S_x96x_S
Petykemano
#1109
>Miért pakoltak volna az epyc io lapkájából funkciókat a chipsetbe és nem a ryzen io lapkájába?
nem tudom a választ. talán a " downstream PCIe connectivity" a kulcsszó.
mindenesetre az ASMedia-ának nem volt PCIe 4.0-ra hitelesített terméke - emiatt kellett ez a szükségmegoldás.
plussz ez talán lehetőség lesz arra is, hogy
- rendes sebességgel mennek a chipset-re kötött kütyük.
- a "security" is jobb lesz.
persze semmi se garantált - meglátjuk a teszteket."
This presents AMD with an opportunity to harden it against vulnerabilities, and have greater control over pricing, not to mention overcoming key design shortfalls of "Promontory," such as downstream PCIe connectivity.
This flies in the face of speculation that AMD would discontinue ASMedia's supply of chipset, especially in the wake of the "Chimera" vulnerability affecting "Promontory" 300-series and 400-series chipsets. The supposedly security-hardened 500-series chipset will feature PCI-Express gen 4.0 certification. What this means is that the chipset bus between the AM4/TR4 SoC and the chipset will be PCI-Express 4.0 x4 (64 Gbps), translating to double the bandwidth. It remains to be seen if the downstream PCIe lanes put out by the chipset are gen 4.0, too. Current 400-series chipsets continue to put out stale gen 2.0 lanes, compensated for by additional gen 3.0 lanes put out by the SoC. Sources also mention that ASMedia-supplied chipsets will only hit the market toward the end of 2019, which means AMD X570 could be the only 500-series chipset option between the mid-2019 launch of 3rd generation Ryzen, and late-2019. You should be able to run these processors on older socket AM4 motherboards via BIOS updates, though.
S_x96x_S
Petykemano
#1103
v2.
>Miért lehet szükséges a chipset aktív hűtése?2019 Januári infó
"The X570 chipset will run at about 15W, rather than 6-8W for the X470 chipset. This will not impact chipset heatsink requirements in any meaningful way, as the chipsets can present run on air, but most manufacturers stick an overkill heatsink on the chipset just for looks. It’s more noteworthy because the X570 chipset will be capable of more throughput (and will run hotter). PCIe 4.0 is part of this potential."
https://www.gamersnexus.net/news-pc/3428-amd-converting-epyc-to-x570-dropping-asmedia -
S_x96x_S
Petykemano
#1103
csak találgatok; valamitől extrém módon melegszik.
Nekem a PCIE4.0 a gyanús.
2X akkora adatforgalmat kell kezelnie és még nem minden van optimalizálva -Egy 16 magos 5Ghz CPU extrém sok adatot ki tud generálni - amit át kell nyomni a chipset-en.
és emiatt kell a hütés.Feltételezem, hogy az AMD referencia alaplapja is tartalmazhatott ilyet.
Remlem, csak túltervezés - és lesz valami refresh - ami megoldja ezt a problémát. -
Petykemano
#1099
Passz, azt nem tudom, én csak szemeztem vele, de végül Kaveriig kihúztam a gépvásárlást. Valamennyire azért fogyhat, mert Aldinál azért időnként előkerülnek AMD-s Medion konfigok, volt náluk Ryzen 5 1600 + RX 560 kombó is nem olyan rég.
Nyitási akcióba is betolták tavaly, eszembe jutott, hogy csináltam képernyőmentést (a hszben lévő link már nem él sajnos).
Petykemano
#1097
Akkor lehet ezt is elsők között lehet majd megvenni nálunk az Aldinál, már ha jut itthonra belőle. Ha jól rémlik, Richland startkor is betoltak egy Medion konfigot A10-6700-al.
joysefke
Petykemano
#1087
Ami a naaagy leaket illeti, abból csak az nem jött be eddig, hogy ces.
És hogyan definiálod azt hogy bejött?
Mert az én definícióm szerint még semmi sem jött be. Majd akkor jön be valami, amikor feketén fehéren múlt idővé válik...
awexco
Petykemano
#1077
Valaki szerint még hiteles a pali ?
syberia
Petykemano
#1062
AMD Showcasing 16 Core & 12 Core Ryzen 3000 Series CPUs to OEMs
Erre gondolsz? Gyanítom nem véletlen volt az egybeesés. Hátha kedved kap pár befektető, az AMD-s papírokhoz.
(#1068) olymind1: Kell a nagy sávszélesség a 12-16 magos processzorokhoz.
Szeszkazán
Petykemano
#1062
Hát az intel magyarázta a szegénységi bizonyítványát a befektetőknek, szerintem nem véletlen a leak.
awexco
Petykemano
#1058
És pár napja amikor a max Freq-re 4,7 tippeltem sokan kinevettek . De lehet éves lebontásban egy kényelmes ütem tervet találtak ki 4.5 , 4,7 , 4,9 . Sokrétű egy cpu teljesítménye de ha minden téren ( ipc , freq , gyártás technológia , adatbusz , stb ) mindig csak egy picit reszelnek az ésszerűsség határán belül és nem holmi világ megváltással próbálkoznak görcsösen az működhet és be is válhat . Mivel ezen sok pici de együttesen korrekt előrelépést produkál .
joysefke
Petykemano
#1052
Most kezdek borúlátó lenni a desktop ZEN2 órajeleivel kapcsolatban.
Azt tippelem, hogy ha jók lennének a max órajelek, akkor nem mozdulnának el a 16 mag irányába AM4-en.
De ne legyen igazam...
joysefke
Petykemano
#1050
Ez egy 16 magos RyZEN3000 ES lenne?
#82819712
Petykemano
#1047
vakmerő főleg abba a pólóba... amikor olyan cikkek jelennek meg amiben arról beszélnek használhatóak e még valamire a 10nm-es fejlesztések. Sokan elmentek AMD oldalról lehetne egy csoportkép ilyen áthúzásokkal.
De Intel CPU-jához tudunk valakiről aki átment ? Oké hogy Intelnél a 10nm nem ugyanaz amit itt annak hívnának de akkoris jön a 6 meg jövőre már jelenik meg az 5nm... az ember nyála meg alig várja hogy kibuggyanjon egy chipletes megoldásra. ECO EPYC-et akarok a diszkrétben
Petykemano
#1041
Egyet értünk abban is, hogy olcsóbban kell adniuk a kékeknél, én csak a várakozásokat próbáltam hűteni. Őszintén nagyon örülnék, ha bejönne a korábbi AdoredTV-s leak.
Az gamernexus cikk nagyon érdekes, az Intel kínálat durván eltolódott i9 felé, a modulosak meg kb azonnal kihaltak AMD-nél az olvasók körében.
(#1042) S_x96x_S: nem hinném, hogy volna jelentősége marketing szempontból, hogy 490 vagy 495. HP-nál is régóta a Probook szériában 5-re végződik az AMD-s verzió, aztán mégis az AMD az underdog. De persze lehet lendít valamit, nem tudom.
Szeszkazán
Petykemano
#1044
Hát igen, majd a benchmarkok döntenek,a PPT nem minden
Petykemano
#1039
Max 560$
699$ az sok
S_x96x_S
Petykemano
#1033
>Ez a supercomputer cakkundpakk $600$ és van/lesz benne 2 kereskedelmi forgalomban
> nem kapható lapka. Hogy éri ez meg? Vagy mégse 300misi egy-egy design (7nm-en)apróságok:
- csak _most_ nem kapható kereskedelmi forgalomban, azért később valamilyen formában csak újrahasznosítják. ( nem hiszem, hogy itt valami kizárólagosságot kért az ügyfél mint a Sony-nál )
- lehet, hogy csak szimplán a feltételezett : SMT4 + AVX512 van eladva 2x marketingesen.
- mivel 2021-ben szállítják szerintem akár még az 5nm-is szóba jöhet ( vagy inkább a biztos 7+nm)szóval az én tippem, hogy csak az I/O die lesz egészen custom.
Ha csak "high bandwidth memory (HBM)" -lesz benne ( CPU + GPU-nak )
akkor nem kell DDR4 és más egyéb egzotikus memóriavezérlő;és akár az Infinity Fabrikot is az adott FIX konfigra tunningolhatják.
( és ebben az esetben az nVidia kártyáival sem kell kompatibilisnek lenni )--- talán konzervativan ez várható --------
ZEN3 core ; SMT4 ; ( az AVX512 nem ad akkora előny a grafikus kártyák miatt )
7+nm ( az 5nm már kockázatos )
és custom - csak erre tunningolt - I/O die. ( GloFo 14HP vagy ennek a javított változata )azért mindjárt 2021. jövő év elején már demózni kell - és utána 1,5 év a gyártásra; összeszerelésre; tunningolásra; tesztelésre.
Cathulhu
Petykemano
#1033
Kerdes, hogy mennyire lesz custom? Szerintem nem annyira, mert olyan dolgokrol beszelunk, amik meg tervezo asztalon vannak. Azt valoszinubbnek tartom, hogy emiatt 1-2 feature nagyobb prioritast kap majd a Zen3-ban es mondjuk a Navi20-ban.
Amugy ezek a sok tizmillios becslesek szvsz nagyon erosen tulzoak, mert igy egy Kaby Lake G vagy egy Subor Z soha az eletben nem terulne meg, es ez nem csak hindsight, hanem elore tervezve se nyulnanak meg bottal se ilyen niche termekekhez. -
awexco
Petykemano
#1017
Frek-re a tippem 4.7 majd köv Genfre 4,9 talán 5 ha be szorzod ipc-vel még reális is lehet . Üzletileg az 5Ghz értelmetlen most .
S_x96x_S
Petykemano
#1026
> custom AMD EPYC CPU
ennyi tudható:
"AMD didn't reveal which specific generation of its GPUs and CPUs will power the system, although CEO Lisa Su did announce that both components are customized for the deployment.
AMD's EPYC processor has been optimized with support for new instructions that provide optimal performance in AI and supercomputing workloads, with Su saying, "it is a future version of our Zen architecture. So think of it as beyond..what we put into Rome."
That could indicate that AMD will use a custom variant of its next-next-gen EPYC Milan processors for the task, but that remains unconfirmed. Those processors have already been tapped for the DOE's Perlmutter supercomputer that is also built with Cray's Shasta building blocks."
https://www.tomshardware.com/news/amd-epyc-radeon-frontier-exascale-supercomputer,39275.html
Petykemano
Petykemano
#1024
"In a press conference previewing the CORAL-2 award to Cray and AMD for Frontier, Pete Ungaro, Cray’s chief executive officer, said that the Frontier system would be comprised of more than 100 cabinets of machinery and would deliver in excess of 1.5 exaflops of raw double precision floating point math capability. Considering that a system architecture generally scales to 200 cabinets at Cray, that seems to imply that it could, in theory, build a 3 exaflops system if someone wanted to pay for it. To give Frontier some physicality, Ungaro said that the machine will be about the size of two basketball courts, will weigh more than 1 million pounds, and will have more than 90 miles of cabling."
(src)"FP16-tal számolva 50000 Vega 20-at kellene beépíteni"
Akkor ha ez az 1.5exaflops FP64-ben értendő, akkor ahhoz 200000 vega20 kéne
Ha 25000node-dal számolunk, amiben akkor 100000 insinct kártya van - ez azt jelenti, hogy a vega20-hoz képest 2021-re duplázódnia kellene az FP64 teljesítménynek! -
Cathulhu
Petykemano
#1018
Ami itt a leginkabb orvendetes, ahogy a phoronixon is irtak, ambar a CPU-s topikban inkabb off, hogy Linux + ROCm lesz (nyilvan) az alap. Azaz a vilag leggyorsabb supercomputere opensource alapokon fog mukodni, es nem a zart CUDA-n, ami hosszu tavon sokkal tobbet hozhat az AMD-nek, mint az a parezer eladott CPU/GPU (+ Stadia is ugyanebbol a szempontbol)
S_x96x_S
Petykemano
#1018
>"scheduled to be delivered to ORNL in 2021."
>"custom AMD EPYC™ CPU, and AMD Radeon™ Instinct GPU processors. "Ez valami spéci csip lesz - vagy csak ugyanaz mint amit a többi vevő is kap ?
2021 -re melyik ZEN core-t kapja ? ZEN4? -
Petykemano
#1022
Ja, bocs, tényleg, ezt jól benéztem, összekevertem a petát az exával. Ez így már izgalmasan hangzik. De most néztem meg úgy rendesen a cikket, s aszerint egy supercomputer fog ennyit tudni, nem egy EPYC + Instinct. Úgyhogy mégse annyira izgalmas. Sőt, ez egy jó nagy semmitmondás, mert nem tudjuk milyen pontossággal és hány GPU fog ennyit tudni.
Petykemano
#1020
Az AMD TFLOPs-nak hívja az AI teljesítményt is. Pedig amúgy igen, TOPs-nak kéne. Egyébként meg elszámoltál valamit, mert nem 12500, hanem csak 12.5 Vega kéne. Ez nem nagy szám, mert dedikált feldolgozóval eleve 4x teljesítményt lehet csinálni AI-ban (lásd NV), így meg csak 3x a különbség, ami 2-3 év alatt nem nagy szám.
Petykemano
#1018
Jelenleg INT4-ben megvan 120 TFLOPs a Vega 20-szal, a Turing meg tud 500-at. Ennek tudatában az 1500 nem nagy szám, ha dedikált feldolgozóval csinálják.
awexco
Petykemano
#1003
8 magos tuti nem 2 szeletből áll ... +io
joysefke
Petykemano
#997
Ha fájna a kákán is csomó keresése, Te ordítanál
ezt hagyjuk.ez még mindig elképesztő módon a 9900K alá ajánlás
(Fenti árak az 1800X-1600X release áraiból származnak)Pont ennek nincsen szerintem értelme.
Miért adnának egy 250$-ért -ennyi most a 2600X- egy nyolc magos ZEN2-t, ami a 9900K-val van pariban.
A 9900K a 8700K és 9700K fölött van egy szinttel teljesítményben és árban is. Miért árazná az AMD a 9700K és 8700K alá a jelenlegi 6c6t core i5-ök szintjére a nyolc magos ZEN2-t? Mi értelme lenne akkor, ha a teljesítmény csakugyan olyan jó lesz, mint amit most pletykátnak (15%IPC, szűk 5GHz turbo)?350-400$-ért nem vinnék el az alacsonyabban clockolt, de szorzózár mentes i9-9900 szintű 8/16 ZEN2-t, de 250$-ért elvinnék? Ha mondjuk 350$-ba kerülne akkor inkább vennének helyette 500$-ért 9900K-t vagy 350-ért-ért jóval lassabb 8700K-t? :F
Ha a 6 magosok frekvenciája alacsonyabb, akkor ebből a kínálatból az elvileg 8magos, elvileg közel 5Ghz-et elérő elvileg magasabb IPC-vel rendelkező zen2 sku és elvileg 8magos, elvileg magasabb IPC-vel rendelkező zen2 procis, alacsonyabb az órajellel rendelkező skulenne a legkelendőbb (pont úgy, ahogy az 1600-1600X is az volt)
Szorzólockról még nem tudunk. Ha tényleg olyan jók lesznek a procik, akkor mondjuk meg lehetne fontolni a szorzólock bevezetését, hogy az X-modellek is jól eladhatóak legyenek, illetve hogy a userek több mint 10%-a számára is legyen valamilyen gyakorlati előnye a nagyobb (8+) magszámnak. Magszámméregetésen kívül is.
Az én tippjeim (ha minden unlocked marad és hozza a teljesítményt amit remélünk):
3950X => hely a számozásban
3900X - 12c24t (később) - 550-650$
3800X - 8c16t - 399-449$
3700 - 8c16t - 299$
2600X - 6c12t - 250$
2600 - 6c12t - 220$egy esetleges 10-magos intel gyors megjelenése ezt nyilván felrughatja
joysefke
Petykemano
#995
3700X visszakerülhet a $500 magasságba
3700 $400
3600X $300(-330) => ez még mindig elképesztő módon a 9900K alá ajánlás
3600 $250Ezek milyen légből kapott modellszámok?
Honnan tudod, hogy mi az hogy 3700x vagy 3600?
joysefke
Petykemano
#993
most már biztos a 8 mag lesz a mainstream, az új i5.
Miért olyan biztos ez?
Ha a ZEN2 tényleg +15%IPC-vel és +10% órajellel és jobb energiahatékonysággal jön, akkor a 6c12t variáns kényelmesen hozni fogja a 8700K teljesítményét. Applikációkban gyorsabb lesz, játékokban mondjuk egál. A 8c16t ZEN2 pedig a 9900K-val lesz mindenhol legalább egálban.
Ha ez teljesül akkor fölösleges megint belemenni egy magszám-háborúba. A 6c12t ZEN2 a fent vázolt teljesítményszint mellett a jelenlegi 2600X, a 8c16t ZEN2 pedig a jelenlegi 2700X árán és az előd kategóriájában is több mint versenyképes tudna lenni.
Futnának ez emberek a boltba hat meg nyolcmagos AMD-t venni, mintha cukorka osztogatás lenne.
Magszám háborúnak akkor van értelme, ha a magszámon és az áron kívül nem tudod a termékedet valamivel a konkurencia elé emelni.
A 8c16t modell fölöttieket (12c24t, esetleg 16c32t bár az utóbbiban nem hiszek) pedig lehetne vaskos haszonnal adni legalább addig amíg nem jön a 10 magos intel....
awexco
Petykemano
#983
Szerintem ez a török kereskedő is ingyenreklámot akar magának mint az orosz .
Anyira sokat nem kell várni és kint lesznek a hivatalos spec-ek .Én személy szerint minden féle alap nélkül saját megérzésem szerint. 3as generáció tetejét 4.7 re várnám majd jövőre 4.9 et
Archttila
Petykemano
#983
Akkor itt nem lesz 3600 turbo 4.5GHz nemde?
mostanaban nem kovettem a valtozasokat... -
Petykemano
#983
Kár lenne, ha a 16 magosnak nem lenne meg az 5Ghz turbó.
De legalább lesz 16 magos, illetve ezen számotás alapján előbb utóbb jöhet egy jobban sikerült 3850 széria.
S_x96x_S
Petykemano
#960
> Talán egy ilyen partner meetinget nehezebb tologatni,
Egyik egy B2B a másik inkább egy B2C esemény; kicsi az átfedés.
Ráadásul - Véletlenek IS előfordulnak.amúgy nem tudom, de ez talán annyira nem egy akkora probléma.
S_x96x_S
Petykemano
#958
>Vajon véletlen, hogy pont ezzel egy napon rajtoltak nvidia kártyák?
kérdés - hogy ki szervezet rá - kire ..
Petykemano
#954
Köszi! OC-ban nem is rossz ezek alapján, remélhetőleg stock órajelben is lesz érdemi emelkedés.
Petykemano
#951
van róla képernyőmentés? Letörölték.
syberia
Petykemano
#951
Most ez forrasztott kupakos lenne? Zen+ magok, de már közeleg a Matisse.
syberia
Petykemano
#949
Lassan ők fizetnek azért hogy elvidd.
S_x96x_S
Petykemano
#934
nem tudok semmit se ..
> Vajon lehet-e az, hogy az MS (vagy a Sony) kiszervezte
> a cloud gaminghez alkalmas hardvergyártást zotac, gigabyte és hasonló cégeknek?- vagy a Microsoft visszamondott egy nagy legyártott mennyiséget .. ÉS átpasszolta az AMD-nek értékesítésre
- vagy lejárt az "X".év tervezési kizárólagosság - és az AMD értékesítheti ezt a HW-t a szabadpiacon.
- vagy ...>de korábban azt nyilatkozták, hogy a zen mindenhová jó.
majd valamikor ...
AMD Aerospace and Defense Solutions:
AMD Embedded SoCs
- AMD Embedded G-Series: optimized for low power
- AMD Embedded R-Series: optimized for low power
- AMD Ryzen™ Embedded V-Series: optimized for ultra-high performance, with support for up to four independent 4K displays
https://www.amd.com/Documents/Aerospace-and-Defense-Application-Brief.pdf -
S_x96x_S
Petykemano
#924
>Mit gondolsz, a core alapú licencelést a szoftverlicencelő érdeke bevezetni, vagy az Intelé,
röviden : nem tudom.
- eddig kialakult egy egyensúlyi állapot;
A legtöbb szoftverhez INTEL HW-t ajánlottak. Ennek vége.- Az Intelnek elméletileg nincs kihatása egy szoftvercég licenszelési politikájára,
főleg úgy hogy egyes cégek Power/Solaris/ARM CPU-ra is licenszelnek.- A szoftvercégek is rivalizálnak, figyelni kell egymás licenszelési politikáját.
- A piacon mindenki a profitmaximalizálásban érdekelt.
- Hogy hol lesz az új egyensúlyi állapot azt nehéz megjósolni.
awexco
Petykemano
#915
Mi az amire ilyen vas kellhet ? Nem jó neki mondjuk 4db 2s .
S_x96x_S
Petykemano
#911
>Csak az elmúlt években az AMD eléggé rászokott erre, hogy nem dobálja évente a teljesen új architektúrákat.
Azért nekem egy szavam sincs.
A Ryzen3xxx 3in1 == gyártástechnika(7nm) + Refreshed Design (ZEN2) + Magduplázás egy lépésben.
( a végleges árakat azért még várjuk ki )mint a vevői oldal - persze ezt is keveslem.
de ha nekem kellene le-projektmenedzselnem, akkor igencsak izgulnék
> a pénzügyi helyzetük nem lépett olyan szintet,
talán ez majd változik, mivel rácuppantak a zsíros - szerver piacra ;
Ráadásul a Threadripper is telitalálat volt - főleg presztizs és marketing szempontból.mindenesetre kiváncsi leszek a 2019 Q2 marginra,
mert ahogy látom most még nem fürödnek a cach-ben.http://ir.amd.com/static-files/9c985e84-bbb6-4e23-99bd-dcbb21f18592
S_x96x_S
Petykemano
#909
>Őszintén szólva én inkább arra számítanék,
>hogy az AMD most kihoz minden terméket DUV-ra, és jövőre frissít EUV node-ra navit,
> (vega20-at cseréli navi20-ra) és a ryzen3k-t.lehetséges.
persze semmi sincs kőbe vésve.
S_x96x_S
Petykemano
#906
>Mindjárt tök olcsó lesz a 7nm,
és megint felteszik a "szokásos" kérdést, hogy miért van "mindig" lemaradva az AMD?
itt van már az 5nm -is ; lassan már a 3nm-ről cikkeznek és az AMD még a 7nm-et se hozta ki."The company expects to reach full utilization on 7nm by Q3 2019, courtesy of increased orders from HiSilicon and AMD. HiSilicon is the fully owned subsidiary of Huawei and is responsible for designing the SoCs used in that company’s flagship devices. AMD has aggressively positioned itself for 7nm ramps in 2019. Its 7nm Radeon Instinct GPUs and Radeon VII cards are already in-market, while its Epyc and Ryzen CPU families will be refreshed on 7nm later this summer. A new 7nm GPU, based on AMD’s Navi family, is also expected."
"TSMC has already begun volume production of its 7nm EUV node according to the same sources. The plan is to use EUV for contacts and vias at 7nm before wider usage of the technology at the 5nm node and below. Mass shipment of EUV chips isn’t expected before the end of the year and it isn’t yet clear which customers are using these products versus sticking with conventional EUV. Timing dictates that Radeon VII must be a first-generation EUV part. Our current understanding is that the upcoming Ryzen CPUs will also be first-generation EUV parts. It’s reasonable to think that AMD could deploy 7nm+ for whatever CPU follows 3rd generation Ryzen before swapping to 5nm when that node is suitable for mainstream big-core CPU manufacturing."
https://www.extremetech.com/computing/288917-report-tsmc-7nm-utilization-improves-on-orders-from-amd-hisiliconEgyébként az új Threadripper-es procik már lehetnének 7nm+ -sak is. a TSMC a Q2-ben ráállt a gyártásra.
Én még azt is elképzelhetőnek tartanám, hogy a tömegcsipekben a 7nm párosítva lesz egy 7nm+ -os chiplettel. ( vagy akár jövőre egy 5nm+ -al )A TSMC - befektetői negbészélésén elhangzottak alapján mindenesetre jövő év első félévére igérik az N5-öt tömegtermelésben.
"Now I will talk about our 5-nanometer status. Our N5 technology development is well on track, with customer tapeout schedule for first half 2019 and volume production ramp in first half 2020. We are already in preparation for N5's ramp. All applications that are using 7-nanometer today will adopt 5-nanometer.
In addition, we are expecting the customer product portfolio at N5 and see expanding addressable market opportunities. We expect more applications in HPC to adopt N5. Thus we are confident that N5 will also be a large and long-lasting node for TSMC.
Now I will talk about the ramp-up of N7 and N7+. Our 7-nanometer has been a very steep and successful ramp in second half 2018 and
we expect continued ramp through 2019. Our customer portfolio is growing stronger while more applications such as HPC and automotive are coming to N7 as well." -
S_x96x_S
Petykemano
#903
>Mit tudott volna 12nm-en.
jó, De mit tudna 5nm-en?
"TSMC and OIP Ecosystem Partners Deliver Industry’s First Complete Design Infrastructure for 5nm Process Technology"
"TSMC’s 5nm process is already in risk production and offers IC designers a new level of performance and power optimization targeted at the next generation of high-end mobile and HPC applications. Compared with TSMC’s 7nm process, its innovative scaling features deliver 1.8X logic density and 15% speed gain on an ARM® Cortex®-A72 core, along with superior SRAM and analog area reduction enabled by the process architecture. The 5nm process enjoys the benefits of process simplification provided by EUV lithography, and is making excellent progress in yield learning, achieving the best technology maturity at the same corresponding stage as compared to TSMC's previous nodes.
https://www.tsmc.com/tsmcdotcom/PRListingNewsAction.do?action=detail&newsid=THPGWQTHTH&language=E -
awexco
Petykemano
#892
A grafén és ötvözetei nagyon kemény tulajdonsággal bírnak . Olvass utána . Kb a következő műanyag lehet mert mindenre is jó .
hokuszpk
Petykemano
#890
thx. de nem kell mindent komoyanvenni, amit Aprilis elsejen irok
Technology Vision khm.
awexco
Petykemano
#886
Erről mesélnél bővebben erről a grafénes dologrol ?
hokuszpk
Petykemano
#886
navvvvvegre !
most megyek es a keblemre olelem az Adoredcsókát. -
hokuszpk
Petykemano
#883
"- Rome biztosan eléri a 2.35GHz alapórajelet"
szoval ezzel ver mindent Rome-má ?
a grafenalapu fejlesztesekrol van valami ?
Petykemano
Petykemano
#883
Meanwhile...
Gigabyte X570, X499 -
awexco
Petykemano
#876
Hát meg se lep sajna vega-ngg .
Tegnapi dátum. -
S_x96x_S
Petykemano
#873
awexco
Petykemano
#873
Ez olyan se füle se farka az egész . Vagy ÁPR 1
awexco
Petykemano
#843
Lásd Walkman . Il pl amíg sztároknak csak szifonos telójuk volt addig mindenki olyat akart.
hokuszpk
Petykemano
#840
" eselteg a külön lapkáb levő io is emelhet valamennyit a fogyasztáson. "
nekem 1 gen van, ezen a kulonfele programok ( de foleg hwinfo64 ) altal kijelzett ertekek alapjan terhelesfuggoen a soc is megeszik 10-30W -t, de ez nincs beleszamolva cpu core powerbe, marpedig ha a cpu+soc powert vennenk a gyari tdp adatnak, akkor mar egy parablakos bongeszesnel boven tullepi.
ha mondjuk a biosban bekorlatozom 45W -ra, akkor a cpu core power 47 volt eddig a max, de alapbol is ez az, ami kb. a gyari tdp korul mocorog. -
awexco
Petykemano
#840
Lehet nem véletlen célszerű max 8 mag ... Kell a magas órajel meg a fogyasztás is .
Mondjuk nem is tudom miért gondolják egyesek a 12, il 16 magot ? Elvileg hivatalos infó nem volt , csak kihagyott hely a procin.Még a végén az AMD is beáll , hogy a kevés magot okosítja (smt4 , avx 512)
hokuszpk
Petykemano
#836
"Ezt a 4.5, meg 4Ghz-et milyen értéknek mondod? max-turbónak, vagy all-core turbónak, vagy alapórajelnek?"
4Ghz all core turbo
az 50% -os fogyasztascsokkenesi adatttal szamolva ket iranybol is pofonegyszeruen le tudom vezetni :1. a 2700X all core 4Ghz korul van. egyszeruen meg kell szorozni kettovel a magok szamat
)2. a Threadripper 2950X 16 mag szinten 4 Ghz koruli all core 180W itt a fogyasztast kell osztani kettovel.
tehat a teoretikus Zen2 16 mag -- a gyartastechnologia adta lehetosegeken kivuli energiatakarekossagi fejleszteseket nemszamolva -- all core valahol 4 Ghz korul lehet 95-105W keretbol.* mondjuk reggel a furdokadban fejben ha jolemlexem a sima 2700-ast vettem alapul, de az azon helyszinen torteno levezeteseket a helysegbol kilepve 10 meter megtetele utan elfelejtem.
hokuszpk
Petykemano
#833
vegulis kb. eleg a jozan esz.
ket allitas volt a 7nm -el kapcsolatban :1. azonos fogyasztas mellett 40% plusz teljesitmeny.
ebbol az jon ki, hogy 8 magon kb. 4Ghz x 1.4 = 5.6Ghz korul lehet a motyo teteje 95-105W -bol.
ezert lesz 12 magos, azt ki lehet hozni ugy 4.5 Ghz vagy picit felette esszeru fogyasztassal, a 16 magos meg max 4Ghz korul mehetne, hogy a regi lapok se egjenek le. de arra meg mindenki huzna a szajat, hogy csak ennyi ? ha meg feltolnak, akkor jonnenek a regebbi sporolos vrmmel rendelkezo lapok tulajai, hogy szar az egesz, belepattintottak, es nem megy vagy leegett.2. azonos teljesitmeny mellett ~50% fogyasztascsokkenes
picit fentebbi Norrod preziben van, a 'Coming soon; reszben hogyaszondja :
2x performance per socket. namost azt is mondja, hogy up to 64 core. ha kiszamoljuk egyszeruen az uj gen 64 coret elosztva az elozo gen 32 core = 2 ; ehhez feltetelezzuk, hogy a fogyasztasi keret nem valtozik akkor siman kijon, hogy a freki kb, marad ahol volt. Marpedig az Epyc orajelei eddig sem voltak az egekben.
2.2 base,3.2 max boost es 2.7 all core. mondhatni alacsony.
es ez a matek meg a 16 mag / ~4 Ghz asztalira is kijon. -
Cathulhu
Petykemano
#828
Persze, ez tiszta sor. Ugyis az utolso MHz is ki lesz sajtolva beloluk az utolso pillanatban, az minden Ryzenbol, Polarisbol es Vegabol is ki van, aztan meg az AMD a kazan. Szvsz olyan 4.6-4.7-re teszem a Zen2 tetejet, de ez csak ex-has. Viszont minden preziben az utobbi fel evben a 7 nanonal az AMD a same performance -50% power, vagy a same power +25% performance -t sulykolta, abbol akar meg az 5 is kijohet.
Valamelyik AMD-s preziben lattam mostanaban (lehet epp itt korabbanszerk: itt), hogy az uj gyartastechnologiakkal ne varjunk nagyobb frekvenciakat, sot, keszuljunk fel, hogy csokkenni is fog. Worst case meg az is elofordulhat, hogy a Zen2 meg a Zen+-t se eri el, de ezt azert ketlem. -
hokuszpk
Petykemano
#828
arrol van valami info, hogy ezt melyik belsos forrasa es hany oldalas mailben szivarogtatta ki ?
Cathulhu
Petykemano
#825
Ha visszaemlekszel 2016-ra, kevesebb mint 4 honappal a launch elott meg csak annyit mert igerni Lisa, hogy 3.4+ GHz a varhato a Ryzentol, boost clockrol meg beszelni sem mert binning elott. Ebbol aztan 3.6/4.1 lett. Itt tobb ido telik el a CES es a launch kozott, szoval meg korai josolni, hogy most best case scenario volt-e. CPU reszrol a kommunikacioban az utobbi idoben ovatosabb volt az AMD (a GPU-t Rajaval most hagyjuk), ebbol barmi lehet. Az overhype meg a leakeknek koszonheto, es pont az az uriember a legnagyobb saros ebben, aki a mostani elemzest is csinalta.
hokuszpk
Petykemano
#821
fut a gyava a sajat maga gerjesztette hype elol.
mondom en, hogy az Intel fizeti. -
S_x96x_S
Petykemano
#823
> Az AMD az elmútl években mindig a legkedvezőbb, legjobb színben mutatta be az érkező termékeit.
az eddigi bemutatók egy korai példánnyal demózott állapotok voltak.
Persze - az" over-hype" -ot ki kellene gyomlálni - de azért én nem következtetnék ebből egy végleges állapotra.A mostani szériában (R3xxx) - rengeteg minden változott ( gyártástechnológia ( és partner) , architektúra, ... ) szóval szerintem izzadnak a mérnökök a háttérben. Biztos van rengeteg nem várt probléma is.
> Az AMD nem szokott sandbagging, tehát biztosak lehetünk benne, hogy amit látunk az a top maximum.
Miért lennénk "biztosak"? És miért lenne ebből "biztos" következtetés egy félévvel későbbi állapotra ?
( pl. a Ryzen 1xxxx szériánál a gyártási hét igencsak korrelált az overlockolhatóssággal )
Ha a "biztos" helyére az "elképzelhető" - szót tesszük be, akkor már nincs semmi bajom a hipotézissel.
ps. a Reddit-en a top kommentek jól körbejárják a témát.
https://www.reddit.com/r/Amd/comments/b2c5pt/zen_2_analysis_a_different_perspective/ -
awexco
Petykemano
#821
Mi lenne a lényeg ? Miért gondolja , hogy bukásra utaló jelek lennének ?
awexco
Petykemano
#818
Infó amit eddig nem tudtunk olyan nincs benne .
Cathulhu
Petykemano
#814
Azert kicsit buzlik, hogy kisebb mint az ARM (melyik?) de gyorsabb mint a Xeon (megintcsak melyik?)
PPT:
Out-of-Order execution with Compiler
Magyarul a proci in order, a tobbit oldja meg a compiler?No custom design, standard cells & SRAMs
Ha nem custom akkor mi ez? Megiscsak ARM, esetleg RISC (de az megiscsak custom lenne)Out-of-order (OOO) execution in software•OOO performance with In-Order area & power
Ertem...Adjatok penzt, startup vagyunk, nagyot mondunk, majd eltununk...
Petykemano
#814
Ez amolyan papíron mindent IS tudó CPU, amiből aztán nem lesz kereskedelmi termék?
Vagy ha lesz, a felét sem tudja majd az ígéreteknek, mert a fordítót nem tudják rendesen megírni hozzá? -
awexco
Petykemano
#798
AMD megmutatja , hogyan kell normálisan tick -tock-olni ?
Cathulhu
Petykemano
#799
8:44 ha valaki nem akar emiatt feleslegesen vegignezni egy ujabb fel oras szerecsenmosdatast
hokuszpk
Petykemano
#796
szvsz az R3 az 4/8 es 6 mag lesz, az R5 6/12 es mezei 8 mag, az R7 az 8/16 es sima 12 mag, es a tetejen az R9 lesz a 12/24
Simid
Petykemano
#787
Nagyon szeretnéd látom ha menthető lenne a csatorna renoméja, de ez a hajó már elment (legalábbis a decemberi leak kapcsán).
Ez egyértelműen az adored leak másolata. Hozzáadták a 10%-os árrésüket és átváltották saját valutára.
Alsó hangon is 3 hónapra vagyunk a megjelenéstől. Tényleg elhiszi valaki, hogy egy szingapúri kisker teljes árlistát kap ennyivel előre?
Legalább vették volna ki a listából leginkább hiteltelenítő Navi IGPs APUkat.... Azokról kb biztosan lehet tudni, hogy ebben a formában idén nem lesznek.
Cathulhu
Petykemano
#778
Zen2-nel az L4 mellett ket indokkal erveltem, egyreszt kompenzalni kicsit a tavoli IO miatti kesleltetest, masreszt fuggetleniteni az IF orajelet a RAM orajeltol. Ez volt ugye a Zen1 egyik rakfeneje, es mar akkor mondtak, hogy ehhez egy koztes buffer kellene, aminek a szerepet szvsz egy gigantikus L4 szepen be tudna tolteni, igy az IF mehetne gyorsabban csokkentve az inter-CCX es mostmar inter-chiplet kesleltetest is.
Tudom, hogy meg a Zen2 duplazott chache-e messze is messze lesz a 3D altal adott lehetosegtol, de jo indikator lehet, hogy mennyit tud profitalni belole a Zen2 (aztan persze az IO kesleltetes lehet negalja az egeszet).
A nagyobb cache mindenkepp segit a cache missek szamanak csokkenteseben, de ha mar eleve jo hatasfoku a cache mechanizmus, akkor sokkal nagyobb cache-el is csak par %-ot lehet nyerni. Minden a jo prefetcheren mulik (sajnos nem talalom, de regen olvastam egy cikket, az mutatta szepen, hogy a prefetcher gyakorlatilag atvette a L3/L4 szerepet). Ez szvsz igazan csak nagyon rosszul megirt programoknal hozhat igazan javulast, bar megvallom a konkret szamokrol nincs fogalmam.
Tudtommal a HBM onmaga 3D stack, mikor GPU-t raksz melle lesz az egesz 2.5D az interposer miatt.
Cathulhu
Petykemano
#775
kosz a tl;dr-t, erdekes kerdesek.
Kivancsi leszek a brutalis cache mit hoz a Zen2-nek. Szvsz a vegtelensegig nem erdemes novelni, egy ido utan minimalis lesz a gain. Hiaba van tele a cache, ha a CPU csak szokoevente nyul egy-egy adathoz. De majd meglatjuk. A 3D stackingnek valoban csak igy latom ertelmet, mert nagy fogyasztasu chipek megfozik egymast. Laptopoknal, mobiloknal viszont hozhat sokat a konyhara, ahol a fogyasztas ugyis limitalja a hotermelest, elobbiben nem erintett igazan az AMD, utobbiban meg az intel. Amugy az AMD tuti up to date a 3D stacking temakorben, nem veletlen kiserletezik evek ota a HBM-mel. -
Petykemano
#758
Jól gondolom, hogy itt is probléma, mint az apple A procik kapcsán, hogy erős persze, de ha x86 kódot kell futtatni, akkor ez mit sem ér, tehát nagyon speciális esetben (nyilván a szerverek világa lehet ilyen) jön ki “matek”
Archttila
Petykemano
#741
A post végére egy nagy Ámen!
-FreaK-
Petykemano
#732
Ha ez igaz, akkor az Intel készítheti a pelenkát. Minimum kettéhugyozza™ az aktuális csúcs procijukat.
Yutani
Petykemano
#726
A 15W fogyasztás a chipset esetén tragédia?
S_x96x_S
Petykemano
#726
>Az X570 esetén a magasabb, 15W fogyasztás magyarázható csak a PCIE4-gyel?
biztos lesz még valami ..
én ezen gondolkodom, hogy mit is jelenthet:
" migrating some of its Epyc IO down to X570, "de Thunderbolt3-nak + 6 NVMe-csatinak is örülnék.
Hátha lesz még benne egy 5GB-os network támogatás. -
Petykemano
#722
Elkészült az Intel FX-9590-je.
S_x96x_S
Petykemano
#718
>De figyelembe véve, hogy mik röppentek fel,
>hogy nem lesz a kimaradó helyen semmiféle GPU (meglátjuk), ....AdoredTV - szerint - másik I/O die kell.
"Matisse" is the complete package which consists either of one or two 7nm CPU chiplet(s) and the "desktop optimized" I/O die. This same "Matisse" package will not substitute one of the CPU dies for a GPU die.
There's a good reason for this - the Matisse "desktop optimized" I/O die lacks any kind of display output because it doesn't need them and they'd simply be a waste of space.
However this does not mean that a later package of 7nm CPU chiplet, I/O die and GPU chiplet won't exist. I'm quite sure it will in fact, and it'll have a "Mobile optimized" I/O die instead, with higher bandwidth for the iGPU.
It won't be called Matisse because it's a different CPU, same as Summit Ridge and Raven Ridge were also different CPUs and given different names. The I/O die difference counts now even if the CPU chiplet remains the same.
via -
S_x96x_S
Petykemano
#716
> Ez egy gyorsító, de... az AMD kissé mintha lemaradt volna a forradalmi chiplettel?
Huawei: "Shipping in Q2 2019"
Majd megnézzük a teszteket és az árazást is
Fiery
Petykemano
#702
Az biztos, hogy az A6-9220C es A4-9120C nem Bristol Ridge vagy Carrizo alapuak, hiszen tul keves CPU-mag es tul keves GPU-mag van bennuk. Stoney Ridge alapunak tunnek nekem, csak -- velhetoen -- kicsit faragtak a power delivery-n, hogy jobb karakterisztikaval mukodjenek alacsony TDP-nel.
S_x96x_S
Petykemano
#702
>a 6W az Stoney Ridge?
talán az. Vagy egy Stoney+
nem irnak róla : https://www.amd.com/en/products/apu/7th-gen-a4-9120c-apu ( Base Clock
1.6GHz )Remélem olcsó NUC szerű dolgok is elárasztják a piacot, hamár a Intel's Celeron N3350 ; Pentium N4200 a versenytárs.
S_x96x_S
Petykemano
#698
terjesztheted
>Ez épp csak versenyképesnek tűnik.
> Igaz, persze, ez még a tavalyi eresztés ráncfelvarrása. Az igptől nagyobb ellépést vártam volna.a 15W - bekorlátozza - és valószinüleg a 10-15 játékból az ideális 3 van feltütntetve.
nézegettem a riválist Intel® Core™ i7-8565U Processor
- $409.00 az ajánlott ár;
- 1.80 GHz base - 4.60 GHz turbo,
- jobb AVXde az AMD talán árban is sokkal versenyképesebb lesz. ; a drivereket is kijavitották talán ; és remélem az akkuteljesítmény is jobb.
A 35W -os ( AMD Ryzen 7 3750H ) lehet nyerő szerintem a teljesítménymániásoknak ;
Amit még látok, hogy a AMD Ryzen 7 3700U - base clock-ja magasabb ( 2,3GHz base 4.Ghz boost )
vagyis várhatóan akkuidőben még az Intel lesz a nyerő a tágabb szabályozás miatt. -
syberia
Petykemano
#691
Mégis igaz lesz a pletyka?
hokuszpk
Petykemano
#685
legalabb nem irnak valosagtol elszakadt arakat es nincs a tablazatban a nevezektanbol "kilogo" 3850X sem.
S_x96x_S
Petykemano
#685
bármi lehet ..
- marketing összehasonlító oldal - olyan lehet mint az árukereső. ( "E-Katalog")
- "Too hard to tell, it looks identical to my leak but that either means it's confirmed or they just copied from my leak."
u/AdoredtTV -
S_x96x_S
Petykemano
#681
>7nm-es szilíciumban gazdag új évet kívánok!
Petykemano
#673
Igen, ha az MS nem bassza el.
Meg ugye arra tartunk, hogy egy gyártótól fogod kapni a teljes rendszert, CPU + GPU, s x86 nélkül az NV megszívná. Azonban ha addig elterjed az ARM, akkor nem. Viszont fogyasztóként mindenképp szopó, mivel nem kombinálhatsz ilyen-olyan GPU-t.
Petykemano
#670
Az Apple-t azért érdekli ARM, hogy megszabaduljon az Intel befolyástól és teljesen saját CPU-t
készíthessenlegózhasson. Szóval ez függetlenségről szól leginkább. Fix hardver, fix szoftver.Az MS is ebbe az irányba megy, de ez egyelőre csakis az MS saját hardvereivel termékekkel fog szerintem működni. És itt viszont a szoftvertámogatottság ami kritikus. Az MS sajátjait átportolhatja natív ARM-ra, viszont a 3rd party Win32 szoftverek max emulációval fognak menni. Bár elvileg van egy megváltónk az UWP személyében, így a jövőbeli programok lazán futhatnának ARM-on. S ez elhozhat egy olyan érát, ahol választhatsz ARM és x86 között, de biztos vagyok benne, hogy nagy megkötések lennének. De szakértelem is kell, mert a natív ARM kóddal messze nincs annyi tapasztalat, mint x86-tal. Ráadásul az ARM chipekből renget mikroarchitektúra van, ahány gyártó, annyiféle. Így nehéz optimalizálni. Szóval sok a buktató.
Ha bejön az ARM, akkor az Intel és az AMD is biztosan beszáll, ez pedig izgalmas lehet. AMD-nek volt pár éve egy ARM-os projektje.
S_x96x_S
Petykemano
#669
Igéretes jövő, de azért nem olyan egyszerű ez az ARM-os szerverpiac.
-A Cavium-ot megvette a Marvell ( ThunderX2 -el talán lesz valami pici áttörés)
-A Calxeda belerokkant az ARM-es szerverchipjébe.
.A Qualcomm nemrég jelentette be, hogy kiszáll az ARM-es szerverpiacról.
-Az Annapurna Labs-ot pedig megvette az Amazon. ( és már elérhető az AWS-en ; 16 core )
-és mint irtad az Apple is saját chipet fejleszt.vagyis sovány profit, egy új cég nehezen tud megkapaszkodni,
a nagyobb cégek pedig nem akarnak már függeni, emiatt inkább saját chipet fejlesztenek - ami a piacot megint elaprózza.De sokaknak még az ARM-is drága , vagy kötött ; emiatt a háttérben a RISC-V -is jön felfelé.
> A qualcomm meg tör fölfelé.
kiszált az ARM-es szerverpiacról a Qualcomm ;
Valószínüleg az AMD-s EPYC is extrém betett az üzleti terveiknek. már nem olyan vonzó az ARM-es szerver - a kockázatok mellett.
>Ennek fényébeőn az AMD vajon ráér-e szüttyögni jövőre is 4-6-8 magos procikkal?
>Vagy valóban indokolt lenne 8-12-16 magos procikkal mindsharet nyerni az.Intel és az arm fölött is?nem ér rá,
de ettől függetlenül - úgy csinálják ahogy tudják.speciel a Ryzen alapu minipc-k ( NUC szerű dolgok ) tömeges megjelenése talán jövőre megtörténik; így kivülről érthetetlen, mit kell ezen ennyit tökölni
de majd a CES-en megtudjuk
Petykemano
#664
Amíg itt az "Atom", addig nem igen van esélye az ARM-nak. Meg egyelőre azt se tudjuk, hogy a Zen hogyan skálázódik lefelé vagy lesz-e az AMD-nek valami apró architektúrája.
S_x96x_S
Petykemano
#664
>Mit gondoltok, melyik gyártó, vagy chipgyártó fog előrukkolni jövőre arm alapú notebookkal, vagy minipcvel?
Ezt most itt az AMD-s témában kérdezed ?
>Mennyi idő lehet, míg megjelenhetnek 16(-32) magos (A76) minipck 35-45W TDP-vel?
szerintem nem lesz jövőre még. Talán 1,5 - 2 év múlva. ( remélem tévedek. )
Esetleg az Ampere lehet itt érdekes; de itt a 32magos - 125W -kér. Az árán és a fogyasztásán talán majd reszelnek egy kicsit ..
Nekem esetleg jól jönne, de akkor is pici lesz rá az igény.
Én a http://linuxgizmos.com/ - szoktam nézegetni, ha ARM-es minipc -re támad kedvem .. ( de aztán lehütöm magam ) -
Cathulhu
Petykemano
#639
Kivancsi vagyok es azt mondom bar lenne igazatok, de en aggodom az extra kesleltetes miatt, ami gyakorlatilag megbenitotta a TR-eket, es nem hiszem, hogy ez varazsutesre megoldodott volna. Igy hiaba az 5GHz meg a +10% IPC, ha kozben meg ehezik a CPU es malmozassal tolti az idot.
Cathulhu
Petykemano
#637
En nem gondolom, hogy a 2019 elejen megjeleno Ryzen3-nak az ev vegen talan megjeleno intelekkel kellene versenyeznie, arra ott lesz majd a Ryzen4 a Zen2+-szal. Raadasul az intel 10 nanojarol nem sokat tudunk, de amit tudunk, abbol nem biztos, hogy az elso generacio lenyegi elorelepest hozna a jelenlegi felhozatalhoz kepest, meg az is elofordulhat hogy keptelenek mondjuk 6-8 magnal komplexebb CPUkat gyartani 10 nanon, szoval erre semmikepp se alapoznek.
Masreszt nem gondolom, hogy a Zen2 alapjaiban mas lenne mint a Zen1. Nyilvan rengeteg mindenben fejlodott es mas lett, de pl a kozponti I/O-s design sem annyira nagy ujdonsag, mivel Zen1-el is ugyanugy megepitheto lenne most IF-en keresztul kapcsolodo IO hubbal. Ezert ugy gondolom, hogy attol, hogy a rosszul skalazodo I/O-t most epp leszedtek rola, attol meg annak a helye ugymond ugyanugy megvan, azaz nem kell teljesen uj designt kesziteni, csak egy olyat amire visszateszik az I/O reszt, ez meg mar mindjart nem akkora munka es koltseg. Az sem igaz, hogy az AMD tartana ettol, mint a tuztol, ha eleg modularis a designjuk, akkor boszen szoktak ennel sokkal kevesbe rentabilis piacokat is ellatni sajat chippel (Vega 64, 28, 24, 11)
A hibas Epyc chipleteknek meg lenne a helye kisebb Epycekben es TR-ekben, mig a hibas Ryzen chipletek pedig mehetnek Ryzen5-nek es 3-nak. -
Petykemano
Petykemano
#636
Pinky Demon:
"Tovabbra is tartom azt, hogy a sima ryzenek 1 chipletes, max 8 magos integralt I/O-s kiszerelessel jonnek. 2019-ben semmi szukseg es semmi nyomas sincs 8 magnal tobbre asztali gepnel. Akinek tobbre van szuksege, lesz majd TR 16-tol 64 magig. Az kozponti I/O-val jaro extra kesleltetes pont agyonvagna az egyszalas teljesitmenyt, ami itt a legfontosabb (FPS). Es mivel ugy nez ki nem lesz L4 az I/O chipben igy az IF megint a RAM sebesseggel lesz szinkronban ami DDR5 hianyaban ugyanugy vallalhatatlan kesleltetest hozna szerintem, mint a jelenlegi TR-eknel."Hogy miért lenne nem praktikus és illogikus korábbi érák érvelése szerint a külön monolitikus design itt leírtam.
A rome IO chipjében elvileg nincs L4. De ez nem jelenti azt, hogy a ryzen chipekhez ne lehetne olyat készíteni - a drágábbakhoz - amin van. Persze tudom, most úgy fogok dobálózni az IO chipekkel, mintha az ingyen lenne, de a GF14nm-én 8MB L3$ 16mm2 64MB kéne 2 zen2 chiplet mögé, a 128mm2. Ha ehhez hozzáadjuk a IO részeket szerintem 200mm2-ból biztosan kijön. Egy ilyen megoldás $15-ral dobhatná meg a költségeket. De Ne azt nézd, hogy ez abszolút értékben mennyi a megszivárogtatott árakhoz képest. Hanem, hogy ehhez képest mennyivel kerülne többe 7nm-en egy másik chipet tervezni, ami nagyobb is, mint a rome-hoz tartozó zen2 chiplet és a rome-ból hátramaradt hulladékot meg a kukába dobni!
Anno bulldozer eraban sem voltak rosszak a dozerek, felso kategoriaban nem versenyeztek, de eros kozepkategoriat megutottek, es mai arakhoz kepest fillerekert lehetett kapni oket. Cserebe hoztak 8 magot 4 helyett, es mire ment vele az AMD? Nem sokra. Most ugyanigy nem latom ertelmet 2019-re a 12-16 magos standard asztali kiszerelesnek. Hasra utok, de ha tudnak kisebb latencyvel mondjuk 10%-ot hozni 1 szalon, az szvsz tobbet jelent egy 8 magos Ryzennel, mint +50% mag. Gamereknel nem fog mindsharet nyerni tobb maggal, ha a legtobb FPS-t a meghatarozo jatekokban intel fog hozni. Jelenleg is aki gamer, az inkabb intelt vesz, hiaba kiegyensulyozottabb valasztas a Ryzen. Tavaly lehetett azt mondani, hogy streamereknek jobb, mert a 8 mag sokkal kiegyensulyozottabb FPS-t hoz mint a 4, de mar az intel sincs lemaradasban itt.Workstation es server piacra ez a strategia tokeletes, epp most veszunk egy 2990WX-et de maris csurog a nyalam, ha bele gondolok mi johet(ne) jovore. Ugyanakkor szerintem nem ez kell ahhoz, hogy az atlag pistit is megnyerjek maguknak, ahhoz az kell, hogy CS:GO-ban, PUBG-ben es Fortniteban is jobb legyen mint az intel, es szerintem az nem fog menni most oszver designnal, mert ahhoz kell az IPC, kell az 5GHz es kelleni fog az alacsony kesleltetes is. Viszont most van szabad 7nm-es kapacitas es forras is vegre, hogy egy kicsit modositott (integralt I/O) lapkat is gyarthassanak.
"Szerintem teljesen más volt az a helyzet, amikor feleolyan erős magokból vehettél 8-at, vagy egységnyi erőt képviselő magokból 4-et. Ehhez képest a Ryzen megjelenésekor úgy dönteni, hogy most veszek 8 magosat, ami magonként 10%-kal gyengébb egy valódi, hosszabb távon gyümölcsöző döntés volt. Nem állítom, hogy ez már beérett, de mivel az intel is elkezdte emelni a magszámot, idővel be fog érni.
Mégegyzer mondom: lehet, hogy a mai intel felhozatallal szemben elégségesnek tűnik, ha ugyanannyi magszámmal rávernek a ma kapható 9900K-ra 10%-ot (mindenféle értelemben) De a ryzen 3000 szerintem nem a 9900K ellen készül, hanem az intel 2019-es felhozala ellen, amiről egyfelől már pletykálják, hogy 10 magos, meg hogy 10nm és minden vonatkozásban előrelépést jelent majd, erősít. Egy 10 magos +50% L1$-t és mindenféle csodákat felvonultató intel újdonság ellen egy 12 magos zen2 szerintem épphogy megütheti +10%-ot.
Abban persze igazad van, hogy ha monolitikus lenne a chip és arra törekednének, hogy minimalizálják a késleltetéseket, akkor akár abból is meglehetne a 8 mag & +10%
Ehhez képest a chiplet, aminek mindenképpen hátránya a lapján kívüli memóriaelérés, a következő előnyökkel kecsegtet:
- nem kell új, nagyobb chipet tervezni 7nm-en. Eddig az AMD mindig megúszósan kezelte a designt, a külön konzumer és pro gpu-ért is hiába könyörgünk.
- Ha egyféle - 8 magos - chipletet használ fel, akkor azok méretüknél fogva rendkívül jól válogathatók
- Ha egyféle - 8 magos - chipletet használ fel, akkor a selejtet fel lehet használni az olcsóbb chipekhez kidobás helyet. Ha két külön design van, akkor egyik selejtjét se nagyon tudod felhasználni.
- Később marha egyszerű lehet a zen2-t átrakni DDR5-ös AM5-re.A video szerint a Ryzen5 és Ryzen7 esetén is 2 zen2 chipletből áll, mindkettőben olyan lapkák, amikben 1 vagy 2 magot le kellett tiltani. Ez tehát abszolút hibás, selejt lapkák felhasználását jelenti. Úgy képzelem, hogy ennek ellenére az 1-1 lapkán üzemelő 4-4 vagy 6-6 mag mellett mind a 32-32MB L3$ aktív lesz. (ilyen ugye a zeppelin lapká felhasználásánál is van, a 4 és 6 magos zeppelin ryzenek rendelkeznek a teljes 16MB L3$-sel)
Ez egy 8 magos selejt chipletből felépűlő proci esetén pont 2x annyi L3$-t jelentene, mint ha monolitikusan készülne maximum 8 maggal. Én azt gondolom, hogy ha a videoban ismertetett felhozatal végül igaznak bizonyul, akkor a Ryzen 5-ök lesznek a legjobb gamer procik. -
hokuszpk
Petykemano
#632
vannak helyek, ahol a multbol nemlehet megelni. mindenki azzal jott, hogy "de hat az RTXet milyen jol eltalaltak". Hoogyne, hiszen, az NVtol kapták az infot. Most meg elfelejtettek megemliteni, hogy ez is az NVtol jott.
Szoval varjuk meg a mai videot, ha nem az lesz benne, hogy "hat ennek csunyan bedoltunk", akkor felolem vedheted is, ugyse dolok be. -
hokuszpk
Petykemano
#625
mar messzirol hápogott.
- Macbook Pro 2019 // i9 // 32GB / 2TB // Számla+Garancia //
- GYÖNYÖRŰ iPhone 13 mini 128GB Starlight -1 ÉV GARANCIA -Kártyafüggetlen, MS3618,96% Akksi
- HIBÁTLAN iPhone 14 128GB Starlight -1 ÉV GARANCIA - Kártyafüggetlen, MS3238
- ÁRGARANCIA!Épített KomPhone Ryzen 7 9800X3D 32/64GB RAM RTX 5070 12GB GAMER PC termékbeszámítással
- PS5 PlayStation 5 Slim (lemezes, 1TB) kiváló állapotban! 6 Hónap Jótállás
