zambozoli
Van egy RPi4B-m és egy ideje nem tudja használni a node a ttyACM0 portot, emiatt persze nem mennek a zigbee-s eszközeim se Domoticz alatt. Hogyan tudom megnézni mely szoftverek hasnálják ezt a portot.
npm ezt adja vissza:
pi@pi:/opt/zigbee2mqtt $ npm start> zigbee2mqtt@1.17.0 start> node index.jsZigbee2MQTT:info 2021-01-04 20:49:48: Logging to console and directory: '/opt/zigbee2mqtt/data/log/2021-01-04.20-49-47' filename: log.txtZigbee2MQTT:info 2021-01-04 20:49:48: Starting Zigbee2MQTT version 1.17.0 (commit #07cdc9d)Zigbee2MQTT:info 2021-01-04 20:49:48: Starting zigbee-herdsman (0.13.46)Zigbee2MQTT:error 2021-01-04 20:49:48: Error while starting zigbee-herdsmanZigbee2MQTT:error 2021-01-04 20:49:48: Failed to start zigbeeZigbee2MQTT:error 2021-01-04 20:49:48: Exiting...Zigbee2MQTT:error 2021-01-04 20:49:48: Error: Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'at Znp.<anonymous> (/opt/zigbee2mqtt/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:136:32)at Generator.next (<anonymous>)at /opt/zigbee2mqtt/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:27:71at new Promise (<anonymous>)at __awaiter (/opt/zigbee2mqtt/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:23:12)at SerialPort.<anonymous> (/opt/zigbee2mqtt/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:134:49)at SerialPort._error (/opt/zigbee2mqtt/node_modules/serialport/node_modules/@serialport/stream/lib/index.js:198:14)at /opt/zigbee2mqtt/node_modules/serialport/node_modules/@serialport/stream/lib/index.js:242:12npm ERR! code 1npm ERR! path /opt/zigbee2mqttnpm ERR! command failednpm ERR! command sh -c node index.jsnpm ERR! A complete log of this run can be found in:npm ERR! /home/pi/.npm/_logs/2021-01-04T19_49_48_652Z-debug.logpi@pi:/opt/zigbee2mqtt $ ls -l /dev/serial/by-idösszesen 0lrwxrwxrwx 1 root root 13 jan 4 20:10 usb-Texas_Instruments_XDS110__02.03.00.18__Embed_with_CMSIS-DAP_L1100HQH-if00 -> ../../ttyACM0lrwxrwxrwx 1 root root 13 jan 4 20:10 usb-Texas_Instruments_XDS110__02.03.00.18__Embed_with_CMSIS-DAP_L1100HQH-if03 -> ../../ttyACM1pi@pi:/opt/zigbee2mqtt $ test -w ttyACM0 && echo success || echo failurefailureKöszönöm!
- I5, GTX 1050 Ti, 16GB DDR4 PC
- Mini PC (ITX) i7 265K 9070 XT 32 GB DDR5 8000Mhz
- Eladó félkonfig - csak egy GPU kell bele!
- Új Gamer PC - Ryzen 7 5700X / RTX 5060 Ti / B550M WIFI / 16GB RAM / 1TB SSD / 650W
- !AKCIÓ! GAMER PC Intel Core i9-10900X/ASUS ROG Strix X299-E Gaming/NVIDIA GeForce RTX 3080/32 GB RAM
- Azonnali készpénzes Sony Playstation 5 lemezes és digitális felvásárlás személyesen/csomagküldéssel
- HIBÁTLAN iPhone 13 128GB Green-1 ÉV GARANCIA - Kártyafüggetlen, MS4347
- Keresünk Galaxy S21/S21+/S21 Ultra/S21 FE
- GYÖNYÖRŰ iPhone XR 128GB Red-1 ÉV GARANCIA - Kártyafüggetlen, MS3984, 100% Akkumulátor
- Dell Latitude 5400 14" FHD IPS, i5 8365U, 8-16GB RAM, SSD, számla, 6 hó gar
wassermann
