OpenWrt topic
Petikeje
Ma hajnali 3:21 magasságában az egyik Asus RT-AC65P dumb ap-nek konfiguralt routeremen elment az 2.4MHz-es wifi: Luci felület alapján a Wireless network enabled, de a státusza disabled. Ha ujrainditom a 2.4-es wifit, akkor ez kerül a System logba:Fri Nov 7 08:10:29 2025 daemon.notice hostapd: Set new config for phy phy0:
Fri Nov 7 08:10:29 2025 daemon.notice wpa_supplicant[1367]: Set new config for phy phy0
Fri Nov 7 08:10:29 2025 daemon.notice netifd: Wireless device 'radio0' is now down
Fri Nov 7 08:10:38 2025 daemon.notice netifd: radio0 (3323): WARNING: Variable 'data' does not exist or is not an array/object
Fri Nov 7 08:10:39 2025 daemon.notice hostapd: Set new config for phy phy0:
Fri Nov 7 08:10:39 2025 daemon.notice wpa_supplicant[1367]: Set new config for phy phy0
Fri Nov 7 08:10:39 2025 daemon.notice hostapd: Set new config for phy phy0: /var/run/hostapd-phy0.conf
Fri Nov 7 08:10:39 2025 daemon.notice hostapd: Restart interface for phy phy0
Fri Nov 7 08:10:39 2025 daemon.notice hostapd: Configuration file: <inline> (phy phy0) --> new PHY
Fri Nov 7 08:10:39 2025 daemon.notice hostapd: Configuration file: Reading configuration file '<inline>'
Fri Nov 7 08:10:40 2025 kern.info kernel: [ 2010.329200] br-lan: port 7(phy0-ap0) entered blocking state
Fri Nov 7 08:10:40 2025 kern.info kernel: [ 2010.340688] br-lan: port 7(phy0-ap0) entered disabled state
Fri Nov 7 08:10:40 2025 kern.info kernel: [ 2010.352172] mt7615e 0000:01:00.0 phy0-ap0: entered allmulticast mode
Fri Nov 7 08:10:40 2025 kern.info kernel: [ 2010.365654] mt7615e 0000:01:00.0 phy0-ap0: entered promiscuous mode
Fri Nov 7 08:10:40 2025 kern.info kernel: [ 2010.383845] mt7615e 0000:01:00.0 phy0-ap0: left allmulticast mode
Fri Nov 7 08:10:40 2025 kern.info kernel: [ 2010.396210] mt7615e 0000:01:00.0 phy0-ap0: left promiscuous mode
Fri Nov 7 08:10:40 2025 kern.info kernel: [ 2010.408708] br-lan: port 7(phy0-ap0) entered disabled state
Fri Nov 7 08:10:40 2025 daemon.err hostapd: Could not set interface phy0-ap0 flags (UP): I/O error
Fri Nov 7 08:10:40 2025 daemon.err hostapd: nl80211: Could not set interface 'phy0-ap0' UP
Fri Nov 7 08:10:40 2025 daemon.notice hostapd: nl80211: deinit ifname=phy0-ap0 disabled_11b_rates=0
Fri Nov 7 08:10:40 2025 daemon.err hostapd: nl80211 driver initialization failed.
Fri Nov 7 08:10:40 2025 daemon.notice hostapd: phy0-ap0: CTRL-EVENT-TERMINATING
Fri Nov 7 08:10:40 2025 daemon.err hostapd: hostapd_free_hapd_data: Interface phy0-ap0 wasn't started
Fri Nov 7 08:10:40 2025 daemon.notice hostapd: hostapd.add_iface failed for phy phy0 ifname=phy0-ap0
Fri Nov 7 08:10:40 2025 daemon.notice netifd: Wireless device 'radio0' is now upMás ugyanilyen típusú routerem gond nélkül megy (az nem dumbap). Hét elején lett minden eszközre telepítve a 24.10.4 openwrt. A vezetékes elérese a roternek ok.
Az I/O error idegesít 1 kicsit. Tönkre mehetett a tárhely? A hét elején volt 2 nap 2szer 1-1 másodperces áramkimaradás.
Van valami ötletetek mi lehet a gond?
Thx! -
Petikeje
E.Kaufmann
#20167
Vargalex, Kaufman: Thx!
Petikeje
Ma elment a net, szolgáltatónál volt hiba. Amíg nem volt net, a telefonomon a wifi azt jelezte, hogy nincs internetkapcsolat. Valamint semmit nem értem el a telefonommal, ami eszközök vannak a hálózatomon (home assistant server, ESPHome eszközök, az openwrts routert nem értem el se IP címmel se hostnévvel...). Viszont az eszközök látták egymást, az ESPHome eszközök státusz ledje nem jelzett hibát, dlna szerverről tudtam filmet nézni. Telefon újraindítása nem segített, több telefonon is ugyanaz volt a helyzet. Van még 2 APm szintén openwrtvel (a "hivatalos" leírás szerint beállítva).
Van valami tippetek, hogy mit kell beállítani, hogyha nincs internetelérés hálózatomon, akkor is elérjem a szerver-szolgáltatásaimat telefonról hálózaton belül?
THX! -
Petikeje
Openwrtsíthető routert keresek a köv paraméterekkel:
Min 4 db gigabites lan port
Gigabites WAN port
Usb port
5GHz-es wifi
Minimum a 22.03 verziót lehessen telepíteni
64+ Mb flash
128+ Mb RAM
Preferált tp-link, xiaomi, Asus (de ezt el tudom engedni)
Hotspotnak lenne.
Tudtok ajánlani vmilyen a fentieknek megfelelő eszközt?
Köszi! -
Petikeje
Van egy Xiaomi Mi Router 3G (21.02.2) és egy Xiaomi Redmi Router AC2100 (21.02.3) routerem a zárojelbe írt openwrt verzióval.
Az openwrt firmware selector alapján mind a kettőre van 22.03.0-rc5, de a supported current rel az adatlapjuk alapján 21.02.3.
Lehet telepíteni rájuk a 22.03-t vagy nem?
A régi konfig fájlok fognak működni?
THX:
P! -
Petikeje
Van egy xiaomi mi3g routerem. Volt rajta openwrt 19.07 és próbáltam frissíteni 21.02re. Valami felrement a frissítésnel, és most tégla. Breed consoleba telneten be tudok lépni, de innen nem tudom, hogy lehet visszahozni az életbe.
Tudtok pls segíteni, mi a teendő?
Thx:
P! -
Petikeje
Azt szeretném kérdezni, hogy m3g routeren, ha paraván fw van, akkor az openwrt bin filet akár betallozhatom az adminisztrációs felületen, vagy kell valami előkészítés? Esetleg teljesen más a telepítési módszer?
A kernel1.bin vagy a rootfs0.bin filet Kell telepíteni?
Thx:
P! -
Petikeje
vargalex
#13319
Ahan THX, valami megmozdult...
Ha betelnetelek, akkor ez az üzenet:
sudo telnet 192.168.1.1
Trying 192.168.1.1...
telnet: Unable to connect to remote host: Connection refused
viszont ez:
sudo telnet 192.168.1.1 22
Connected to 192.168.1.1.
Escape character is '^]'.
SSH-2.0-dropbear
mindenféle krix-krax, és nincs promptom
Erre van 5letetek?
THX:
P! -
Petikeje
van egy 1043-s v1.10-es routerem, amit sikeresen brickeltem.
Próbálom tftp szerveren keresztül rendberakni, de nem akarja az igazat:
Az atftpd szerver raspberry pi-n fut
A raspberrynek 192.168.0.66 az ipcíme
A router lan1 portja össze van kötve a raspberry portjával
A tftp szerver könyvtárában elérhető az utolsó hivatalos firmware vágott verziója átnevezve wr1043nv1_tp_recovery.bin-re
Flash modeba rakom a routert: a sys led nagyon gyorsan villog (szinte folyamatosan világít), de nem történik semmi:
A tftp szerver logjában nem látszódik, hogy valami vinne el fájlt
A router meg csak villogEzeket próbáltam már:
wan portot kötöttem össze raspberryvel
wr1043ndv1_tp_recovery.bin fájlnevű firmwareval
nem vágott firmwarevalMit csinálok rosszul?
Illetve ha ez végkép tégla marad mit ajánlotok helyette? Routeren nekem adblockra meg vpnre lenne szükségem, és opentwrt alatt ezeket össze tudom kalapálni.THX:
P! -
Petikeje
OpenWrt Attitude Adjustment 12.09 van telepítve tplink1043nd routeremre.
ipdns.hu-n van regisztrálva hostom.
ddns beállítások:
A jelszót ellenőriztem többszőr is.
10 percenkéént kapok egy figyelmeztető levelet:
IPDNS autentikációs hiba(Rákerestem itt is és a router topicjában is, egy helyen azt találtam, hogy wget-tel nem jó, hanem curl-t kell telepíteni. ?)
Mit rontok el?
THX:
P! -
Petikeje
1043nd routeren AA OpenWrt van extroot-tal. Minden működik rendesen, de a szolgáltató 50/5-ös netet ad, amit modemen keresztül (router nélkül) el is ér, viszont routerrel kb. 20/2-s sebességet tapasztalok. Mi lehet a baja?
Thx:
P! -
Petikeje
Petikeje
Headless
#8057
THX,
kipróbálom. Egyébként szerintem, ha helyhiány lenne, akkor az lenne a hibaüzenet, hogy unable to save resume file no space left on device.
megpróbálom még valami magasabb log level-lel futtatni a transmission-t...UUID alapján van mountolva.
Egy 1043ND-s router 1.10-es. AA volt rajta most raktam rá a CC-t, azért, mert ezt "ismertem". nem is tudtam, hogy van előre csomagolt.
Üdv:
P! -
Petikeje
Headless
#8055
Hello,
először én is erre gondoltam, de szerintem nem:
/etc/config/transmission-ból:
option config_dir '/etc/transmission'df -h:
Filesystem Size Used Available Use% Mounted on
rootfs 91.8M 17.3M 67.5M 20% /
/dev/root 2.3M 2.3M 0 100% /rom
tmpfs 14.0M 9.1M 5.0M 65% /tmp
/dev/sda1 91.8M 17.3M 67.5M 20% /overlay
overlayfs:/overlay 91.8M 17.3M 67.5M 20% /
tmpfs 512.0K 0 512.0K 0% /dev
/dev/sda3 873.0G 666.1G 160.3G 81% /mnt/sda3mount:
rootfs on / type rootfs (rw)
/dev/root on /rom type squashfs (ro,relatime)
proc on /proc type proc (rw,noatime)
sysfs on /sys type sysfs (rw,noatime)
tmpfs on /tmp type tmpfs (rw,nosuid,nodev,noatime)
/dev/sda1 on /overlay type ext4 (rw,relatime,data=ordered)
overlayfs:/overlay on / type overlay (rw,noatime,lowerdir=/,upperdir=/overlay/upper,workdir=/overlay/work)
tmpfs on /dev type tmpfs (rw,relatime,size=512k,mode=755)
devpts on /dev/pts type devpts (rw,relatime,mode=600)
/dev/sda3 on /mnt/sda3 type ext4 (rw,relatime,data=ordered)
debugfs on /sys/kernel/debug type debugfs (rw,noatime) -
Petikeje
1043nd routeren van OpenWrt telepítve CC. Ext-overlay beállítva.
Transmission valamiért nem működik rendesen. Torrentet elkezdi letölteni, egyszer csak megáll a töltés (pause), és utána nem lehet elindítani. Ha elindítom pár másodperc után a torrent kliens elveszti a kapcsolatot a transmissionnal, és mire újra megnyitom, a torrent pause státuszban van. Egyszer kaptam el egy hibaüzenetet Unable to save resume file: bad address (error code 3), de ezt szerintem az adblockerem csinálta (azt már kikapcsoltam). A torrent kliensnél azt írja, hogy a port zárva van, de ha a router wan ip-jén ellenörzöm a portot, akkor nyitott.
Miért állnak le maguktól a letöltések?
Thx:
P! -
Petikeje
1043-as routeren CC van telepítve. A transmission portja nyitva van, habár a webes kliens azt mondja, hogy zárt a port. Feltöltés megy, letöltés viszont nem (illetve nem tudom). Letöltés közben a webes felület folyamatosan disconnectel pár másodperccel hogy betöltene, és folyamatosan úgy látszódik, hogy 0% a letöltes...
Van beállítva a dnsmasq alatt blocked hosts lista.
Hogy lehet működésre bírni a letöltést, és a webes klienst?
Thx:
P! -
Petikeje
Egy TP-WL1043ND ver1.1 routeremen OpenWRT AA 12.09 van. WiFi jól be van állítva.
Vettem egy ez Share wifi kártyát, amit ha belerakok a fényképezőgépbe, akkor generál egy WiFi hálózatot. Ha ehhez a WiFi hálózathoz csatlakozok, akkor elérek egy oldalt, amin keresztül látom a fényképeket. Minden működik frankón, de hogy a fényképeket pl telefonon tudjam nézni, át kell jelentkeznem másik wifi hálózatra (olyan számítógépről, amin nincs wifi, pedig nem működik).
A kérdésem az lenne, hogy meg lehet-e csinálni, és hogyan, hogy a router kapcsolódik az ezShare kártyához wifin keresztül, és a router wifijén keresztül érem el a kártyán lévő képeket.
THX:
P!
- A TCL egyebek mellett egy 1040 Hz-re képes monitorral készül az idei évre
- Windows 11
- AliExpress tapasztalatok
- iPhone Ultra néven jöhet az Apple első foldja, nem lesz olcsó mulatság
- Filmvilág
- Gumi és felni topik
- BESZÁMÍTÁS! Intel Core i7 6700K 4 mag 8 szál processzor garanciával hibátlan működéssel
- PlayStation Okosító Blu-ray lemezek - PS4 GoldHEN Loader / BD-JB Lapse és PS5 Auto Jailbreak AIO
- iking.hu Apple iPhone 15 128GB Blue használt, karcmentes 86% akku 6 hónap garancia
- Apple iPhone 12 Pro / 128GB / Kártyafüggetlen / 12Hó Garancia
- ÁRGARANCIA!Épített KomPhone Ryzen 5 7600X 32/64GB RAM RTX 5060 Ti 8GB GAMER PC termékbeszámítással
trl+AltGr+g és kaptam egy telnet promptot:
