Blazs120gl
#9
nem mondtam, hogy az ő hibájuk. azt sem, hogy bárkinek a hibája.
"...Az említett videojáték-motor az első rajzolási parancs végrehajtása előtt 517 darab erőforrás-áthelyezést csinált..."
Hellо, I am a compiler.
I just scanned thousands of lines of code while you were reading this sentence. I browsed through millions of possibilities of optimizing a single line of yours using hundreds of different optimization techniques based on a vast amount of academic research that you would spend years getting at. I won't feel any embarrassment, not even a slight ick, when I convert a three-line loop to thousands of instructions just to make it faster. I have no shame to go to great lengths of optimization or to do the dirtiest tricks. And if you don't want me to, maybe for a day or two, I'll behave and do it the way you like. I can transform the methods I'm using whenever you want, without even changing a single line of your code. I can even show you how your code would look in assembly, on different processor architectures and different operating systems and in different assembly conventions if you'd like. Yes, all in seconds. Because, you know, I can; and you know, you can't.
P.S. Oh, by the way you weren't using half of the code you wrote. I did you a favor and threw it away.
- Eredeti játékok OFF topik
- Renault, Dacia topik
- Dell notebook topic
- Így ismerd fel AI nélkül az AI képeket!
- Hivatalos: ekkor mutatkozik be a vivo X300 Ultra, és így néz ki hátulról
- Külföldi prepaid SIM-ek itthon
- Nagyrobogósok baráti topikja
- ÚJ BONTATLAN Apple Macbook Air 15,3 M4 10C CPU/10C GPU/16GB/256GB - Égkék - HUN - mc7a4mg/a 3 év gar
- 27% - Samsung S27D360GAU VA Monitor! 100Hz / 1920x1080 / 4ms
- Újra raktáron! MacBook Pro 14" M1 32GB RAM 27%-os áfás számla
- ÁRGARANCIA!Épített KomPhone Ryzen 9 5900X 16/32/64GB RAM RTX 5070 12GB GAMER PC termékbeszámítással
- 27% - Samsung S27FG904XU Odyssey 3D IPS Monitor! 3840x2160 / 165Hz / 1ms / FreeSync
