  • Bodz
    válasz stemplar07 #65434 üzenetére
    Ezek csak számok, azt igazából nem árulják el, hogy hogyan szól. :) De másolok be én is kupacot, mit tudunk meg belőle? Jól, rosszul szólhat ez alapján?
    XLR
    x Output level switchable +19 dBu, +13 dBu, +7 dBu, +1 dBu @ 0 dBFS
    x Signal to Noise ratio (SNR) @ +7/+13/+19 dBu: 117 dB RMS unweighted, 120 dBA
    x Signal to Noise ratio (SNR) @ +1 dBu: 115,4 dB RMS unweighted, 118,9 dBA
    x Frequency response @ 44.1 kHz, -0.1 dB: 0 Hz – 20.2 kHz
    x Frequency response @ 96 kHz, -0.5 dB: 0 Hz – 44.9 kHz
    x Frequency response @ 192 kHz, -1 dB: 0 Hz – 88 kHz
    x Frequency response @ 384 kHz, -1 dB: 0 Hz – 115 kHz
    x Frequency response @ 768 kHz, -3 dB: 0 Hz – 109 kHz
    x THD @ -1 dBFS: -112 dB, 0.00025 %
    x THD+N @ -1 dBFS: -110 dB, 0.00032 %
    x THD @ -3 dBFS: -116 dB, 0.00016 %
    x Channel separation: > 120 dB
    x Output impedance: 200 Ohm balanced, 100 Ohm unbalanced
    Cinch
    As output XLR, but:
    x Output: 6.3 mm RCA jack, unbalanced
    x Output level 6 dB lower than XLR (-5 dBu to +13 dBu @ 0 dBFS)
    x Signal to Noise ratio (SNR) @ +13 dBu: 117 dB RMS unweighted, 120 dBA
    x Signal to Noise ratio (SNR) @ +1/+7 dBu: 114/116 dB RMS unweighted, 117/119 dBA
    x Signal to Noise ratio (SNR) @ -5 dBu: 109 dB RMS unweighted, 113 dBA
    Phones
    As Cinch, but:
    x Output: 6.3 mm TRS jack, unbalanced, stereo
    x Output impedance: 0.1 Ohm
    x Output level at 0 dBFS, High Power, load 100 Ohm or up: +22 dBu (10 V)
    x Output level at 0 dBFS, Low Power, load 8 Ohm or up: +7 dBu (1.73 V)
    x Signal to Noise ratio (SNR) @ +22 dBu: 117 dB RMS unweighted, 120 dBA
    x Signal to Noise ratio (SNR) @ +7 dBu: 116 dB RMS unweighted, 119 dBA
    x THD @ +18 dBu, 32 Ohm load, 1.2 Watt: -110 dB, 0.0003 %
    x THD+N @ + 18 dBu, 32 Ohm load: -107 dB, 0.00045 %
    x THD @ +14 dBu, 16 Ohm load, 0.94 Watt: -110 dB, 0.0003 %
    x Max power @ 0.001% THD: 1.5 W per channel
    IEM
    As Phones, but:
    x Output level at 0 dBFS: -3 dBu, 0.55 V
    x Signal to Noise ratio (SNR) @ -3 dBu: 115 dB RMS unweighted, 118 dBA
    x Max power, 8 Ohm, 0.001% THD: 40 mW per channel
