MPowerPH
MPowerPH
#4761
Ezt találtam, de elég nonszensz ez a módszer.
"Ok i found a fix for Nvidia users, at least it worked with me without changing the compatibility mode. First, uninstall your graphics driver and physx driver. Next download the new update for your nvidia card. Restart your computer then install the new update. This is the most important part, don't install the physx driver on the cd before you install the nvidia update because the update comes with a physx driver that isn't as new as the one on the NFS Shift CD. So after you have installed your new nvidia update, uninstall the physx driver that came with it and install the one from the CD. If you did this correctly your game should work."
- Opel topik
- Samsung kuponkunyeráló
- Kecskemét és környéke adok-veszek-beszélgetek
- Milyen légkondit a lakásba?
- AliExpress tapasztalatok
- Linux haladóknak
- Micron 5200 ECO 480 GB 2,5 SATA Enterprise/Datacenter Server SSD
- Komplett gép: i7 12700 - 4.90 Ghz / 32 GB DDR5 / 512 GB NVMe / Win 11 Pro - HP Z2 tower G9
- Asztali PC , i5 9500T , 1660 Super , 16GB DDR4 , 512GB m.2
- Asztali PC , i5 12400F , RX 6600 XT , 16GB RAM , 512GB nVME , 1TB HDD
- iPhone 13 256GB Midnight - Kártyafüggetlen - 88%
- Telefon felvásárlás!! Samsung Galaxy S23/Samsung Galaxy S23+/Samsung Galaxy S23 Ultra
- Eladó/BONTATLAN Lenovo LOQ i7-13650HX 24GB 1TB RTX 4060 8GB
- ÁRGARANCIA!Épített KomPhone i5 12400F 16/32/64GB RAM RTX 5060 Ti 16GB GAMER PC termékbeszámítással
- Surface Pro 7+ i5-1135G7 16GB 512GB 1 év garancia
- iPhone 15 Plus 256GB 100% (1év Garancia) - ÚJ EREDETI AKKUMULÁTOR
