Mozilla Firefox
movax
Na ok, megoldottam. Szerencsére egy régi profilmentésből van egy korábbi handlers.json fájlom, azzal felülírtam az újat, majd a Beállításokban amit kellett, Ask first-re állítottam, most már megy minden.
Ha valakinek kell, itt a handlers.json fájl tartalma:
{"defaultHandlersVersion":{"en-US":4},"mimeTypes":{"application/pdf":{"action":3,"extensions":["pdf"],"ask":true},"image/jpeg":{"action":0,"ask":true,"extensions":["jpg","jpeg","jfif","pjpeg","pjp"]},"application/x-zip-compressed":{"action":0,"ask":true,"extensions":["zip"]},"application/epub":{"action":0,"ask":true,"extensions":["epub"]},"image/png":{"action":0,"ask":true,"extensions":["png"]},"audio/mpeg":{"action":0,"ask":true,"extensions":["mp3"]},"application/vnd.openxmlformats-officedocument.wordprocessingml.document":{"action":0,"ask":true,"extensions":["docx"]},"application/octetstream":{"action":0,"ask":true,"extensions":["srt"]},"application/vnd.openxmlformats-officedocument.spreadsheetml.sheet":{"action":4,"ask":true,"extensions":["xlsx"]},"application/msword":{"action":0,"ask":true,"extensions":["doc"]},"text/xml":{"action":3,"extensions":["xml"]},"image/svg+xml":{"action":3,"extensions":["svg"]},"image/webp":{"action":3,"extensions":["webp"]},"application/zip":{"action":4,"ask":true,"extensions":["zip"]},"application/x-msdownload":{"action":0,"ask":true,"extensions":["msi"]},"application/rtf":{"action":0,"ask":true,"extensions":["rtf"]},"application/vnd.ms-excel":{"action":4,"ask":true,"extensions":["xls"]},"application/force-download":{"action":3,"ask":true,"extensions":["pdf"]},"video/mp4":{"action":0,"ask":true,"extensions":["mp4"]},"application/x-download":{"action":0,"ask":true,"extensions":["pdf"]}},"schemes":{"irc":{"stubEntry":true,"handlers":[null,{"name":"Mibbit","uriTemplate":"https://www.mibbit.com/?url=%s"}]},"ircs":{"stubEntry":true,"handlers":[null,{"name":"Mibbit","uriTemplate":"https://www.mibbit.com/?url=%s"}]},"mailto":{"stubEntry":true,"handlers":[null,{"name":"Yahoo! Mail","uriTemplate":"https://compose.mail.yahoo.com/?To=%s"},{"name":"Gmail","uriTemplate":"https://mail.google.com/mail/?extsrc=mailto&url=%s"}]},"magnet":{"action":4},"zoommtg":{"action":4,"ask":true},"ms-settings":{"action":4,"ask":true}}}
movax
Ráadásul nem engedi piszkálni a fájltársításokat kezelő handlers.json fájlt a Profil mappában, ha kézzel belemászol, a FF átnevezi corrupted-nek és automatikusan létrehoz egy újat, amiben gyakorlatilag semmiféle fájltípus nincs, tehát már a beállításokban sem lehet állítgatni. Szívás.
movax
Igen, a fájltársításnál átállítja default Save as-re, amit vissza kell álltani megkérdezősre, ennyi, működik.
UPDATE
Na várjunk csak. .xlsx fájlokra rákérdez, de az .xls fájlokat automatikusan mentené, hiába állítom át Ask first-re.
Aztakib@szott!!!!! Nem működik a Kép megnyitása új tabon sem, töltené lefele!
movax
Gond nélkül működik nálam is a 96-os FF, két napja frissítettem. Egész nap nyitva van, 9-10 tabbal. Win10 Pro 21H1.
movax
Vajon a legfrissebb FF update szétcseszi a custom CSS-t? Valaki feltette már?
movax
ArthurShelby
#64722
Külön szálakon intézik az adatforgalmat, nincs átjárás közöttük cookie- és history-szinten, így pl. a GoodleAds vagy a Facebook nem tudja követni a böngészésed, ha külön konténerekben futtatod őket. De az is előny, hogy pl. több Google-profilt tudsz használni egy böngészőben, külön fülekben (pl. magán gmail, céges gmail).
movax
NeoPampalini
#64639
Nem, ez nem FF gond, ebben a keresők durván sárosak.
movax
Rendszeresen beleszaladok, frissen telepített FF-szal is, Chrome-mal is. Általában az első keresési találatok rendben vannak, utána kizárólag zagyvaság jön.
Példa: fürdőkádjavítási tippeket keresek "epoxi, kád" kulcsszavakkal, legfrissebb FF. A második oldalon már ilyen találatok vannak (nézzük az URL-ket): -
movax
nubreed
#64496
Itt nézd meg a "Restyling tab buttons" fejezetben van külön beállítás tabos hangszóróikonhoz
movax
Eddig ez a legbájosabb win10-anomália
Egyszer csak átáll az egérgörgetés eddigi 5 soros sebessége 1 sorra, de csak úgy, a semmiből. Utoljára a win95-98 korszakban tapasztaltam ilyesmit.
movax
Egyetlen példát mondok, de van több is. A Backspace míg a világ egy lépés vissza funkcióként működik. Erre valami nagyokos kitalálja a Mozillánál, hogy egyszer csak nem működik így. Persze, az about:configban vissza lehet állítani, de miért kell azt nekem, buherálva visszaállítanom?? Ez olyan, mintha a mindörökké a mentést jelentő Ctrl+S-et megszüntetnék. Fölösleges és baromság.
A 91-es frissítés óta egyébként nálam lassabb az oldalbetöltés, főleg a képkezelés, pedig viszonylag friss a telepítés, és nincs ezer addonom sem.
movax
SamSem58
#64427
/* Use Normal top and bottom padding for compact */#PlacesToolbarItems .bookmark-item {padding-top: 0px !important;padding-bottom: 0px !important;}/***Tighten up drop-down/context/popup menu spacing ***/menupopup > menuitem, menupopup > menu {padding-block: 2px !important;}:root {--arrowpanel-menuitem-padding: 2px 8px !important;} -
movax
A jó büdös k... é...be!!! Megint szétcseszett mindent az update! Proton-beállítások, tabs on bottom, napokig vesződtem vele nemrég, most minden ismét elúszott, a userChrome.css-beállítások sem működnek.
movax
tonermagus
#64263
Mindkét esetben teljesen legyalnulnám és újratenném a foxit.
movax
GreenGoblin
#64250
Ez a "tönkremegy a tárhely" egy hatalmas baromság, amit már számtalanszor, sokan és rég megcáfoltak, de valamiért makacsul tartja magát...
movax
snakebait
#64056
Beírod, hogy about:support, ott megkeresed a Profile foldert és megnyitod. Ott létrehozod a chrome mappát, majd oda Notepad-del létrehozol egy sima szövefájlt userChrome névvel, .css kiterjesztéssel. A fájlba bemásolod a kódot, mentés, bezár.
Beírod, hogy about:config, megkeresed azt, hogy toolkit.legacyUserProfileCustomizations.stylesheets és true-ra állítod.
Firefox restart és kész.
movax
Tabs on bottomra ha tud valaki megoldást, ne fogja vissza magát. (Tökömé' kell szétcseszni működő dolgokat...).
Itt vannak okosságok egyébként a 89-es dizájnolásához css-sel.
movax
Predator2
#63922
Attól függ, hogy miként vannak feltéve. Ha youtube-embed, akkor az url-be a youtube helyett ssyoutube-ot írsz és letöltöd. Ha nem máshonnan beágyazott, akkor Inspectorral ki lehet bogarászni a direkt linkjét a videónak és ráhúzod a FF letöltőikonjára az eszköztárban.
movax
Hegyirabló
#63755
Nem akarom kétségbe vonni, amit írtál, csak mennyire érdekes, hogy én úgy egy évtizede nem találkoztam semmilyen, mondom SEMMILYEN különösebb hibával sem az oprendszer, sem a driverek, sem a hardverek szintjén. Flottul működik minden, nem láttam kékhalált, nem omlott össze semmi. Egy idén 9 éves laptopról tolom most is prímán, az azon levő win7-est upgradeltem 10-esre úgy 5 évvel ezelőtt, a Firefox is szépen működik, a kiegészítők is, minden. Szerencse?
movax
movax
moongoose
#63687
Elnézést, siettem
A csík az a vörös mező, ami megjelenik, ha a listán levő elemekre kattansz. És persze a Preview-t is érdemes a Create előtt használni. A létrehozott szabályok az uBlock beálításaiban vannak a My filters fülön, a legújabbak a lista alján, onnan lehet törölni, ha valamit elbénázunk vagy vissza akarunk térni a korábbi állapotra. -
movax
ArthurShelby
#63496
Nézem, hogy szép sunyiban kiszedték az opciókból a tabok privát ablakban megnyitását. Eddig lehetett: jobkatt a fülön és Move tab to new private window. De most már nincs.
movax
UPDATE
A Youtube-cookiek törlése és a Clear data-ban a Cached web content törlése megoldotta. Valószínűleg az utóbbi is elég. -
movax
A Zoom Page WE legújabb verziója azt okozza, hogy ha egy ablakaban vagy fülön gugliznék, a kurzor nincs a keresősávban. Bosszantó, mert írnám is be, de előtte oda kell klikkolni. Beállítási lehetőség nincs, ez valami bug, remélem, a következő verzióban javítják.
movax
meroly
#62957
1. Beírod a címsorba, hogy
about:supportés Enter. Megkeresed aProfile foldersort, mellette megnyomod azOpen foldergombot.
2. A könyvtárak között megkeresed achrome-ot Ha nincs, létrehozod. Azon belül létrehozol Notepaddal egy txt fájlt, aminek ezt a nevet és kiterjesztést adod:userChrome.cssHa megvan, belemásolod a kódot, amit fennebb írtam és elmented.
3. Firefox bezár és újraindít. Ha minden okésan ment, a tabok szövege eltűnt. -
movax
Minimum 10-12 tabbal dolgozom naponta, nagyjából megvan a sorrendjük, de azért ide-oda húzgálom az egérrel őket. Egy ideje azonban igen érzékennyé vált a művelet, az éppen húzgált tab gyakran átugrik új ablakká, amit vissza lehet ugyan húzni az eredeti helyére, de roppant zavaró, néha egy igen kicsi függőleges kurzormozgással is átugrik.
Ha mást is zavar ez a viselkedés, itt a megoldás:
about:config-ban megkeresni a browser.tabs.allowTabDetach beállítást és false-ra állítani.
Ezzel a tabok húzigálhatók jobbra-balra, de már nem ugranak át új ablakba.
movax
vyrnwy_31
#62834
Pedig azok a kukik eltűnnek valahogy. Próbáld meg elindítani csökkentett módban kiegészítők nélkül, ha nem megy, töröld a cache-t, a kukikat, mindent.
Ha így sem megy, én újratenném az egész Ffoxot, kiegészítőkkel, mindenestül, ez megold egy csomó "érthetetlen" hibát. Előtte persze mindent le kell irtani a gépről, ami ezzel kapcsolatos.
movax
Két napig hibátlanul működött, aztán lehalt a görgetés a privát ablakos Google-ben, csak az uBlock kikapcsolása segített. Végül töröltem a két elem szűréét, majd felvettem az I dont care about cookies filterlistáját az uBlockba, de ez sem segített. Viszont az említett önálló addon telepítése tényleg megoldja, ahogy @csako kolléga írja.
movax
uBlock Originben épp most szűrtem ki a privát ablakos felugró beleegyezést. Egyelőre működik.
Simán nem megy, csak az uBlock Element picker eszközével. Most az uBlock-beállításokban a My filters fülön ez jelenik meg ere vonatkozóan (az egyik a felugró téglalap, a másik az egész képernyős overlay):
! 2020-09-23 https://www.google.hu
www.google.hu##.wwYr3.aID8W.bErdLd
www.google.hu##.aID8W.m114nf.t7xA6Nem privát ablakban egyszer elfogadtam, ott többé nem jelenik meg, nem vagyok bejelentkezve, de ez amúgy is cookie-alapon működik.
movax
#62654
Nemrég kezdtem nulláról egy 8 éve frissítgetett FF-szal, vagyis: teljes gyalu, minden maradék fájl töröltem, még a regiszterekből is kigyomláltam, majd mindent ismét újratettem. Az előzőből csak a könyvjelzőket és az userChrome-css-t hoztam át, majd az addonokat (csak 4 van) is ismét feltettem, uBlockból ezt-azt áthoztam és kész. Pedig rettegtem tőle, hogy odavész a sok beállítgatás, aboutconfigos tapogatás stb., meg hogy napokig szívok majd a rekonfiggal. Ehhez képest félóra alatt minden vissza volt állítva és remekül működik. Syncet nem használok, soha nem is használtam.
Azért mondom mindezt, mert nálam is voltak rejtélyes jelenségek a FF-ban, ezek valószínűleg az évek során baszkurált aboutconfiggal függtek össze. Na, ezek most megszűntek. -
movax
dethroner
#62651
Nem kell bejelentkezve lenni, csak sütit nem kell törölni. Jó ötlet egyébként a konténerezés, nálam külön homokozóban fut egyidejűleg két gmail-fiók, egy harmadikban a Facebook, egy negyedikben meg netezek, és nem akadnak össze. Sőt, ha privát ablakban guglizol (ahol viszot nincs sütirögzítés, kéri is mindig az okézást), tényleg nem szórja szembe mindenhol a korábbi kereséseket a Google Ads.
movax
dethroner
#62611
Hát, azt a rengeteg androidos telefont, ami a világban van, nem is lehet google-fiók nélkül használni.
Ami az üzenetet illeti, nem is igazán tudom, miről van szó, nekem soha nem jelent meg, erre írtam le, hogy én hogy használom, lehetséges módszer gyanánt.
Harmadrészt, de nem utolsósorban, ez a Firefox-topik.
movax
dethroner
#62607
Van. FF-ban a gmail mindig nyitva van, munkához kell, plusz még 6-7 fül. Ezeket soha nem csukom be és a gépet sem kapcsolom le, csak hibernálom (na jó, hetente egyszer kap egy egészségügyi rebootot). Ha a FF-t becsukom, ha csak lehet, Restore Previos Session-nel hozom vissza. Örö és bódottá 8 éve, amióta megy ez a rendszer.
movax
Brutál megnőtt a legújabb FF memóriaigénye, jelenleg 7 tabbal 1,9 GB, ez korábban max. ennek a fele volt.
movax
farkas-j
#61962
UPDATE: Bocs, farkas-j, véletlenül ment neked.
Hogy ezt a lenyíló url-sávot mi az édes jó k...a, r...c, t...s, sz...b...tt édes jó a...kért kellett megszüntetni, hát itt bénázok három napja, folyton nyomogatom a címsáv jobb oldalát, ahol eddig a lenyitó nyíl volt . Vannak ezzel foglalkozó emberek a mozillánál, akik régi, jól bevált, jól működő funkciókat b...nak szét?
Annyit legalább megcsináltam css-ben, hogy nem lesz nagyobb a címsor, ha rákattanok (hogy mi a funkciója ennek, hát komolyan....), de valahogy nem lehet visszahozni azt a k...a lenyíló menüt??
movax
Láttad az update-et, ugye?
De, használom, évek óta, két gmail-fiók, de nem bookmarkból, hanem "kézi módszerrel": előbb megnyitom a konténert, majd benne automatikusan az ott bejelentkezett gmail-fiók nyílik meg, ha elkezdem beírni, hogy gmail (mert a bejelentkezéseket megtartjk a konténerek). És mivel folyamatosan nyitva vannak a böngészőben, soha nem kell bookmarkból meghívni. -
movax
DrojDtroll
#61700
Multi-Account Containers-t használok én is évek óta, teljesen okés.
movax
Bal0924
#61603
Tipikus user error, bocs, nem akarlak bántani, de meg kell tanulni a beállításokat, reklámblokkolók rendes használatát, utána kell nézni, olvasni, a tanulást nem lehet kispórolni ebből (sem). Az esetek legnagyobb részében sem az oprendszer, sem a böngésző, sem egyéb szoftver nem hibás.
movax
Fire/SOUL/CD
#60929
Touché.
movax
Gizmo94
#60794
Szép, tiszta megoldás a tabok alulra tevéséhez, ideteszem, legyen visszakereshető, az első sort törölni kell (ami áthúzva van). A tabok szögletesek, használható kerekítő megoldást nem találtam.
@namespace url("http://www.mozilla.org/keymaster/gatekeeper/there.is.only.xul"); /* only needed once */
/* TABS on bottom */
#navigator-toolbox toolbar:not(#nav-bar):not(#toolbar-menubar) {
-moz-box-ordinal-group: 10;
#TabsToolbar {
-moz-box-ordinal-group: 1000 !important;
#TabsToolbar {
display: block !important;
position: absolute !important;
bottom: 0 !important;
width: 100vw !important;
#main-window:not([chromehidden*="toolbar"]) #navigator-toolbox {
padding-bottom: var(--tab-min-height) !important;
#tabbrowser-tabs {
#TabsToolbar #window-controls {
display: none !important;
#tabbrowser-tabs {
#main-window:not([chromehidden*="toolbar"]) #navigator-toolbox {padding-bottom: var(--tab-min-height) !important;}
/* TABS: height */
:root {
--tab-toolbar-navbar-overlap: 0px !important;
--tab-min-height: 35px !important; /* adjust to suit your needs */
:root #tabbrowser-tabs {
--tab-min-height: 35px !important; /* needs to be the same as above under :root */
--tab-min-width: 80px !important;
#TabsToolbar {
height: var(--tab-min-height) !important;
margin-bottom: 1px !important;
box-shadow: ThreeDShadow 0 -1px inset, -moz-dialog 0 1px !important;
#tabbrowser-tabs,
#tabbrowser-tabs > .tabbrowser-arrowscrollbox,
.tabbrowser-tabs[positionpinnedtabs] > .tabbrowser-tab[pinned] {
min-height: var(--tab-min-height) !important;
max-height: var(--tab-min-height) !important;
/* drag space */
.titlebar-spacer[type="pre-tabs"],
.titlebar-spacer[type="post-tabs"] {
width: 40px;
/* Override vertical shifts when moving a tab */
#navigator-toolbox[movingtab] > #titlebar > #TabsToolbar {
padding-bottom: unset !important;
#navigator-toolbox[movingtab] #tabbrowser-tabs {
margin-bottom: unset !important;
#navigator-toolbox[movingtab] > #nav-bar {
margin-top: unset !important;
}/* Hide blue stripe on active tab */
.tab-line[selected="true"] {
opacity: 0 !important;
● Olvasd el az összefoglalót!
● Mozilla blog az ITcafé-n.
- Soha nem szabta ilyen pénztárcabarátra új CPU-it az Intel
- Youtube Android alkalmazás alternatívák reklámszűréssel / videók letöltése
- Filmvilág
- Tőzsde és gazdaság
- Milyen autót vegyek?
- Építő/felújító topik
- PC Game Pass előfizetés
- 35" ASUS ROG Swift PG35VQ curved GAMER monitor
- AZONNAL KÉSZLETRŐL! AMD Ryzen 7 9800X3D 64GB DDR5 RAM 2TB Gen4 SSD RTX 5090 32GB GDDR7 1200W
- Lenovo 13w Yoga 2in1 Gen 2 AMD Ryzen 3 7330U 8 GB RAM 256 GB SSD Premium garancia FHD IPS TOUCH
- Gamer PC-Számítógép! Csere-Beszámítás! I5 9600KF / RTX 3060Ti / 16GB DDR4 / 256SSD + 2TB HDD
de nélküle sem. Egy FF és uBlock Origin reinstall kellene sztem. És tényleg nem kell törölgetni a sütiket.
