TP-Link WDR3600 - N600 router
donmackó
#9582
Ezt én nem tudom megmondani Neked, majd jön suste, és felhomályosít a pontos teendőkről! Lehet SMART-ot olvasni USB-n keresztül is, ha ezt támogatja a HDD keret! Nekem is működik...
root@INT-ROUTER:/tmp/home/root# smartctl --all /dev/sda
smartctl 6.3 2014-07-26 r3976 [mips-linux-2.6.22.19] (localbuild)
Copyright (C) 2002-14, Bruce Allen, Christian Franke, www.smartmontools.org
=== START OF INFORMATION SECTION ===
Model Family: Western Digital Scorpio Blue Serial ATA (AF)
Device Model: WDC WD5000BPVT-00HXZT1
Serial Number: WD-WXG1A6136123
LU WWN Device Id: 5 0014ee 601628a2f
Firmware Version: 01.01A01
User Capacity: 500,107,862,016 bytes [500 GB]
Sector Sizes: 512 bytes logical, 4096 bytes physical
Rotation Rate: 5400 rpm
Device is: In smartctl database [for details use: -P show]
ATA Version is: ATA8-ACS (minor revision not indicated)
SATA Version is: SATA 2.6, 3.0 Gb/s
Local Time is: Wed Oct 22 23:43:06 2014 CEST
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
General SMART Values:
Offline data collection status: (0x00) Offline data collection activity
was never started.
Auto Offline Data Collection: Disabled.
Self-test execution status: ( 0) The previous self-test routine completed
without error or no self-test has ever
been run.
Total time to complete Offline
data collection: (11760) seconds.
capabilities: (0x7b) SMART execute Offline immediate.
Auto Offline data collection on/off support.
Suspend Offline collection upon new
command.
Offline surface scan supported.
Self-test supported.
Conveyance Self-test supported.
Selective Self-test supported.
SMART capabilities: (0x0003) Saves SMART data before entering
power-saving mode.
Supports SMART auto save timer.
Error logging capability: (0x01) Error logging supported.
General Purpose Logging supported.
Short self-test routine
recommended polling time: ( 2) minutes.
Extended self-test routine
recommended polling time: ( 117) minutes.
Conveyance self-test routine
recommended polling time: ( 5) minutes.
SCT capabilities: (0x7035) SCT Status supported.
SCT Feature Control supported.
SCT Data Table supported.
SMART Attributes Data Structure revision number: 16
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE
1 Raw_Read_Error_Rate 0x002f 200 200 051 Pre-fail Always - 0
3 Spin_Up_Time 0x0027 207 204 021 Pre-fail Always - 650
4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 49
5 Reallocated_Sector_Ct 0x0033 200 200 140 Pre-fail Always - 0
7 Seek_Error_Rate 0x002e 200 200 000 Old_age Always - 0
9 Power_On_Hours 0x0032 089 089 000 Old_age Always - 8436
10 Spin_Retry_Count 0x0032 100 253 000 Old_age Always - 0
11 Calibration_Retry_Count 0x0032 100 253 000 Old_age Always - 0
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 49
192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 47
193 Load_Cycle_Count 0x0032 193 193 000 Old_age Always - 22377
194 Temperature_Celsius 0x0022 109 101 000 Old_age Always - 38
196 Reallocated_Event_Count 0x0032 200 200 000 Old_age Always - 0
197 Current_Pending_Sector 0x0032 200 200 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0030 100 253 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 0
200 Multi_Zone_Error_Rate 0x0008 100 253 000 Old_age Offline - 0
SMART Error Log Version: 1
No Errors Logged
SMART Self-test log structure revision number 1
No self-tests have been logged. [To run self-tests, use: smartctl -t]
SMART Selective self-test log data structure revision number 1
SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
Selective self-test flags (0x0):
After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay. -
suste
donmackó
#9547
szia
TM nálam is teleszemeteli a logot, de a "mag" -on minden torrentem aktív, és nem estem visszább a helyezésben sem (sőt)
tracker hibát sem ír nálam egyik torrent semannyira nem vágom a témát, de én megint az IPv6-ra gyanakszom.....lehet kihagyom a következő buildből...használja valaki???
én minden lehetséges helyen disabledre tettem, de továbbra is szemetel
ha valaki tudja, hogy hogyan lehet kiiktatni működő openwrt alatt az IPv6-ot, akkor ne tartsa magában
suste
donmackó
#9500
simán, én is így csináltam
alényeg, hogy a TM "Beállítási fájl könyvtára" a HDD-re legyen irányítva most (pl: /mnt/transmission), és az új fw-ben is ugyan oda legyen
így amikor indítod az új fw-ben a TM-et, akkor mindent beolvas a régi rendszer szerint, tehát nem fog újra ellenőrizni semmitegyébként a beállítások átvitele sem egy nagy ügy:
1: csinálsz most egy mentést
2: a mentésbe belépsz TC-vel, majd mindent kitörölsz belőle, csak ezek maradjanak:
csak az etc/config könyvtár és abban a "ddns, dhcp, firewall, fstab, minidlna, network, qos, samba, transmission, wireless".
3: amikor töröltél minden mást és kilépsz a mappából, akkor a TC újracsomagolja a mentést
4: felrakod az uj fw-t úgy hogy kiveszed a pipát a beállítások megtartása elöl, és a HDD nélkül
5: a megcsonkított mentést visszatöltöd az új fw-ben
6: áramtalaítod a routert, rádugod a HDD-t, majd áramot adsz nekipersze ha van extroot-od, akkor sajna ez nem megy ilyen egyszerűen.....
suste
donmackó
#9265
na az király!!!
én pont az utolsó vezióban nem próbáltam ki a luciba (előző verziókban nem ment ott), csak a 8081-est
de az király, ha ott is megy, met akkor nem kell az indítóscriptes, parancssoros buheramég annyit mondj, hogy te írtad be az "ntfs-3g" -t vagy választható volt?
Victoryus:
te hogy csatoltad az ntfs-t??? -
Zirowe
donmackó
#9017
15 kapcsolati szal/torrent, 30mbites netet maxon kihajtja, felfele 3mbit, ezen ertekek mellett stabilan, normalis sebesseggel tudok netezni.
Viszont mostanaban neha a feltoltes felmegy 5mbitig, amitol viszont teljesen belassul a bongeszes, akkor is, ha le mar nem tolt.
suste
donmackó
#8979
külön interfészre kell tenni, aztán a qos-sel beállítani neki a sebességet
1: luci/hálózat/wifi: szerkesztés, hálózatnál LAN helett újhoz: "wifi", mentés alkalmazás
2:luci/hálózat/interfész/wifi: IP=192.168.2.1, MASZK=255.255.255.0, alul DHCP bekapcs, fizikai fülön megnézed hogy be van-e pipálva a létező wifit, tűzfal fülön: WAN, mentés alkalmazás
3: qos fülön új, név=wifi, le felsebességek fordítva megad, mentés alkalmazás
Így már szabályozva van, de csak netrelát ki, LAN-ra nem, vagyis nem látja a belső hálót, de az ismegoldható a tűzfalban....
Ha mégsem megy így, akkor a klaszikus GUEST hálózat módszer tuti, hogy működik... -
- Trollok komolyan
- Jövedelem
- Postal: Bullet Paradise - A játék amit bejelentettek, majd el is kaszáltak
- CADA, Polymobil, és más építőkockák
- World of Tanks - OFF topic
- Mikrokontrollerek Arduino környezetben (programozás, építés, tippek)
- BESZÁMÍTÁS! SAPPHIRE B650M R7 8700F 32GB DDR5 512GB SSD RX 6800XT 16GB Zalman Z1 GIGABYTE 750W
- BESZÁMÍTÁS! MSI B650 R7 8700F 32GB DDR5 512GB SSD RX 6800 16GB Zalman Z1 Plus Cooler Master 750W
- HP ProBook 650 G8 Intel i5-1145G7 16GB 512GB magyarbill 1 év garancia
- Bomba ár! HP ProBook 440 G6 - i5-8GEN I 8GB I 256SSD I HDMI I 14" FHD I Cam I W10 I Gari!
