Sunzi
Ja, megtaláltam közben a leírását.. meg, hogy hol is van ez: ''The Prefetcher component in Windows XP is part of the Memory Manager''... Ma is tanultam valamit
Ha valakit érdekel...:
Logical Prefetcher in WinXP Post Comment
Along with WinXP a new enhancement to the memory management was made. It is called the Logical Prefetcher and it can make boot time and application start time faster. The Logical Prefetcher records disk usage in certain scenarios(Bootup, Application Start), and when the same scenario reappear, it loads all the data needed for that scenario from disk to memory, before the data is requested.
On the WinXP Home- and Professional- edition both BootUp and Application is prefetched.
On the WinXP Server and beyond only BootUp is prefetched.
The behavior of the Prefetcher is controlled with this DWORD registry key :
[HKEY_LOCAL_MACHINE \SYSTEM \CurrentControlSet \Control \Session Manager\ Memory Management \PrefetchParameters]
EnablePrefetcher = 3 (Disabled = 0, Application = 1, BootUp = 2, Application AND BootUp = 3)
Note if using other values like 5 or 6 then it will either disable the prefetcher or only activate one of the prefetching types.
The recording of these scenarios is saved in *.pf files by the Task Scheduler in this directory (Deleting the contents will remove all scenarios until the applications are run again):
C:\WinNT\Prefetch or C:\Windows\Prefetch
Note the above directory also contains a file Layout.ini, which is generated from the saved scenarios. The Layout.ini is used when doing a full defragmentation where frequently used files are aligned for faster loading. The Layout.ini is generated automaticly along with a partial defragmentation (dfrgntfs.exe) when the computer is idle (or within every 3rd day). To force this generation run this command (Will run for 1-10 min):
rundll32.exe advapi32.dll,ProcessIdleTasks
Note one can stop the automatic generation of the Layout.ini (Will become outdated if not updated manually), along with the partial defragmentation (dfrgntfs.exe), by setting this DWORD registry key:
[HKEY_LOCAL_MACHINE \Software \Microsoft \Windows \OptimalLayout]
EnableAutoLayout = 0 (Disabled = 0, Enabled = 1, Default = 1)
Note one can do a quick defrag according to the Layout.ini, and only optimize the boot- and application- files for faster startup.
defrag c: -b
Note when enabling the prefetcher(Especially for applications) one is also enabling a service that monitors disk reads and memory usage. This can cause a downgrade in performance especially on low end machines with CPU slower than 800 Mhz and less than 512 MByte RAM, so in this situation it is recommeded to disable prefetch for applications.
More Info Windows Hardware and Driver Central
More Info MS Technet
More Info MS KB Q307498 -
Sunzi
No, a #31-ben pont ez a registry key van leírva,a PwrTys is ezt kapcsolgatja, ezt kipróbáltam.
Viszont HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Prefetcher alatt peddig ennek a műveletnek a státuszai látszódnak.
Ha meg valakit érdekel, az ini file-ban( C:\WINDOWS\Prefetch\Layout.ini) megvannak azok a file-ok, amiken dolgozik/zott... A fele tmp file-ok halmaza... -
Sunzi
Meg ez is érdekes, így végigolvasva...
Bővebben: link -
Sunzi
A Windows nem defragol csak úgy magától. Szabadidejében főleg nem.
Inkább kapcsold ki a felseleges service-ket, ha van Nálad ilyen...
1-2 useful apróság: Bővebben: link
Ne felejtsük el, hogy pl. az Event-log is írkál, ha kell azt is ki lehet kapcsolni, bár én ezt nem ajánlom.
Csak kíváncsiság, milyen service-k futnak nálad jelenleg? -
Sunzi
Filemon, ilyesmi felrak, és megnéz, melyik process írkál, abból kiderül, hogy a win abejgatja a swap-et, vagy valami más az oka... Utána lehet megoldást keresni.
Bővebben: link
- E-roller topik
- Mégis meglepi egy új GeForce-szal a rajongókat az NVIDIA?
- Gyúrósok ide!
- Építő/felújító topik
- Samsung kuponkunyeráló
- Pécs és környéke adok-veszek-beszélgetek
- Tőzsde és gazdaság
- 18. helyet ért a Samsung Galaxy S26 Ultra kamerarendszere a DxOMarknál
- Konzolokról KULTURÁLT módon
- 1 TB Samsung, HGST, Western Digital 2,5" SATA-s winchesterek eladóak! 100/100
- 500 GB 2,5" SATA-s winchesterek eladóak (Samsung, Toshiba, Seagate) 100/100
- 500 GB 3,5" SATA-s winchesterek eladóak (Western Digital, Toshiba, Seagate) 100/100
- Hitachi 500GB 2,5"-os laptop hdd-k (ár és állapot a leírásban)
- BESZÁMÍTÁS! 2TB Kingston KC3000 NVMe SSD meghajtó garanciával hibátlan működéssel
- iPhone 13 128GB 100% Green (1év Garancia) - AKCIÓ
- magyar billentyűzet - 151 - Lenovo LOQ (15IAX9) - Intel Core i5-12450HX, RTX 4060 (ELKELT)
- Új Apacer 16GB DDR4 3200MHz
- 146 - 147 - 167 - 168 - 169 - Lenovo Legion Pro 7 (16IRX9H) - Intel Core i9-14900HX, RTX 4090
- HIBÁTLAN iPhone 13 Pro Max 256GB Graphite -1 ÉV GARANCIA - Kártyafüggetlen, MS4666
