Nagyon jó az új ESET Internet Security. 1 éve nem használtam de látszik, hogy továbbra is kiváló minőség és maximális védelem jellemzi.
Changlog:
Version 11.1.42.0
Added: UEFI scanning option (Boot sectors/UEFI) added to Computer scan
Added: Additional Diagnostics setting for advanced license logging under Diagnostics folder
Added: Updated Banking and Payment Protection module to support Chrome version 64
Added: Operating system information is displayed for some devices types by Connected Home Monitor
Added: Ability to manually remove devices identified by Connected Home Monitor
Added: Ability to manually specify categories of devices in Connected Home Monitor
Added: Screen reader support for Offline and Live installers
Improved: Security via more frequent update checks for detection engine and modules
Improved: Product installation time reduced
Improved: ESET application status reporting
Improved: Various activation improvements to decrease activation failures
Changed: Anti-Ransomware Protection renamed to Ransomware Shield
Fixed: "Update has not been run yet" is displayed after ESET is already updated
Fixed: Antimalware Scan Interface Integration fails after installation and before restart (Win 10x64 16215)
Fixed: All default tasks are reset after running repair
Fixed: Blue screen error (BSOD) caused by stack overflow
Fixed: Advanced setup menu is corrupted after clicking Default
Fixed: After changing a check box value, text is not read by JAWS
Fixed: The URL for "I forgot my password" is incorrect
Fixed: Cannot select items in context menu
Fixed: Various minor bugs and localization improvements -
Darth_Revan
#5497
Nem az van, hogy érvényes kulcshoz a legújabb verzió jár? Amúgy szerintem szeptember-október fele jelenik meg a 10-es.
Rövid google keresés után találtam pár hasonló hibabejelentést de még eset fórumon se tudtak vele mit kezdeni. Vedd fel a kapcsolatot a hazai forgalmazóval, vásárolt licenszed van szóval meg kell oldaniuk. Ha más nem visszaadják a pénzed. Elérhetőségeikért klikk ide.
Valamivel összeakadhat a rendszeretekben, nem általános hiba.
Kékes525
#5053
Ilyen nekem is volt, 7 napos volt az adatbázis dátum szerint mire vinnyogott, hogy nem naprakész de még gyorsítótár ürítés után se akart frissíteni, mivel rátelepítettem a 8-asra ezért leszedtem teljesen és újratelepítettem. Ha még egyszer előjön akkor dobom a francba, sokan írják, hogy sok a bug bár nekem ezen kívül más nem volt.
King Unique
#4950
Én mindig manuálisan ráfrissítek, sose volt még vele problémám.
Az ESET Smart Security az ESET Live Grid szolgáltatáson keresztül folyamatos kapcsolatban áll az ESET szervereivel, amelyek egy nagyméretű adatbázisban tárolják a felhőben fellelhető összes futtatható fájl ellenőrző összegét (MD5 hash) és annak fertőzött vagy tiszta voltát. Ez az adatbázis a felhasználók gépéről folyamatosan frissül, így ha megjelenik egy fertőzés, akkor az a fájl azonnal tiltólistára kerül a felhasználók gépén a vírusadatbázis frissítése nélkül, megakadályozva ezzel a fertőzés további terjedését. A felhőből származó információk alapján az ESET szerverei egy dinamikus fehérlistát építenek, amely érezhetően lerövidíti számítógépének ellenőrzési idejét.
Tölthető a végleges magyar nyelvű 7-es verzió!
Mosanke
#3563
Annyira mint az aki használja. Sajnos nem fog a Nod minden spyware-t felismerni és riasztani rá de nincs az a vírusirtó amelyik 100%-os pontossággal ismerne minden új vírust. Vannak technikák, pl. HIPS ami bizonyos alapvető tudás esetén segítségére lehet a usernek de akinél nincs meg az az alapvető tudás annak tök mindegy mert minden felugró ablakot engedélyezni fog, valószínűleg így jutott arra a notebookra is a kártevő.
Az én jó tanácsom, hogy Malwarebytes(lehetőleg Pro) és Hitman Pro(scannelésre jó az ingyenes is) legyen a gépen. Be lehet állítani ütemezett keresést mindkettőnél, Malwarebytes-nál felesleges ha a Pro verziót használja az ember de Hitman Pro-nál érdemes hetente 1 ütemezett keresés, gyorsan megcsinálja, nem zavaró. Nálam ez a 2 program alap akármilyen vírusirtót is használok.
Androidos változat nem tudjátok, hogy mikor lesz végleges? Nem találtam infot se fórumon, se honlapjukon erről.
Dictator^
#1739
Igen, a win 95-nek is kisebb a gépigénye az XP-nél vagy Vistanal. Nem szabadna, hogy ennyire zavarjon, mondjuk nyilván függ a hardveredtől illetve ha valami gubanc van szoftveresen, pl. összeakad más védelmi alkalmazásokkal, driverekkel stb. az tényleg okozhat ilyen és ehhez hasonló anomáliákat. Nem tudok mit tanácsolni, én több gépre is telepítettem a 3-ast amióta létezik és most már a 4-est, nem volt vele gond. Használd akkor a 2.7-est, az is jó.
btw.
Új verzió: 4.0.424
- fixed random email corruption with large attachment when scanning read messages
- fixed startup of Mozilla Thunderbird after reinstallation/upgrade from V3 to V4 or after adding an extension
- fixed problems with older Novell clients -
pukkancska
#1723
Moonline.
#1701
A 3-asnál az volt a baj, hogy először fordítóirodának adták, akik ültek rajta pár hónapig, aztán gondolom a Sicontact Kft. mikor kézhez kapta a fordítást a hajuk égnek állt(ahogy az lenni szokott ha ilyen dolgokat fordítóirodára bíznak) és elkezdték újra fordítani, maga a forgalmazó, a Sicontact Kft. Szerencsére most nem cseszik el, nem adták oda senkinek, a Sicontact Kft. fordítja a 4-est is.
wilddog
#1685
Vagy 2.7-es verziót teted fel vagy egy ősrégi 3.0-ás alverziót. A 3.0-ból a legújabb 2008 év végi adatbázissal rendelkezik a 4-es pedig 2009 márciusival.
2.7-et csak akkor használj ha win 2000-ed van, ha újabb rendszerrel rendelkezel ennél akkor ideje lenne 4.0-ra áttérni, nem fogja jobban a géped a 2.7-nél. Ha zavar az angol nyelv akkor 3.0-át tegyél fel, de már csak hetek kérdése a 4.0-ás magyar verzió megjelenése.
cellpeti
#1672
Fájl kivételeket adhatsz csak szerintem, egy bizonyos pendrive-ot nem.
Egyébként új verzió jött ki, nagyon ajánlott frissíteni.
ESET Smart Security v4.0.417.0
ALL
* Fixed display of size when scanning multi-gigabyte archives
ESET SMART SECURITY
* Certificate list now correctly displayed in protocol filtering
ESET PERSONAL FIREWALL
* Added detection for Win32/Conficker worm in firewall
* Fixed detection of binary rules on IPv6 network connections
* Fixed detection of DNS cache poisoning attack
* Fixed detection of TCP streams
* Fixed issue with network disconnections with NICs and residential gateway routers
* Fixed potential hang during Windows login
* Fixed scanning of ARP protocol
* Fixed stop error (BSOD) in Windows Vista when accessing mapped drives
* Fixes and changes to ICMP filtering -
gyáliSanyi
#1637
Nincs mit, örülök, hogy megoldódott.
Nekem is ADSL-em van, de ilyen problémám még nem volt. :S
Ezért sárgul be az ikonja figyelmeztetés céljából 14 nappal a lejárat előtt. Mondjuk ez akkor is szemétség, bár lehet nem szándékos. Arra tudok gondolni, hogy ugye ha lejár a licenced akkor nem frissül az adatbázis, nem tud hatékonyan védeni ezért biztonsági okokból tiltja a netelérést.
gyáliSanyi
#1633
Próbáld felrakni a 3.0.684, ez a legfrissebb, eset.hu-ról letöltheted. Szerintem nem a Nod hibája, Futtatásba írd be, hogy msconfig és nézd meg milyen felesleges dolgok indulnak a rendszereddel. Ha nem vagy biztos benne, hogy mit tilthatsz le akkor másold be ide a nevüket.
gyáliSanyi
#1631
Milyen géped van? Milyen verzió a Nod? Milyen op. rendszer? Mi indul még a Nod mellett a Windows-zal?
- Path of Exile (ARPG)
- Lexus, Toyota topik
- Robogó, kismotor
- Xbox Series X|S
- BestBuy topik
- Milyen program, ami...?
- AKCIÓ! Dell Latitude 5455 14 FHD+ üzleti notebook - Qualcomm X Plus X1 16GB DDR5 512GB SSD W11
- HP Z420 Workstation,Xeon E5-1620 CPU,8GB RAM,500GB SATA3 HDD,WIN10
- Ventilátor bazár /NZXT/CORSAIR/LIAN LI/DEEPCOOL/ZALMAN/120MM/140MM/VEZÉRLŐK/LED KIT-ek/
