tildy
Kicsi más:canon a60, mint webkamera:
1) Download SoftCam http://www.softcam.com
2) Install SoftCam (damm!)
3) Connect the camera to PC and switch it to the Review mode (the same used to download the photos to PC)
4) Turn on the camera
5) Close any window that opened for downloading photos.
6) Open the RemoteCapture software and connect to the camera.
7) Expand the ''Detail Setting'' option
8) At the Angle Adjustment tab, click on the Viewfinder On option
Ok, at this point, you should be seeing the image from your camera
9) Open the SoftCam. At the main window, go to Options: Set it to Default
Live Video Source as ''SoftCam Screen Capture''. OK
10) Drag the button 'Stored x Live' to the Live position
11) A square will appear, drag it so that it frames the camera image. As shown on the preview, it is already capturing what is on screen and emulating a webcam!
12) Open MSN an see if it display a image (or logo) of a webcam. If so, you did it! Note that every time you open a device that uses a webcam, the damm Live X Stored button switch back to Stored.
Persze most merult le az akksim.
probalom egyebkent izzitani szerintem menni fog!!!
- Dell Latitude Precision Üzleti gépek, 2-in-1 gépek, 3-11. gen.
- AKCIÓ! MacOS 26! UTOLSÓ GEN iMac 27" 5K i7-10700K 64GB RAM 512GB NVMe Radeon Pro 5700 XT 16GB gar
- ÁRGARANCIA!Épített KomPhone i5 14600KF 32/64GB RAM RTX 5060Ti 16GB GAMER PC termékbeszámítással
- HIBÁTLAN iPhone 15 Pro 128GB Black Titanium-1 ÉV GARANCIA - Kártyafüggetlen, MS4660
- HP Elitebook / Probook üzleti kategóriás notebookok - i5 - i7 - Ryzen - nagy választékban számlával
