pi pi 4096 szept 11 20:19 .local
-rw-r--r-- 1 pi pi 807 aug 20 12:31 .profile
drwxr-xr-x 11 pi pi 4096 okt 19 12:16 qb43
drwxr-xr-x 11 pi pi 4096 szept 11 20:21 qbit_old
drwxr-xr-x 11 pi pi 4096 okt 22 10:22 qBittorrent
-rwxr-xr-x 1 pi pi 2872 nov 19 12:45 run.sh
-rw-r--r-- 1 pi pi 72 nov 20 22:30 .selected_editor
drwxr-xr-x 3 pi pi 4096 okt 16 12:16 snap
drwxr-x--- 3 pi pi 4096 nov 19 13:02 var
-rw-r--r-- 1 pi pi 180 nov 19 12:46 .wget-hsts
pi@raspberrypi4:~ $ sudo
sudo: /usr/bin/sudo a(z) 0 uid tulajdona kell legyen, és a setuid bitnek beállítva kell lennieEgy sudo parancsot nem tudok kiadni
Egyébként a lomorage-t próbáltam beizzítani (home cloud backup). Ismeri vki?
Hát így semmit nem tudok csinálni a géppel:
pi@raspberrypi4:~ $ service qbittorrent start
==== AUTHENTICATING FOR org.freedesktop.systemd1.manage-units ===
Hitelesítés szükséges a következő elindításához: „qbittorrent.service”.
Authenticating as: root
polkit-agent-helper-1: needs to be setuid root
Error: Incorrect permissions on /usr/lib/policykit-1/polkit-agent-helper-1 (needs to be setuid root)
==== AUTHENTICATION FAILED ===
Failed to start qbittorrent.service: Access denied
See system logs and 'systemctl status qbittorrent.service' for details.
pi@raspberrypi4:~ $ sudo service qbittorrent start
sudo: /usr/bin/sudo a(z) 0 uid tulajdona kell legyen, és a setuid bitnek beállítva kell lennie -
Láttatok már ilyet?
sudo: /usr/bin/sudo a(z) 0 uid tulajdona kell legyen, és a setuid bitnek beállítva kell lenniepi@raspberrypi4:~ $ ls / -all
összesen 84
drwxr-xr-x 22 pi pi 4096 nov 13 11:33 .
drwxr-xr-x 22 pi pi 4096 nov 13 11:33 ..
drwxr-xr-x 2 pi pi 4096 aug 20 12:32 bin
drwxr-xr-x 3 root root 3584 jan 1 1970 boot
drwxr-xr-x 18 root root 3680 nov 20 22:17 dev
drwxr-xr-x 107 pi pi 4096 nov 19 13:20 etc
drwxr-xr-x 4 pi pi 4096 szept 11 20:27 home
drwxr-xr-x 17 pi pi 4096 okt 16 12:12 lib
drwx------ 2 pi pi 16384 aug 20 12:47 lost+found
drwxr-xr-x 3 pi pi 4096 nov 20 13:29 media
drwxr-xr-x 4 pi pi 4096 okt 31 09:19 mnt
drwxr-xr-x 5 pi pi 4096 nov 19 12:59 opt
dr-xr-xr-x 151 root root 0 jan 1 1970 proc
drwx------ 6 pi pi 4096 nov 19 13:04 root
drwxr-xr-x 27 root root 920 nov 21 06:03 run
drwxr-xr-x 2 pi pi 4096 nov 19 12:49 sbin
drwxr-xr-x 4 pi pi 4096 okt 16 12:17 snap
drwxr-xr-x 2 pi pi 4096 aug 20 12:26 srv
dr-xr-xr-x 12 root root 0 jan 1 1970 sys
drwxrwxrwt 4 pi pi 4096 nov 21 00:00 tmp
drwxr-xr-x 11 pi pi 4096 okt 16 12:26 usr
drwxr-xr-x 12 pi pi 4096 okt 16 12:12 varA pi felhasználó tulajdonába került az egész rootfs... Ezt, h csináltam?
Nem, nem adtam ki a chown -R pi:pi / parancsot
Most azt próbálom, h áttettem másik gépre a meghajtót és oda adtam a root-nak a /-t
Most próbál boot-olni (meg ellenőriz egy jó nagy letöltő vinyót).
Egyébként tegnap próbáltam feltenni rá vmit ami több komponenst is hozott, lehet ott kavart be vmi? -
CPT.Pirk
#16223
Unigine Heaven Benchmark 4.0
FPS:
15.7
Score:
395
Min FPS:
5.9
Max FPS:
28.8
System
Platform:
Linux 3.7.6-201.fc18.x86_64 x86_64
CPU model:
AMD Phenom(tm) II X4 945 Processor (3013MHz) x4
GPU model:
GeForce GT 440 PCI Express 304.64 (1024MB) x1
Settings
Render:
OpenGL
Mode:
1360x768 fullscreen
Preset
Custom
Quality
High
Tessellation: Disabledezen se hasít túlságosan, de elviselhetőbb mint a notin...
CPT.Pirk
#16215
FPS:
8.6
Score:
215
Min FPS:
4.4
Max FPS:
16.4
System
Platform:
Linux 3.7.3-101.fc17.x86_64 x86_64
CPU model:
Intel(R) Core(TM) i5 CPU M 520 @ 2.40GHz (2393MHz) x4
GPU model:
NVS 5100M PCI Express 304.64 (1024MB) x1
Settings
Render:
OpenGL
Mode:
1366x768 fullscreen
Preset
Custom
Quality
High
Tessellation: Disableda vindózomon még nv driver sincs (csak amit az ms szállít a w7-hez) ahhoz az 1 progihoz amiért a gépen van nincs szükségem a driver-ra...
lionhearted
#16208
Én lefuttattam egy Quadro NVS 5100M aka GT216 (hp eltebook 8540p) hát a cikkben szereplő felbontáson / beállításokkal siralmas
De szép dolognak tartom, h már linux-on is elérhető ez a teszt
whatnot: nem tudom miért erőlteted, ha vmi nem megy ne használd. használd azt ami "megy". mi köszönjük szépen: nekünk megy...
jackbacsi87
#16013
A legjobb: PhotoRec
McSzaby: a szerver gépen először is fel kell venni a felhasználókat. useradd jancsika majd a jelszót passwd jancsika ezután csinálni neki szekciót az smb.conf-ba [jancsika megosztása] és alatta paraméterezni
CPT.Pirk
#15903
Elkezdtem olvasni azt az írást és komolyan azt hittem, h valaki linux-ot szeretne tenni de nem tudja melyiket, és a halom régi pc world mellékleteiből szeretne választani...
Mondom magamba: ez mér nem tölt le vmit...? Utána jöttek a hda jelű partíciók, azok se mai dolgok...
Aztán rájöttem, h ez egy ősrégi post lenne
Amúgy tetszik az ötlet
scream
#14591
A puppyt nem annyira egyszerű telepíteni mint más "nagy" disztrót, de vállalható (ha ráérsz). Itt egy guide hozzá, sok sikert
Fényévekkel gyorsabb lesz mint akármilyen kiherélt debian. Nekem van egy compac presario 1245 "notim" (12.1" - K6-2 - Puppy - 32 MB RAM - 3.2 GB), száguld vele
DuplaZso
#14517
Ha van logó akkor a prginak is ott kell lennie (nem csak azért mert van logó...
terminálba: whereis java -> ez megnézi neked, h merre van a java parancsod
kb ezt kéne dobjabody@fedorka ~$ whereis java
java: /bin/java /usr/bin/java /etc/java /lib64/java /usr/lib64/java /usr/share/java /opt/jre1.7.0_04-x64/bin/javade az eredménytől függetlenül megpróbálhatod úgy indítani, h bin/java vagy usr/bin/java
DuplaZso
#14498
pl.: mpg123/mpg321 – The Command Line MP3 Players
de ezek is jók lehetnek: 14 of the Best Free Console Based Linux Multimedia Apps -
Az apró tele van ilyen "kőkori" kártyákkal, pl.:
Eladó 6db AGP-s vga --- 1000-3000 Ft
NVidia Inno3D GeForce MX440 128MB DDR (128-bit) [olcsón]+[csere]
MX440 SE 64MB
kicsit alkuszik az ember és ingyen is viheti
jackbacsi87
#14414
Az a és d végűt tartalmazza a kernel a tied b azt nem, érdekes...
Láttam egy 2009es 0 kommentes thread-es is a problémádról...
Esetleg megpróbálhatod betölteni a 2 másik modult hátha, de szerintem meg kell, h íveld
Itt a doksi ami segíthet. -
jackbacsi87
#14406
lsusb mit mond?
No-kia
#12358
Hát javítsd:
Re: How to fix broken packages?
Try
Code:sudo apt-get update
to update your package list.
Then
Code:sudo apt-get autoclean
to clean up any partial packages.
Then
Code:sudo apt-get clean
to clean up the apt cache.
Code:sudo apt-get autoremove
will clean up any unneeded dependencies.
If while doing this you can identify the broken package this code will very forcefully remove it.
Code:sudo dpkg --remove -force --force-remove-reinstreq package name
Change package name to the real name of course.
---remélem érthető
No-kia
#12349
nyiss egy terminált, oda:
sudo apt-get update
sudo apt-get upgrade
ezzel "naprakészre" hozod a rendszert. Ha még támogatott...
A zárt meghajtót ubin egy menüből tudod telepíteni, ha jól rémlik adminisztráció -> zárt meghajtók.
De persze ez nem jelenti azt, h menni is fog mivel a rendszered 2009-es a kártyád meg pár évvel fiatalabb, de prószáld meg
Mr. Elliot
#12278
Ha jól rémlik a pppoeconf "végén" megkérdezi, h automatice kapcsolódjon é a következő boot-kor... Nem e?
mrcrnl
#12197
Kezdésnek vladi elvtárs cikkét tanulmányozd át a programfordításról
De pár mondatba, annyi kb. az egész, h lemásolod a cd-ről (vagy letöltöd a linkről) a tömörített cuccot, kibontod (klikk-klikk majd extract).
Ha nagyon alap a rendszer ehhez jól jön majd egy archívumkezelő. Meg tegyél fel egy synaptic-ot is, h könnyebben keresgélj függőségeket. Kelleni fog a fordításhoz még pár dolog, ezeket terminálba 1 sor beírásával felteheted:
sudo apt-get install file-roller synaptic build-essential gcc
Ha kitömörítetted terminálba navigálj oda. Érdemes könnyen megtalálható helyre tenni pl.: Asztal
cd ~/Desktop/könyvtáradneve
majd amit lentebb írtál:
sudo su
make
make install
modprobe rt5370sta
exitsok sikert
MacCaine
#11914
Szerintem ezzel nem sokra fog menni szegény kezdő júzer...
Valahogy így kellene:
1. Nyiss egy terminált (Itt le kell írni miaz és hol található a menürendszerbe)
2. a. Pötyögd be (inkább másold): lspci | grep wifi <- vagy mittudoménmi...
2. b. hameg nem pci a cucli hanem usb: lsusb | gerp wifi
3. másold ide a kimenetet
4.
Milyen program ami... [link]
- Teszt [Linux] A Flatpak
- Robogó, kismotor
- AMD vs. INTEL vs. NVIDIA
- Fejhallgatós találkozó
- Apple MacBook
- Ingatlanos topic!
- BLACK FRIDAY! - Jogtiszta Windows - Office & Vírusirtó licencek- Azonnal - Számlával - Garanciával
- Eladó Steam kulcsok kedvező áron!
- Path of Exile 2 (POE2) Early Access kulcs
- Samsung Galaxy A80 128GB, Kártyafüggetlen, 1 Év Garanciával
- Nintendo Switch 2 // Számla + Garancia //
- Eladó Apple iPhone 14 Pro Max 128GB / 12 hó jótállás
- Apple iPhone 16 Pro Max 256GB, Kártyafüggetlen, 1 Év Garanciával
- Alkatrészt cserélnél vagy bővítenél? Nálunk van, ami kell! Enterprise alkatrészek ITT
