Superman
Most nagyon fáradt vagyok már, de ha nem értesz valamit, akkor lefordítom. A részlet a Microsoft oldaláról való:
''The Stop 0x77 message indicates that a page of kernel data requested from the paging (virtual memory) file could not be found or read into memory. This Stop message can also indicate disk hardware failure, disk data corruption, or possible virus infection.
Interpreting the Message
This Stop message has four parameters. The following set of definitions applies only if the first and third parameters are both zero:
This value is 0x00000000 (zero).
Value found in the stack.
Address of signature on kernel stack.
Otherwise, the following definitions apply:
Status code.
I/O status code.
Page file number.
Offset into page file.
Frequently, the cause of this error can be determined from the second parameter, the I/O status code. Some common status codes are:
0xC000009A, or STATUS_INSUFFICIENT_RESOURCES, indicates a lack of nonpaged pool resources.
0xC000009C, or STATUS_DEVICE_DATA_ERROR, generally indicates bad blocks (sectors) on the hard disk.
0xC000009D, or STATUS_DEVICE_NOT_CONNECTED, indicates defective or loose data or power cables, a problem with SCSI termination, or improper controller or hard disk configuration.
0xC000016A, or STATUS_DISK_OPERATION_FAILED, also indicates bad blocks (sectors) on the hard disk.
0xC0000185, or STATUS_IO_DEVICE_ERROR, indicates improper termination, defective storage controller hardware, defective disk cabling, or two devices attempting to use the same system resources.
For information about other possible status codes that can be returned, see the file Ntstatus.h of the Windows XP Professional Driver Development Kit (DDK). For more information about the DDK, see the Driver Development Kits link on the Web Resources page at http://www.microsoft.com/windows/reskits/webresources.
Resolving the Problem
The following suggestions are specific to Stop 0x70 errors. For additional troubleshooting suggestions that apply to all Stop errors, see ''Stop Message Checklist'' later in this appendix.
Stop 0x77 messages can be caused by bad sectors in the virtual memory paging file or a disk controller error. In extremely rare cases, depleted nonpaged pool resources can cause this error. If the first and third parameters are zero, the stack signature in the kernel stack is missing, which is an error typically caused by defective hardware. If the I/O status is 0xC0000185 and the paging file is on a SCSI disk, check for cabling and termination issues. An I/O status code of 0xC000009C or 0xC000016A indicates that the requested data could not be found. You can try to correct this by restarting the computer. If a problem with disk integrity exists, Autochk, a program that attempts to mark bad disk sectors as defective so that they are not used in the future, starts automatically. If Autochk fails to run, you can manually perform the integrity check yourself by following the instructions to run Chkdsk provided in ''Stop 0x00000024 or NTFS_FILE_SYSTEM'' earlier in this appendix. For more information about Autochk and Chkdsk, see ''Troubleshooting Disks and File Systems'' in this book.
Another cause of Stop 0x77 messages is defective, malfunctioning, or failed memory hardware, such as memory modules, Level 2 (L2) SRAM cache, or video adapter RAM. If you added new hardware recently, remove and replace it to determine if it is causing or contributing to the problem. Run diagnostics software supplied by the system manufacturer to determine if the component has failed.
The problem might also be due to cracks, scratched traces, or defective components on the motherboard. If all else fails, take the system motherboard to a repair facility for diagnostic testing.
Problems that cause Stop 0x77 messages can also cause Stop 0x7A messages. For more information about Stop 0x7A messages, see ''Stop 0x0000007A or KERNEL_DATA_INPAGE_ERROR'' later in this appendix.
For more information about Stop 0x77 messages, see the Microsoft Knowledge Base link on the Web Resources page at http://www.microsoft.com/windows/reskits/webresources. Search using keywords winnt, 0x00000077, and 0x77.''
- Hardcore café
- NIOH 3
- AliExpress tapasztalatok
- E-roller topik
- Villanyszerelés
- eBay-es kütyük kis pénzért
- A TCL egyebek mellett egy 1040 Hz-re képes monitorral készül az idei évre
- Gumi és felni topik
- Annyira drága a DRAM, hogy bukta a legjobb konfigurációját a Mac Studio
- Azonnali készpénzes Intel i3 i5 i7 i9 12/13/14 gen processzor felvásárlás személyesen / csomagküldés
- AKCIÓ! CSAK KIBONTOTT Honor 200 Lite 8GB 256GB mobiltelefon garanciával hibátlan működéssel
- LG 77C3 - 77" OLED evo - 4K 120Hz 1ms - NVIDIA G-Sync - FreeSync Premium - HDMI 2.1 - PS5 és Xbox!
- LG 65B4 - 65" OLED - 4K 120Hz 1ms - NVIDIA G-Sync - FreeSync Premium - HDMI 2.1 - PS5 és Xbox Ready
- GYÖNYÖRŰ iPhone 12 128GB Black -1 ÉV GARANCIA - Kártyafüggetlen, MS4567
