Sonja
Tomiboy65
#570
Nem töröl, csak megjelöli, és nem látod.
Nekem is ilyet írt, amikor a törlésről kérdeztem.
De nekem ez ráadásul nem is lehetséges, mivel microSD kártyára másolgatom könyveket, és ott nem jelenik meg olyan opció. Nevetséges.
Beidézem a teljes levelet, amit írtak:
"Warm greetings from Barnes and Noble!
We're pleased to receive your email. Alexis here, from Digital Support. On behalf of Barnes & Noble.com, please accept our sincere apologies for any inconvenience. I am sorry to learn of your dissatisfaction. I understand that it's really an inconvenience not having the ability to delete an eBook directly from your NOOK Simple Touch.
Unfortunately, we don't have an estimated time frame when will we have a software update again for our NOOK Simple Touch which will enable you to delete your eBooks directly from the device. As of the moment, only the option to have the eBook archived is the one that I recommend for you to use.
Archiving an eBook will delete the book from your NOOK library but will still stay on your online account (cloud) so anytime you would like to read it again, you can simply unarchive it. In this way, you could still access your eBooks again anytime you want to and you would also save memory space of your device.
To Archive an eBook:
1. Go to library.
2. Double-tap on the cover or title of the eBook or periodical.
3. On the details page, tap the "Archive" button.
4. The eBook or periodical is listed in a shelf in your library called "Archived."To Unarchive an eBook:
1. Go to library.
2. Tap the category menu, then tap the "Archived" menu choice.
3. Double-tap on the cover or title of the eBook.
4. On the details page, tap the "Unarchive" button.
5. The eBook or periodical is now back in the library.However, I have passed along your comments to our management for our NOOK developer to review your suggestion for improvement and possible implementation.
We truly regret the troubles this has caused. I hope you find this information helpful. Should you have any further concern, please do not hesitate to email us back and we would be grateful to assist you.
I hope that every service we provide will meet your high standards. It is my great honor and privilege to assist you with this concern. Take care and have a wonderful day!
Sincerely,
Alexis
Customer Service Representative - Digital Support
Barnes & Noble" -
Sonja
Barnes and Noble Claims they will Continue to Make Tablets and e-Readers
"All Nook devices will continue to be backed by world-class pre- and post-sales support in Barnes & Noble stores, as well as ongoing software upgrades and improvements to the digital bookstore service."
Érdekes helyzet. Eddig pont az ellenkezője volt.
Vajon most tényleg folytatja a tablet gyártást, és az e-readerek software-es fejlesztését is?!
Jó lenne, ha oda is figyelnének végre az igényekre.
Sonja
Írtam már a Barnes & Noble-nak a könyv törlésével kapcsolatban. Dél körül írtam, most válaszoltak. Abszolút nem sablon válasz volt, ráadásul elég hosszú, ami meglepett. A lényeget bemásolom ide:
"Unfortunately, we don't have an estimated time frame when will we have a software update again for our NOOK Simple Touch which will enable you to delete your eBooks directly from the device. As of the moment, only the option to have the eBook archived is the one that I recommend for you to use."
Sonja
Ha egy könyvet kiolvastam, akkor utána le szoktam rögtön törölni a készüléken. Ez a Kindle Touch-on egyszerű volt, mert csak hosszan nyomtam egyet a könyvön, utána a megjelenő menűben kiválasztottam, hogy delete, és ennyi. Itt egyszerűen nem találok törlési lehetőséget egy könyvre!
Csak én vagyok most ilyen béna, vagy tényleg nem lehet?!
Sonja
Egész jó ez a nook, végülis tetszik.
Azért 1-2 bosszantó dolog azért akad (pl. nincs külön "vissza" gomb a bal felső részen, mint a Kindle Touch esetében, így kénytelen vagyok mindig az N gombot megnyomni, majd home), de ez nem olyan nagy probléma.
Sajna PDF file-nak nem jeleníti meg a borítóját, akár mit csinálok.
Vagy csak nagyon nem jól csinálom.
Pedig elvileg úgy kell, hogy egy lapot beszúr az ember az elejére, majd beilleszti a jpg file-t, és elmenti. Calibre nem jó, mert elcseszi a PDF-et. -
Sonja
No, most teljesen kikapcsoltam (nem csak alvóba tettem), zölden világított. Kihúztam a töltőt, bekapcsoltam és 100%-ot mutat és Full-t ír. Remélem tényleg feltöltött.
Igaz, legalább 5 órát töltődött, szvsz fel kellett neki tölteni, nem?!
Sonja
Hmm... Most 77%-ot ír ki, és "Not charging"-ot, hiába van az USB kábel bedugva!
Most ilyenkor mi van?
Miért nem tölti ~100%-ra?
Szerk.: Most teljesen kikapcsoltam, most úgy néz ki, hogy tölti, mert narancssárga lett alul a led.
Sonja
Lassan 4 órája töltöm, és még mindig csak 68%-on van az akku.
Nem lassú ez egy kicsit?
A papírja 3-3,5 órát ír. Igaz, az nem egy full lemerült akkura.
Egy 500mA-es USB fali töltővel töltöm, amivel a Kindle Touch-om is szoktam.
Sonja
Sonja
Megjött a Nook-om.
Viszont nem tudom bekapcsolni.
Most rátettem tölteni, és tölti is elvileg, mert alul narancssárga a led. Látom, hogy azt írja, hogy első bekapcsolás előtt fullosan fel kell tölteni, de addig valóban nem tudom bekapcsolni? Vagy nálam van valami?!
Sonja
- iPad Pro 11" M1 - 3. gen - 256 GB - Space Gray - Cellular - HIBÁTLAN - Logitech Billentyűzet
- KÜLÖNLEGES RITKASÁG! VADIÚJ Microsoft Surface Pro 12 12" Snapdragon X Plus 16GB 512GB LEVENDULA 686g
- Surface Pro 7+ i5-1135G7 16G 256GB 1 év garancia
- Surface Pro 7+ i5-1135G7 16GB 1000GB 1 év garancia
- iPad - 10. gen - 64 GB - Kék - Wifi - HIBÁTLAN - Tok
- GYÖNYÖRŰ iPhone 14 Pro 128GB Space Black -1 ÉV GARANCIA - Kártyafüggetlen, MS4322
- ÁRGARANCIA!Épített KomPhone Ryzen 7 9800X3D 32/64GB RAM RTX 5070 12GB GAMER PC termékbeszámítással
- Ultimate előfizetés akár 3856 Ft/hó áron! Azonnali, automatizált aktiválással, csak Nálam!
- Creality HALOT ONE gyantás nyomtató
- iKing.hu Apple iPhone 14 Pro Deep Purple 128GB használt megkímélt 100% akku 6 hónap garancia
Pfuhh, csak nagyon le volt merülve.
