juve600
Megin sikerült alkotnia a készitőknek:
Mante ha be van kapcsolva akkor nem működik a barátmeghivás meg az shift+tab kombó sem megy
irtam a hivatalos lapra a rebellion szerint a steam hibája,a steam szerint a rebellion hibája
juve600
laceszgamer
#5
nem de teszek fel arról is képet
juve600
ULTRÁN:
Sniper Elite 3 Benchmark Report (Mantle)
Created: 2014-10-02 at 20:58:54
Version 1.11 Build Version: 2014.10.02.001
================================================================Average FPS: 150.3
Minimum FPS: 61.7
Maximum FPS: 314.6Number Of Frames: 11410
Average Frame: 6.655ms
Minimum Frame: 3.179ms
Maximum Frame: 16.219msMachine Name: JUVE
Monitors: 1
Operating System: Windows 8 Professional (build 9200), 64-bit
System RAM: 8147MB
CPU: Intel(R) Core(TM) i5-3470 CPU @ 3.20GHz
Number of Cores: 4GPU Name: ASUS R9 280 Series
Feature Level: Mantle
Dedicated VRAM: 3072MBResolution Width: 1920
Resolution Height: 1080
Texture Detail: ULTRA
Shadows Detail: ULTRA
Draw Distance: ULTRA
Anti-aliasing: OFF
Supersampling: OFF
Anisotropic Level: 1
Obscurance Fields: OFF
Tessellation: OFF
Ambient Occlusion: OFF
Motion Blur: OFF
Vertical Sync: OFF
Reduce Mouse Lag: ON
Stereo 3D: OFF -
juve600
Created: 2014-10-02 at 20:12:39
================================================================Average FPS: 179.1
Minimum FPS: 66.5
Maximum FPS: 270.3Number Of Frames: 13594
Average Frame: 5.583ms
Minimum Frame: 3.699ms
Maximum Frame: 15.046msMachine Name: JUVE
Monitors: 1
System RAM: 8147MB
Texture Detail: MEDIUM
Shadows Detail: MEDIUM
Draw Distance: MEDIUM
Anti-aliasing: OFF
Supersampling: OFF
Tessellation: OFF
Motion Blur: OFF
Vertical Sync: OFF
Reduce Mouse Lag: ON -
juve600
MANTLE NÉLKÜL:
Sniper Elite 3 Benchmark Report (DirectX)
Created: 2014-10-02 at 20:00:20
Version 1.11 Build Version: 2014.09.30.004
================================================================Average FPS: 156.3
Minimum FPS: 43.3
Maximum FPS: 242.2Number Of Frames: 11871
Average Frame: 6.397ms
Minimum Frame: 4.129ms
Maximum Frame: 23.069msMachine Name: JUVE
Monitors: 1
System RAM: 8147MB
Feature Level: DX11.0
Dedicated VRAM: 3054MBResolution Width: 1920
Anti-aliasing: OFF
Supersampling: OFF
Tessellation: OFF
Motion Blur: OFF
Vertical Sync: OFF
Stereo 3D: OFFMANTLE BEKAPCSOLVA :
Minimum FPS: 43.3
Monitors: 1
System RAM: 8147MB
Anti-aliasing: OFF
Supersampling: OFF
Tessellation: OFF
Motion Blur: OFF
Vertical Sync: OFF
Stereo 3D: OFF -
juve600
üdv
a mai frissitéssel végre megkapta a játék a mantle-t illetve a 2 -ből jól ismertt benchmarkot is, a mantle-t a játék inditása után a megjelenő kis ablakban a beállitásoknál tudjátok aktiválni,a benchmark pedig a játékon belül az extrák menüpontban található,nálam is hozott fps növekedést a mantle
- Automata kávégépek
- aquark: Zsebszámológépek
- Kés topik
- Eredeti játékok OFF topik
- Sweet.tv - internetes TV
- Makulátlan hófehér Lenovo,FullHD IPS, core i5 ,GTX 2/6GB 128bit VGA,8-32GB DDR4 RAM/SSD+HDD,Win.11
- HP EliteBook 630 G10 - 13,3'FHD IPS - i5-1335U - 16GB - 1TB - Win11 - 1 év garancia - MAGYAR
- Újszerű Lenovo 15,6"FullHD,10.gen.Core i5(8x3,6Ghz)Intel UHD VGA,8-40GB DDR4 RAM/256-512SSD,jó akku
- Dell Optiplex 3020 SFF,i3-4150,4GB RAM,250GB HDD,DVD+RW,WIN10
- Apple Watch Ultra 3 GPS + Cellular 49mm Natural Titanium Case with Blue/Bright Blue Trail Loop - M/L
- Xbox One S 512 GB + kontroller 6 hó garancia, számlával!
- Lenovo Thinkpad X1 Yoga 6th Gen. i7 11th, 32GB RAM 27% ÁFÁS (0326)
- áthajtós érintős 360 szinteÚJ Dell 16 Plus 2-in-1 Ultra 7 258V INTEL Arc 140V 32GB 1TB SSD 16QHD+
- Dobozos Új HP OmniBook 5 Flip 2-in-1 érintőkijelzős laptop i5-1334U 16gb ram 512ssd Garancia
- Keresünk iPhone 15/15 Plus/15 Pro/15 Pro Max
