Ubuntu Linux Összefoglaló
Hivatalos Ubuntu dokumentáció
lspci
lsusb
dragon1993
Sziasztok Ubuntu Server 14.04 LTS alatt kaptam ezt a hibát, hogyan tudnám megoldani ?
From root@DOMAIN.com Mon Jul 20 06:43:30 2015
Return-Path: <root@DOMAIN.com>
X-Original-To: root
Delivered-To: root@DOMAIN.com
Received: by DOMAIN.com (Postfix, from userid 0)
id 49F4412063B; Mon, 20 Jul 2015 06:43:30 +0200 (CEST)
To: root@DOMAIN.com
Subject: Cron <root@sarkanydavid> test -x /usr/sbin/anacron || ( cd / && run-parts --report /etc/cron.daily )
Content-Type: text/plain; charset=ANSI_X3.4-1968
X-Cron-Env: <SHELL=/bin/sh>
X-Cron-Env: <PATH=/usr/local/sbin:/usr/local/bin:/sbin:/bin:/usr/sbin:/usr/bin>
X-Cron-Env: <HOME=/root>
X-Cron-Env: <LOGNAME=root>
Message-Id: <20150720044330.49F4412063B@DOMAIN.com>
Date: Mon, 20 Jul 2015 06:43:30 +0200 (CEST)
/etc/cron.daily/logrotate:
error: error running shared postrotate script for '/var/log/nginx/*.log '
run-parts: /etc/cron.daily/logrotate exited with return code 1 -
dragon1993
dragon1993
#17160
A "sudo apt-get install bsdutils" megoldotta.
dragon1993
Sziasztok. Az openvz-s VPS-emen lenne egy kis problémám.
Nem tudok se mysql se mariadb-t telepíteni.A következő hibát dobja:
dpkg: error processing package mysql-server-5.6 (--configure):
subprocess installed post-installation script returned error exit status 127Teljes output:
root@vps:~# apt-get install mysql-server-5.6
Reading package lists... Done
Building dependency tree
Reading state information... Done
The following extra packages will be installed:
libaio1 libdbd-mysql-perl libdbi-perl libhtml-template-perl libmysqlclient18
libterm-readkey-perl mysql-client-5.6 mysql-client-core-5.6 mysql-common
mysql-common-5.6 mysql-server-core-5.6
Suggested packages:
libclone-perl libmldbm-perl libnet-daemon-perl libplrpc-perl
libsql-statement-perl libipc-sharedcache-perl mailx tinyca
The following NEW packages will be installed:
mysql-common-5.6 mysql-server-5.6 mysql-server-core-5.6
0 upgraded, 12 newly installed, 0 to remove and 0 not upgraded.
Need to get 20.6 MB of archives.
After this operation, 155 MB of additional disk space will be used.
Do you want to continue? [Y/n] Y
Get:1 http://nl.archive.ubuntu.com/ubuntu/ trusty/main libaio1 i386 0.3.109-4 [6 578 B]
Get:2 http://nl.archive.ubuntu.com/ubuntu/ trusty-security/main mysql-common all 5.5.38-0ubuntu0.14.04.1 [14.1 kB]
Get:3 http://nl.archive.ubuntu.com/ubuntu/ trusty-security/main libmysqlclient18 i386 5.5.38-0ubuntu0.14.04.1 [592 kB]
Get:4 http://nl.archive.ubuntu.com/ubuntu/ trusty/main libdbi-perl i386 1.630-1 [881 kB]
Get:5 http://nl.archive.ubuntu.com/ubuntu/ trusty/main libdbd-mysql-perl i386 4.025-1 [99.6 kB]
Get:6 http://nl.archive.ubuntu.com/ubuntu/ trusty/main libterm-readkey-perl i386 2.31-1 [27.2 kB]
Get:7 http://nl.archive.ubuntu.com/ubuntu/ trusty-security/universe mysql-client-core-5.6 i386 5.6.19-0ubuntu0.14.04.1 [4347 kB]
Get:8 http://nl.archive.ubuntu.com/ubuntu/ trusty-security/universe mysql-client-5.6 i386 5.6.19-0ubuntu0.14.04.1 [4873 kB]
Get:9 http://nl.archive.ubuntu.com/ubuntu/ trusty-security/universe mysql-server-core-5.6 i386 5.6.19-0ubuntu0.14.04.1 [4223 kB]
Get:10 http://nl.archive.ubuntu.com/ubuntu/ trusty-security/universe mysql-server-5.6 i386 5.6.19-0ubuntu0.14.04.1 [5459 kB]
Get:11 http://nl.archive.ubuntu.com/ubuntu/ trusty/main libhtml-template-perl all 2.95-1 [65.5 kB]
Get:12 http://nl.archive.ubuntu.com/ubuntu/ trusty-security/universe mysql-common-5.6 all 5.6.19-0ubuntu0.14.04.1 [15.0 kB]
Fetched 20.6 MB in 2s (10.1 MB/s)
debconf: delaying package configuration, since apt-utils is not installed
Selecting previously unselected package libaio1:i386.
(Reading database ... 13205 files and directories currently installed.)
Preparing to unpack .../libaio1_0.3.109-4_i386.deb ...
Unpacking libaio1:i386 (0.3.109-4) ...
Selecting previously unselected package mysql-common.
Preparing to unpack .../mysql-common_5.5.38-0ubuntu0.14.04.1_all.deb ...
Unpacking mysql-common (5.5.38-0ubuntu0.14.04.1) ...
Selecting previously unselected package libmysqlclient18:i386.
Preparing to unpack .../libmysqlclient18_5.5.38-0ubuntu0.14.04.1_i386.deb ...
Unpacking libmysqlclient18:i386 (5.5.38-0ubuntu0.14.04.1) ...
Selecting previously unselected package libdbi-perl.
Preparing to unpack .../libdbi-perl_1.630-1_i386.deb ...
Unpacking libdbi-perl (1.630-1) ...
Selecting previously unselected package libdbd-mysql-perl.
Preparing to unpack .../libdbd-mysql-perl_4.025-1_i386.deb ...
Unpacking libdbd-mysql-perl (4.025-1) ...
Selecting previously unselected package libterm-readkey-perl.
Preparing to unpack .../libterm-readkey-perl_2.31-1_i386.deb ...
Unpacking libterm-readkey-perl (2.31-1) ...
Selecting previously unselected package mysql-client-core-5.6.
Preparing to unpack .../mysql-client-core-5.6_5.6.19-0ubuntu0.14.04.1_i386.deb . ..
Unpacking mysql-client-core-5.6 (5.6.19-0ubuntu0.14.04.1) ...
Selecting previously unselected package mysql-client-5.6.
Preparing to unpack .../mysql-client-5.6_5.6.19-0ubuntu0.14.04.1_i386.deb ...
Unpacking mysql-client-5.6 (5.6.19-0ubuntu0.14.04.1) ...
Selecting previously unselected package mysql-server-core-5.6.
Preparing to unpack .../mysql-server-core-5.6_5.6.19-0ubuntu0.14.04.1_i386.deb . ..
Unpacking mysql-server-core-5.6 (5.6.19-0ubuntu0.14.04.1) ...
Setting up mysql-common (5.5.38-0ubuntu0.14.04.1) ...
Selecting previously unselected package mysql-server-5.6.
(Reading database ... 13577 files and directories currently installed.)
Preparing to unpack .../mysql-server-5.6_5.6.19-0ubuntu0.14.04.1_i386.deb ...
debconf: unable to initialize frontend: Dialog
debconf: (No usable dialog-like program is installed, so the dialog based frontend cannot be used. at /usr/share/perl5/Debconf/FrontEnd/Dialog.pm line 76.)
debconf: falling back to frontend: Readline
Configuring mysql-server-5.6
While not mandatory, it is highly recommended that you set a password for the
MySQL administrative "root" user.
If this field is left blank, the password will not be changed.
New password for the MySQL "root" user:
Repeat password for the MySQL "root" user:
Unpacking mysql-server-5.6 (5.6.19-0ubuntu0.14.04.1) ...
Selecting previously unselected package libhtml-template-perl.
Preparing to unpack .../libhtml-template-perl_2.95-1_all.deb ...
Unpacking libhtml-template-perl (2.95-1) ...
Selecting previously unselected package mysql-common-5.6.
Preparing to unpack .../mysql-common-5.6_5.6.19-0ubuntu0.14.04.1_all.deb ...
Unpacking mysql-common-5.6 (5.6.19-0ubuntu0.14.04.1) ...
Setting up libaio1:i386 (0.3.109-4) ...
Setting up libmysqlclient18:i386 (5.5.38-0ubuntu0.14.04.1) ...
Setting up libdbi-perl (1.630-1) ...
Setting up libdbd-mysql-perl (4.025-1) ...
Setting up libterm-readkey-perl (2.31-1) ...
Setting up mysql-client-core-5.6 (5.6.19-0ubuntu0.14.04.1) ...
Setting up mysql-client-5.6 (5.6.19-0ubuntu0.14.04.1) ...
Setting up mysql-server-core-5.6 (5.6.19-0ubuntu0.14.04.1) ...
Setting up mysql-server-5.6 (5.6.19-0ubuntu0.14.04.1) ...
debconf: (No usable dialog-like program is installed, so the dialog based fronte nd cannot be used. at /usr/share/perl5/Debconf/FrontEnd/Dialog.pm line 76.)
/var/lib/dpkg/info/mysql-server-5.6.postinst: line 111: logger: command not foun d
2014-08-11 08:30:41 0 [Warning] Using unique option prefix key_buffer instead of key_buffer_size is deprecated and will be removed in a future release. Please u se the full name instead.
2014-08-11 08:30:41 0 [Warning] TIMESTAMP with implicit DEFAULT value is deprecated. Please use --explicit_defaults_for_timestamp server option (see documentati on for more details).
/var/lib/dpkg/info/mysql-server-5.6.postinst: line 189: logger: command not found
Setting up libhtml-template-perl (2.95-1) ...
Setting up mysql-common-5.6 (5.6.19-0ubuntu0.14.04.1) ...
Processing triggers for libc-bin (2.19-0ubuntu6.1) ...
Errors were encountered while processing:
mysql-server-5.6
E: Sub-process /usr/bin/dpkg returned an error code (1)
- Vélemény Ubuntu 20.04 LTS
- BESZÁMÍTÁS! MSI Thin GF63 15,6 FHD Gamer notebook-i5 11400H 16GB DDR4 512GB SSD RTX 3050 Ti 4GB W11
- GMKTec NucBox M6 Ultra mini számítógép - R5 7640HS 16GB 4800MHz DDR5 512GB SSD AMD Radeon 760M W11
- HIBÁTLAN iPhone 14 Plus 128GB Yellow -1 ÉV GARANCIA - Kártyafüggetlen, MS4472
- Apple Watch Series 8 41mm GPS, Újszerű, 1 Év Garanciával
- HIBÁTLAN iPhone 12 mini 64GB Black -1 ÉV GARANCIA - Kártyafüggetlen, MS3818
