OpenWrt topic
pChriss
-Prometheus-
#1667
tanacstalan vagyok, akarmit probalok vele, nem akar mukodni
pChriss
-Prometheus-
#1658
Mindent a leírtak alapjan csinaltam, megsem akarja az igazat
# Server configuration
config uhttpd main# HTTP listen addresses, multiple allowed
list listen_http 0.0.0.0:81
# list listen_http [::]:81# HTTPS listen addresses, multiple allowed
list listen_https 0.0.0.0:443
# list listen_https [::]:443# Server document root
option home /www# Reject requests from RFC1918 IP addresses
# directed to the servers public IP(s).
# This is a DNS rebinding countermeasure.
option rfc1918_filter 0# Maximum number of concurrent requests.
# If this number is exceeded, further requests are
# queued until the number of running requests drops
# below the limit again.
option max_requests 3# Certificate and private key for HTTPS.
# If no listen_https addresses are given,
# the key options are ignored.
option cert /etc/uhttpd.crt
option key /etc/uhttpd.key# CGI url prefix, will be searched in docroot.
# Default is /cgi-bin
option cgi_prefix /cgi-bin# List of extension->interpreter mappings.
# Files with an associated interpreter can
# be called outside of the CGI prefix and do
# not need to be executable.
# list interpreter ".php=/usr/bin/php-cgi"
# list interpreter ".cgi=/usr/bin/perl"# Lua url prefix and handler script.
# Lua support is disabled if no prefix given.
# option lua_prefix /luci
# option lua_handler /usr/lib/lua/luci/sgi/uhttpd.lua# CGI/Lua timeout, if the called script does not
# write data within the given amount of seconds,
# the server will terminate the request with
# 504 Gateway Timeout response.
option script_timeout 60# Network timeout, if the current connection is
# blocked for the specified amount of seconds,
# the server will terminate the associated
# request process.
option network_timeout 30# TCP Keep-Alive, send periodic keep-alive probes
# over established connections to detect dead peers.
# The value is given in seconds to specify the
# interval between subsequent probes.
# Setting this to 0 will disable TCP keep-alive.
option tcp_keepalive 1# Basic auth realm, defaults to local hostname
option realm OpenWrt# Configuration file in busybox httpd format
# option config /etc/httpd.conf# Certificate defaults for px5g key generator
config cert px5g# Validity time
option days 730# RSA key size
option bits 1024# Location
option country HU
option state Budapest
option location Budapest# Common name
option commonname OpenWrtconfig uhttpd web
option listen_http 0.0.0.0:80
option home /mnt/share -
pChriss
-Prometheus-
#1649
elvegeztem a modositasokat, ezt kaptam puttyban:
root@OpenWrt:~# /etc/init.d/uhttpd restart
bind(): Address already in use
getaddrinfo(): Name or service not known
Error: No sockets bound, unable to continue
root@OpenWrt:~#se listazas, se oldal
pChriss
Egy nekem elegge bonyolultnak tuno kerdessel fordulnek hozzatok.
Adott egy TP-LINK TL-WR842ND router, vargalex v1.1.7 r35342 verzioju openwrt-vel.
Amit szeretnek az egeszbol kihozni, az egy itthoni file server lenne, ami a ra dugott usb /mnt/share mappa tartalmat osztana meg.
Elindultam azon az uton, h telepitettem a routerra egy 2.2.15-3 verzioju Apache servert, ugy ahogy beis konfiguraltam, de itt megall a tudomanyom. Esetleg valaki segithetne az apache konfigolasban is.
Luci-ban a szoftverek kozt latszik h felvan teve, de a rendszerinditasi listaban mar nem talalom, lehet nem is kell latszodnia ?
A myddns-t is bekonfigoltam, de mikor kivulrol akarom elerni a hostomat, csak a Luci login oldalat dobja, mintha nem is menne az apache...
Kerdesem az volna, h ez az elgondolas eletkepes.e vagy esetleg valaki tud jobb es egyszerubb megoldast a problemamra ?
Elore is koszonom a valaszokat.
- The Elder Scrolls Online Imperial Collector s Edition
- Apple iPhone 12 Mini 64GB, Kártyafüggetlen, 1 Év Garanciával
- Lenovo Thunderbolt 3 kábel (4X90U90617)
- Fém, összecsukható és kihúzható fotó állvány eladó
- Apple iPhone 13 Pro Max 128GB, Kártyafüggetlen, 1 Év Garanciával
