S_x96x_S
AMD Releases the A520 Chipset: For Ryzen on a Budget
https://www.anandtech.com/show/15999/amd-releases-the-a520-chipset-for-ryzen-3000-on-a-budget -
S_x96x_S
Petykemano #3712 üzenetére
Izgalmas időszak jön
> Alibaba azt állítja,
Hot Chips 2020 Live Blog: Alibaba Xuantie-910 RISC-V CPU (3:00pm PT)
https://www.anandtech.com/show/15991/hot-chips-2020-live-blog-alibaba-xuantie910-riscv-cpu-300pm-pt--------------
Viszont az XBOX chipje érdekes ... (főleg mivel AMD tervezés )
- N7 Enhanced-re irják .. lehet,, hogy a ZEN3-asok is ilyenek lesznek?
Hot Chips 2020 Live Blog: Microsoft Xbox Series X System Architecture"
Q:Coherency CPU and GPU?
A: GPU can snoop CPU, reverse requires softwareQ: TSMC 7nm enhanced, is it N7P, N7+, or something else?
A: It's not base 7nm, it's progressed over time. Lots of work between AMD and TSMC to hit our targets and what we neededQ: Says Zen 2 is server class, but you use L3 mobile class?
A: Yeah our caches are different, but I won't say any more, that's more AMD.Q: With 20 channels GDDR6, is that really cheaper than 2 stacks HBM?
A: We're not religious about which DRAM tech to use. We needed the GPU to have a ton of bandwidth. Lots of channels allows for low latency requests to be serviced. HBM did have an MLC model thought about, but people voted with their feet and JEDEC decided not to go with it." -
S_x96x_S
Microsoft Xbox Series X's AMD Architecture Deep Dive at Hot Chips 2020
https://www.tomshardware.com/news/microsoft-xbox-series-x-architecture-deep-dive -
S_x96x_S
Benchmarks: Amazon EC2 C5ad Instances Launch For AMD EPYC Rome With Local NVMe Storage
https://www.phoronix.com/scan.php?page=article&item=amazon-ec2-c5ad&num=1 -
S_x96x_S
Hot Chips 2020 Live Blog: AMD Ryzen 4000 APU (Noon PT)
https://www.anandtech.com/show/15988/hot-chips-2020-live-blog-amd-ryzen-4000-apu-noon-ptQ: Melt, Spectre?
A: Melt doesn't impact AMD. Zen 2 has hardware mitigations for Spec v2/v4. Added Guest mode execution, virtualization security, IOMMU throughput, TMEQ: 8 cores in this size, trade offs?
A: We wanted to provide the 8 core perf, and as we analyzed with 7nm that if we took care we could enable 8 cores. Lots of content creation takes advantage of 8 cores. These come in handy with high perf applications. On the GPU, we were also careful in perf/watt and perf/mm2 that we can drive. We figured out in 7nm we could get higher frequency, so we balanced resources and that's why we went for 8 CUs. Vega with mem bandwidth gives better UX in 15W....
vs.Hot Chips 2020 Live Blog: Intel's Tiger Lake Mobile CPU (12:30pm PT)
https://www.anandtech.com/show/15989/hot-chips-2020-live-blog-intels-tiger-lake-mobile-cpu-1230pm-pt -
S_x96x_S
https://www.anandtech.com/show/15986/hot-chips-2020-live-blog-marvell-thunderx3-1030am-pt
" Q: Any competitive comparison? What areas does the TX3 chip stand out?
A: vs Intel on ST, Intel turbos to higher freq. Even though on a per-GHz TX3 is faster, overall on Intel single thread, Intel tends to be faster. But lower core count on Intel, so our throughput on SPECintrate, we are higher than Intel. On AMD, it's a little bit of a reverse. TX3 does better than AMD on single thread. On throughput, limited cache sharing, AMD does better. But code with more sharing, producers/consumers, then scaling seems to shop. TX3 is better on database performance codes. For Graviton2 - that's a really good chip. Frequency is low, no threading, but its a good chip." -
S_x96x_S
lassan már itthon is kapni minipc-t .. persze a 8 magosok még nem elérhetőek ( nálunk )
Asus PN50-BBR343MD-CSM - Ryzen 3 4300U ~ 107e Ft
https://www.argep.hu/product_2850747.htmlAsus: https://www.asus.com/Mini-PCs/Mini-PC-PN50/
https://geizhals.eu/?fs=ASUS+Mini+PC+PN50 -
S_x96x_S
Petykemano #3704 üzenetére
Most van a "Hot Chips 32 held Sunday-Tuesday, August 16-18, 2020."
Ma lesznek még érdekes előadások: https://www.hotchips.org/program/
- "AMD Next Generation 7nm RyzenTM 4000 APU"
( persze sajnos csak 1 AMD-s előadás .. )-----
> IBM Power10:
https://www.hardwareluxx.de/index.php/galerie/komponenten/prozessoren/ibm-power10-press-conference-deck.html
- PCIe 5 x64Azért kíváncsi leszek, hogy az AMD-nek lesz-e PCIe5.0 -ja jövőre ..
( az IBM és az Intel is 2021 -re tervezi ) -
S_x96x_S
előbb - utóbb ki-kalapálják a játékengineket is, hogy (rendesen) támogassák :
- a többmagos CPU-kat is ..
- és a next-gen konzolokat isUnity3D Roadmap to 2021
https://blogs.unity3d.com/2020/08/13/the-road-to-2021/"We are also continuing our efforts for our Data-Oriented Technology Stack (DOTS) to lay the foundation for the future of Unity and the architecture that delivers multithreaded performance by default
. More on that in future blog posts.""
"Platform reach: platform support and launch-day content
for next-generation consoles, Apple silicon, new AR/VR platforms, and continued optimization and support for mobile architecture."
S_x96x_S
Ha lassan is .. de kezdik a szoftvereket is tuningolni az új AMD-s hardverekre ..
Autodesk's Arnold Renderer új verziójában
a 3990X - 1.42x gyorsabban fut - ez szép
a 3990X gyorsabb lett mint a 3995WX - ami viszont furcsa ..
( az előző verzióban még a 3995WX gyorsabb )referenciaként: az Intel -es konfigok csak icipicit gyorsultak.
S_x96x_S
Petykemano #3686 üzenetére
> De azt nem értem, hogy az AMD miért bontaná meg az egész jó,
> kompakt zen magokat, ...
> L2$ két különböző feldolgozó egységet tápláljon?
furcsa, .. az Intel -nél is valamifajta osztott L2 lehet ??
( lásd "1.5M L2" az ábrán )
( via ) -
S_x96x_S
(ha lesz) akkor szerintem elsőként a monolitikus 5nm/3nm-es APU-kban lehet ilyen big-little felépítés.
Az ARM-es konstrukciók most kb >24h rendelkezésre állást tudnak,
az x86 ( AMD /Intel ) ennek a fele ...
És ki tudja, hogy a jelenlegi laptopok jövője mennyire van megszámolva .. lassan a telefonhoz elég egy kihajtható képernyő és egy kihajtható billentyűzet. a felhasználók nagy részének nem kell igazából laptop .. vagyis valamit lépni kell .. mert az X86 piac egyre zsugorodik ..és a szerver fronton is várható hasonló trend ..
S_x96x_S
már volt téma a big-little ( és lehet, hogy ez is posztolva lett valamilyen formában )
de most megint felkapta a sajtó a 2020Jun30- i AMD szabadalom alapján ( ami annyira nem új, mert vannak előzményei )Ami érdekes , hogy már az L1/L2 cache -en kapcsolódnak,
ami mélyebb integrációt sejtet .. vagyis ezek már a CCX szintjén is integráltak, és nem csak egy sima összetokozás .."AMD Files Patent for big.LITTLE-esque Hybrid Computing Technique"
https://www.tomshardware.com/news/amd-patent-biglittle--hybrid-computing-implementation -
S_x96x_S
a-X2P | Portable Dual EPYC Workstation PC
https://www.mediaworkstations.net/systems/portable-amd-workstations/a-x2p/ -
S_x96x_S
> , a Renoir ... iGP része viszont hasít,
ha meg lesz oldva a GPU chipletesítése ( és legózása )
akkor szerintem több variáció is lehet - még nagyobb teljesítménnyel.
Én a Threadripperes APU-t várom .Amúgy a mostani is csak egy közbenső lépés ... majd jövőre megint iterálják ..
S_x96x_S
hokuszpk #3675 üzenetére
> szerintem ezt az oromet meghagyjak a
az is lehet, hogy a marketingesek döntik el,
és a 4950X -nek véletlenül 4950 Mhz lesz a turbója( 4.95Ghz )
A 4900X -nek meg 4900MhzA marketingesek furcsa népség ..
Amúgy szerintem lehet, hogy tényleg kihagyják a 4-es számozást .
mert a 4-es a keleti kultúrában balszerencsés .. -
S_x96x_S
még egy kicsit reszelik és csak meglesz az az 5.0Ghz
AMD Ryzen 9 4950X could boost up to 4.9 GHz
100-000000061-06_ 49/37 _Y
https://videocardz.com/newz/amd-16-core-zen3-ryzen-9-4950x-engineering-sample-boosts-up-to-4-9-ghz -
S_x96x_S
DeskMini X300 Series
- Renoir, Picasso, Raven Ridge, up to 65W
- overlockolható ;
- friss BIOS : 2020/8/6
https://www.asrock.com/nettop/AMD/DeskMini%20X300%20Series/index.asp#Overview -
S_x96x_S
"kisbőrönd"
a-XP | Portable Threadripper Workstation PC -
alapár: $7,997
de nekem sikerült felkonfigurálni: $34,332 -re ( maximalista vagyok )"Featuring AMD Threadripper CPUs up to 64 cores, 256GB RAM and a single GPU, the a-XP Portable Workstation PC is the portable version of our a-X, a cost effective and powerful portable workstation."
https://www.mediaworkstations.net/systems/portable-amd-workstations/a-xp/via:
https://www.tomshardware.com/news/take-this-portable-threadripper-3990x-workstation-wherever-you-go -
S_x96x_S
új kérők az ARM-re ..
TSMC, FoxconnAz is érdekes lesz az AMD-re nézve, hogyha a TSMC veszi meg.
"Rumor: AMD skipping desktop 4000 series naming, Ryzen 5000 incoming?"
https://wccftech.com/arm-becomes-the-focal-point-of-a-growing-bidding-war-as-tsmc-and-foxconn-jump-into-the-fray/ -
S_x96x_S
Report: AMD Ryzen 9 4950X/5950X engineering sample boosts up to 4.8 GHz
https://videocardz.com/newz/report-amd-ryzen-9-4950x-5950x-engineering-sample-boosts-up-to-4-8-ghz+ "Rumor: AMD skipping desktop 4000 series naming, Ryzen 5000 incoming?"
S_x96x_S
Exclusive: The State Of AMD’s Supply Chain, August 2020
https://wccftech.com/exclusive-the-state-of-amds-supply-chain-august-2020/"So to answer the question, no, AMD is not capacity constrained. They are experiencing a supply chain lag due to conservative forecasts by the ecosystemas well as unprecedented demand for a product that has brought strong competition back to the market, and should be able to rise up to meet demand in a month or two. This is one of the reasons why I believe AMD has also guided up on revenue (since they expect to be able to meet any further demand). On the contrary, AMD's ability to scale to demand is actually impressive considering the 200% increase in unit shipments over a quarter and more on the way."
S_x96x_S
S_x96x_S
-vitya- #3649 üzenetére
> avx512 ... Már emelik is bele, gondolod?
ha már kész a szilikon terv(ZEN4); akkor már benne is lehet,
most már a ZEN5-öt tervezhetik ..
(ZEN4-re pletykálták az AVX512-öt .. de az még ~1,5 év míg piacra kerül)AVX512 saját vélemény:
- HPC/Enterprise vonalon szükséges a versenyképességhez.
- és az Intel újabban már a 10nm-es mobilprocikba is belerakja ...
( ami miatt egyre több fejlesztő optimalizálja a programot )
- Az ARM SV2 128 - 2048 bit-ig skálázódik .. mégha nem is tökéletes az AVX512 ; valami választ kell adni x86 os oldalon is -
S_x96x_S
marketshare (desktop:19.20; server 5.8%; mobil:19.9% )
.. ici picit nőtt ...nem hittem volna, hogy a mobil nagyobb mint a desktop
A szervernél meg el kell érni az a bűvős 10.00% -ot ( az már két számjegynek számít )https://www.tomshardware.com/news/amd-vs-intel-highest-overall-x86-chip-market-share
"According to the Mercury Research analysis, AMD now holds 5.8% of the total server share. That's an increase of 0.7 points over the prior quarter, and 2.4 points over the prior year. AMD has told us that it will share IDC's report soon, and we expect it will be closer to AMD CEO Lisa Su's projection that the company had finally reached its oft-quoted goal of a double-digit percentage of the server market. AMD also announced that it had doubled its EPYC server chip sales during the last quarter."
S_x96x_S
#Dali - Szeptemberben jön 2 Lenovo konfig - oktatási célra
( A Celeron N4120 ellen pozicionálva )
CMOS: 14nm -en gyártva"Available in September 2020, Lenovo 100e 2nd Gen with AMD 3015e will start from $219 and Lenovo 300e 2nd Gen with AMD 3015e will start from $299."
AMD Zen now at 6W TDP: Dual Core for Education
https://www.anandtech.com/show/15953/amd-zen-now-at-6w-tdp-dual-core-for-educationhttps://www.amd.com/en/processors/windows-for-education
https://news.lenovo.com/pressroom/press-releases/lenovo-enhances-portfolio-of-education-solutions-to-meet-evolving-demands-of-hybrid-learning/
off:
- ami még érdekes, hogy a Lenovo az osztálytermekbe akarja vinni a VR-t
( VR Classroom 2 — Immersive Learning Made Easy for 21st Century Education ) -
S_x96x_S
Petykemano #3645 üzenetére
töpreng ...
Az új APU 7nm-en 156 mm2 ( 8 core + GPU )
Ez alapján nem biztos, hogy APU ..A ZEN2 chiplet viszont az AT -szerint 74-80 mm2
"The Zen 2 design paradigm, compared to the first generation of Zen, has changed significantly. The new platform and core implementation is designed around small 8-core chiplets built on TSMC’s 7nm manufacturing process, and measure around 74-80 square millimeters."Viszont az AVX-512 -nek kell a hely
.. és amit megnyerünk a méret csökkentéssel - elveszítjük a fejlesztésekkel. -
S_x96x_S
úgy néz ki, hogy az új 8 magos mobil APU-k kifogytak
.. és kb 2 hónap kell ( szeptember vége )
a készletek feltöltéséhez.
Nemcsak az XMG - 4800H prociknál gond ez,
de az új AMD-s Thinkpad-eknél ( PRO proci )
is levették a 8 magos customizálást
--- és 8 hetes átfutási időt pletykálnak. ( ami ~ 2 hónap )a siker átka ... mindegyik Notebook Gyártó óvatosan rendelt ..
az AMD ezek alapján gyártatott .. - de most hirtelen kifogytak a készletek, mert a vásárlók elkapkodták a 8magosokat ..
Ez a gyenge pontja az AMD-nek .. nem olyan flexibilis ..https://videocardz.com/newz/xmg-facing-serious-amd-ryzen-7-4800h-renoir-cpu-shortage
S_x96x_S
S_x96x_S
HBM / Stacked memory device /
avagy a réteges dobostorta készítés elveinek átültetése
a chipkészítésbe. ...
AMD July 28 2020 Patent:
"Method and Apparatus for temperature-gradient aware data-placement for 3D stacked DRAMs".
https://twitter.com/VideoCardz/status/1288885301398720514 -
S_x96x_S
AMD EPYC 7552 Benchmarks and Review
https://www.servethehome.com/amd-epyc-7552-benchmarks-and-review/"AMD offers a larger memory footprint with up to 4TB in 8-channel DDR4-3200 versus 1TB in 6-channel DDR4-2933. AMD has more PCIe I/O with 64, 96, or 128 PCIe Gen4 lanes per socket compared to Intel’s 48x PCIe Gen3 lanes. Intel has features such as AVX-512 and VNNI instructions (DL Boost) that AMD does not have but are new for 2nd Generation Intel Xeon Scalable. Perhaps the biggest feature Intel has is Optane DCPMM support. We should note here that DCPMM support is limited by memory capacity since the Gold 6258R is not a “L” SKU. Still, if one wants fast storage, DCPMM is a significant option that AMD does not have. If you are not using small DCPMM footprints, nor the new instructions, then AMD is extremely competitive."
S_x96x_S
S_x96x_S
paper launch?
a) Launch client Zen 3 this year guaranteed
b) Will attempt for on-shelf availability this year too, but not guaranteed
https://twitter.com/IanCutress/status/1288236494747049984 -
S_x96x_S
AMD Reiterates 2020 Roadmap: Zen 3 Client & Server, RDNA 2, CDNA Late This Year
"Meanwhile on the server side of matters, the picture is much the same. AMD reports that they are on track to begin shipping the Zen 3-based “Milan” EPYC processors late in 2020. As well, AMD’s first CDNA architecture GPU for the data center market is set to launch late this year as well."
S_x96x_S
AMD Reports Q2 2020 Earnings: Notebook and Server Sales Drive a Record Quarter
Driving this growth for AMD will be a mix of the slow expansion of server products, as well as new products launched in the second-half of the year. AMD is expecting EPYC sales to continue to grow and for the company to gain market share there as more server vendors further ramp up their EPYC server production. Meanwhile AMD is reiterating that it’s expecting to begin shipping its Zen 3-based “Milan” EPYC processors late this year. AMD’s upcoming CDNA-based data center GPUs are also set to launch around at time.As for the consumer side of matters, AMD is expecting continued sales success with its consumer products, particularly Ryzen Mobile. None the less, all eyes are going to be on AMD’s future products, as AMD is reiterating their 2020 launch plans. The company reports that it’s on track to launch Zen 3 client CPUs in late 2020, and the company’s eagerly-anticipated RDNA2 products, which will eventually encompass a full stack refresh, will launch in late 2020 as well."
S_x96x_S
STH piacelemzése az Intel bejelentések kapcsán
( AMD, Arm, nVidia, PCIe Gen4 /5 érintve)
https://www.servethehome.com/the-2021-intel-ice-pickle-how-2021-will-be-crunch-time/ -
S_x96x_S
ma már igyekszem nem csodálkozni semmin se
(pletyka) "INTEL CPUs Could Be Made On TSMC 3nm As Well"
https://wccftech.com/intel-ponte-vecchio-gpu-tsmc-6nm/ -
S_x96x_S
S_x96x_S #3616 üzenetére
"Intel = 7nm delay, AMD = Baba Yaga"
https://twitter.com/TechEpiphany/status/1286399731216855041Baba Yaga =
"Baba Jaga az orosz (cseh, szlovák) népmesék gonosz boszorkánya (bár a XX. századtól kezdve néha nem negatív szereplő, akárcsak Kékszakállú herceg a magyarok számára). Pl. gyerekeket eszik, mint a Jancsi és Juliska boszorkánya, de nem kolbászból van a kerítése, hanem koponyákból és csontokból. " ( link )
https://en.wikipedia.org/wiki/Baba_Yaga -
S_x96x_S
AnandTech kielemezte az Intel *"váratlan"* bejelentését ..
Kérdés, hogy mit gyártat majd az Intel a TSMC-n és mekkora kapacitást foglal le
.. mindenesetre az Intel 3rd party gyártása
az AMD-nek kevésbé jó hír.Viszont most már az Intel nem engedheti meg,
hogy tököljön ahogy eddig ...
kénytelen pragmatikusan állni ehhez ...Intel 7nm Delayed By 6 Months; Company to Take “Pragmatic” Approach in Using Third-Party Fabs
S_x96x_S
> Ha évről évre kevesebb pc kerül eladásra
> akkor mibe teszik a procikat ?cloud / data center
... ami megnyomta az eladásokat ... főleg, hogy a covid miatt sok cég felgyorsította a felhőbe költözést ...
https://www.anandtech.com/show/15925/intel-reports-q2-2020-earnings-data-center-sales-fuel-another-record-quarterami érdekes AMD szempontból, hogy csúszik az Intel 7nm.
"... announcing that their 7nm CPU plans have been pushed back by 6 months, and that 7nm yields are about 12 months behind where Intel planned for them to be. This is due to a defect in their 7nm process, which the company has since root caused and is correcting, but none the less it’s caused a 7nm delay they can hardly afford. Intel’s first consumer 7nm chips are now not expected to land until at least late 2022, if not later."
Az AMD negyedéves a jövő héten jön ki.
* "Tuesday, July 28, 2020 after the close of market." -
S_x96x_S
insider view .. AMD history ...
"While we kept plodding on the “pure dual-core”, Intel, still smarting from the x64 defeat just slapped two 1x cores together, did some smart interconnects, & marketed it as “dual core”. Joke at AMD was that Intel’s marketing budget was > our R&D (true fact). Customers ate it up.
While all this APU work was going on, AMD totally missed the iPhone wave. When we built chips for the PC, world was moving to laptops, when we moved to laptops, they moved to tablets, & when we moved there, world moved to cell phones.
We also missed the GPU wave trying to introduce a fundamentally better but also fundamentally new architecture: APUs (CPU+GPU on same die - we love “same die everything” I guess). CATEGORY CREATION IS HELL but “if you’re going through hell, keep going”. We hesitated and 2008 crisis happened & we were totally caught with our pants down. After that, AMD basically lost the market to pretty much everyone: Intel, ARM, Nvidia. I learned it the hard way how SUPERIOR PRODUCTS LOSE TO SUPERIOR DISTRIBUTION LOCK-INS & GTM.
Even madder props to Lisa Su who now leads AMD. Lot of my engineer friends are still there building world best tech and I can’t imagine what they must have had to go through: multiple heavy layoffs, salary cuts, leadership changes (2 CEO changes b/w 08-11 alone), low morale.
AMD was a “TRIBE”. For so many it was their 1st job out of college in late 80s & they are still there after 30yrs! I guess this is how AMD survived multiple near-deaths & this is also why when it comes to AMD I still say “we” as if I’m still the fanboy I was as a college student!
teljes:
https://threadreaderapp.com/thread/1285234687267356672.html -
S_x96x_S
> Ha az NVidia felvásárolná tuti sokan szarul járnának ...
pl. az AMD ..
az AMD eredeti "tartalékterve" .. a közös x86 + Arm foglalat ...
( https://www.amd.com/en/amd-opteron-a1100 )
ha ARM ügyben az nVidia dominál a tárgyalóasztal végénél,
akkor egészen más a tárgyalás - hangulata ...Persze az nVidia is lépéskényszerben van, mert nincs alatta rendes CPU
architektúra ... és az x86 -ból kezd kiszorulni,
főleg mert az Intel és az AMD elég erős GPU + CPU -val bír ..A sötét ló az Apple ... vajon erre mit lép ...
A Softbank - aki az ARM jelenlegi befektetője meg pénzt akar látni
vagy a licence költséget emelné .. vagy drágán eladná/piacra vinné a céget .. persze emiatt várhatóan elindul az elvándorlás a RISC-V felé a költségérzékeny ügyfeleknél ..."SoftBank: Oi, we paid $32bn for you, when are you going to strong-Arm some more money out of your customers?" [1]
https://www.theregister.com/2020/07/16/softbank_arm_licensing_price_rise/Nvidia may be mulling lopping Arm off Softbank: GPU goliath said to have shown interest in acquiring CPU design house
Well, when the chips are down...
+ https://www.theregister.com/2020/07/22/nvidia_arm_purchase/de ha hirtelen pénz kell .... akkor ki kell facsarni azt ami van ...
[1] """
Yet it seems SoftBank appears not to have understood the chip universe, imagining that a majority share in a market provided it the opportunity to reap massive profits. It also thought an era of 5G-connected Internet-of-Things devices would mean a vast increase in chips shipped, but that time has still to come.So, um, money...
Now SoftBank is reportedly looking at selling the chip biz off to recoup its investment and free up capital, especially given its poorly performing massive investments in WeWork, Uber and others. Goldman Sachs has apparently been hired to look at the possibilities, and SoftBank's COO is talking to the press about getting “most of the value” of the company, potentially by taking it public. Arm also just announced it planned to jettison its Internet-of-Things device management cloud operation
S_x96x_S
Petykemano #3599 üzenetére
> Vajon miért most akar pénzt látni ebből a softbank?
Talán mert kompenzálni akarja a WeWork, Uber veszteségeket ..
https://www.bloomberg.com/news/articles/2020-05-18/softbank-vision-fund-books-17-7-billion-loss-on-wework-uber -
S_x96x_S
Cathulhu #3597 üzenetére
nézegetve az egy hetes hírt[1] .. úgy néz ki, hogy a SoftBank nagyon pénzt akar csinálni ... és úgy gondolhatja hogy mostanra kell időzíteni
( miután bejelentette az Apple a váltást ? )
Szerintem az Apple lehet az akinek van pénze és fontos lehet még ...
talán fel akarja tornázni az árakat ...A másik lehetőség, hogy kimegy tőzsdére ( IPO ) mint a többi cég.
07.14.2020 ( ~ 1 hete )
"Softbank is said to have been weighing the possibility of holding an initial public offering (IPO) for Arm Holdings, but now there’s said to be at least one company out there that wants to straight-up buy Arm from Softbank."
[1]
https://www.eetimes.com/softbank-said-to-have-a-buyout-offer-for-arm/# -
S_x96x_S
uborkaszezon ..
Ha az nVidia felvásárolja az ARM-et ..
akkor az eléggé átrendezi a CPU piac jövőjét ... és az X86 - jövőjét is.
( egyes internetes vélemények szerint ez se az Apple-nek se az AMD-nek nem jó hír ...)
Nvidia expresses interest in SoftBank's chip company Arm Holdings: Bloomberg News
https://www.reuters.com/article/us-arm-holdings-m-a-nvidia-idUSKCN24N2P1 -
S_x96x_S
Petykemano #3593 üzenetére
nem tudom ... én is találgatok magamban ...
viszont találtam már rendelhető APU-kat .. árral ...
és valamiből 2 verzió is van ( MPK =?= dobozos )
https://prohardver.hu/tema/re_teritette_az_amd_az_asztali_ryzen_soc_apu-kat/hsz_29-29.htmlremélem ez alapján csak valami OEM-es szivesség .. és 1 hónapon belül mindenkinek elérhető.
S_x96x_S
az nem jó hír, hogyha csak OEM-eknek ...
persze majd meglátjuk "holnap" ( amikor publikus lesz a hír ) ...
We can now confirm that tomorrow AMD will announce three Ryzen 4000G non-PRO processors.
AMD Ryzen 4000G for pre-built OEM system
https://videocardz.com/newz/amd-to-announce-ryzen-7-4700g-ryzen-5-4600g-and-ryzen-3-4300g-for-oem-systems -
S_x96x_S
Kütyü ... Ryzen Embedded SoCs : EFCO’s “VideoStar100”
+ "SecuBoot security solution. Billed as “the most advanced security available for digital displays,” SecuBoot prevents malicious applications introduced via the Internet or USB devices during the boot process. The algorithm includes BIOS Lock, Device Verification, Storage Checksum, and Whisper Talk features."
"You get 4x 4K-ready DisplayPorts on the dual- or quad-core V1000-based VideoStar100-V and 3x DP on the dual-core R1000-based VideoStar100-R for 4x or 3x simultaneous displays, respectively. In either case, there are dual DDR4 slots for up to 32GB RAM: 3200MHz for the VideoStar100-V and 2400MHz for the VideoStar100-R."
http://linuxgizmos.com/ryzen-embedded-signage-system-offers-secure-boot/
S_x96x_S
nézegetve a német DIY CPU eladási statisztikát
a Ryzen XT procikból nem nagyon lesz tömegtermék ..
( persze lehet, hogy ez még csak tört hét ..az XT -k szempontjából )
pár hét múlva újra ránézek ..
https://twitter.com/TechEpiphany/status/1284800864490848257 -
S_x96x_S
kíváncsi leszek, hogy lesz-e idén az AMD-nek
5nm-es terméke a TSMC-vel gyártva .. [1]
Mindeközben a Samsung küszködik az 5nm-el. [2]Nem könnyű azért ..
[1] "TSMC expects to see 5nm process technology account for about 8% of its total wafer revenue in 2020, compared with the about 10% estimated previously. " ( Friday 17 July 2020 )
( https://www.digitimes.com/news/a20200717PD201.html )[2] Samsung struggling to improve 5nm process yield, say sources https://www.digitimes.com/news/a20200720PD203.html
S_x96x_S
AsrockRack - mini DTX - SP3 ..
( via )
Ultra Compact EPYC7000 Server Board with Dual 10GbE
- CPU Socket SP3 (LGA4094), supports AMD EPYCTM 7002 Series Processors
- Memory Capacity 4DIMM Slots (1DPC); Supports DDR4 R-DIMM up to 3200MHz, 64GB/ LR-DIMM up to 3200MHz, 256GB
- Expansion PCIe slot 1 PCIe4.0 x16
- M.2 1 M-key (PCIe4.0 x4 or SATA 6Gb/s), supports 2280 form factor -
S_x96x_S
ilyen is ritkán van .. AdoredTV hűti a várakozásokat ..
szerinte nem lesz +50% lebegőpontos teljesítmény növekedés a ZEN3-nál ..
az "5.3 petaflops" -alapján visszaszámolva
https://adoredtv.com/confirmed-zen-3-will-not-have-50-higher-floating-point-performance/A tegnapi postja
"EXCLUSIVE: ZEN 3 TO FEATURE OVER 20% HIGHER INTEGER PERFORMANCE THAN ZEN 2, PRODUCTION IN SEPTEMBER"
https://adoredtv.com/exclusive-zen-3-to-feature-over-20-higher-integer-performance-than-zen-2-production-in-september/ -
S_x96x_S
"The Linux Performance For AMD Rome vs. Intel Cascade Lake One Year After Launch"
https://www.phoronix.com/scan.php?page=article&item=rome-cascade-2020&num=1"When taking the geometric mean of all 116 benchmark results, the AMD EPYC 7742 2P with the newer "2020" software stack (Ubuntu 20.10 daily + GCC 10 + Linux 5.8) yielded a 4% improvement to the system performance. The Xeon Platinum 8280 2P saw a 6% improvement with the upgraded software. For these over 100 tests run, the AMD EPYC 7742 2P on the latest Linux software packages yielded 14% better performance over Intel's top-end non-AP Xeon Platinum 8280 dual socket server."
S_x96x_S
Petykemano #3582 üzenetére
Amúgy az STH keresztelte el WEPYC-nek
https://www.servethehome.com/amd-threadripper-pro-is-a-workstation-epyc-or-wepyc/ -
S_x96x_S
WEPYC == AMD Threadripper Pro == Workstation EPYC
S_x96x_S
hivatalos oldal:
AMD Ryzen™ Threadripper™ PRO 3000WX Series Processors
https://www.amd.com/en/processors/ryzen-threadripper-pro+ egy hivatalos video https://www.youtube.com/watch?v=rQj4PJvPFeU
S_x96x_S
"AMD Ryzen 9 3900XT Memory Scaling Performance Under 100 Different Tests"
https://www.phoronix.com/scan.php?page=news_item&px=Ryzen-9-3900XT-DDR4-Memory -
S_x96x_S
STH-s értelmezés:
"Google Cloud Confidential Computing Enabled by AMD EPYC SEV"
https://www.servethehome.com/google-cloud-confidential-computing-enabled-by-amd-epyc-sev/ez a trend eleje ... jönnek majd az Intel-es titkosítások is ..
"Confidential computing is still in its early days. Looking beyond this announcement, we fully expect that this will become more commonplace in public clouds within the next 18-24 months. Beyond AMD’s “Rome” today and the next-gen EPYC 7003 “Milan” chips, we expect Intel to expand SGX functionality and memory encryption in Ice Lake Xeons as they round out the 3rd gen Intel Xeon Scalable lines. There are also non-x86 vendors working in this space. As we see the hardware proliferate to make this possible, we expect confidential computing to be more commonplace. It is great to see Google forging ahead early in the capability lifecycle here."
S_x96x_S
Google’s new Confidential Virtual Machines on 2nd Gen AMD EPYC
"Secure Encryption Virtualization in AMD’s 2nd Gen EPYC processors allows cloud providers to encrypt all the data and memory of a virtual machine at the per-VM level. These are generated on-the-fly in hardware, and are non-exportable, reducing the risk of side attacks by potentially aggressive neighbors. Previously this sort of computing model was only possible if a host assumed control of a whole server, which for most use cases isn’t practical.
With SEV2, technically AMD allows for up to 509 keys per system. Google will offer images for its cVMs with Ubuntu 18.04/20.04, COS v81, and RHEL 8.2; other operating system images will be available in due course."https://www.anandtech.com/show/15909/googles-new-confidential-virtual-machines-on-2nd-gen-amd-epyc
https://cloud.google.com/confidential-computing -
S_x96x_S
Linus ... AVX-512
avagy szépen spanyolul ... : Espero que el AVX-512 tenga una muerte dolorosamásképpen megfogalmazva ... az AVX-512 -ből nem lehet pici chipet csinálni .. nem lehet letranszformálni kis design-ra ... és ez a mobil felhasználást eleve megakadályozza
https://www.realworldtech.com/forum/?threadid=193189&curpostid=193209
the problem with AVX512.
I'd argue that you simply can't put it in a smaller chip. Not while actually making it worth using. It wasn't designed that way.
Some of the AVX512 parts I like: intel did make things more generic with it. I think the masking stuff is new to AVX512, no?. But that's less about the width, and more about cleaning things up and making them more useful in general.
But I think the 512-bit part is a hot mess, and I think ARM potentially did things much better with SVE2. Exactly because hopefully you can have a small and large implementation co-existing, instead of the fragmentation that is the AVX world.
Are there any actual SVE2 chips and users out that validate that point? Not that I know. I haven't really followed it. But I appreciate people trying to do it right. Maybe SVE2 won't work out well, but at least ARM tried.
Not like Intel.
I'll give kudos to Intel when they do things well, and they do do many things well (well, used to, and I'm still hoping to see the old Intel come roaring back, because it's been so depressing lately). But I'll also point out when I think they've screwed up. AVX512 and transactional memory have been bad, I think. They've been bad both from a technical standpoint, but equally importantly from that "fragmenting the market" standpoint.Linus
S_x96x_S
Petykemano #3559 üzenetére
> De miért ne lehetne az AVX512-t, vagy későbbieket olyanná "tenni"
majd valamit az AMD kitalál ...
de amúgy nincs könnyű helyzetben ...
ha meg teljesen új dolgot csinál .. akkor csak a fragmentációt növeli ..én amúgy az AMD helyében az APU-s dolgot erőltetném ...
vagyis az AVX-512 -es utasításokat valami belső fordító áttolja a GPU részre .. és ott hajtódnak végre. persze ez a gyakorlatban nem biztos, hogy optimális ...ami érdekes az Raja - OneApi -ja ... ami automatikusan osztja el a feladatot a cpu és a gpu között ... szerintem ez lehet az Intel "B" terve ... az AVX-512 mellett ...
és ne felejtsük el a fejlesztés alatt álló Centaur Technology -s CNS -core ... ami szintén az AVX-512 -es piacra pályázik ...
> hiszen az SVE2-ben ha jól értem az utasításkészlet megegyezik,
> és a hardver vektorhossz-képességével lehet szegmentálni.
> Az intel meg ezt összekötötteigen .. az én megértésem is hasonló ..
Az ARM kód binárisan ugyanaz ..
mig az X86( Intelnél) ... nem lehet tudni, hogy az 1024 bites utasításoknak mi lesz a kódja ..
a 2048-asokat meg végképp nem .lehet tudni ..
míg az új ARM-es hardvereket rögtön ki tudják használni a szoftverek ..
az új Inteles AVX-1024 -es kódnál ez nem igaz .. . hasonló mint most az AVX-512 ... kevés program használja ki .. kell új fordító támogatás ... stb ...
nehezebb a hibakeresés és a debuggolás is ...--------------------
amúgy ha valaki nem érti az avx-512 fragmentációt annak itt egy ábra .. -
S_x96x_S
Petykemano #3555 üzenetére
> Mármint az ARMos SVE - túl azon, hogy ott dinamikus/változtatható
> a bithossz - mennyiben jobb?
> az SVE-t az armos oldalon istenítik.
ARM-es oldalon nem kell újrafordítani a szoftvert ..
ha 2048 bitesre megírod .. mögötte a hardver lehet 128 vagy akár 2048 bites ..vagyis a következő öt évre a szoftvereket a hardver automatikusan skálázza ... nem lesz olyan mint az X86 -oldalon, hogy mindig újra kell fordítani az AVX-512 ... majd az AVX-1024 .. vagy az AVX-2048 -ra ...
és ez az Apple oldalon nagy előny ...
mert támogatni fogja az SVE2 -öt.lesz egy gyenge mag ... ami 128 bites hardverre fordítja a 2028 bites utasításokat ..
és lesz egy erős mag ... ami 1024 bites hardver ...
és ARM-es oldalon a kettő között egyszerű az átjárás .. szoftveres kompatibilitás megvan ... könnyű hibrid CPU -t összerakni.------------------------------------------
mig most az Inteles oldalon a Hibrid cpu-knál erős és a gyenge mag két külön implementáció hardveresen és szoftveresen .. a gyenge nem tudja az AVX-512 -öt .. emiatt az erősön is le kell tiltani
mivel fontos a homogenitás az utasításkészletben ...
... szívás és hajtépés ....
Ahogy az AT -irta
https://www.anandtech.com/show/15877/intel-hybrid-cpu-lakefield-all-you-need-to-know/5"
The hair-pulling out moment occurs when a processor has two different types of CPU core involved, and there is the potential for each of them to support different instructions or commands. Typically the scheduler makes no guarantee that software will run on any given core, so for example if you had some code written for AVX-512, it would happily run on an AVX-512 enabled core, but cause a critical fault on a core that doesn’t have AVX-512. The core won’t even know it’s an AVX-512 instruction until it comes time to decode it, and just throw an error when that happens. Not only this, but the scheduler has the right to move a thread when it needs to – if it moves a thread in the middle of an instruction stream, that can cause errors too. The processor could also move a thread to prevent thermal hotspots occurring, which will then cause a fault.There could be a situation where the programmer can flag that their code has specific instructions. In a program with unique instructions, there’s very often a check that tries to detect support, in order to say to itself something like ‘AVX512 will work here!’. However, all modern software assumes a homogeneous processor – that all cores will support all of the same instructions.
It becomes a very chicken and egg problem, to a certain degree.
The only way out of this is that both processors in a hybrid CPU have to support the same instructions completely. This means that we end up with the worst of both worlds – only instructions supported by both can be enabled. This is the lowest common denominator of the two, and means that in Lakefield we lose support for AVX-512 on Sunny Cove, but also things like GFNI, ENCLV, and CLDEMOTE in Tremont (Tremont is actually rather progressive in its instruction support)."
S_x96x_S
> Egy pár mondatban összefoglalható, hogy mi az ellenszenv oka?
az én értelmezésem szerint a fragmentáció a legnagyobb problémája
.... a rengeteg AVX-512 variáció
https://en.wikichip.org/wiki/x86/avx-512#Implementation
... aminek nehéz a támogatása ...
meg összehasonlítva az ARM SVE2 -vel .. az AVX-512 .. gányolás...Az ARM-es SV2 bár késői szülés ... de alaposabban átgondolt mint az Inteles rögtönzés - és jobban skálázódik .. mobiltelefontól --- az ARM-es HPC -ig .. egy utasításrendszer ... amit bárhol lehet használni ...
későbbi e-mail -ben jobban kifejtette ...
"Now, that said, do I hate MMX/SSE/AVX/AVX2 with the same burning passion as AVX512? No. Because there's a big difference between them.MMX/SSE was a first-attempt (plus fixes). The i387 was a particularly nasty thing to be compatible with anyway, it's entirely understandable why it was done the way it was done. In hindsight, maybe it could have been done better, but a "in hindsight" argument is always complete BS. So that's not a valid argument. MMX/SSE was fine.
AVX/AVX2 were reasonable cleanups and honestly, I don't think 256 bits is a huge pain even as a baseline. And Intel has been good about keeping AVX always there. Afaik, new CPU's really have gotten AVX reliably. So it hasn't been a fragmentation issue, and while I think it has the same state dirtying issue ("helper function using MMX instructions and saves/restores the instructions it modifies will be clearing upper bits in AVX registers and trashing state"), I think it was a fairly reasonable extension.
So again, AVX/AVX2 was fine. Was it "lovely"? No. But I think it's a reasonable baseline.
So what's different with AVX512?
One fundamental difference is that fragmentation issue. It came up before AVX512 was even out, with the failed multi-core Knights atoms having a completely different versions. But it's really been obvious lately, with even today, in CPU's being sold, it being a "marketing feature".
But the other - and to me really annoying - fundamental issue is "by now, you should have damn well have learnt from your mistakes".
Here, look at the real competition for Intel and x86 long-term: ARM. They had an equally disgusting and horrendously bad FPU situation originally. Yes, their FPU situation was differently bad from the i387, but the whole soft-FP vs VFP vs random other implementations was arguably worse than Intel ever had, even if at the time, you would find the usual ARM fanbois that made excuses for just how horrendous the situation was.
But then ARM got their act together, and NEON happened. I'd say that was roughly the equivalent to SSE, because I'll call the original mess of nasty shit comparable to the nofp/i387/IBM-mis-wiring-the-exception-pin/MMX era. The timing may not line up, but with NEON, ARM at least had gotten rid of their messy lack of standards, and I think it's fair to compare it to Intel and SSE conceptually.
So ARM did SVE, and I'll call that their AVX/AVX2. But now you see signs of differences. Part of it is just the name. "S" for "Scalable". ARM is starting to do something interesting and fundamentally different from what AVX was for Intel.
And then ARM designed SVE2, and again, let's see how it actually plays out in real life, but I think it has the potential to be their "AVX512 done right". And they designed it to have a reasonable downgrade/upgrade path, to be extensible, to do that masking and memory accesses etc that is so important for compilers to auto-parallelize.
Honestly, if I were into HPC and vectorization, I'd be all in on the ARM bandwagon.
As it happens, I'm not into HPC and vectorization, and it's possible that exactly because I'm not into it, I'm missing why SVE2 has some horrible problems. And I realize that AVX512 does some things that a very very very small minority of people care deeply about (I don't know why, but some people really love the shuffle instructions and will put up with absolutely anything if they get them).
So just as a bystander, I'm looking at AVX512, and I'm looking at SVE2, and I'm going "AVX512 really is nasty, isn't it"?
And by now it's the third big generation, and the "it wasn't clear what the right answer was" is no longer an excuse for doing things wrong. People knew that scaling up and down the CPU stack was an issue. This wasn't something where Intel couldn't have seen it coming - when Intel was designing AVX512, Intel was still trying to also enter the smartphone and IoT area.
Have I sufficiently explained why I absolutely despise AVX512?
And yes, maybe in five years, AVX512 is there everywhere and my fragmentation argument goes away.
Buy maybe in five years, SVE2 is everywhere too, and is happily working in cellphones and in supercomputers, and I think I won't be the only person in the room that says "AVX512 is a butt-ugly disgrace".
We'll see, even if it might take years. I'm happy to be proven wrong.
And I'm here for the heated technical discussion anyway. Tell me why I'm a pinhead and a nincompoop, and why SVE2 is so bad, and why AVX512 is clearly better.
Because this forum is about architecture design and implementation, isn't it? So I think it's very fair to put down that gauntlet: AVX512 vs SVE2. "Gong plays" - FIGHT!
Linus"
https://www.realworldtech.com/forum/?threadid=193189&curpostid=193248 -
S_x96x_S
#versenytárs ; #X86 utasítások
Linus Torvalds megátkozta az AVX512-öt.Linus Torvalds: "I Hope AVX512 Dies A Painful Death"
https://www.phoronix.com/scan.php?page=news_item&px=Linus-Torvalds-On-AVX-512"I hope AVX512 dies a painful death, and that Intel starts fixing real problems instead of trying to create magic instructions to then create benchmarks that they can look good on.
I hope Intel gets back to basics: gets their process working again, and concentrate more on regular code that isn't HPC or some other pointless special case.
I've said this before, and I'll say it again: in the heyday of x86, when Intel was laughing all the way to the bank and killing all their competition, absolutely everybody else did better than Intel on FP loads. Intel's FP performance sucked (relatively speaking), and it matter not one iota.....
And AVX512 has real downsides. I'd much rather see that transistor budget used on other things that are much more relevant. Even if it's still FP math (in the GPU, rather than AVX512). Or just give me more cores (with good single-thread performance, but without the garbage like AVX512) like AMD did.
S_x96x_S
AMD Ryzen Threadripper PRO 3000 final specifications leaked
- up 128 PCIe 4.0 lanes
- up to 2TB of UDIMM (Unbuffered DIMM) , RDIMM (Registered DIMM), LRDIMM (Load-Reduced DIMM) and 3DS (three-dimensional stacking) RDIMM EEC memory.
-https://videocardz.com/newz/amd-ryzen-threadripper-pro-3000-final-specifications-leaked -
S_x96x_S
több TRX80 modell várható (12c; 16c; 32c; 64c)
Ryzen Threadripper Pro 3975WX Benchmarks Suggest Impending AMD CPU Launch
https://www.tomshardware.com/news/ryzen-threadripper-pro-3975wx-benchmarks-suggest-impending-amd-cpu-launch
AMD Ryzen Threadripper PRO 3975X 32 Core CPU Spotted, Benchmarks Leak Out – At least Four Workstation Models In The Work
https://wccftech.com/amd-ryzen-threadripper-pro-3975wx-32-core-cpu-specs-benchmarks-leak/AMD Ryzen Threadripper PRO on Lenovo workstation leaks
https://videocardz.com/newz/amd-ryzen-threadripper-pro-3975wx-also-spotted -
S_x96x_S
Petykemano #3545 üzenetére
> A józan ész persze azt mondatja az emberrel,
> .... a 8chTR most kerül a piacra, akkor a zen3 még biztos jó messze van.kivéve, hogyha Lenovo exclusive - mint ahogy pletykálják pár napja ..
( kisebb legelő == kisebb piac ; de a tehenek száma ( Lenovo ) is kevesebb == 1 )
és ha kisszámú is ... azért vannak olyan ügyfelek, akiknek ez megéri már most ..."This is also a major hint as to the availability of the 3995WX. It won't surprise us if the processor will be an OEM-exclusive (if not a Lenovo-exclusive). The Threadripper PRO 3995WX, in addition to the Ryzen PRO feature-set, reportedly features an 8-channel DDR4 memory interface, doubling the memory bandwidth over that of the current retail-channel flagship 3990X."
https://www.techpowerup.com/269665/amd-ryzen-threadripper-pro-3995wx-to-debut-with-a-lenovo-workstationszerintem ez tipikusan az a "prémium" terület,
ahol akár már az új N7/LP12+ -on gyártott kis számú még ZEN-es Rome chipletes procikat ki lehetne nyomni a piacra ...de amúgy nem kell sok ..
- csak re-brandelnek egy High Freq -es 64 magos Epyc chipet ..
egy minden jóval ( hangchip; ) feltunningolt Epyc alaplappal ..most leggyorsabb EPYC: az EPYC 7H12 64c/128t
- Base FREQ 2.6 GHZ
- Max Boost Clock Up to 3.3GHzde a Threadripper™ 3990X ennél is többet tud , csak sajnos 4 csatornás.
- Base Clock 2.9GHz
- Max Boost Clock Up to 4.3GHzvan rá piac ..
Anandtech: " However, there are still markets that want high frequency components, and quite often users will look at consumer hardware, which doesn’t offer the trimmings of the enterprise world, such as ECC memory, RAS features, management, and high-speed IO. We’ve seen OEMs build servers on super rare ‘consumer-grade’ processors, like the auction-only 5 GHz 14-core parts that offer the peak of performance, but fall down on basic enterprise features, such as ECC memory." -
S_x96x_S
Petykemano #3541 üzenetére
> Mit gondolsz, a Ryzen 4000 PRO és a hagyományos asztali verzió együtt rajtol?
nem tudom ...még a Threadripperes WS -t emésztem
... vagy kamu ... vagy sikerült a szivárgást kiküszöbölnie az AMD-nek ..és ha nincs szivárgás ... minden váratlan és meglepő ...
amúgy örülnék neki, ha minél több mindent piacra nyomnának ..
S_x96x_S
Augusztus vége HOT Chips konferencia ..
lesz benne AMD-s előadás is ... "AMD Next Generation 7nm Ryzen 4000 APU"
meg a versenytársak újdonságai .. ( ARM, POWER, Intel ... )
és lesz RISC-V is "Manticore: A 4096-coreRISC-V Chiplet"
S_x96x_S
TB4 + AMD ...
háááát ... semmi se biztos .. megy a pin-pongozás ....
én ezek alapján nem vagyok biztos a támogatásban ...""""
AnandTech: When asked specifically if AMD-Vi meets the requirements for TB4, AMD stated:AMD: If the question is to do we support DMA? The answer is yes. Any questions about if this would satisfy another companies requirements for an interface they are developing would need to be directed at them.
AnandTech: When we asked Intel to confirm if AMD-Vi met the requirements for TB4's DMA protection, we were given the following quote:
INTEL: Thunderbolt is open to non-Intel-based systems. Like any other system, devices must pass Thunderbolt certification and end-to-end testing conducted by third-party labs. Thunderbolt 4 requirements include Intel VT-d based or an equivalent DMA protection technology that provides IO virtualization (often referred to as IO Memory Management Unit or IOMMU), as well as OS implementation support. If the equivalent technology supports prevention against physical attacks, then that should meet the requirement.
"""https://www.anandtech.com/show/15902/intel-thunderbolt-4-update-controllers-and-tiger-lake-in-2020
S_x96x_S
7/7 - Ryzen 3000XT
7/14 - Ryzen Threadripper PRO?
7/21 - Ryzen 4000 Renoir PRO?
7/28- ???????
https://twitter.com/hms1193/status/1280826206770868226 -
S_x96x_S
pletyka ... habár új alaplap kell ehhez és furcsa, hogy semmi alaplapos hír nem szivárgot ki ezzel kapcsolatban ..
AMD Ryzen Threadripper PRO 3995WX spotted, could launch next week
https://videocardz.com/newz/amd-ryzen-threadripper-pro-3995wx-spotted-could-launch-next-week"AMD Threadripper PRO is said to feature 8-channel memory and up to 2TB of capacity. For comparison, consumer Threadripper series are 4-channel only and they support up to 256GB."
S_x96x_S
A google belecsapott a lecsóba ..
és a chiptervezési belépési küszöb megint lejjebb ment130nm-es node-on
az OpenSource-os chipterveket ingyen szilikonba önti ...én rengeteg speciális gyorsító chipet ( chiptervet ) várok ...
ami a következő 10 év architektúráját - és a jelenlegi nagyok monopoliumát is átalakítja ..
Vagyis az Intel, AMD, ARM számára egy lehetőség - és egy veszély isAkit még érdekel a téma :
- HN: https://news.ycombinator.com/item?id=23755693---------------------
"Produce your own physical chips. For free. In the Open."
https://fossi-foundation.org/2020/06/30/skywater-pdk
" you can actually produce chips with the SkyWater foundry in the 130nm node.
That leaves you as chip designer only with one road block: money. Manufacturing chips is expensive – even for more than a decade old nodes like the 130nm node, you need to spend at least a couple thousand dollars.
You know what? Don’t worry – Google and efabless have got you covered! They are providing completely free of cost chip manufacturing runs: one in November this year, and multiple more in 2021. All open source chip designs qualify, no further strings attached!
S_x96x_S
S_x96x_S #3370 üzenetére
Mobil Ryzen 4xxx EU státusz:
https://geizhals.de/?cat=nb&xf=6763_Ryzen+4000
06-11 -én:
Acer (29) ASUS (60) Dell (1) HP (24) Lenovo (22) MSI (3) Schenker (7)most:
Acer (49) ASUS (60) Dell (1) HP (45) Lenovo (32) MSI (4) Schenker (7)----------------------------------------
Ryzen PRO 4000 :
https://geizhals.de/?cat=nb&xf=6763_Ryzen+PRO+4000
csak: Lenovo (6) -
S_x96x_S
"GIGABYTE TRX40 AORUS XTREME REV 1.1"
https://twitter.com/KOMACHI_ENSAKA/status/1280069496565198849amire kíváncsi vagyok,
- hogy lesz -e a TRX40 ( threadripper ) platforma - XT-s refresh ...-----------------------------
válasz magamnak:
valószínüleg kicsi rá az esély ..
főleg addig amíg a 3950 -ből nem lesz XT-s verzió ..folytatva:
- de miért nincs a 3950XT ? vagy csak később lesz ? .. de annak nem sok értelme, mert lassan itt a ZEN3 - az év vége felé ... -
S_x96x_S
pletyka ..
AMD’s Next-Gen 7nm+ Zen 3 Powered EPYC Milan CPU Spotted For The First Time, Up To 2.2 GHz Clocks On Early ES Chip
https://wccftech.com/amd-epyc-milan-zen-3-7nm-cpu-spotted/"AMD Eng Sample: 100-000000114-07_22/15_N"
S_x96x_S
Petykemano #3515 üzenetére
> Ezzel együtt persze érdekelne is, hogy milyen architekturális különbség
> állhat a háttérbenszoftveres oldalról - hogy a 128 thread .. mögött SMT2 vagy SMT4 van annyira nagy különbség nincs ..
- vannak jól párhuzamosítható feladatok ..
- és vannak rosszul párhuzamosítható feladatok,
- és vannak régi - párhuzamosságra nem felkészített - szoftverkódok ..Az új programozási nyelvek - pl. GO - egész új szemléletmódott hozott be - viszonylag egyszerűen implementálva az alkalmazásfejlesztésnél ..
https://divan.dev/posts/go_concurrency_visualize/
ha jól megírom .. ami nem nehéz a csatornákkal ... akkor akár >4096 mag-ig is automatikusan skálázza magát ..a webes feladok nagyrészt jól párhuzamosíthatóak ..
S_x96x_S
joysefke #3516 üzenetére
> Én pld az sem értem, hogy "Az AMD CPU-k jövője, amit tudni vélünk"
> topikban miért az ARM a fő téma, vagy
> hogy egyáltalán hogyan kerül ide az ARM.
versenytárselemzés és iparági trendek.
persze néha illene odatenni pár mondatot - hogy az AMD-nek erre, hogy kellene reagálnia ... ( amit én is elfelejtek néha )de amúgy részben jogos a megjegyzésed
Javaslat: mindenki tegyen pár mondatos kapcsolódást a fő témához IS .. pl. hogy ez-meg az hogy érintheti az AMD-t ..
> Hát például azért mert a kutyát nem érdekli az ARM
> és kb senki sem gondolja, hogy belátható időn belül
> egy két speciális területtől eltekintve alternatívája lehet az x86-nak.
sok Inteles menedzser is - ugyanezt gondolhatta - és kommunikálhatta
de a valóság ~ (ARM szerver erősödés; + Apple más elképzelései )
kezdik lassan felébreszteni őket.Kvázi a 2 fős X86-os duo-polium megvan még, de annyira lement a belépési küszöb CPU fronton, hogy - boldog - boldogtalan CPU-t készít.
A https://www.tachyum.com/ egyik fejlesztőközpontja például Pozsonyban van . https://www.tachyum.com/sk/kariera.shtmlMíg az ARM-es versenytársak pl. a különböző célpiacra - egészen különböző architektúrát fejlesztenek -
az AMD-nek nincs meg ez a luxusa ..
jelenleg csak 1 versenyképes architektúrája van .. és csak a ZEN -core ..
azzal nemtud mindenütt és mindennel versenyezni -
S_x96x_S
újabb a nyomás az ARM-es szerverek oldaláról
... már jönnek a Gigabyte-os ThunderX3 arm-es szerverek,
( 96core-ig ; Arm v8.3+ core , SMT4 , max 384 threads/socket )
https://www.servethehome.com/gigabyte-shows-marvell-thunderx3-r282-2u-server/
viszont a ThunderX3 -ban nincs Arm Scalable Vector Extension (SVE) .. ami a FujitsuA64FX -ben már van ..Egyre több és specializáltabb versenytárs - amelyek mind az Inteles űrt próbálják betölteni ..
persze ettől az AMD-nek kétfrontos technológiai és marketing versenyt kell vivnia ..
"We still have several months until the next x86 server platform launch. In the meantime, expect Gigabyte with its partners such as Marvell to turn up their efforts marketing their new cloud servers. Intel’s 10nm delays have opened the door to a host of new competitors that have AMD EPYC Rome-like features such as 8-channel DDR4-3200 and PCIe Gen4 well before Intel will release Ice Lake Xeon platforms." -
S_x96x_S
pletyka ..
[XFastest/ITCooker] Ryzen 7 4700G Scores 2168 in Cinebench R15, 5102 in Cinebench R20!
https://imgur.com/a/PIqY4iBwccftech: AMD Ryzen 7 4700G Flagship Renoir 8 Core Desktop APU Benchmarked, Matches The Ryzen 7 3800X 95W CPU
https://wccftech.com/amd-ryzen-7-4700g-flagship-renoir-8-core-desktop-apu-benchmarked-matches-95w-ryzen-7-3800x/ -
S_x96x_S
ouch .. A 8 magos Ryzen 7 PRO 4750G -ért 388 EUR ...
az kb 150e Ft körül lesz nálunkés ez a 3900X ára körül van ... az most 407 EUR a mindfactorynál.
persze ez PRO-s .. üzleti - extra biztonsággal felvértezett kivitel ...
a sima mezei consumer kivitel ennél olcsóbb lesz.
Ryzen 7 PRO 4750G 4.40GHZ 8C 12MB 65W
Ryzen 5 PRO 4650G 4.30GHZ 6C 11MB 65W
Ryzen 3 PRO 4350G 4.10GHZ 4C 6MB 65W -
S_x96x_S
SCHENKER VIA 15 Pro
› 15.6" Full HD IPS | 100% sRGB
› max. AMD Ryzen 7 4800H | 2.9 - 4.2 GHz
› AMD Radeon RX Vega 7
› max. 64 GB DDR4 RAM | 3200 MHkonfigurator
- R5 4600H (6c/12t) - helyett R7 4800H (8c/12t) opció +82,86EUR
- augusztusi végétől szállítás. ( "estimated from end of August")
- választható magyar bill! felár nélkül. "Backlit keyboard | Hungarian"
- 500Eur felett az eu-s szállítás ingyenes.
https://bestware.com/en/schenker-via-15-pro.html
érdekes marketing
... ha nem kell a "Schenker" logo , akkor fizess érte: + 28,27 EUR
Azért várjuk meg a teszteket ...
S_x96x_S
S_x96x_S #3488 üzenetére
>> GF 12LP+ ; AMD vajon fogja használni valamire?
> ZEN3 I/O Die ..és mivel
a ZEN2 I/O die -ból csinálták az X570 -es chipsetet ..
akár
a ZEN3 I/O die -ből lehet az X670 -es chipset ( GF 12LP+ )
( mint tartalékterv )azért tartalékterv ... mert ...
(2019Dec) A pletykák szerint külsősök próbálkoznak az új chipset-el."At the end of 2020, AMD Ryzen 4000 processors will be released together with the matching X670 motherboards. The processors are based on the Zen 3 architecture and are said to be the last for the AM4 socket. The X670 chipset is likely not designed by AMD, but another manufacturer like ASMEdia or VIA. X670 is said to provide better support for PCIe 4.0 and increase the connectivity for M.2, SATA and USB 3.2 drives. "
https://www.guru3d.com/news-story/ryzen-4000-and-x670-scheduled-for-late-2020.html -
S_x96x_S
várunk ...
ZEN3 - Techpowerup gyűjtése:
( a ZEN3+AVX512 -ben nem vagyok annyira biztos ...
és inkább november lehet a release ... )
-----------------------------------------------AMD Zen 3
- Release Date: September 2020
- Design completed as of Aug 2019
- Codename: Vermeer (CPU), Dali (APU w/ IGP), Milan (Server), Grey Hawk (Embedded), Genesis Peak (Threadripper)
- Zen 3 refresh, possibly based on improved tech called "Warhol"
- CCX removed, so that all cores on the CCD share a single large L3 cache
- Continues to use Socket AM4 for desktop
- Redesigned chiplets with 32+ MB shared L3 on each chiplet, as opposed to 2x 16 MB shared between CCX groups
- Zen 3 processors are compatible with B450, X470, B550 and X570 motherboards (after BIOS flash)
- Server platform codename "Genesis SP3"
- Up to 64-cores (128-threads) across eight 8-core chiplets
120 - 225 W TDP
- Clock frequencies: 3.8 to 4.0 GHz base, 4.4 to 4.6 GHz boost
PCIe Gen 4
- 8-channel DDR4 memory
- New process tech: 7 nm Plus (probably not 7 nm+ EUV)
- 20% increase in transistor density, 10% lower power consumption
- Up to 15% IPC improvement + more from higher clock frequencies
- Up to 50% faster floating point
- Possibly support for AVX-512
- New CPU corehttps://www.techpowerup.com/review/future-hardware-releases/
S_x96x_S
AnandTEch-es Intel elemzés - benne AMD-s kitenkintések
https://www.anandtech.com/print/15877/intel-hybrid-cpu-lakefield-all-you-need-to-know"One other benefit that a chiplet process can bring is total silicon size of the product. Standard monolithic silicon designs, due to the manufacturing process technologies we use today, have an upper bound of how big a single piece of silicon can be. By implementing chiplets, suddenly that upper limit isn’t much of a concern unless each chiplet reaches that limit - using multiple chiplets can give a total silicon area bigger than a single monolithic chip design. An example of this is AMD’s Rome CPUs, which total an area of over 1000 square millimetres, while the single largest monolithic silicon die is NVIDIA’s A100 GPU, coming in at 826 square millimetres."
"This sort of chiplet based approach also lends people to believe that AMD could swap out a compute based chiplet for a graphics based chiplet, or an AI-focused chiplet, and thus AMD could in the future offer different variants of its products depending on customer requirements for different workloads that the organization might have."
S_x96x_S
S_x96x_S #3466 üzenetére
nucológia ... lassan, de lesz normális ryzen-es választék is ..
A minisforum nuc - eredetileg Ryzen 5 3550H procival jönne,
de tervben van a Ryzen 4000-es verzió is."and that the company has a Ryzen 4000-powered model coming in the future."
Minisforum Details Ryzen 5-Powered Mini PC, Future Ryzen 4000 Model (Update)
https://www.tomshardware.com/news/minisforum-details-ryzen-5-powered-mini-PC-future-ryzen-4000-model -
S_x96x_S
HBM2E SK Hynix - elkezdődött a tömegtermelés ..
( amúgy partneri viszonyban vannak az AMD-vel )Seoul, July 02, 2020 – SK hynix Inc. (or ‘the Company,’ www.skhynix.com) announced that it has started the full-scale mass-production of high-speed DRAM, ‘HBM2E’, only ten months after the Company announced the development of the new product in August last year.
https://videocardz.com/press-release/sk-hynix-announces-mass-production-of-hbm2e-high-speed-dram -
S_x96x_S
(AMX) The x86 Advanced Matrix Extension (wikichip.org)
https://fuse.wikichip.org/news/3600/the-x86-advanced-matrix-extension-amx-brings-matrix-operations-to-debut-with-sapphire-rapids/A HN-on van pár érdekes hozzászólás:
https://news.ycombinator.com/item?id=23688761amit kiemeltek:
- Az Intel/X86 fix szélességű (128,256,512) SIMD megközelítése nem optimális ..
Az ARM,Cray, .. rugalmas megközelítése sokkal praktikusabb.
és az örök dilemma:
- túl sok szilikont igényel ... amit kevés alkalmazás használ ki ... és nem is lehet, tudni, hogy sikeres lesz-e ... ráadásul az AVX512-se egységes ..Ráadásul ez az AMX verzió csak
- az AMX-INT8 és a AMX-BF16 -ot támogatja ... ami behatárolja a használhatóságot. -
S_x96x_S
Petykemano #3489 üzenetére
> És akkor gondolod a Vermeer erre várt?
nem tudom ...
ez már túl erős kijelentés lenne ..- még az se biztos, hogy a Vermeer ezt használja
- vajon a GF részéről ez egy paper launch -e
- mi volt az eredeti GF roadmap-en, amit az AMD-vel kommunikáltak.de nem is zárom ki
... annyira nem lennék meglepve, hogyha kiderülne, hogy mégis 12LP+de most még nincs elég infó.
nem tudom.
S_x96x_S
Petykemano #3486 üzenetére
- 1600AFFFFFF
- ZEN3 I/O Die ???
( A Matisse I/O die 12nm "likely GlobalFoundries 12LP" ) -
S_x96x_S
AMD UEFI Inside: What is really behind AGESA, the PSP (Platform Security Processor) and especially Combo PI?
https://www.igorslab.de/en/inside-amd-bios-what-is-really-hidden-behind-agesa-the-psp-platform-security-processor-and-the-numbers-of-combo-pi/ -
S_x96x_S
> Amit nem értek az pedig az , h a konzol alatt is zen mag fog do
> rombolni azok a fejlesztések miért nem kerülnek át win10be ?
amit érdemes .. az lassan - de biztosan át fog kerülni
jó munkához idő kell ...
A konzolnál csak egy adott konfigurációt - architektúrát kell támogatni .. és arra elég könnyű az optimalizáció ..----
mivel a Microsoft a Ryzen 4000-res procit használja a legújabb Surface-ben ... szerintem további optimalizálások várhatóak ..
https://www.techradar.com/news/the-surface-laptop-4-may-be-rocking-amd-ryzen-4000-silicontürelem ..
( persze én elfogult Linux-os vagyok, de megértem, hogyha valaki Windows-t használ ) -
S_x96x_S
> Intel cpu is ennyire gyenge win alatt ?
privát vélemény
szerintem ez időről-időre változik ... és prociról - procira is.nem lehet túlságosan általánosítani,
tesztelni kell ... mindig ...ahogy érzékelem:
Valamikor a Linux-ra hoznak ki hamarabb egy optimalizációt - valamikor a windowsra .. és ez az Inteles security patch-ek különböző implementációja is más ...
jelenleg: amúgy az szerintem igaz lehet, hogy az idő az AMD-nek dolgozik ..
- egyre jobbak a fordítóprogramok a ZEN architektúra optimalizálásában.
( hatékonyabb kódot generálnak ) - és emiatt egyre gyorsabb lesz ...
( egy év múlva akár +2 ; +3% -al .. )
- Közben az Intel 14nm-es régi architektúráján egyre több security bug-ot fedeznek fel, vagyis idővel egyre lassabb lesz. ( akár -5% -al )-------- egy pár teszt neked ------
A "Core i9 10900K" -nál az Ubuntu 20.04 LTS vs Windows 10 May 2020
nál kevesebb a különbség.
https://www.phoronix.com/scan.php?page=article&item=10900k-windows-linux&num=8az előző évben - az előző évi prociknál az "Intel Core i9 10980XE" - nál a Windows elég jól szerepelt ..
https://www.phoronix.com/scan.php?page=article&item=10980xe-windows-linux&num=7 -
S_x96x_S
"AMD Ryzen 5 4500U Performance On Windows 10 vs. Six Linux Distributions"
https://www.phoronix.com/scan.php?page=article&item=4500u-windows-linux&num=1"The top performing Linux distribution was Ubuntu but followed closely by openSUSE, Manjaro, and Fedora. From the slowest (Windows 10) to fastest (Ubuntu 20.10 + Linux 5.7) was just a 16% difference or just 9% difference among the Linux distributions tested on this Lenovo Flex laptop with Ryzen 5 4500U."
S_x96x_S
kezdenek szivárogni a Thinkpad-es ryzen4000-ek.
A 4700u(8c/8t)-hoz hasonló Inteles Thinkpad verzió (4c/8t;14nm) 100Eur-ral drágább és multi-core-ban sokkal lassabb ..
"The first ThinkPad with Ryzen 4000 has arrived: AMD much faster than Intel"
"The E15 Gen.2 is the first Lenovo ThinkPad with the new AMD Renoir processor in our editorial office. Initial benchmark results show that the Ryzen 7 4700U is sometimes twice as fast as a current Core i7 from Intel. The integrated Vega GPU is also faster than the dedicated RX640 GPU."
https://www.notebookcheck.net/The-first-ThinkPad-with-Ryzen-4000-has-arrived-AMD-much-faster-than-Intel.477477.0.html -
S_x96x_S
közben az Intel új utasítás architektúrájának megjelent a specifikációja ..
( "AMX" a Sapphire Rapids-hoz )- kérdés, hogy ez sikeres lesz-e .. ( elterjed-e a támogatás )
- és mikor fogja implementálni az AMD.INTEL AMX ( Advanced Matrix Extensions )
https://twitter.com/IanCutress/status/1276221811475308544
https://twitter.com/KOMACHI_ENSAKA/status/1276222564809838592 -
S_x96x_S
nuc (killer) Ryzen powered .. https://www.minisforum.com/
https://www.youtube.com/watch?v=NomAkaR6wrU"AMD Ryzen-Powered Mini-PC Has The Potential To Be The NUC Killer"
https://www.tomshardware.com/news/amd-ryzen-powered-mini-pc-has-the-potential-to-be-the-nuc-killer -
S_x96x_S
Petykemano #3464 üzenetére
> Az intel Végülis jó okkal volt kisgömböc
> ... a mindent egybeintegrálunk ....
az Intel lépése racionális volt ... ezen nincs vitaviszont emlékszem még annó a PC korszak kezdetére.
A Klónok háborújára ..
ott volt alattam az Amiga - ( egy jól egybeintegrált ( szoftver + hardver )) ideális hobbi gép ...
és a PC-s klónok innovációban simán lekörözték
( + még kellett hozzá pár hülye döntés a Commodore részéről )
Az Apple viszont integrációban elég jól megy ( vagyis eddig jól ment )
viszont a nyitottabb PC-s és az Andorid-os platform mindig fenyegetni fogja. Elég 1-2 stratégiailag rossz lépés ... ( habár van pénze .. túléli ..)vagyis mindegyikre van pozitiv és negativ példa is ..
nehéz megjósolni a jövőt ...
- ASUS TUF Gaming A620M-Plus + AMD Ryzen 5 8400F + 16GB 5600MHz Kingston Fury Beast + hűtő
- Eladó Erős Gamer PC - Akár Cyberpunk 2077-re Is Készen! (Ryzen 3 2200G RX 570 8GB 32GB RAM AIO
- MacBook Pro 2019 '16 2,6 Ghz 6mag Intel Core i7 16/512gb - Space Gray Touch Bar
- Xiaomi 13T 256GB, Kártyafüggetlen, 1 Év Garanciával
- Honor Magic6 Lite 256GB, Kártyafüggetlen, 1 Év Garanciával
- Bomba ár! Lenovo ThinkPad T580 - i5-8G I 16GB I 256SSD I 15,6" FHD I HDMI I W11 I Cam I Garancia!
- Acer Predator Helios 300 - 17,3"FHD IPS 144Hz - i7-9750H - 256GB SSD+1TB HDD - GTX 1660 Ti - Win11
- Prémium PC házak akár 20-40% kedvezménnyel eladók garanciával, számlával!
- Fujitsu USB Port Replicator PR09 docking station (1x5K vagy 2x4K felbontás) (DisplayLink)
- Bomba ár! Lenovo IdeaPad V110 - i3-6GEN I 4GB I 128GB SSD I 15,6" I HDMI I Cam I W10 I Garancia!
