Agyasima
slashing
#22286
Ha megy az angol, akkor nem verném a billentyűzetet feleslegesen, javaslom ebből a hozzászólásból az OFF részt elolvasni.
Agyasima
Agyasima
#22278
Lejárt a szerkesztési idő, de találtam választ a kérdésemre, bár megoldást nem. A lényeg, hogy ezt a "feature"-t nem lehet kikapcsolni sehogy.
MS fórumokon találtam:
So let me get this straight. Instead of coming out and stating the answer ("No, you can't simply turn the auto correct off"), you avoid answering the question, and state 1) How he is wrong for even wanting to do it in the first place, and that despite the inconvenience, Microsoft knows better then him and is forcing him to use workarounds, and 2) How to implement these workarounds, despite the fact that he clearly states in his question that he knows of them already.3/88 is NOT a date! (Excel changes it to 3/1/88) If you want to get technical about it, 1/4 is not a date either (nor a number), its a text string. It is inconsistent to change 11/4 into 4-Nov (11/4/2010) while 111/4 remains unchanged. What's the difference between those two text strings? One character. It is simple arrogance to assume that because a text string fits into a common format, that it must be interpreted as that format WITHOUT GIVING THE SIMPLE OPTION OF TURNING THIS AUTO-FORMATING OFF! It is frustrating that this happens. It is even more frustrating to know that it is trivially simple to include this as an option, and the reason that this was never included as an option is pure arrogance.
Since this question was never officially answered, I will ask it again:
Is there a way to turn off the auto-formatting "feature" in which Excel automatically changes anything that it thinks looks like a date into a date (registry hack, software patch, ANYTHING).
Agyasima
Olyat csinál nekem az Excel 2010, hogy ha beírom egy cellába, hogy "5.05" akkor csinál belőle automatikusan egy "2014.05.05"-öt, ha kell, hanem. Hogy a pitliben lehet ezt kikapcsolni?
- Ford topik
- Fogyókúrával kínálnak több tányért a Toshiba új merevlemezei
- Filmvilág
- VoLTE/VoWiFi
- MW2 - MW3 játékosok baráti köre
- Drasztikus változást mutat a Sony mobilja az első képeken
- Nintendo Switch 2
- PC Játékok (Márc 30. UP!) Olvass...
- AKCIÓ! Asrock Z270 i7 6700K 16GB DDR4 512GB SSD RTX 2060 6GB GameMax Storm 2 AB Adata 600W
- 8 GB-os GeForce RTX 2060 SUPER (OEM HP) - garanciával
- Apple iPhone 13 Pro 256GB, Kártyafüggetlen, 1 Év Garanciával
- ÁRGARANCIA!Épített KomPhone i5 12400F 16/32/64GB RAM RTX 5070 12GB GAMER PC termékbeszámítással
Fferi50
