Delila_1
Sub Áthelyezés()
Dim usor As Integer, sor As Integer, sor_1 As Integer
usor = Range("A50000").End(xlUp).Row
sor_1 = 1
For sor = 1 To usor Step 5
Range(Cells(sor, 1), Cells(sor + 4, 1)).Copy
Cells(sor_1, 3).Select
Selection.PasteSpecial Paste:=xlPasteValues, Transpose:=True
sor_1 = sor_1 + 1
Next
End Sub -
Gh0sT
Egy kis elmélet:
''Internal XL passwords are about as useful for security as tissue paper. The reason is that the passwords you enter (i.e., with Tools/Protect/Protect Worksheet or /Protect Workbook) are not used directly in protection. Instead they are hashed (mathematically transformed) into a much less secure code. Effectively, any password of any length is transformed into a string of 12 characters, the first 11 of which have one of only two possible values. The remaining character can have up to 95 possible values, leading to only
2^11 * 95 = 194,560 potential passwords. This may seem like a lot, but it only takes a few seconds for a modern computer to try them all. As a comparison, a 4-character password containing just the 26 lower case alphabet characters has 456,976 combinations, and a 3-character password consisting of lower case, upper case and the digits 0-9 will have 238,328 combinations.''
- RÉSZLETFIZETÉS.BANKMENTES.KAMATMENTES. Új noblechairs EPIC Mercedes-AMG Petronas
- iKing.hu Apple iPhone 14 Pro Deep Purple 128GB használt megkímélt 100% akku 6 hónap garancia
- GYÖNYÖRŰ iPhone 14 Plus 256GB Midnight -1 ÉV GARANCIA - Kártyafüggetlen, MS4526
- Apple iPhone 13 256GB, Kártyafüggetlen, 1 Év Garanciával
- Surface Pro 7+ i5-1135G7 16GB 512GB 1 év garancia
Fferi50
