fLeSs
http://www.rage3d.com/board/showthread.php?t=33773350#post1333060935
The Catalyst 4.9 beta drivers are a sneak peak into future drivers that ATI is continuously working on. They were released mainly for the OpenGL component update, targeting improved Doom3 performance. Having said that, newer generations of hardware will get the most benefit from this driver (X800* series). While I haven't done specific benchmarks, X800 users can see performance increase of 5~30%, depending on the level and the system/hardware type. Regretfully, older hardware, such as 9700's and even 9800's will not get as much benefit. And if paired with a slower system (or with less memory) might see +/- performance improvements.
We are working very hard to get future drivers out that will add quite a bit to the performance of these.
Remember that these are Beta drivers, and so are unsupported. If you want stability and good speed, please stick with the release drivers. Cat 4.8 has not been skipped, and should arrive soon.
- Apple MacBook
- MWC 2026 exkluzív: Bemutatom a Pininfarina mobilt
- Telekom mobilszolgáltatások
- Huawei P30 Pro - teletalálat
- Vállalom Xiaomi Okoskamerák szoftveres javíttását
- ÁRGARANCIA!Épített KomPhone i5 12400F 16/32/64GB RAM RX 9060 XT 8GB GAMER PC termékbeszámítással
- ÁRGARANCIA!Épített KomPhone Ryzen 7 9800X3D 32/64GB RAM RTX 5070 12GB GAMER PC termékbeszámítással
- Acer LED monitor (B247Y)
- BESZÁMÍTÁS! Asus TUF F15 FX506HE FHD notebook - i5 11400H 16GB DDR4 512GB SSD RTX 3050 Ti 4GB WIN11
