phoenixke
Ezek utan nem mond hogy automatikusan errl meg arrol meg igy meg ugy :D
phoenixke
Megtalaltam a BIOS leirasat. Ezek utan boldogulnod kell.
[L]http://www.fujitsu-siemens.se/partners/sweden/techsupport/eplb/systems/Manualer/sc_mob_5xx_user.pdf[/L]
A fontosabbak esetunkben:
1.
Diskette A: - floppy disk drive
This field shows the type of the built-in floppy disk drive.
360KB - 5 1/4“, 720KB - 3 1/2“, 1.2MB- 51/4“, 1.44MB - 3 1/2“, 2.88MB - 3 1/2“
The entry depends on the floppy disk drive installed.
Not Installed A floppy disk drive is not installed.
2.
Floppy disk B: - Set external floppy disk drive
This field shows the type of the floppy disk drive in the MobiDock.
360KB - 5 1/4“, 720KB - 3 1/2“, 1.2MB - 51/4“, 1.4MB - 3 1/2“, 2.8MB - 3 1/2“
The entry depends on the floppy disk drive in the MobiDock.
3.
In the Boot menu you define the sequence in which the system BIOS searches the drives for system
files to start the operating system
Phoenix BIOS Setup
Main Advanced Security Power Docking Boot Exit
1. Removable Devices
2. Hard Drive
3. CD-ROM Drive
Hard Drive
Removable Devices
Item Specific Help
F1 Help ¯.|. Item Space Change Values
ESC Exit ¬ ®.|. Menu
Example for Boot menu
Default entry:
2. Hard Drive
3. CD-ROM Drive
If you want to change the start-up sequence:
Place the cursor on the entry for the drive you to which wish to move forward or back.
Press the ) function key to move the selected drive up.
Use the key or the Space key to move forward the selected drive -
phoenixke
Invalid system disk az akkor jelenik meg, ha mar beolvasott valamit, ezen van a hangsuly. Vagyis nem a floppyt olvassa ha az jo. Akkor viszont kell hogy legyen vhol beallitasi lehetoseg. Akkor is latod kerregni a floppyt ha bootol, ha nem feltetlenul arrol megy a boot, mert becsekkolja inditasnal. A regebbi laptopok biosa tud neha furcsa lenni, de kell lennie boot beallitasnak.
- Vezetékes FEJhallgatók
- Parkside szerszám kibeszélő
- Bambu Lab 3D nyomtatók
- BestBuy topik
- Dark Souls sorozat
- ThinkPad T14s Gen 2 i5-1135G7 16GB 512GB FHD 1 év garancia
- Dobozos Új Dell Xps 15 9530 i7 13620h 16gb ram 1tb ssd intel uhd graphics+ Intel Arc A370M
- ÚJ könyv: Walter Isaacson Elos Musk - keménykötésű
- SZÁLCSISZOLT FÉM HATÁSÚ Dell Latitude 5420 14" Touchscreen i5-1135G7 16GB 256GB 1 év garancia
- Új HP 15 Victus FHD IPS 144Hz i7-13620H 4.9Ghz 10mag 16GB 1TB SSD Nvidia RTX 5060 8GB Win11 Garancia
