salaud
daninet
#14483
Átnyálaztam a Fujitsu oldalát, de Fujitsu TE772B monitor nincs. A 772-es típusok datasheet-jében meg hasonló, de nem ugyanakkora frissítési értékek szerepelnek.
Tudd meg a monitorod valódi típusát, akkor tudok segíteni.B772-1: 30–72 kHz
50–160 HzX772-1: 30–70 kHz
50–160 HzE772-1: 30–72 kHz
50–160 HzMCM 172V: : 30–70 kHz
50–120 HzMint látod, mind hasonló méretű, felbontású Fujitsu monitorok, mégsem egyforma. PONTOS típus kell.
salaud
-=Sziszi=-
#14457
Nálam működik a 9.04 beta. És a monitorom is a modeline szerint üzemel.
Milyen monitorod van? Pontos típust adj, és az xorg.conf-od -
salaud
-=Sziszi=-
#14440
Ezt próbáld meg:
# xorg.conf (X.Org X Window System server configuration file)
# This file was generated by dexconf, the Debian X Configuration tool, using
# values from the debconf database.
# Edit this file with caution, and see the xorg.conf manual page.
# (Type "man xorg.conf" at the shell prompt.)
# This file is automatically updated on xserver-xorg package upgrades *only*
# if it has not been modified since the last upgrade of the xserver-xorg
# package.
# If you have edited this file but would like it to be automatically updated
# again, run the following command:
# sudo dpkg-reconfigure -phigh xserver-xorg
Section "ServerLayout"
Identifier "Default Layout"
Screen 0 "aticonfig-Screen[0]-0" 0 0
EndSection
Section "Files"
EndSection
Section "Module"
Load "dbe"# Double-Buffering Extension
Load "v4l"# Video for Linux
Load "extmod"
Load "type1"
Load "freetype"
Load "synaptics"
Load "glx"# 3D layer
Load "dri"# direct rendering
Load "drm"
EndSection
Section "InputDevice"
Identifier "Generic Keyboard"
Driver "kbd"
Option "XkbRules" "xorg"
Option "XkbModel" "pc105"
Option "XkbLayout" "hu"
Option "XkbOptions" "lv3:ralt_switch"
EndSection
Identifier "Configured Mouse"
Driver "mouse"
Option "CorePointer"
EndSection
Section "Monitor"
Identifier "Configured Monitor"
VendorName "ATI Proprietary Driver"
ModelName "Generic Autodetecting Monitor"
HorizSync 30.0 - 70.0
VertRefresh 50.0 - 120.0
ModeLine "1152x864@85" 119.65 1152 1224 1352 1552 864 865 868 907 -HSync +Vsync
Option "DPMS" "true"
EndSection
Section "Device"
Identifier "aticonfig-Device[0]-0"
Driver "fglrx"
Option "VideoOverlay" "on"
Option "OpenGLOverlay" "off"
Option "TexturedVideo" "off"
Option "RenderAccel" "true"
Option "AddARGBVisuals" "true"
BusID "PCI:2:0:0"
EndSection
Section "Screen"
Identifier "aticonfig-Screen[0]-0"
Device "aticonfig-Device[0]-0"
Monitor "aticonfig-Monitor[0]-0"
DefaultDepth 24
SubSection "Display"
Virtual 1152 864
Viewport 0 0
Depth 24
Modes "1024x768@100.00" "1152x864@85.00"
EndSubSection
Option "AddARGBGLXVisuals" "true"
Defaultdepth 24
EndSection
Section "DRI"
Mode 0666
EndSectionFIGYELEM! A
VertRefresh 50.0 - 120.0értékeinek helyére a saját monitorod értékeit írd. Megtalálod a monitor kiskönyvében, illetve a windows driver .inf file-jában, vagy a gyártó weboldalán.
- Revolut
- Projektor topic
- Egér probléma
- Gitáros topic
- BESZÁMÍTÁS! ASUS H110M i3 6100T 8GB DDR4 250GB SSD GTX 1050 Ti 4GB Kolink Inspire K2 aRGB 400W
- Apple iPhone 15 Pro 128GB,Újszerű,Dobozaval12 hónap garanciával
- Samsung Galaxy Z Flip5 512GB,Újszerű,Adatkabel,12 hónap garanciával
- BESZÁMÍTÁS! Apple Macbook Air 15 M4 16GB RAM 512GB SSD notebook garanciával hibátlan működéssel
- S22 Ultra 512/12
