TRob1
Megjelent a Total Commander 9.51!
TRob1
"Szokás" szerinti szerdán megjött az újabb RC!
Total Commander 9.22 release candidate 2 -
TRob1
Total Commander 9.22 release candidate 1
Complete list of changes
27.02.19 Release Total Commander 9.22 release candidate 1 (32/64)
27.02.19 Fixed: String "Search result:" in drive label field wasn't updated when changing language (the fix also updates the current tab, but not other tabs) (32/64)
27.02.19 Fixed: Synchronize dirs: Do not warn if local dir contains 2 identical names with different case, e.g. a.txt and A.txt. However, sync functions are limited in this case (32/64)
27.02.19 Fixed: Ctrl+D, add directory to subfolder containing nested subfolders -> it wasn't added at the end of the subfolder, but before the first nested subfolder (32/64)
26.02.19 Fixed: Accessing tab with inaccessible network path can cause a hang when using IgnoreDirErrors=1 (32/64)
26.02.19 Fixed: After uploading zip file to virtual path (e.g. Android device), it could sometimes be opened internally by mistake (32/64)
26.02.19 Added: Included latest unrar dll 5.70.0 from www.rarlab.com (32/64)
22.02.19 Fixed: Handle directory traversal bug in unacev2.dll, affecting only the "unpack all" (Alt+F9) function (32)
17.02.19 Fixed: Shift+F4 dialog: Buttons "Tree" and "Cancel" were incorrect when using Cyrillic translation on English locale (32)
01.02.19 Fixed: Search: Detection of infinite loops in hard links/junctions/reparse points didn't always work (32/64)
23.01.19 Fixed: Couldn't drag directory from separate tree to empty space in tab header to add it (32/64)
21.01.19 Added: Always look in registry for key if no wincmd.key file is found in the supported locations (32/64)
21.01.19 Fixed: ZIP packer: ???? were shown instead of the name when packing to Unicode extra field, and verifying any Unicode mode (32/64)
14.01.19 Fixed: Directory history with shift+mouse wheel not working (64)
14.01.19 Fixed: Lister (F3), internal media player: Window size too small when viewing a lot of mp3 files, so the menu is broken into 2 lines (64)
14.01.19 Fixed: Lister (F3) was ticking the wrong codepage in the "Encoding" menu when opened (64)
14.01.19 Fixed: Folder tabs: when not using multiple lines for tabs, drag & drop of a tab to the opposite panel would add it to the source panel if it had hidden (scrolled) tabs under that position (32/64)
14.01.19 Fixed: Ignore X64Menu option on 32-bit Windows (32)
14.01.19 Fixed: When using X64Menu=1 in 64-bit version, the dialog in context menu - X32 - Configure was very small (64)
12.11.18 Fixed: ZIP packer: An incompressible file slightly smaller than 4GB, resulting in a compressed file >4GB appeared with a size of -1 in the created ZIP (but could still be unpacked) (32/64)
11.11.18 Fixed: Re-upload to FTP after editing now also works when the FTP connection is not displayed in one of the two panels, but still active (32/64)
11.11.18 Fixed: Compare by content, 2 files on the same FTP server but different user names -> edited file could be re-uploaded to the wrong server (32/64)
04.11.18 Fixed: Select all, switch between full and brief view mode: Entire list was scrolled slowly (64)
04.11.18 Fixed: FTP Upload/Download: Selection wasn't cleared when adding files to already opened background transfer manager with F5 - F2 (32/64)
04.11.18 Fixed: Header-encrypted RAR: Open archive, minimize+restore TC, try to unpack file, enter wrong password (remember password checked) -> user isn't asked again for the correct password (32/64)
30.10.18 Fixed: Dual screen, TC on the right screen: Search in separate process, maximize, minimize, restore -> search window had 0*0 pixel size (32/64)
01.10.18 Fixed: FTP error "Command in progress" in special case: Synchronize dirs, compare local dir with ftp, compare by content, edit remote file, save file, close compare tool, re-upload (32/64)
01.10.18 Fixed: Function to check file system links (junctions, reparse points) for infinite loops didn't handle relative paths created e.g. via "mklink /D MyDirLink ..\MyDir" while in directory "C:\MyDir" (32/64)
25.09.18 Fixed: Button bar: cd *.ext (to set custom filter) didn't support Unicode when using separate Left/Right menus (32/64)
24.09.18 Fixed: Multi-rename tool: [f] option didn't work for manually entered text, only for placeholders like [N] -> [f] is now applied for the entire text until the end or the next upper-/lowercase placeholder (32/64)
24.09.18 Fixed: Click on locked tab (directory changes not allowed) showed message about new tab when using TabEnterDirChange=2, but only if it was already the active tab (32)
24.09.18 Fixed: Click on locked tab (directory changes not allowed) showed message about new tab when using TabEnterDirChange=2 (64)
24.09.18 Fixed: Crash when starting external sync tool with /S=S parameter when PreventScrollbarCrash=1 was set (the default on Windows 8.1) (64)
24.09.18 Fixed: Search function: when going through list of old searches with up/down keys while the combobox was closed, the "RegEx" checkmark was only set, not removed (32/64)
24.09.18 Fixed: Search function: when going through list of old searches with up/down keys, the index reverted to the first item when a search with regular expression was encountered (64)
24.09.18 Fixed: Open archive with alternate packer via right click menu (internal association: **ext), then press Ctrl+B -> the default packer was now used (32/64)
23.09.18 Fixed: Crash viewing ICO files containing multiple PNG images (the problem seems to be re-using the TLazReaderPNG) (64)
23.09.18 Fixed: Search in archives by size wouldn't reliably find files >=2GBytes (32/64)
23.09.18 Fixed: Crash unpacking xz-packed zipx archives (because the necessary functions were missing from newer TCMDLZMA.DLL / TCLZMA64.DLL files) (32/64) -
TRob1
3db RC után megjelent a végleges 9.21-es verzió!
TRob1
Már a Total Commander 9.20 rc2-nél járunk!
Úgy néz ki, lassan lesz végleges (ha valaki csak azt szereti
TRob1
Total Commander 9.20 beta 6, ha valaki próbálgatná a friss verzákat.
TRob1
Végre újra van mozgás! Új Total Commander 9.20 beta 1, sok javítással és új funkcióval.
TRob1
TRob1
Na és az új 9.10 beta-t használjátok már?
New functions in Total Commander 9.10:
User interface:
Support for multiple screens with different densities (DPI) per screen on Windows 10 (requires latest release version, "Creators Update", or newer).
Support for Windows 10 fall Creators Update, mainly OneDrive online only file support
Set font quality (e.g. force antialiasing on/off)
Support new pseudo environment variables from values described here - just leave out the FOLDERID_ prefix, e.g. %$AccountPictures%
File operations:
"New folder" (F7) can now use the same placeholders as the multi-rename tool (e.g. date+time), and create multiple directories in one step using a counter
"New text file" (Shift+F4) now supports the same placeholders as the multi-rename tool
"New text file" (Shift+F4) now also works in archives, on FTP servers, and with file system plugins
Option to use latest "Everything" tool in Alt+Shift+Enter/Spacebar free space calculations
Internal 7zip unpacker: Support background unpacking
Lister:
Support touch screen scrolling+text selection
Support Unicode names when loading images via Irfanview (needs new Unicode version of Irfanview)
Compare by content:
Set width in binary mode to 8, 16, 24 or 32 bytes
Multi-rename tool:
New placeholders for inserting current date+time
IMPORTANT-IMPORTANT-IMPORTANT:
We are no longer sending new version notifications by e-mail because they were often deleted by spam filters.
Please use the new manual or automatic update check function, see description here. -
TRob1
Nem is ezzel van a baj... de 7 év alatt azért csak foltozgattak vmit rajta. Pl. ki tudja hány biztonsági rést javítottak ki. Na ezért érdemes (fontos) frissen tartani mindent, nem feltétlen az új funkciók miatt.
Annyi változás volt azóta, hogy végig se lehet olvasni.
TRob1
TRob1
2010-ben adták ki! Látom frissen van tartva a rendszer.
(Persze ez a "hiba" nem feltétlenül ennek tudható be, nade akkor is...
