Teréz Atya
KaiotEch
#36615
Hat ezert hanyagoltam eddig en is a micro brushless racereket.
Jon az Emax Babyhawk, 90 dolcsi lesz az ARF, az szerintem beszakitja az arakat. De mire kijon mar reg nagygepes ido lesz.
@Geller - ahogy kaio is irta, mennie kene. Afhds 2A protokoll, ra is van nyomtatva a tavra. Ha kikapcsolod, akkor mennie kene a micro vevokkel.
syler123
KaiotEch
#36400
Köszi, akkor nem a probléma forrása. Szomorú. Ötletem nincs mit lehetne vele kezdeni. Motorok forognak, de max fél fordulaton.
Esetleg akinek falconja van, megnézné hogy jó-e ez a log?
Entering CLI Mode, type 'exit' to return, or 'help'
# dump
# version
# Cleanflight/SPRACINGF3 1.12.0 Jan 11 2016 / 16:01:46 (7a4bc02)
# dump master# mixer
mixer QUADX
mmix reset
smix reset# feature
feature -RX_PPM
feature -VBAT
feature -INFLIGHT_ACC_CAL
feature -RX_SERIAL
feature -MOTOR_STOP
feature -SERVO_TILT
feature -SOFTSERIAL
feature -GPS
feature -FAILSAFE
feature -SONAR
feature -TELEMETRY
feature -CURRENT_METER
feature -3D
feature -RX_PARALLEL_PWM
feature -RX_MSP
feature -RSSI_ADC
feature -LED_STRIP
feature -DISPLAY
feature -ONESHOT125
feature -BLACKBOX
feature -CHANNEL_FORWARDING
feature VBAT
feature FAILSAFE
feature RX_PARALLEL_PWM# map
map AETR1234# serial
serial 0 1 115200 57600 0 115200
serial 1 0 115200 57600 0 115200
serial 2 0 115200 57600 0 115200# led
led 0 15,15:ES:IA:0
led 1 15,8:E
F:0
led 2 15,7:E
F:0
led 3 15,0
E:IA:0
led 4 8,0
:0
led 5 7,0
:0
led 6 0,0
W:IA:0
led 7 0,7
F:0
led 8 0,8
F:0
led 9 0,15:SW:IA:0
led 10 7,15:S
F:0
led 11 8,15:S
F:0
led 12 7,7
F:0
led 13 8,7
F:0
led 14 7,8
F:0
led 15 8,8
F:0
led 16 8,9:
:3
led 17 9,10:
:3
led 18 10,11:
:3
led 19 10,12:
:3
led 20 9,13:
:3
led 21 8,14:
:3
led 22 7,14:
:3
led 23 6,13:
:3
led 24 5,12:
:3
led 25 5,11:
:3
led 26 6,10:
:3
led 27 7,9:
:3
led 28 0,0:::0
led 29 0,0:::0
led 30 0,0:::0
led 31 0,0:::0# color
color 0 0,0,0
color 1 0,255,255
color 2 0,0,255
color 3 30,0,255
color 4 60,0,255
color 5 90,0,255
color 6 120,0,255
color 7 150,0,255
color 8 180,0,255
color 9 210,0,255
color 10 240,0,255
color 11 270,0,255
color 12 300,0,255
color 13 330,0,255
color 14 0,0,0
color 15 0,0,0set looptime = 2000
set emf_avoidance = OFF
set i2c_overclock = OFF
set gyro_sync = OFF
set gyro_sync_denom = 1
set mid_rc = 1500
set min_check = 1050
set max_check = 1900
set rssi_channel = 0
set rssi_scale = 30
set rssi_ppm_invert = OFF
set rc_smoothing = ON
set input_filtering_mode = OFF
set min_throttle = 1050
set max_throttle = 1950
set min_command = 1000
set servo_center_pulse = 1500
set 3d_deadband_low = 1406
set 3d_deadband_high = 1514
set 3d_neutral = 1460
set 3d_deadband_throttle = 50
set motor_pwm_rate = 400
set servo_pwm_rate = 50
set retarded_arm = OFF
set disarm_kill_switch = ON
set auto_disarm_delay = 5
set small_angle = 25
set fixedwing_althold_dir = 1
set reboot_character = 82
set gps_provider = NMEA
set gps_sbas_mode = AUTO
set gps_auto_config = ON
set gps_auto_baud = OFF
set serialrx_provider = SPEK1024
set sbus_inversion = ON
set spektrum_sat_bind = 0
set telemetry_switch = OFF
set telemetry_inversion = ON
set frsky_default_lattitude = 0.000
set frsky_default_longitude = 0.000
set frsky_coordinates_format = 0
set frsky_unit = IMPERIAL
set frsky_vfas_precision = 0
set hott_alarm_sound_interval = 5
set battery_capacity = 0
set vbat_scale = 110
set vbat_max_cell_voltage = 43
set vbat_min_cell_voltage = 33
set vbat_warning_cell_voltage = 35
set current_meter_scale = 400
set current_meter_offset = 0
set multiwii_current_meter_output = OFF
set current_meter_type = ADC
set align_gyro = DEFAULT
set align_acc = DEFAULT
set align_mag = DEFAULT
set align_board_roll = -10
set align_board_pitch = 0
set align_board_yaw = 90
set max_angle_inclination = 500
set gyro_lpf = 42HZ
set moron_threshold = 32
set imu_dcm_kp = 2500
set imu_dcm_ki = 0
set yaw_control_direction = 1
set pid_at_min_throttle = ON
set yaw_motor_direction = 1
set yaw_jump_prevention_limit = 200
set tri_unarmed_servo = ON
set servo_lowpass_freq = 400
set servo_lowpass_enable = OFF
set failsafe_delay = 10
set failsafe_off_delay = 200
set failsafe_throttle = 1050
set failsafe_kill_switch = OFF
set failsafe_throttle_low_delay = 100
set failsafe_procedure = 1
set rx_min_usec = 885
set rx_max_usec = 2115
set acc_hardware = 0
set baro_hardware = 0
set mag_hardware = 0
set blackbox_rate_num = 1
set blackbox_rate_denom = 1
set blackbox_device = SPIFLASH
set magzero_x = 0
set magzero_y = 0
set magzero_z = 0# rxfail
rxfail 0 a
rxfail 1 a
rxfail 2 a
rxfail 3 a
rxfail 4 h
rxfail 5 h
rxfail 6 h
rxfail 7 h
rxfail 8 h
rxfail 9 h
rxfail 10 h
rxfail 11 h
rxfail 12 h
rxfail 13 h
rxfail 14 h
rxfail 15 h
rxfail 16 h
rxfail 17 h# dump profile
# profile
profile 0# aux
aux 0 1 0 900 1350
aux 1 2 0 1375 1850
aux 2 0 0 900 900
aux 3 0 0 900 900
aux 4 0 0 900 900
aux 5 0 0 900 900
aux 6 0 0 900 900
aux 7 0 0 900 900
aux 8 0 0 900 900
aux 9 0 0 900 900
aux 10 0 0 900 900
aux 11 0 0 900 900
aux 12 0 0 900 900
aux 13 0 0 900 900
aux 14 0 0 900 900
aux 15 0 0 900 900
aux 16 0 0 900 900
aux 17 0 0 900 900
aux 18 0 0 900 900
aux 19 0 0 900 900# adjrange
adjrange 0 0 0 900 900 0 0
adjrange 1 0 0 900 900 0 0
adjrange 2 0 0 900 900 0 0
adjrange 3 0 0 900 900 0 0
adjrange 4 0 0 900 900 0 0
adjrange 5 0 0 900 900 0 0
adjrange 6 0 0 900 900 0 0
adjrange 7 0 0 900 900 0 0
adjrange 8 0 0 900 900 0 0
adjrange 9 0 0 900 900 0 0
adjrange 10 0 0 900 900 0 0
adjrange 11 0 0 900 900 0 0# rxrange
rxrange 0 1000 2000
rxrange 1 1000 2000
rxrange 2 1000 2000
rxrange 3 1000 2000# servo
servo 0 1000 2000 1500 45 45 100 -1
servo 1 1000 2000 1500 45 45 100 -1
servo 2 1000 2000 1500 45 45 100 -1
servo 3 1000 2000 1500 45 45 100 -1
servo 4 1000 2000 1500 45 45 100 -1
servo 5 1000 2000 1500 45 45 100 -1
servo 6 1000 2000 1500 45 45 100 -1
servo 7 1000 2000 1500 45 45 100 -1set gps_pos_p = 15
set gps_pos_i = 0
set gps_pos_d = 0
set gps_posr_p = 34
set gps_posr_i = 14
set gps_posr_d = 53
set gps_nav_p = 25
set gps_nav_i = 33
set gps_nav_d = 83
set gps_wp_radius = 200
set nav_controls_heading = ON
set nav_speed_min = 100
set nav_speed_max = 300
set nav_slew_rate = 30
set alt_hold_deadband = 40
set alt_hold_fast_change = ON
set deadband = 0
set yaw_deadband = 0
set throttle_correction_value = 0
set throttle_correction_angle = 800
set default_rate_profile = 0
set gimbal_mode = NORMAL
set acc_cut_hz = 15
set accxy_deadband = 40
set accz_deadband = 40
set accz_lpf_cutoff = 5.000
set acc_unarmedcal = ON
set acc_trim_pitch = 0
set acc_trim_roll = 0
set baro_tab_size = 21
set baro_noise_lpf = 0.600
set baro_cf_vel = 0.985
set baro_cf_alt = 0.965
set mag_declination = 0
set pid_controller = MWREWRITE
set p_pitch = 58
set i_pitch = 20
set d_pitch = 51
set p_roll = 48
set i_roll = 20
set d_roll = 55
set p_yaw = 50
set i_yaw = 40
set d_yaw = 0
set p_pitchf = 1.400
set i_pitchf = 0.400
set d_pitchf = 0.030
set p_rollf = 1.400
set i_rollf = 0.400
set d_rollf = 0.030
set p_yawf = 3.500
set i_yawf = 0.400
set d_yawf = 0.010
set level_horizon = 3.000
set level_angle = 5.000
set sensitivity_horizon = 75
set p_alt = 50
set i_alt = 0
set d_alt = 0
set p_level = 45
set i_level = 50
set d_level = 100
set p_vel = 120
set i_vel = 45
set d_vel = 1
set yaw_p_limit = 500
set gyro_soft_lpf = OFF
set dterm_cut_hz = 0
set yaw_pterm_cut_hz = 0
set gtune_loP_rll = 10
set gtune_loP_ptch = 10
set gtune_loP_yw = 10
set gtune_hiP_rll = 100
set gtune_hiP_ptch = 100
set gtune_hiP_yw = 100
set gtune_pwr = 0
set gtune_settle_time = 450
set gtune_average_cycles = 16# dump rates
# rateprofile
rateprofile 0set rc_rate = 90
set rc_expo = 65
set rc_yaw_expo = 0
set thr_mid = 50
set thr_expo = 0
set roll_rate = 75
set pitch_rate = 65
set yaw_rate = 50
set tpa_rate = 40
set tpa_breakpoint = 1650#
Geller72
KaiotEch
#36309
..Akinek nem inge..
. Amúgy meg ennél azért már te is tudod, hogy sokkal szarabb helyre ilyen módon gyárilag nem is tehették volna. (Mondom, most már te is tudod.) Nekem a jövő héten jön a pótlása, én máshogy oldom meg, az tuti.
. De talán Teréz írta joggal, hogy az anyját.******...aki egy kétoldalas raggal oldotta meg ezt.
Baku
KaiotEch
#36016
Olyasmi.... 85%-a soha nem kell semmire.... No de az a 15%!!! Az KINCS! Sokszor fordult már elő,hogy olyan "kincs" segített ki, amit sehol nem tudtam beszerezni, de ott lapult belőle néhány a láda mélyén.... Ja, nálam "halál fia" aki kidob valami "kincset". Majd ha feldobom a pacskert, akkor hívnak egy kontainerest....
Ehhez a gimball pöcök moddoláshoz (csak a példa kedvéért) az alábbi anyagokat használtam fel:
- Cipő merevítő műanyag cső (új cipőből, ami mindenki másnak szemét)
- Műanyag fogpiszkáló (külföldről hoztam, a munkahelyemről)
- Piros szívószál....és lehet röhögni....
DJGABI
Minstrel
KaiotEch
#35878
Én szoktam, laptopból kiszedett cellákra rá tudtam csiptetni, mert azokon voltak kis lemezdarabok, de most már a normál akkukhoz vettem inkább ilyen foglalatot [link]
A lipo módban töltés is jó, ugyanazok a feszültségek, ha eléri akkor úgyis megáll.
Én csak egyenként töltöttem, főleg azért is, mert kerestem melyik a rossz.
Geller72
KaiotEch
#35828
Nincs összefüggés. A kicsi nyákokból gondolom van egy komplett nyákon kb 20 db. Ezt a konvejorról betöltik a szalagra, ami viszi végig a soron. Az első gép a pasztázó, vagy a ragasztó, attól függ, milyen a gyártástechnológia. Aztán vannak különböző beültető gépek egymás után több is. A beültetést az egész sorra optimalizálja egy program, figyelembe véve mindegyik gépet a sorban. Ezt ne részletezzük, mert ez mindegy. Az a nyák lejön, leszeletelik, mint az uborkát és egy szerelősoron összeszerelik. Na itt lett elqrva. Az a helyzet, hogy gondolom, legyártottak ezer darabot és ennyi, itt a vége, most ezért van belőle hiány. Ha lesz új, akkor gondolom, az már máshogy lesz. Nem lenne rossz, ha jönne, mert még él a 20% kupon.
Már a Realacc 210-ből sincs készleten, gondolom ott is sokan ugrottak a 20-as kuponra. -
Petyuska111
KaiotEch
#35729
MultiStar Universal Drone Backpack Vízálló, minden belefér. Mondjuk kézben nem annyira vihető, ez hátitáska.
syler123
KaiotEch
#35424
Igen, jó hogy rátok hallgattam. Kicsit túl nagy volt a lelkesedésem, pedig még 1 géppel sem repültem. Az xk x250-el megtanulok szépen repülni és majd utána lépek tovább brushless gépre, így már annyira nem is bánom, hogy nem lett falcon 180, szerintem törtem volna az első repüléskor.A h8s tölthető nagyobb töltővel? Jelenleg hubon keresztül töltöm, ami rá van kötve egy 2,4A-es blitzwolf töltőre, de így kb max 0.5A-al tölt. Köthetem közvetlen a 2,4A-re? Volt egy helim, de gyanúsan gyorsan feltöltötte az akkuját.
Geller72
KaiotEch
#35397
A mocikkal beszoppantottam, mert azt hollandon keresztül küldik, ami azt jelenti, hogy a kici kínai előre elkéri a holland postától a tracking numbert és ha megérkezik hollandba, akkor a kici kínai ráragasztja a kapott tracking numbert és onnantól jön valójában holland postával. A cumi az, hogy amíg nem scannelik be a post.nl-nél, addig akárhol lehet a csomi.
. Ezt hívják "The item is pre-advised"-nek. December 25.-én vettem meg, 29.-én kérték meg rá a tracking numbert és január negyedikétől van úton hollandból. Mondanám, hogy hű de gyors, viszont ez egy Priority Direct Mail volt, megtámogatva némi apróval a postaköltség. És még nem érkezett meg. Jött olyan csomim is, amin még tracking number sem volt, full free shippinggel jött és hét munkanap alatt itt volt.
Ünnepek alatt. -
Geller72
KaiotEch
#35394
Az én tapasztalatom az (drónos holmiktól függetlenül) hogy sok esetben szerencse kérdése, viszont ahogy megfigyeltem, az akksikat általában alapból svéd postán keresztül kapom. Azt is észrevettem, hogy nem kezdők a kici kínaiak, tudják hogy mit, hol jobb küldeni. Jött svájci postán keresztül is csomagom. Most is úton van több svéd, két cseh, 3 német, és egy rakás holland (belga) postai csomim. Nekem ez a tapasztalatom.
syler123
KaiotEch
#35389
Kivárom, majd a dédunokám megrendeli nekem
Bár lehet addigra benő a fejem lágya és nem pazarolom ilyenre a nyugdíjat (már ha lesz akkor még olyan hogy nyugdíj).Na mindegy is, most hogy nincs falcon 180 szintű gép 100 dollár környékén így most kivárok. Remélem be lesz ide dobva, ha valami bestbuy racer jelenik meg a piacon.
syler123
KaiotEch
#35258
Már azt hittem az RTF ennyi
Sajnos az még kuponnal is 181.23$. Lesz ez még olcsóbb is, majd ha kifuttatják és új modellt szánnak a helyére. Majd akkor nem agyalok annyit, mint a Falcon-al és nem csúszok le róla.40eFt-ot kért érte, amit kicsit sokallok, persze lehet hogy annyiért is jó vétel lehetett volna, belegondolva hogy tuti nem lesz rá áfa.
MAxxYD
KaiotEch
#35207
Nem tudtam neki ellenállni, még tegnap este megrendeltem és már postázták is.
Már csak egy távot kell vennem hozzá.
Remélem, hogy nem akad fenn a vámon
Ha valakit esetleg érdekelne:
Némi utánajárás után kinyomoztam, hogy az SP F3 csak a standard verzió, nincs benne sem barométer, sem pedig compass. -
maximilian4
KaiotEch
#35147
Teljesen így csinálom. A kijelzőn is ugyanezeket írja ki ahogy haladok és direkt ilyen sorrendben is csinálom. 100-szor megnéztem hogy mi lehet a hiba és egyszerűen nem értem... Egyedül arra reagál a gép ha a gáz kart felnyomom fullra és a jobb kart pl előre tolom fullra, vagy jobbra-balra. Ekkor csipog egyet egyet a drón, de amúgy semmi..
maximilian4
KaiotEch
#35123
nem válasznak
Néztem videókat a motor és az esc illesztéséről. Egy dolgot nem értek. Ha jól emlékszem akkor a cw-t úgy kötötték be, hogy a motorból kijövő 3 vezetéket az esc-nek az azzal szembe lévő pontjába forrasztották (ugye 3 db forrasztási pont van), tehát a bal vezetéket az esc-n lévő bal pontba, középsőt a középsőbe, a jobb vezetéket a jobb oldali pontba. Viszont a másik 2 motornál 2 vezetéket tetszőlegesen felcserélt és úgy forrasztotta (pl. a középső vezeték ment balra, a bal vezeték középre, a jobb ment ugyanúgy szembe). Ezt minden esetben így kell? Akkor is ha a motor eleve ccw? Vagy a fenti eset akkor van ha a cw motort kötöm be ccw-nek?
syler123
KaiotEch
#35121
Nem is az hogy annyira csodálkozok, de ennyiért jó vétel lett volna, kitudja mikor lesz hasonló árban ilyen tudású gép. Mindegy is, lehet akkor veszek még egy ilyen akksi pakkot az xk 250-hez. Vagy nem lesz valami élvezetes ezzel a géppel a repülés, elég belőle egyszerre 8 perc?
Ezen nem dobna picit, ha 3 szárnyú propellert tennék rá? Melyik mehet ilyenből rá? Még nem vettem hozzá plusz propellert, mert gyárilag adnak hozzá tartalékot.
syler123
KaiotEch
#34990
Tökéletesen leírtad miért nem kell nekem az x251. És ahhoz képest meg drága hogy ráunok aztán vagy eltudom adni vagy nem, ezért kell megtalálnom az optimális Racert, amire nem megy rá a gatyám
Így a vezérlő miatt gondolom a Falcon is kizárva.A Wizard-hoz F3 6DOF vezérlő jár. Milyen áron szokott ez lenni akcióban? Mert sürgősnek nem sürgős nekem, kivárom az akciót ha szokott lenni, jó lenne ha távval együtt 50k-ba beleférne.
Amúgy ezek már 250g fölött vannak, mehetek engedélyeztetni?
Sőt a wizard fél kiló fölött. Lehet megvárom hogy mire jut ez a szabályozás idehaza.Geller_1972: Add el a Falcon-t a fenébe nem kell az neked a Wizard mellé! (Megveszem
)Annak örülnék ha írnál majd róla, a Wizardról meg a Falcon 180-ról is. Össze is tudod hasonlítani hogy szerinted ég és föld-e a kettő, vagy nem nagy ugrás.
syler123
KaiotEch
#34983
Akkor az is megfelelhet végső soron. Annyi biztos, hogy nekem Lesz ugye a h8s, az xk 250 ha megjön és még egy Brushless gép és én kiszálltam
Tuti nem fogok több drone-t venni, maximum ezekhez alkatrészeket. Ezért lenne fontos megtalálni ezért az árért kapható legjobbat, aminek élvezetes a vezetése, nehezen megunható, gyors és jó fpv-re.
Amúgy a Falcon 180 többféle controllerrel kapható, bangood-on pont CC3D-vel amit te nem ajánlottál.Robocat kizárva a gyagyi váz miatt. Azt nem szeretném hogy könnyen törjön, annak ellenére hogy elég óvatos vezető leszek, míg ki nem tapasztalom komolyabban az irányítást.
Geller_1972: Mi a gond egy Racer repülésével? Mit nem tud, amit egy xk x251 vagy az x1 igen?
syler123
KaiotEch
#34972
Igen a srác is írja, hogy vezérlőből inkább ezt.Power boardból pedig ezt vegyük.
Köszi, megnézem videók alatt a Wizardot.
A falcon 180 a videók alapján sokkal sokkal gyengébb, mint az az épített robocat. Pont az hiányzik belőle, ami az élményt adja a Robocatnél, elengedem a gázt és lazán megfogja, max gázzal meg kilövi magát, mint a rakéta.
Teréz Atya
KaiotEch
#34855
Eachine Pioneer? Most van ra 20% kupon. Ugy 190 euro korul megall vamvizsgalattal az olcsobb. Lehet hozza venni telemetria modult (30$) mobil apphoz meg 2d gimbalt(70$???). De alig van valakinek.
Ja fpv. ado 20$, meg kb 50-70 a monitor.Most igy szamolom, megint 400 dollar korul vagyunk. 500 meg a dji p3s es az kulcsra kesz.
hege21
KaiotEch
#34836
Megoldotta egyenlőre
Geller72
KaiotEch
#34802
Aki meg szoliban van, az meg holnap.
vagy már ma másnaposan ment be.Én csak ma több seggrészeget láttam rókát kergetni az utcán, miközben jöttünk/mentünk repülni, mint tavaly egész ünnepi szezon alatt.
Mindenkinek boldog új évet.
. Jó pihenést, vastag lakossági folyószámlát, valid webshop-accokat kívánok.
syler123
Geller72
KaiotEch
#34633
A yaw sebessége attól is függ, hogy a távon hány százalékon vagy. 50%-on olyan tetű minden, hogy nyugodtan lehet vele forgolódni. 100%-on igen ideges a kicsike, de sokszor kell is. Meglepően nagy a hatótávja, kezdő törögetős gépnek szerintem simán vehető, ráadásul krvra bírja is, mert könnyű. Iszonyat, mit kibír.
syler123
KaiotEch
#34624
Úgy gondoltam, hogy a gyári akku elbírná a kamerát, nem? Legfeljebb nem 200mV-on használom. Én a drone alján láttam csatikat arra rátudom kötni a kamerát hogy kapjon tápot vagy valami kell hozzá? Átalakítóra gondolok, forrasztani nem szeretnék. A kamerát valahogy rágumiznám, az a baj hogy a tetejére nem nagyon lehet a drone formája miatt, ez még nem nagyon lett átgondolva.
Így jó lehet?
Saccco használja telefonnal, nem tudom neki hogyan került a telefonjára ez a driver. Vagy mik az előfeltételek, ezt sehol nem írják.
Azért nem rendeltem még meg a kamerát sem, míg nincs komplett terv.
syler123
KaiotEch
#34617
Linkeltétek korábban a Rambo Whoop videót, attól nekem nem hiszem hogy kellene nagyobb távolság. Itt sincs totálisan nyílt terep. Videótesztben az xk x250 távolságát nagyon dicsérték, és mondta a fazon hogy tényleg tudja a 300m-t, az bőven lefedné azt a terepet, amit bejárnék így vele. Otg-t azt tud a tab, nem tudom még milyen feltétel kell ehhez az Easycap-hez. Oneplus 3 telefonom tuti alkalmas rá, mert mindenféle új technológiát támogat, de a tabot szeretném használni, ami egy Tesco Opendott tab
syler123
KaiotEch
#34555
Köszi, hát végül találtam Gearbest-en a CCW-ből 2db 6,5 dollár, a CW pedig 7,17. Szóval nem vállalhatatlan. 31. ig kell döntenem melyik drone-t vegyem. Valamiért beleszerelmesedtem az xk 250-be, pedig nem biztos hogy az a legjobb választás. Eladással nem fogok foglalkozni, tehát ha később veszek is komolyabbat, akkor is fogom azt is reptetni amit most megveszek
Más: Tényleg ennyit számít h8s-nél hogy kihúzzuk a házból az antennákat? A videóban szereplő emberke azt írja 25m-ről 80-100ra nőtt a távolság. Ha így van, akkor én is rögtön megcsinálom ezt a h8s-en.
Alatta lévő hozzászóló szerint meg csak az időnket vesztegetjük vele. -
Geller72
KaiotEch
#34530
Ennyiért ugyanott találtam ekkora kapacitásút, de már 4S-ben.
.És ez méretben és súlyban is nagyon jó.
.Amúgy vegyesben nézelődök, mindkét gépre.
. A töltővel leszek bajba. Amit beszéltünk is. Kell egy jó töltő, a 4S miatt is. Olyan, amivel tudok tölteni akár 4 akkut is.
(Már most fáj
)Lenne egy kérdésem:
-Rep időben tapasztalatotok alapján a nagyobb kapacitású, de nehezebb akku kombó több repidőt ad e általában még a plusz súly miatt is,mint a kisebb mAh-s, de kisebb súlyú akku? Azért is előfordulnak, ahogy látom, 10 deka(!) difik is két akku közt.
virbo
KaiotEch
#34519
Én pont ezt fogom elkövetni.
Kidobtam a nehéz PDB-t is, kapott könyebb OSD-set, aminek a váz mellett jön ki a csatija. A felső lapot átalakítottam, hogy lejebb tudjam hozni. Majd kell egy valami ami a kamerát védi, mert kb 20mm-re lesz a felső lap a főváztól, és ebből az kilóg. Hely az gyakorlatilag nulla marad belül.
Ha megjön végre a vevőm be is tudom fejezni. -
Geller72
Geller72
KaiotEch
#34513
Nekem tűzálló anyagnak tűnik. Gondolom, hogy a feltöltött akkuknak van, az a veszélyes, nem a lemerült. Ezért is van írva mindenhol hogy töltetlen állapotban szállítsd. Vagy ebben. Arra van, hogy a már feltöltötted biztonságban tudd elvinni A-ból B-be. "arra a tecsos szatyor is jó" -nem gondolnám.
.Az akkut, amit linkeltetek, azzal az a baj, hogy a 180-BA nem fér bele, mert a linkelt 4S-es akku szélesebb, mint amit a 180 befogad. 220-ra nem lesz rossz.
Úgy emlékszem, írtam is, hogy a 3S akkuk MELLÉ rendelném a 4S-es akkukat.
Mentem a 3S-el, írtam is, hogy többre számítottam, nem volt ez olyan vészes, szignifikánsabb difire gondoltam. Nem lesz ez rossz, csak ne füstölt volna el a motor a második felszállásnál egy méter magasan. Kicsit ijesztő volt, ahogy "leájult".
. Semmi előjele nem volt. -
Jackal2
KaiotEch
#34482
Van egy fasza táska, ami nagyon tetszik, csak 20 rugó. De hajlok rá, hogy megveszem. Végül is csak egyszer kell letudni ezt a témát. HK-n is láttam, a Nighthawkomhoz mondjuk pici, de lassan úgy is elbúcsúzom a régi gépektől, mert nem nagyon éri meg hegesztgetni őket.
Ez hogy tetszik a népeknek? Ez a HK-s.
Vaze
KaiotEch
#34462
milyen motor ajanlott falcon 180-hoz?ez a fajta jo?
syler123
KaiotEch
#34458
Úgy látom van rajta egy switch, amivel változtatható a teljesítmény, tehát rátehetem kisebb drone-ra is, ami nem rendelkezik nagy akkuval. Kérdés hogy hogyan? Van ennek ugye egy csatija amivel kap áramot, de mi van ha a drone ilyennel nem rendelkezik? Kell valami elosztó hozzá? Pl próbaképpen rátenném a h8s-re. Tudom nem sok értelme van, mert az úgy sem megy messzire, de tesztkörnek jó lenne.Saccco: linket kérhetnék a droidos fpv progihoz? Megszeretném nézni hogy elindul-e x86-os tabon.
syler123
KaiotEch
#34449
Lejárt a szerkesztés. Igen eddig az fpv változatot néztem, de ha magukat a droneokat akarjuk egymáshoz hasonlítani, akkor úgy érdemes, hogy mind a kettő pl kamera nélküli. Úgy viszont a Nihui a drágább. Pont ez lenne a kérdésem, hogy így is a Nihuit ajánlanád? Mert ennyire erővel az x250-re is vehetek olcsó kamerát.
Nihui 12k, x250 10k. -
syler123
KaiotEch
#34449
Pont ezaz, hogy a Nihuihoz semmit sem adnak, tehát drágább, mint az x250. Azért nem értelek, hogy miért a Nihui ajánlott. Az XK Alien X250-et nem ajánlod 35 dollárért = 10eHuf. Míg a Nihui ennyiért jó vétel? (vagyis többért, mert 10k környékén nincs is) A Nihui jobb gép, mint az x250?
syler123
KaiotEch
#34414
Igazándiból az a Nihui nem sokkal olcsóbb, mint az xk x250 (itt maga az fpv drága).
3000ft van a kettő között. Használtan nem igazán látok, de 2000 ft-al olcsóbban nem is vennék használtat, kitudja milyen előélete volt
Még agyalok rajta, spórolás végett akár hagyhatok is ki kategóriát, a h8s-el gyakorlok és utána jöhetne valami komolyabb, nem repülnék először vele magasra, meg nem mennék irreálisan nagy sebességgel és akkor azzal ugyanúgy gyakorolhatok. Az a baj hogy eladni utána nem nagyon tudom az olcsóbb gépet sem.
Ránézésre az x250 komolyabbnak tűnik. -
Jackal2
KaiotEch
#34405
Mert széthullnak. Én már annyi alkatrészt vettem,hogy abból kijött volna egy drágább, ami nem hullik szát.
Geller. Jah, emelnek asszem 1470 grammot a motorok
Amire ki akartam lyukadni, hogy még egy 1000 grammot emelő motorral szerelt gépet is NAGYON nehéz irányítani.Ma volt egy 2206-os motor a kezemben, 1800 grammot emel, Emaxból kivált mérnökgárda tervezte, itthon még nem kapható, csak sample.
Szóval kicsit elmebeteg módon kezdenek elszaladni a számok...Csak akku nem lesz hozzá.
A PDB, amit adnak hozzá 4x50A...
syler123
KaiotEch
#34395
Sajnos nem vagyok Pesti. De köszi hogy felajánlottad
Szerintem a fejes helyett akkor tabot fogok használni, mert azzal olcsóbban jövök ki. De így az a baj még nincs konkrét összeállítás, amit megvehetnék.
De nézelődök aztán ha találok valamit bemásolom ide, ti jobban értetek hozzá. -
syler123
KaiotEch
#34387
Köszi! Hát ez elég drága mulatság. Maga az Eachine VR D2 önmagában 30k
Vicces lenne egy 5k-s dronehoz használni
Akkor abból sem árt valami komolyabb, ami normális hatótávval rendelkezik.35k maga az fpv, meg ehhez kell még egy normális drone és akkor még a legalapabb cuccokat vettem.
Ettől az Eachine TX01 kamerától van jobb, ami nem sokkal drágább? Vagy mindegyiknek ilyen zajos a képe (úgy sejtem igen)?. A távolságot elégnek érzem amit tud.
Ennek az Eachine VR D2-nek mintha nyújtott lenne a képe? Gondolom a kamera 4:3-at ad, ez a kijelző meg nem 4:3-as.
● Quadkopterek, felső tagozat
● Fimi drónok
● DJI topic
- Házimozi haladó szinten
- Linux kezdőknek
- Delta Force (2024)
- Brutálisan elszállhat az új PC-s Snapdragon fogyasztása
- Számos VGA kihalhat a memóriapánik miatt
- OLED TV topic
- Hiányzik a Marathon? Jelentkezz a következő tesztre!
- Gumi és felni topik
- Xiaomi Redmi Note 14 Pro+ 256GB,Újszerű,Dobozával,12 hónap garanciával
- HIBÁTLAN iPhone 13 mini 128GB Starlight -1 ÉV GARANCIA - Kártyafüggetlen, MS3828, 100% Akksi
- GYÖNYÖRŰ iPhone 13 256GB Midnight -1 ÉV GARANCIA - Kártyafüggetlen, MS3921, 100% Akkumulátor
- Honor Pad X8 / 4/64GB / Wi-Fi / 12 Hó Garancia
- Apple iPhone 12 Pro Max / 128GB / Kártyafüggetlen / 12Hó garancia
F:0
E:IA:0
:0
:3
Ünnepek alatt.
