A Linux Mint bemutatása
Csavargoo8
0xmilan
#10053
checkAPT.py:
CHECK_APT_ERROR---EOL---
<class 'apt.cache.FetchFailedException'>
Error: E:The repository 'http://ftp.freepark.org/ubuntu bionic Release' does not have a Release file., W
pdating from such a repository can't be done securely, and is therefore disabled by default., W:See apt-secure(8) manpage for repository creation and user configuration details., E:The repository 'http://ftp.freepark.org/ubuntu bionic-updates Release' does not have a Release file., W
pdating from such a repository can't be done securely, and is therefore disabled by default., W:See apt-secure(8) manpage for repository creation and user configuration details., E:The repository 'http://ftp.freepark.org/ubuntu bionic-backports Release' does not have a Release file.
Traceback (most recent call last):
File "/usr/lib/python3/dist-packages/apt/cache.py", line 541, in update
pulse_interval)
apt_pkg.Error: E:The repository 'http://ftp.freepark.org/ubuntu bionic Release' does not have a Release file., W
pdating from such a repository can't be done securely, and is therefore disabled by default., W:See apt-secure(8) manpage for repository creation and user configuration details., E:The repository 'http://ftp.freepark.org/ubuntu bionic-backports Release' does not have a Release file.During handling of the above exception, another exception occurred:
File "/usr/lib/linuxmint/mintUpdate/checkAPT.py", line 343, in <module>
check.refresh_cache()
File "/usr/lib/linuxmint/mintUpdate/checkAPT.py", line 92, in refresh_cache
self.cache.update()
File "/usr/lib/python3/dist-packages/apt/cache.py", line 543, in update
raise FetchFailedException(e)
apt.cache.FetchFailedException: E:The repository 'http://ftp.freepark.org/ubuntu bionic Release' does not have a Release file., W
pdating from such a repository can't be done securely, and is therefore disabled by default., W:See apt-secure(8) manpage for repository creation and user configuration details., E:The repository 'http://ftp.freepark.org/ubuntu bionic-backports Release' does not have a Release file. -
Csavargoo8
0xmilan
#10051
Terminálból ugyanúgy hibás. Nálam is a Kfki szervere van beállítva, eddig működött, de most nem megy, ahogyan más sem.
Sudoers:
Defaults env_reset
Defaults mail_badpass
Defaults secure_path="/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/snap/bin"# Host alias specification
# User alias specification
# Cmnd alias specification
# User privilege specification
root ALL=(ALL:ALL) ALL# Members of the admin group may gain root privileges
%admin ALL=(ALL) ALL# Allow members of group sudo to execute any command
%sudo ALL=(ALL:ALL) ALL# See sudoers(5) for more information on "#include" directives:
#includedir /etc/sudoers.d
Csavargoo8
Pár napja nem működik a MintUpdate. Frissítésnél ilyen hibaüzenetet kapok:
Could not download all repository indexes
The repository may no longer be available or could not be contacted because of network problems. If available an older version of the failed index will be used. Otherwise the repository will be ignored. Check your network connection and ensure the repository address in the preferences is correct.
Illetve ezt az információt (log file):
10.28@21:04 ++ Starting refresh (including refreshing the APT cache)
10.28@21:04 ++ Auto-refresh will happen in 0 minutes, 2 hours and 0 days
10.28@21:05 ++ Error in checkAPT.py, could not refresh the list of updates
10.28@21:09 ++ Starting refresh (including refreshing the APT cache)
10.28@21:12 ++ System is up to date
10.28@21:12 ++ Refresh finishedPróbáltam több software source-ot is, de mindegyiknél ugyanez a hiba.
Failed to download repository informationCheck your Internet connection.
Mi lehet a probléma?
Csavargoo8
18.2 KDE-t használok. Egy pár hete olyan gondom van, hogy a Firefoxban és a Double Commanderben nem tudom a menüket használni. Hiába kattintok rá egérrel nem történik semmi. A Firefox kiegészítőket sem tudom így használni.
Mi lehet a gond? Tud valaki segíteni? -
Csavargoo8
Asus X751S laptopon futtatok 18.1 Mintet. Egyedüli oprendszer, nem dual-boot. A felfüggesztéssel és a hibernálással van egy különös problémám. Ha felfüggesztéssel vagy hibernálással állítom le a rendszert, akkor az indulás után változó idővel (20perc-2óra) lefagy a rendszer. Semmire nem reagál, csak újraindítani lehet.
Próbáltam rákeresni a hibára, de nem találtam semmit. Még azt sem tudom eldönteni, hogy hardveres vagy szoftveres a hiba. Valakinek van valami ötlete?
Csavargoo8
Lenovo P2-es telóm csatlakoztatásával szenvedek. Telepítettem az MTPFS-t és az MTP-TOOLS-ot az itt olvasottak szerint. Csatlakoztatom a telómat MTP módban. Erre megjelenik a Double Commanderben egy Lenovo Suite nevű meghajtó, rajta 3 exe fájlal. Ezekkel lehet Usb drivert és programokat telepíteni. Windowsra
. De én linuxon mit kezdjek ezekkel? Segítenétek, hogy hogyan lépjek tovább?
A topik célja: Segítségnyújtás a Linux Mint-et használó kezdők és haladók valamint a még csak azzal ismerkedők számára.
Kérdés előtt olvasd el a topik összefoglalóját! -> [link]
- The Elder Scrolls Online Imperial Collector s Edition
- Keresünk iPhone 16/16e/16 Plus/16 Pro/16 Pro Max
- REFURBISHED - Lenovo ThinkPad 40AF Dock (DisplayLink) (2 4K felbontás)
- iPhone 16 Pro 512GB 96% (1év Garancia) ! Utángyártott, jó minőségű kijelző !
- HIBÁTLAN iPhone 12 Pro 128GB Graphite -1 ÉV GARANCIA - Kártyafüggetlen, MS4644
- LG 65EU961H 4K OLED 65" TV! 3840x2160
Rowon
