Xiaomi AX3600 WiFi 6 AIoT Router
joq3
friss újonc
I'm sorry for speaking English, but I found this forum thread after having big issues with my AX3600 running 3.0.22 (stock firmware with SSH enabled). After restoring the device and reinstalling firmware I am having issues with Wifi, it seems like /etc/config/wireless is missing completely. So the file system has not been rewritten when I reinstalled the firmware.
Found this firmware by one of your users, which seems to remove bloat:
https://prohardver.hu/tema/xiaomi_ax3600_wifi_6_aiot_router/hsz_2305-2305.html
Is this a good choice in 2024? Also heard about this NSS OpenWRT firmware, but I am not sure it will be stable enough to run on my daily router: https://forum.openwrt.org/t/ipq807x-nss-build/148529/2088What do you recommend? And do you know how to restore the firmware and filesystem completely when installing stock firmware?
Thank you!
Hope it is OK with my English!
- Nvidia Quadro P400/ P600/ P620/ P1000/ T400/ T600/ T1000 - Low profile (LP) + RTX A2000 6/12Gb
- ÁRGARANCIA!Épített KomPhone Ryzen 7 7800X3D 32/64GB RAM RTX 5090 32GB GAMER PC termékbeszámítással
- Konzol felvásárlás!! Nintendo Switch
- BESZÁMÍTÁS! Asus H370 i7 9700K 16GB DDR4 512GB SSD RX 6600 XT 8GB SHARKOON RGB Slider ADATA 600W
- BESZÁMÍTÁS! ASUS PRIME H510M i5 10400F 16GB DDR4 512GB SSD RX 6600 XT 8GB Chieftech BD-25B 600W
