Keresés
  • KonzolKartel
    Ez van a router logjában. Rájöttem, hogy ha kihúzom, vissza dugom a tápot, akkor helyre áll a halózat egy 10-15 percig, így sikerült kimenteni a logot.
    Jan 1 01:00:50 unknown syslog.info syslogd started: BusyBox v1.21.1
    Jan 1 01:00:50 unknown user.notice kernel: klogd started: BusyBox v1.21.1 (2013-11-20 11:19:56 CET)
    Jan 1 01:00:50 unknown user.notice kernel: Linux version 2.6.22.19 (root@tomato) (gcc version 4.2.4) #1 Wed Nov 20 11:34:10 CET 2013
    Jan 1 01:00:50 unknown user.warn kernel: CPU revision is: 00029006
    Jan 1 01:00:50 unknown user.warn kernel: Setting the PFC to its default value
    Jan 1 01:00:50 unknown user.warn kernel: Determined physical RAM map:
    Jan 1 01:00:50 unknown user.warn kernel: memory: 02000000 @ 00000000 (usable)
    Jan 1 01:00:50 unknown user.debug kernel: On node 0 totalpages: 8192
    Jan 1 01:00:50 unknown user.debug kernel: Normal zone: 64 pages used for memmap
    Jan 1 01:00:50 unknown user.debug kernel: Normal zone: 0 pages reserved
    Jan 1 01:00:50 unknown user.debug kernel: Normal zone: 8128 pages, LIFO batch:0
    Jan 1 01:00:50 unknown user.warn kernel: Built 1 zonelists. Total pages: 8128
    Jan 1 01:00:50 unknown user.notice kernel: Kernel command line: root=/dev/mtdblock2 noinitrd console=ttyS0,115200
    Jan 1 01:00:50 unknown user.warn kernel: Primary instruction cache 16kB, physically tagged, 2-way, linesize 16 bytes.
    Jan 1 01:00:50 unknown user.warn kernel: Primary data cache 16kB, 2-way, linesize 16 bytes.
    Jan 1 01:00:50 unknown user.info kernel: Synthesized TLB refill handler (19 instructions).
    Jan 1 01:00:50 unknown user.info kernel: Synthesized TLB load handler fastpath (31 instructions).
    Jan 1 01:00:50 unknown user.info kernel: Synthesized TLB store handler fastpath (31 instructions).
    Jan 1 01:00:50 unknown user.info kernel: Synthesized TLB modify handler fastpath (30 instructions).
    Jan 1 01:00:50 unknown user.warn kernel: PID hash table entries: 128 (order: 7, 512 bytes)
    Jan 1 01:00:50 unknown user.warn kernel: CPU: BCM4704 rev 8 pkg 0 at 264 MHz
    Jan 1 01:00:50 unknown user.warn kernel: Using 132.000 MHz high precision timer.
    Jan 1 01:00:50 unknown user.info kernel: console [ttyS0] enabled
    Jan 1 01:00:50 unknown user.warn kernel: Dentry cache hash table entries: 4096 (order: 2, 16384 bytes)
    Jan 1 01:00:50 unknown user.warn kernel: Inode-cache hash table entries: 2048 (order: 1, 8192 bytes)
    Jan 1 01:00:50 unknown user.info kernel: Memory: 29196k/32768k available (36k kernel code, 3572k reserved, 2954k data, 124k init, 0k highmem)
    Jan 1 01:00:50 unknown user.debug kernel: Calibrating delay loop... 262.96 BogoMIPS (lpj=1314816)
    Jan 1 01:00:50 unknown user.warn kernel: Mount-cache hash table entries: 512
    Jan 1 01:00:50 unknown user.info kernel: NET: Registered protocol family 16
    Jan 1 01:00:50 unknown user.warn kernel: PCI: Initializing host
    Jan 1 01:00:50 unknown user.warn kernel: PCI: Fixing up bus 0
    Jan 1 01:00:50 unknown user.warn kernel: PCI: Fixing up bridge
    Jan 1 01:00:50 unknown user.debug kernel: PCI: Setting latency timer of device 0000:01:00.0 to 64
    Jan 1 01:00:50 unknown user.warn kernel: PCI: Fixing up bus 1
    Jan 1 01:00:50 unknown user.info kernel: NET: Registered protocol family 2
    Jan 1 01:00:50 unknown user.info kernel: Time: MIPS clocksource has been installed.
    Jan 1 01:00:50 unknown user.warn kernel: IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
    Jan 1 01:00:50 unknown user.warn kernel: TCP established hash table entries: 1024 (order: 1, 8192 bytes)
    Jan 1 01:00:50 unknown user.warn kernel: TCP bind hash table entries: 1024 (order: 0, 4096 bytes)
    Jan 1 01:00:50 unknown user.info kernel: TCP: Hash tables configured (established 1024 bind 1024)
    Jan 1 01:00:50 unknown user.info kernel: TCP reno registered
    Jan 1 01:00:50 unknown user.info kernel: squashfs: version 3.0 (2006/03/15) Phillip Lougher
    Jan 1 01:00:50 unknown user.info kernel: io scheduler noop registered (default)
    Jan 1 01:00:50 unknown user.info kernel: HDLC line discipline: version $Revision: 4.8 $, maxframe=4096
    Jan 1 01:00:50 unknown user.info kernel: N_HDLC line discipline registered.
    Jan 1 01:00:50 unknown user.info kernel: Serial: 8250/16550 driver $Revision: 1.90 $ 2 ports, IRQ sharing disabled
    Jan 1 01:00:50 unknown user.info kernel: serial8250: ttyS0 at MMIO 0xb8000300 (irq = 3) is a 16550A
    Jan 1 01:00:50 unknown user.info kernel: serial8250: ttyS1 at MMIO 0xb8000400 (irq = 3) is a 16550A
    Jan 1 01:00:50 unknown user.info kernel: PPP generic driver version 2.4.2
    Jan 1 01:00:50 unknown user.info kernel: MPPE/MPPC encryption/compression module registered
    Jan 1 01:00:50 unknown user.info kernel: NET: Registered protocol family 24
    Jan 1 01:00:50 unknown user.info kernel: PPPoL2TP kernel driver, V0.18.3
    Jan 1 01:00:50 unknown user.info kernel: PPTP driver version 0.8.5
    Jan 1 01:00:50 unknown user.info kernel: Physically mapped flash: Found 1 x16 devices at 0x0 in 16-bit bank
    Jan 1 01:00:50 unknown user.debug kernel: Physically mapped flash: Found an alias at 0x800000 for the chip at 0x0
    Jan 1 01:00:50 unknown user.debug kernel: Physically mapped flash: Found an alias at 0x1000000 for the chip at 0x0
    Jan 1 01:00:50 unknown user.debug kernel: Physically mapped flash: Found an alias at 0x1800000 for the chip at 0x0
    Jan 1 01:00:50 unknown user.warn kernel: Amd/Fujitsu Extended Query Table at 0x0040
    Jan 1 01:00:51 unknown user.warn kernel: Physically mapped flash: CFI does not contain boot bank location. Assuming top.
    Jan 1 01:00:51 unknown user.notice kernel: number of CFI chips: 1
    Jan 1 01:00:51 unknown user.notice kernel: cfi_cmdset_0002: Disabling erase-suspend-program due to code brokenness.
    Jan 1 01:00:51 unknown user.notice kernel: Flash device: 0x800000 at 0x1c000000
    Jan 1 01:00:51 unknown user.notice kernel: Creating 5 MTD partitions on "Physically mapped flash":
    Jan 1 01:00:51 unknown user.notice kernel: 0x00000000-0x00040000 : "pmon"
    Jan 1 01:00:51 unknown user.notice kernel: 0x00040000-0x007f0000 : "linux"
    Jan 1 01:00:51 unknown user.notice kernel: 0x0012d000-0x00780000 : "rootfs"
    Jan 1 01:00:51 unknown user.notice kernel: 0x00780000-0x007f0000 : "jffs2"
    Jan 1 01:00:51 unknown user.notice kernel: 0x007f0000-0x00800000 : "nvram"
    Jan 1 01:00:51 unknown user.warn kernel: Found a 0MB serial flash
    Jan 1 01:00:51 unknown user.err kernel: sflash: found no supported devices
    Jan 1 01:00:51 unknown user.warn kernel: u32 classifier
    Jan 1 01:00:51 unknown user.warn kernel: OLD policer on
    Jan 1 01:00:51 unknown user.warn kernel: Netfilter messages via NETLINK v0.30.
    Jan 1 01:00:51 unknown user.warn kernel: nf_conntrack version 0.5.0 (512 buckets, 4096 max)
    Jan 1 01:00:51 unknown user.warn kernel: ip_tables: (C) 2000-2006 Netfilter Core Team
    Jan 1 01:00:51 unknown user.info kernel: ipt_account 0.1.21 : Piotr Gasidlo <quaker@barbara.eu.org>, http://www.barbara.eu.org/~quaker/ipt_account/
    Jan 1 01:00:51 unknown user.warn kernel: net/ipv4/netfilter/tomato_ct.c [Nov 20 2013 11:34:09]
    Jan 1 01:00:51 unknown user.info kernel: NET: Registered protocol family 1
    Jan 1 01:00:51 unknown user.info kernel: NET: Registered protocol family 10
    Jan 1 01:00:51 unknown user.warn kernel: ip6_tables: (C) 2000-2006 Netfilter Core Team
    Jan 1 01:00:51 unknown user.info kernel: NET: Registered protocol family 17
    Jan 1 01:00:51 unknown user.info kernel: 802.1Q VLAN Support v1.8 Ben Greear <greearb@candelatech.com>
    Jan 1 01:00:51 unknown user.info kernel: All bugs added by David S. Miller <davem@redhat.com>
    Jan 1 01:00:51 unknown user.warn kernel: VFS: Mounted root (squashfs filesystem) readonly.
    Jan 1 01:00:51 unknown user.info kernel: Freeing unused kernel memory: 124k freed
    Jan 1 01:00:51 unknown user.warn kernel: Warning: unable to open an initial console.
    Jan 1 01:00:51 unknown user.warn kernel: emf: module license 'Proprietary' taints kernel.
    Jan 1 01:00:51 unknown user.debug kernel: PCI: Setting latency timer of device 0000:00:01.0 to 64
    Jan 1 01:00:51 unknown user.warn kernel: eth0: Broadcom BCM47xx 10/100 Mbps Ethernet Controller 5.10.147.0
    Jan 1 01:00:51 unknown user.debug kernel: PCI: Setting latency timer of device 0000:00:02.0 to 64
    Jan 1 01:00:51 unknown user.warn kernel: PCI: Enabling device 0000:01:02.0 (0000 -> 0002)
    Jan 1 01:00:51 unknown user.debug kernel: PCI: Setting latency timer of device 0000:01:02.0 to 64
    Jan 1 01:00:51 unknown user.warn kernel: eth1: Broadcom BCM4318 802.11 Wireless Controller 5.10.147.0
    Jan 1 01:00:51 unknown user.warn kernel: Algorithmics/MIPS FPU Emulator v1.5
    Jan 1 01:00:51 unknown user.info kernel: usbcore: registered new interface driver usbfs
    Jan 1 01:00:51 unknown user.info kernel: usbcore: registered new interface driver hub
    Jan 1 01:00:51 unknown user.info kernel: usbcore: registered new device driver usb
    Jan 1 01:00:51 unknown user.notice kernel: SCSI subsystem initialized
    Jan 1 01:00:51 unknown user.info kernel: Initializing USB Mass Storage driver...
    Jan 1 01:00:51 unknown user.info kernel: usbcore: registered new interface driver usb-storage
    Jan 1 01:00:51 unknown user.info kernel: USB Mass Storage support registered.
    Jan 1 01:00:51 unknown user.info kernel: ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
    Jan 1 01:00:51 unknown user.warn kernel: PCI: Enabling device 0000:01:03.2 (0000 -> 0002)
    Jan 1 01:00:51 unknown user.info kernel: ehci_hcd 0000:01:03.2: EHCI Host Controller
    Jan 1 01:00:51 unknown user.info kernel: ehci_hcd 0000:01:03.2: new USB bus registered, assigned bus number 1
    Jan 1 01:00:51 unknown user.info kernel: ehci_hcd 0000:01:03.2: irq 12, io mem 0x40004000
    Jan 1 01:00:51 unknown user.info kernel: ehci_hcd 0000:01:03.2: USB 2.0 started, EHCI 1.00
    Jan 1 01:00:51 unknown user.info kernel: usb usb1: configuration #1 chosen from 1 choice
    Jan 1 01:00:51 unknown user.info kernel: hub 1-0:1.0: USB hub found
    Jan 1 01:00:51 unknown user.info kernel: hub 1-0:1.0: 4 ports detected
    Jan 1 01:00:52 unknown user.debug hotplug[388]: Attached USB device 1-0:1.0 [INTERFACE=9/0/0 PRODUCT=1d6b/2/206]
    Jan 1 01:00:52 unknown user.info sd-idle[390]: initialized
    Jan 1 01:00:52 unknown user.info kernel: usb 1-1: new high speed USB device using ehci_hcd and address 2
    Jan 1 01:00:52 unknown user.info kernel: usb 1-1: configuration #1 chosen from 1 choice
    Jan 1 01:00:52 unknown user.info kernel: scsi0 : SCSI emulation for USB Mass Storage devices
    Jan 1 01:00:52 unknown user.debug hotplug[413]: Attached USB device 1-1:1.0 [INTERFACE=8/6/80 PRODUCT=bc2/3008/138]
    Jan 1 01:00:52 unknown user.debug kernel: vlan0: add 33:33:00:00:00:01 mcast address to master interface
    Jan 1 01:00:52 unknown user.debug kernel: vlan0: add 01:00:5e:00:00:01 mcast address to master interface
    Jan 1 01:00:52 unknown user.info kernel: vlan0: dev_set_allmulti(master, 1)
    Jan 1 01:00:52 unknown user.info kernel: vlan0: dev_set_promiscuity(master, 1)
    Jan 1 01:00:52 unknown user.info kernel: device eth0 entered promiscuous mode
    Jan 1 01:00:52 unknown user.info kernel: device vlan0 entered promiscuous mode
    Jan 1 01:00:53 unknown user.info kernel: device eth1 entered promiscuous mode
    Jan 1 01:00:53 unknown user.info kernel: br0: port 2(eth1) entering forwarding state
    Jan 1 01:00:53 unknown user.info kernel: br0: port 1(vlan0) entering forwarding state
    Jan 1 01:00:53 unknown user.warn kernel: vlan1: Setting MAC address to 00 1f c6 3d 9a 3e.
    Jan 1 01:00:53 unknown user.debug kernel: vlan1: add 33:33:00:00:00:01 mcast address to master interface
    Jan 1 01:00:53 unknown user.debug kernel: vlan1: add 01:00:5e:00:00:01 mcast address to master interface
    Jan 1 01:00:53 unknown user.info kernel: IMQ starting with 2 devices...
    Jan 1 01:00:53 unknown user.info kernel: IMQ driver loaded successfully.
    Jan 1 01:00:53 unknown user.info kernel: Hooking IMQ after NAT on PREROUTING.
    Jan 1 01:00:53 unknown user.info kernel: Hooking IMQ before NAT on POSTROUTING.
    Jan 1 01:00:54 unknown user.notice kernel: scsi 0:0:0:0: Direct-Access Seagate FreeAgent 0138 PQ: 0 ANSI: 4
    Jan 1 01:00:54 unknown user.notice kernel: sd 0:0:0:0: [sda] 976773166 512-byte hardware sectors (500108 MB)
    Jan 1 01:00:54 unknown user.notice kernel: sd 0:0:0:0: [sda] Write Protect is off
    Jan 1 01:00:54 unknown user.debug kernel: sd 0:0:0:0: [sda] Mode Sense: 1c 00 00 00
    Jan 1 01:00:54 unknown user.err kernel: sd 0:0:0:0: [sda] Assuming drive cache: write through
    Jan 1 01:00:54 unknown user.info kernel: sda: sda1
    Jan 1 01:00:54 unknown user.notice kernel: sd 0:0:0:0: [sda] Attached SCSI disk
    Jan 1 01:00:54 unknown user.warn kernel: fuse init (API version 7.8), DCACHE_BUG enabled
    Jan 1 01:00:56 unknown daemon.info pppd[541]: Plugin rp-pppoe.so loaded.
    Jan 1 01:00:56 unknown daemon.info pppd[541]: RP-PPPoE plugin version 3.10 compiled against pppd 2.4.5
    Jan 1 01:00:56 unknown daemon.notice pppd[542]: pppd 2.4.5 started by root, uid 0
    Jan 1 01:00:56 unknown user.info redial[543]: Started. Time: 10
    Jan 1 01:00:56 unknown daemon.info pppd[542]: PPP session is 566 (0x236)
    Jan 1 01:00:56 unknown daemon.warn pppd[542]: Connected to 00:24:1d:8a:97:e8 via interface vlan1
    Jan 1 01:00:56 unknown daemon.info pppd[542]: Using interface ppp0
    Jan 1 01:00:56 unknown daemon.notice pppd[542]: Connect: ppp0 <--> vlan1
    Jan 1 01:00:56 unknown daemon.notice pppd[542]: PAP authentication succeeded
    Jan 1 01:00:56 unknown daemon.notice pppd[542]: peer from calling number 00:24:1D:8A:97:E8 authorized
    Jan 1 01:00:56 unknown daemon.notice pppd[542]: local IP address 84.236.6.105
    Jan 1 01:00:56 unknown daemon.notice pppd[542]: remote IP address 10.0.0.1
    Jan 1 01:00:56 unknown daemon.notice pppd[542]: primary DNS address 193.110.56.8
    Jan 1 01:00:56 unknown daemon.notice pppd[542]: secondary DNS address 193.110.57.4
    Jan 1 01:00:56 unknown user.debug ip-up[551]: 182: pptp peerdns disabled
    Jan 1 01:00:56 unknown authpriv.info dropbear[553]: Running in background
    Jan 1 01:00:59 unknown daemon.info dnsmasq[584]: started, version 2.67 cachesize 1500
    Jan 1 01:00:59 unknown daemon.info dnsmasq[584]: compile time options: IPv6 GNU-getopt no-RTC no-DBus no-i18n no-IDN DHCP DHCPv6 no-Lua TFTP no-conntrack ipset Tomato-helper auth
    Jan 1 01:00:59 unknown daemon.info dnsmasq[584]: asynchronous logging enabled, queue limit is 5 messages
    Jan 1 01:00:59 unknown daemon.info dnsmasq-dhcp[584]: DHCP, IP range 192.168.1.2 -- 192.168.1.51, lease time 1d
    Jan 1 01:00:59 unknown daemon.info dnsmasq[584]: reading /etc/resolv.dnsmasq
    Jan 1 01:00:59 unknown daemon.info dnsmasq[584]: using nameserver 193.110.57.4#53
    Jan 1 01:00:59 unknown daemon.info dnsmasq[584]: using nameserver 193.110.56.8#53
    Jan 1 01:00:59 unknown daemon.info dnsmasq[584]: read /etc/hosts - 2 addresses
    Jan 1 01:00:59 unknown daemon.info dnsmasq[584]: read /etc/dnsmasq/hosts/hosts - 3 addresses
    Jan 1 01:00:59 unknown daemon.info dnsmasq-dhcp[584]: read /etc/dnsmasq/dhcp/dhcp-hosts
    Jan 1 01:00:59 unknown user.debug init[1]: starting rstats.
    Jan 1 01:00:59 unknown user.debug init[1]: starting cstats.
    Jan 1 01:01:00 unknown daemon.notice ntfs-3g[596]: Version 2013.1.13 integrated FUSE 27
    Jan 1 01:01:00 unknown daemon.notice ntfs-3g[596]: Mounted /dev/sda1 (Read-Write, label "FreeAgent Drive", NTFS 3.1)
    Jan 1 01:01:00 unknown daemon.notice ntfs-3g[596]: Cmdline options: iocharset=utf8,noatime,nodev
    Jan 1 01:01:00 unknown daemon.notice ntfs-3g[596]: Mount options: iocharset=utf8,nodev,allow_other,nonempty,noatime,fsname=/dev/sda1,blkdev,blksize=4096
    Jan 1 01:01:00 unknown daemon.notice ntfs-3g[596]: Ownership and permissions disabled, configuration type 1
    Jan 1 01:01:00 unknown user.info hotplug[504]: USB ntfs fs at /dev/sda1 mounted on /tmp/mnt/FreeAgent_Drive
    Jan 1 01:01:42 unknown user.info init[1]: Broadcom 3/0x042f//0x10/0x0110: Tomato 1.28.0000 MIPSR1-115 K26 USB VPN
    Jan 1 01:01:43 unknown daemon.warn minidlna[832]: Starting MiniDLNA version 1.0.26 [SQLite 3.7.5].
    Jan 1 01:01:43 unknown daemon.err nmbd[825]: Samba server UNKNOWN is now a domain master browser for workgroup WORKGROUP on subnet UNICAST_SUBNET
    Jan 7 10:09:15 unknown daemon.warn minidlna[832]: Creating new database...
    Jan 7 10:09:16 unknown daemon.warn minidlna[832]: HTTP listening on port 27647
    Jan 7 10:09:19 unknown daemon.info pppd[542]: System time change detected.
    Jan 7 10:09:21 unknown daemon.info dnsmasq-dhcp[584]: DHCPREQUEST(br0) 192.168.1.4 10:68:3f:4e:41:16
    Jan 7 10:09:21 unknown daemon.info dnsmasq-dhcp[584]: DHCPACK(br0) 192.168.1.4 10:68:3f:4e:41:16 android-69bf921fc8bb26f4
    Jan 7 10:09:23 unknown daemon.err nmbd[825]: Samba server UNKNOWN is now a domain master browser for workgroup WORKGROUP on subnet 192.168.1.1
    Jan 7 10:09:23 unknown daemon.warn minidlna[864]: Scanning /tmp/mnt
  • KonzolKartel
    Windows IP Configuration
    Host Name . . . . . . . . . . . . : N
    Primary Dns Suffix . . . . . . . :
    Node Type . . . . . . . . . . . . : Hybrid
    IP Routing Enabled. . . . . . . . : No
    WINS Proxy Enabled. . . . . . . . : No
    Ethernet adapter Ethernet:
    Connection-specific DNS Suffix . :
    Description . . . . . . . . . . . : Realtek PCIe GBE sorozatú vezérlő
    Physical Address. . . . . . . . . : 54-04-A6-07-34-1E
    DHCP Enabled. . . . . . . . . . . : Yes
    Autoconfiguration Enabled . . . . : Yes
    Link-local IPv6 Address . . . . . : fe80::512e:cd86:bcf2:ec41%3(Preferred)
    Autoconfiguration IPv4 Address. . : 169.254.236.65(Preferred)
    Subnet Mask . . . . . . . . . . . : 255.255.0.0
    Default Gateway . . . . . . . . . : 2620:9b::1900:1
    DHCPv6 IAID . . . . . . . . . . . : 55837862
    DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-1A-28-D0-94-54-04-A6-07-34-1E
    DNS Servers . . . . . . . . . . . : fec0:0:0:ffff::1%1
    fec0:0:0:ffff::2%1
    fec0:0:0:ffff::3%1
    NetBIOS over Tcpip. . . . . . . . : Enabled
    Tunnel adapter isatap.{4DAFF5B6-1EBA-4644-BC80-0B291F3B631A}:
    Media State . . . . . . . . . . . : Media disconnected
    Description . . . . . . . . . . . : Microsoft ISATAP adapter
    Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0
    DHCP Enabled. . . . . . . . . . . : No
    Egy idő után ez történik :((
  • KonzolKartel
    Valamiért, amióta beállítottam a file share-t, azóta 10-15 perc alatt elfossa magát a hálózat, és csak a router reset gombbal tudom helyre pofozni. A router Asus 500gP V1. Tegnap vettem, de tuti hibátlan.
  • KonzolKartel
    válasz KonzolKartel #1779 üzenetére
    Ez a sor nem tetszik.
    "When no shares are specified and auto-sharing is disabled, /mnt directory is shared in Read Only mode."
    Bár be van kapcsolva az auto-sharing, de gyanús. Mára azt hiszem feladom. Vagyis nem teljesen, de alszom egyet:).
  • KonzolKartel
    válasz Intruder2k5 #1776 üzenetére
    Most csöppentem bele ebbe a Tomato-s témába. Legújabb Shibby féle Tomato van fent. Azt szeretném elérni, hogy az USB-re csatolt merevlemezt eltudják érni az eszközök pl. tv, telefon stb. (DLNA).
    Ezt megcsináltam, mountoltam a hdd-t, így ez a része meg van. Viszont, most szerettem volna kikölcsönözni egy filmet a tékából, de nem tudom átmásolni a wincseszterre. A hálózati helyeknél van egy TomatoUSB-m, ahhol megtalálom a merevlemezt, de nem tudok rá másolni. Lejátszani letudok, de nem hozzá adni nem.
    Mit kéne beállítani? :R
