ubyegon2 #89556 üzenetére
Szerintem még vagy Linux, vagy Winf0s alatt frissítettem a firmwaret a Samsung Magiciannal. Linux alatt is lehet firmwaret frissíteni fwupdmgr-rel.
A Trimről nekem egyedül a hajvágó gépek szakállvágó funkciója jut eszembe, más nem, pedig SSD-kkel kapcsolatban is sokat hallottam már.
Szerintem ha azt kihagyom, nem lesz nagy gond.
ubyegon2 #89548 üzenetére
sudo smartctl -x /dev/nvme1n1
smartctl 7.3 2022-02-28 r5338 [x86_64-linux-6.2.12-1-default] (SUSE RPM)
Copyright (C) 2002-22, Bruce Allen, Christian Franke, www.smartmontools.org
=== START OF INFORMATION SECTION ===
Model Number: Samsung SSD 980 500GB
Serial Number:
Firmware Version: 3B4QFXO7
PCI Vendor/Subsystem ID: 0x144d
IEEE OUI Identifier: 0x002538
Total NVM Capacity: 500.107.862.016 [500 GB]
Unallocated NVM Capacity: 0
Controller ID: 5
NVMe Version: 1.4
Number of Namespaces: 1
Namespace 1 Size/Capacity: 500.107.862.016 [500 GB]
Namespace 1 Utilization: 92.089.303.040 [92,0 GB]
Namespace 1 Formatted LBA Size: 512
Namespace 1 IEEE EUI-64: 002538 d321d60121
Local Time is: Sat Apr 29 14:23:17 2023 CEST
Firmware Updates (0x16): 3 Slots, no Reset required
Optional Admin Commands (0x0017): Security Format Frmw_DL Self_Test
Optional NVM Commands (0x0055): Comp DS_Mngmt Sav/Sel_Feat Timestmp
Log Page Attributes (0x0f): S/H_per_NS Cmd_Eff_Lg Ext_Get_Lg Telmtry_Lg
Maximum Data Transfer Size: 512 Pages
Warning Comp. Temp. Threshold: 82 Celsius
Critical Comp. Temp. Threshold: 85 Celsius
Namespace 1 Features (0x10): NP_Fields
Supported Power States
St Op Max Active Idle RL RT WL WT Ent_Lat Ex_Lat
0 + 5.24W - - 0 0 0 0 0 0
1 + 4.49W - - 1 1 1 1 0 0
2 + 2.19W - - 2 2 2 2 0 500
3 - 0.0500W - - 3 3 3 3 210 1200
4 - 0.0050W - - 4 4 4 4 1000 9000
Supported LBA Sizes (NSID 0x1)
Id Fmt Data Metadt Rel_Perf
0 + 512 0 0
=== START OF SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
SMART/Health Information (NVMe Log 0x02)
Critical Warning: 0x00
Temperature: 37 Celsius
Available Spare: 100%
Available Spare Threshold: 10%
Percentage Used: 0%
Data Units Read: 5.450.812 [2,79 TB]
Data Units Written: 6.656.503 [3,40 TB]
Host Read Commands: 60.127.369
Host Write Commands: 89.006.613
Controller Busy Time: 97
Power Cycles: 529
Power On Hours: 661
Unsafe Shutdowns: 63
Media and Data Integrity Errors: 0
Error Information Log Entries: 0
Warning Comp. Temperature Time: 0
Critical Comp. Temperature Time: 0
Temperature Sensor 1: 37 Celsius
Temperature Sensor 2: 42 Celsius
Error Information (NVMe Log 0x01, 16 of 64 entries)
No Errors Logged
ubyegon2 #89348 üzenetére
Drága jó Uby ki antiuefis.
Pendrájvról udtam telepíteni ezt a Endaeoizét, sajnos ventoyt nem szereti.
A telepítést követően semmit, ismétlem semmit se mókoltam se grubba se efibe se semmibe csak reboot amit a telepítő fel is ajánl (Kalamares installja van).
Itt a UEFI választómenü:
Itt az Endaeoizé grubmenüje, Ubuntu undora van az szentigaz de a Windowst felvette a grub válaszómenübe:
És itt van vajsimán.
Itt az EFI partíció, betette magát, se Ubit se Windowst nem bántott, mindhárom OS indítója békésen elfér az efibe.
Hogyan képes elindulni lila gőzöm sincs mert az efibe neki nincsen grub.cfg ami megmutatja hogyan tovább.
Érdekes.
De működik.
Vagyis ha én most ezt MBR telepítéssel csinálom ugyanúgy felülök a szopórollerre mint a kolléga, uefibe meg minden flottul választható és megy.
gigabytman
ubyegon2 #89359 üzenetére
Az SGX-et nem kapcsoljuk be, mert szétüti a BIOS-t. Konkrétan még a reset gomb sem hozza vissza. PC szétbont gombelem ki / vissza, most már elérhető a BIOS a windowsba is be tud boot-tolni. Beléptem az "e" betüvel, így néz ki:
A "quiet s\plash -- "szavak közé kellene beszerkeszteni? Hova is hogyan? Bocsi én kezdő vagyok, ilyet nem csináltam.
Elindul a linux újratelepítés nélkül is, de hibával:A 4096 nem lehet hogy a VGA dedikált memóriája, mert pont ennyi volt az Nvidia kártyán amit kiszedtem?
-szabi-
ubyegon2 #89344 üzenetére
Rendben ezt a parancsot nem fogom használni.
Nemo fájlkezelőben én a felső menüsorban kerestem admin módot.
Nekem nano helyett sokkal szimpibb xed.
Nem tudom nálam ZFS van e.
#89346 tordaitibi
Nem emlékszem ilyen lehetőségre, hogy GRUB telepítés sehová, de következő alkalommal figyelni fogok.
Régi gép 13-14 éves alaplap, megnéztem a bios-t de nincs efi mód.EndeavourOS is Arch alapú. Azután raktam fel, hogy Manjaro elromlott.
Eddig arra hajlok, hogy visszateszem OpenSuse-t.#89349 csixy
Én még wines ssd-t le is húztam nehogy belemókoljon annak bootjába. -
-szabi-
ubyegon2 #89336 üzenetére
#89331 csixy írta:
"vagy az utolsó sor helyett Linux Mintben jó a:sudo update-grub
parancs is."
Ezért azt használtam.Nálam van
GRUB_DISABLE_OS_PROBER
sor a Mint GRUB-jában.sudo nano etc/default/grub
Ez nem működött de a neten találtam ilyet:xed admin:///etc/default/grub
Ezzel tudtam szerkeszteni átállítottam false-ra.Újra lefuttattam ezeket
sudo grub-install /dev/sda
sudo grub-install --recheck /dev/sda
sudo grub-mkconfig -o /boot/grub/grub.cfg
Az utolsó parancs lefutásakor ezt kaptam:
device-mapper: remove ioctl on osprober-linux-sda2 failed: Az eszköz vagy erőforrás foglalt
Command failed.
/usr/sbin/grub-probe: hiba: ismeretlen fájlrendszer.
Megtalált EndeavourOS Linux (rolling) ezen: /dev/sda2
kész
Azért újraindítottam de továbbra sincs Mint boot menü választható OS-el.
-szabi-
ubyegon2 #89326 üzenetére
Közben keresgéltem a Mint particióján és EndevaourOS-el ellentétben 11 találatot listáz 2 update-grub fájlra. (ezt nem értem miért így csinálja a kereső)
sudo: /run/media/szabi/Mint/usr/sbin/update-grub
sudo: /run/media/szabi/Mint/usr/lib/grub-legacy/update-grub
Azonban hiába próbálom bármelyiket az útvonal megadásával futtatni parancs nem található a válasz, pedig a fájlok ott vannak. -
-szabi-
ubyegon2 #89310 üzenetére
Ezt tudtam futtatni:
sudo mount /dev/sda1 /mnt && sudo mount --bind /dev /mnt/dev && sudo mount --bind /dev/pts /mnt/dev/pts && sudo mount --bind /proc /mnt/proc && sudo mount --bind /sys /mnt/sys && sudo chroot /mnt
A másodikkal viszont már kínlódni kellett:grub-install /dev/sda && update-grub
Először nem találta a parancsot pedig a bin könyvtárban ott volt.
Többszöri próba után már lefutott de akkor megupdate-grub
nem volt jó.
Így továbbra sincs Mint a boot menüben.Egyébként a problémámon felül, ez az EndeavourOS nem igazán tetszik.
Egyáltalán nem felhasználó barát.
Nem találom vagy nincs benne lemezkezelő miközben telepítéskor még volt.
A telepítés utáni kezdőképernyőn frissíteni lehet a csomagszervereket, de nincs csomagkezelő sem.
Ennél még Manjaro is barátságosabb volt amíg működött. -
Ezért nem kell telepíteni.
ha elmenti az EFI ubuntu bejegyzést és utána visszamásolja, én véleményem szerint megjelenik a választómanübe.
Vagy, töltse le a [Supergsubdisk] nevű segéd isot, penre kiíír, abba a manuális boot, utána a kézi OS indítás. Rákkattint a Mint legurolsó kernelére a listába és már röffen is a Mintje.chroot ellen-helyett óriási találmány, és az egész os indul nem terminálba felcsatolt mappákkal kell bűvészkedni.
Épp ma használtam havernál, kisséelkefélte a Mintje bootját a szerencsétlen és csak egy sudo update-grub kellett.
CPT.Pirk
ubyegon2 #89208 üzenetére
Brománcotok további építésére javaslom a Linuxos OFF topicot.
ubyegon2 #89206 üzenetére
Felesleges, ha kellemetlenül érzed magad, ugyanis egy internetes fórumon általában nem úgy társalognak az emberek egymással mint a való életben. Ezzel arra utalok, hogy itt gyakran félreértjük, hogy a másik mire gondol és sokszor én sem úgy szoktam reagálni, ahogy normális lenne. Az emberi agy nem ehhez van hozzászokva, mert tudniillik a kommunikáció két ember között nem szöveges üzenetek küldözgetése, hanem durván ~60%-a nonverbális dolgokból tevődik össze, ami egy fórumon ugye kiesik. Az emojik meg a normális érzéseket nem pótolják és lehet velük csalni is.
ubyegon2 #89199 üzenetére
Jajj Uby túldramatizálod.
A boot sebessége téma elkanyarodott másfelé és én arra reagáltam.
Különben meg ami nagyon keveset tudok a 2 rendszerről, annak kb. 70%-át itt PH-n szedtem magamra és a múltbéli csatározásoknak is ebben oroszlánrésze volt, mégha akkoriba a stílus néha kivetnivalót is hagyott maga után.
Átvitt értelemben és valóságosan is Uborka Egonnak is köszönhetem hogy a koszon kívül valami rámragadt Linux vonalon.
Na most már azért jobban alszol -
ubyegon2 #89185 üzenetére
Uby ez nem Thinkbook vagy bármi egyedi sajátosság hanem egy a gépen futó OS beépített funkciója aminek minden gépen működnie kell.
Mintahogy a safe menübe a uefibe rebootnak, a parancsorba indításnak VGA alapfelbontással rebootnak stb.stb.
Ez kb. hasonló a Linux reco és kernelválasztó modehez. Az is működik minden gépen mert nem gép hanem osfüggő feature.
Természetesen szerényen fejet hajtok a Te tudásod előtt és neked még ezt is elhiszem -
urandom0
ubyegon2 #89184 üzenetére
Nézd, az a baj, hogy össze-vissza keversz mindenfélét.
A fast startup a Windows 8 óta létezik. Azért ha valaki az átlagfelhasználónál komolyabb szinten ért a PC-khez, akkor elvárható lenne, hogy tudja 1) hogy kell kikapcsolni a gyorsindítást 2) hogy kell úgy újraindítani úgy a gépet, hogy bedobja safe módba, hogy ezt a képernyőt kapd.Te most pontosan azt csinálod, mint amikor jön a Windows-os csávó, és megmagyarázza, hogy "a linux szar mert letöltöttem egy exe fájlt és nem futtatja le!!!!". Te most pont ezt adod elő, csak Linuxos oldalról.
ubyegon2 #89170 üzenetére
"Amikor Windows a jelentkezne be akkor a bekapcsoló gombot legalább 6 másodpercig. Amikor kikapcsolt akkor utána kapcsold be és a F12 a boot menü."
Nem, ez a rosszabb megoldás egy épp bootoló OS lába alól kirántani a talajt. Valamint ez, a hiányzó F8 safe menü csak 5 ilyen próbálkozásra jön be.
Ráviszed az egeret a Start-kikapcsolás és nyomva tartott SHIFT bill. mellett rákkattintva leállítod.
Ilyenkor teljes normál leállás van.Totron #89171
Egyszer az életbe bootold be a Windowst és a fennti módon állítsd le.
Megszűnik a problémád.
Hogy ez miért van az 5223x le lett írva, a Fast startup, Gyorsindítás amitől tényleg gyorsan áll fel a Win az gyakorlatilag egy félhibernálás állapot.
Vagyis valaki valahol valamikor 3-4-10 évvel ezelőtt így állította le a Windowst, az egész lemez, a leírók stb. az jelenleg is a Windows tulajdonában van, pont úgy mintha épp futna az oprendszer.
Teljesen érthető hogy nem tudsz semmivel a lemezre írni hisz egy élő OS fut rajta éppen mégha hibernálva is van.Vagy ami esetleg segíthet ha nem tudod bebootolni, bár elindul akár USB csatiról is,
lefuttatsz a teljes lemezen egy checkdisket, chkdsk. Ez csak másik Win alól lehetséges és ez is helyre tudja tenni a foglalt leírókat ha szerencséd van. Ha nincs akkor sajnos a 'Lemez foglalt' hibával marad az első megoldás.Próbáld ki fordítva, hibernálj egy Linuxot és próbálj kívülről írni a csatolt fájlrendszereire.
Ugyanez lesz, csak Szarawindows helyett Szaralinugz reakció.
Pedig nem nem szar hanem 101%-os tudatlanság azaz user error.Ugyanebbe futnak bele kismillióan amikor egy faststartupos Win mellé az Istennek nem lehet Linuxot telepíteni, persze hogy nem.
Meg lehet erőszakolni csak nem jó út. -
urandom0
Olyan hülyeségeket írkálsz néha, ne is haragudj.
nem tudom egyszerűen kikapcsolni, csak valami spéci módszerrel
Nem találod meg a Start menüben a leállítást, vagy mi?minden indítást egy előtöltött állapotból hajt végre... egyszerű user hagyományos módon nem tudja kikapcsolni/rebootolni
Fast startupnak hívják (gyorsindítás), az egyszerű user a Vezérlőpultból két kattintással ki tudja kapcsolni.
totron
ubyegon2 #89172 üzenetére
Gyakorlatilag van egy tároló meghajtód, amin csak Wint tárolsz és nem írható?
Miért akarnék túlmutatni a mindenkori népigényen? Hát ki vagyok én?Tévére való tartalmak vannak rajta és a lejátszó nem tudja írni, gépen megy a dolog azért.
Ez egy linuxos lejátszó és ki van adva az írásjog alapból, de így az nem érvényesül.
De nem ez az a dolog, amit a Win csinál a tárolóval, ha be van kapcsolva a fastboot opció?
De-de, pontosan, ez a legfőbb gyanúm. Majd ha UEFI-s gép közelébe kerülök ki is kapcsolom a fastbootot. Jók az ilyen meglepetések egyébként, masszírozza az elmét és biztosan tanulsz is belőlük.(#89178) gregory91, HDD-k esetén szempont lehetett, de ott is inkább elméleti csak.
totron
fatpingvin
ubyegon2 #89162 üzenetére
most minek kerülgessem a kását. a Debian tök jó disztró (bár mostanában már van pár olyan irányvonal ami nekem annyira nem szimpi de ez egy másik nóta) de minimálisan kell hozzá érteni, abban az értelemben hogy képben vagy a teljes felépítésével, nem csak azzal hogy hogyan működik az apt.
ubyegon2 #89140 üzenetére
Előbb csak poen volt, hogy Cinnamon ajánlott, Archklónokhoz inkább Plasma fekszik, mondjuk minap kíváncsiságból épp Cinnamonnal próbáltam meg öreg notebookon...annyira azért nem is rossz a boot ideje.
[ubyegon@endev-hpelitebook8570p ~]$ systemd-analyze
Startup finished in 2.610s (kernel) + 1.426s (initrd) + 3.756s (userspace) = 7.793s
graphical.target reached after 2.723s in userspace.
[ubyegon@endev-hpelitebook8570p ~]$ inxi -Fxx
System:
Host: endev-hpelitebook8570p Kernel: 6.2.9-zen1-1-zen arch: x86_64 bits: 64
compiler: gcc v: 12.2.1 Desktop: Cinnamon v: 5.6.8 tk: GTK v: 3.24.37
dm: LightDM Distro: EndeavourOS base: Arch Linux
Machine:
Type: Laptop System: Hewlett-Packard product: HP EliteBook 8570p
v: A1029D1102 serial: <superuser required> Chassis: type: 10
Mobo: Hewlett-Packard model: 17A7 v: KBC Version 42.38
serial: <superuser required> BIOS: Hewlett-Packard v: 68ICF Ver. F.62
date: 04/07/2015
Battery:
ID-1: BAT0 charge: 35.6 Wh (95.7%) condition: 37.2/37.2 Wh (100.0%)
volts: 12.2 min: 10.8 model: Hewlett-Packard Primary
serial: 33254 2013/03/12 status: not charging
CPU:
Info: dual core model: Intel Core i7-3520M bits: 64 type: MT MCP
arch: Ivy Bridge rev: 9 cache: L1: 128 KiB L2: 512 KiB L3: 4 MiB -
csixy
growler
ubyegon2 #89032 üzenetére
A legelso EFI-s kiserleti telepitesemet (Ubuntu 19.10) - emlekeim szerint -
igy csinaltam:
- Inditottam a live telepiton a GParted -et.
- gpt-s particios tablat hoztam letre az eszkozon. (kis meretu SSD)
- 300 MB Fat32 particio boot+esp jelolovel
- 25-30 GB Ext4 particio
- A maradek Ext4 ... (Nem csinaltam SWAP particiot)- Bezartam a GParted-et, es inditottam a telepitest.
- A telepitovel csak az elokeszitett particiok csatolasi pontjat adtam meg.
- 300 MB -> /boot/efi csatolasi pont
- 25 GB -> / csat. pont
- A tobbi -> /home csat. pontA telepitesi procedura befejezeset kovetoen indult az Ubuntu 19.10.
csixy
Ha GPT-s partíciós sémád van, akkor ugye nincs MBR a lemezeden. Az UEFI működéshez az EFI System Partícióba írogat a grub és onnan bootol az UEFI-s rendszered. De, ha ragaszkodsz a Legacy működéshez, akkor a grub be tudja írni azt a pár körömpiszoknyi infóját abba az 1MiB-es partíciócskába és az helyettesíti a Master Boot Recordot , nyugodtan titulálhatod /dev/sda-nak, vagy esetedben /dev/nvme0n1-nek. Formázatlan partíciónak szoktuk partícionálni, de mindegy is neki, mert teljesen belefészkeli magát a grub2 core.img és Ő viselkedik úgy mint a Master Boot Record. Ennek a partíciócskának van egy bios_grub jelölője, avagy zászlója. Ilyentet csak a linux tud , a windows nem tudja használni. Tartozik hozzá még néhány huncutság, ha a GPT lemezedet UEFI módra használod többnyire, de olykor Legacy módra is akarod használni (ennek akkor van értelme, ha a külsős adathordozódra telepített linuxodat néha kénytelen vagy Legacy vagy őskori MBR-es vasban bebootolni). Ennek szemléltetéséhez átbútolok linuxba. Na csá. Majd még írok.
Crvsh3R
ubyegon2 #88905 üzenetére
Ez a TRIM-es megoldás számomra zsákutcának tűnik (ami úgy tűnt számomra először, hogy működik), megint ugyanaz a gond és most a TRIM sem segít:
- PI SSD-ről PI HDD-re: belassul pár másodperc után szinte 0-ra az átvitel
- SSD-ről asztali PC-re (SAMBA-n keresztül) és onnan a PI HDD-re: normális sebességgel megy a másolás végig
- PI HDD-ről PI SSD-re: normál sebességgel megy a másolás
Teljesen tanácstalan vagyok. Ha haldoklana az SSD, akkor gondolom a többi esetben is gond lenne, de csak ha helyileg másolok (PI-n belül) az SSD-ről a HDD-re, akkor jön elő a gond és ez korábban nem volt. Annyit néztem még htop-ban, hogy ilyenkor a másolást végző process 100%-on pörgeti a procit. -
Crvsh3R
ubyegon2 #88904 üzenetére
Köszi az észrevételeke! Overprovisioning nincs beállítva (a másolás pillanatában 100+GB szabad hely volt rajta), ez egy 1TB-os meghajtó, WD Red SA500 NAS SATA SSD M.2 2280.
A kimenete a parancsnak:
smartctl 7.2 2020-12-30 r5155 [aarch64-linux-6.1.19-v8+] (local build)
Copyright (C) 2002-20, Bruce Allen, Christian Franke, www.smartmontools.org
Model Family: WD Blue / Red / Green SSDs
Device Model: WDC WDS100T1R0B-68A4Z0
Serial Number: XXX
LU WWN Device Id: 5 001b44 8b128ad43
Firmware Version: 411000WR
User Capacity: 1,000,204,886,016 bytes [1.00 TB]
Sector Size: 512 bytes logical/physical
Rotation Rate: Solid State Device
Form Factor: M.2
TRIM Command: Available, deterministic, zeroed
Device is: In smartctl database [for details use: -P show]
ATA Version is: ACS-4 T13/BSR INCITS 529 revision 5
SATA Version is: SATA 3.3, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Sun Mar 26 10:29:32 2023 CEST
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
AAM feature is: Unavailable
APM level is: 254 (maximum performance)
Rd look-ahead is: Enabled
Write cache is: Enabled
DSN feature is: Unavailable
ATA Security is: Disabled, NOT FROZEN [SEC1]
Wt Cache Reorder: Unavailable
=== START OF READ SMART DATA SECTION ===
General SMART Values:
Offline data collection status: (0x00) Offline data collection activity
was never started.
Auto Offline Data Collection: Disabled.
Self-test execution status: ( 0) The previous self-test routine completed
without error or no self-test has ever
been run.
Total time to complete Offline
data collection: ( 0) seconds.
capabilities: (0x11) SMART execute Offline immediate.
No Auto Offline data collection support.
Suspend Offline collection upon new
command.
No Offline surface scan supported.
Self-test supported.
No Conveyance Self-test supported.
No Selective Self-test supported.
SMART capabilities: (0x0003) Saves SMART data before entering
power-saving mode.
Supports SMART auto save timer.
Error logging capability: (0x01) Error logging supported.
General Purpose Logging supported.
Short self-test routine
recommended polling time: ( 2) minutes.
Extended self-test routine
recommended polling time: ( 10) minutes.
SMART Attributes Data Structure revision number: 4
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME FLAGS VALUE WORST THRESH FAIL RAW_VALUE
5 Reallocated_Sector_Ct -O--CK 100 100 --- - 0
9 Power_On_Hours -O--CK 100 100 --- - 12804
12 Power_Cycle_Count -O--CK 100 100 --- - 337
165 Block_Erase_Count -O--CK 100 100 --- - 53084803
166 Minimum_PE_Cycles_TLC -O--CK 100 100 --- - 2
167 Max_Bad_Blocks_per_Die -O--CK 100 100 --- - 180
168 Maximum_PE_Cycles_TLC -O--CK 100 100 --- - 28
169 Total_Bad_Blocks -O--CK 100 100 --- - 632
170 Grown_Bad_Blocks -O--CK 100 100 --- - 0
171 Program_Fail_Count -O--CK 100 100 --- - 0
172 Erase_Fail_Count -O--CK 100 100 --- - 0
173 Average_PE_Cycles_TLC -O--CK 100 100 --- - 9
174 Unexpected_Power_Loss -O--CK 100 100 --- - 40
184 End-to-End_Error -O--CK 100 100 --- - 0
187 Reported_Uncorrect -O--CK 100 100 --- - 0
188 Command_Timeout -O--CK 100 100 --- - 0
194 Temperature_Celsius -O---K 056 074 --- - 44 (Min/Max 24/74)
199 UDMA_CRC_Error_Count -O--CK 100 100 --- - 0
230 Media_Wearout_Indicator -O--CK 001 001 --- - 0x0062005a0062
232 Available_Reservd_Space PO--CK 100 100 004 - 100
233 NAND_GB_Written_TLC -O--CK 100 100 --- - 9604
234 NAND_GB_Written_SLC -O--CK 100 100 --- - 10046
241 Host_Writes_GiB ----CK 253 253 --- - 9703
242 Host_Reads_GiB ----CK 253 253 --- - 334267
244 Temp_Throttle_Status -O--CK 000 100 --- - 0
||||||_ K auto-keep
|||||__ C event count
||||___ R error rate
|||____ S speed/performance
||_____ O updated online
|______ P prefailure warning
General Purpose Log Directory Version 1
SMART Log Directory Version 1 [multi-sector log support]
Address Access R/W Size Description
0x00 GPL,SL R/O 1 Log Directory
0x01 SL R/O 1 Summary SMART error log
0x02 SL R/O 2 Comprehensive SMART error log
0x03 GPL R/O 1 Ext. Comprehensive SMART error log
0x04 GPL,SL R/O 8 Device Statistics log
0x06 SL R/O 1 SMART self-test log
0x07 GPL R/O 1 Extended self-test log
0x10 GPL R/O 1 NCQ Command Error log
0x11 GPL R/O 1 SATA Phy Event Counters log
0x24 GPL R/O 1957 Current Device Internal Status Data log
0x25 GPL R/O 1957 Saved Device Internal Status Data log
0x30 GPL,SL R/O 9 IDENTIFY DEVICE data log
0x80-0x9f GPL,SL R/W 16 Host vendor specific log
0xde GPL VS 8 Device vendor specific log
SMART Extended Comprehensive Error Log Version: 1 (1 sectors)
No Errors Logged
SMART Extended Self-test Log Version: 1 (1 sectors)
Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error
# 1 Short offline Completed without error 00% 12668 -
# 2 Short offline Completed without error 00% 6915 -
Selective Self-tests/Logging not supported
SCT Commands not supported
Device Statistics (GP Log 0x04)
Page Offset Size Value Flags Description
0x01 ===== = = === == General Statistics (rev 1) ==
0x01 0x008 4 337 --- Lifetime Power-On Resets
0x01 0x010 4 12804 --- Power-on Hours
0x01 0x018 6 20348761502 --- Logical Sectors Written
0x01 0x020 6 31058800 --- Number of Write Commands
0x01 0x028 6 701009799064 --- Logical Sectors Read
0x01 0x030 6 82441973566 --- Number of Read Commands
0x07 ===== = = === == Solid State Device Statistics (rev 1) ==
0x07 0x008 1 0 N-- Percentage Used Endurance Indicator
|||_ C monitored condition met
||__ D supports DSN
|___ N normalized value
Pending Defects log (GP Log 0x0c) not supported
SATA Phy Event Counters (GP Log 0x11)
ID Size Value Description
0x0001 4 0 Command failed due to ICRC error
0x0002 4 0 R_ERR response for data FIS
0x0005 4 0 R_ERR response for non-data FIS
0x000a 4 1 Device-to-host register FISes sent due to a COMRESET
Néha le szoktam futtatni, rövid SMART teszt nem mutatott hibát. Elméletben 600TBW-s a meghajtó, annak még a közelében sincs. -
Az online(azonnali) discard TRIM és az ütemezett fstrim teljesen jól elvan egymás mellett. A discard paramétert akkor nem célszerű használni, ha nagy fájlokkal zajló I/O műveletek történnek, mert abba belekvarhat és lassulást okoz időlegesen. Emiatt tiltják az NVME SSD-nél is, mert alapból ez a nagy fájlokkal és gyors másolással operál.
A noatime opció azért jó, mert minden fájlművelethez így nem fűz naplóbejegyzést, ami által gyorsul az I/O művelet.
De ha elég szabad helyed van, akkor az is bőven elegendő ha pár hetente lefuttatod a manual TRIM parancsot, pár napja olvastam, hogy a relatív nagy overprovisioning mellett akár szükségtelenné válhat a TRIM. Gondolom emiatt van az, hogy a gyártó 7-28% overprovisioning-et javasol, a consumer SSD-nél 7%-ot alkalmaznak gyárilag, a professional meghajtóknál viszont 28%-ot. (már amelyik alkalmazza mindkettőt)
Ezeket találtam régebbi hsz-ekben, de egyébként ha nem akarsz online TRIM-et(discard), akkor beállíthatod napi ütemezett lefutásra is az fstrim-et, itt egy mód erre:
Rimuru
Rimuru
ubyegon2 #88700 üzenetére
Amugy a forditott mukodest arra mondom hogy a nagyobb betumeret miatt novekedhed pl egy panel merete (es lehet hogy a benne levo tobbi elem is) mert nem ferni ki a nagyobb betu igy tunhet annak, hogy az egesz skalazodik.
De ha senki nem próbálja ki, amit írok - de natë nem ezt kereste.
Rimuru
ubyegon2 #88698 üzenetére
Ez asztali elemeket nagyít, azon belül nyilván nagyobb lesz a látható betűméret is - szerintem inkabb forditva mukodik.
Eleg specifikus dolgot mutattal "Betutipus beallitasok / szovegmeretezes"... majd nezd meg Cinnamon alatt a display beallitasokat (gondolom) ott lesz az amirol szo van.
ubyegon2 #88033 üzenetére
Az számít a KdiskMarknak, hogy ntfs vagy ext4-e a pendrive?
"Ha valahová be tudod dugni direktbe a pent, teszteld le ott is...ha szerinted a PCI csatoló kártya a bűnös, de amúgy előlapi kimenetben is próbáltad már, nem? "
Igen, ezeket a sebességeket a ház előlapi USB 3.0 kimenetén mértem. A PCIe kártyát már kivettem tegnap, nem bolygatom az elállási idő miatt.
I02S3F
ubyegon2 #87749 üzenetére
"KDE esetén nem tudok róla, hogy lenne ilyen sok hetes fejlesztői összecsiszolás."
- Még, ha a disztró kreátorok tesztelik is az alkalmazás ökoszisztémát. Hát azért gondolom a kde fejlesztők is összedolgoznak. Például egész szépen össze vannak integrálva a kde appok egyenként.Jó! Hogy ez mennyi ideig tart az jó kérdés!
csixy
ubyegon2 #87715 üzenetére
Nemtom. Talán CPT. Pirk írta pár hónapja, hogy ha a uname -r frissebbet mutat, akkor töröljem nyugodtan.
Végülis engem nem zavar, hogy ott van. Viszont a Discordot nem értem, hogy miért jelöli elavultnak, a hivatalos repón keresztül raktam fel (asszem), ha nincs újabb verzió, akkor what is elavult...
csixy
ubyegon2 #87716 üzenetére
'Szeretünk veszélyesen élni!'
A Westnotebookos garancia ragasztón muszály volt egy lukat ütnöm, hogy hozzáférjek egy csavarhoz, mert be kellett dugnom a második ramot a laposba hogy meglegyen a dualchannel. ... Ennyit a garanciáról. .. Azóta már eltelt az a hat hónap.
#87716 ubyegon2
A flexelt SSD-t egy keskenykliensbe szerkesztettem be. Egy plasztik játékkártyával izoláltam a wlan kártyától. Nagyon sokáig jül muzsikált a Windows10 rajta mindaddig míg egy bios flasheléssel meg nem öltem a wasat. -
K0zm0
ubyegon2 #87704 üzenetére
Szintén zenész!
Én ha látom, hogy kernelfrissítés lesz, akkor minden felhasználói progit kilövök, (Brave, torrent, stb.), csinálok egy Timeshift mentést, ráengedem az új kernelt. Utána reboot, terminálban sudo apt autoclean && autoremove -y és folytatom ahol abbhagytam.
A Timeshift-ben is mindig csak egy mentést, a legutóbbit hagyom. (Az automatikus mentést még az elején kiikattam belőle helyspórolás miatt.) -
csixy
ubyegon2 #87682 üzenetére
Én is nagyon linux mint függő voltam, de jött ez a linux-live-slax mániám és mintből nem jó azt csinálni, mert megdöglik benne az egér és emiatt váltottam a debian (amitől eddig nagyon féltem) cinnamon non-free verzióra és rájöttem , hogy tökugyanaz majdnem mint a Mint, csak a Thai nyelvi támogatást , a rengeteg értelmetlen játékot és a firefox és a thundenbird felesleges sok idegen nyelvi i18-n fájlját kell belőle izzasztó makacs synapticos munkával kiirtani. Cserébe nincs benne az a sok snap meg ilyen hülyeségek. Viszont nem nyalja ki a seggem mert a régi kernelt nekem magamnak kell belőle kivakarnom. .... Megszerettem. Már ez lesz. Ennyi. Azért a régi összkomfortos Linux Mint cinnamon telepítéseimet nem fogom kiirtani. A manjaróról rég leszoktam és az Arch sem olyan fényes már nekem.
#63718632
ubyegon2 #87552 üzenetére
Röviden annyi, hogy a disztróba össze van gereblyézve minden, amit utólag kellene a Fedora-hoz hozzáadni. RPM fusion, zárt driverek, firmware-k, Wine + a szükséges dolgok játékhoz, kodekpakkok, ecetera. Függetlenek a Fedora projektől és nem egy fajta közösségi Spin, hanem önálló disztró. Minden könnyen telepíthető GUI-ról.
Három féle ISO-t adnak, Pure Gnome, Pure Plasma és az Official. Ami egy extension-nökkel beállított Gnome (alsó tálca, start menü, stb). Amit külön-külön kéne beállítgatni. Nekem ez utóbbi tetszik. Ha Gnome-ot használnék így állítanám be.
Érdekesen partícionál, ha neki adod a teljes lemezt. Efi (/efi/boot, ha abban telepíted, /boot -ext4 és btrfs /home és / osztással. Swap zram0-ba.
Elsőre sokalltam a fogyasztott memóriát és arra gondoltam, hogy a btrfs miatt van. Csináltam egy egyéni partícionálásos telepítést btrfs nélkül sima /-ext4 formában. Ott valami gebasz lehetett, mert a Grubot nem tudta telepíteni. Nem menetem utána, hogy miért.
Lehet ez sem lesz jó Win mellé dualbootban.
Flatpak-et támogat, elő van készítve. meg megy simán a dnf csomagkezelő is.
Most indítva 1GB körül eszik a memóriából, úgy hogy nem a btrfs a hunyó. Vagyis nem az volt, inkább a friss telepítés utáni nagyobb cache és az abban még meglévő dolgok.
Pattogós rendszer, sokkal jobban, mint a Vanilla. -
RaZroX
ubyegon2 #87520 üzenetére
Lesz rá alkalom
Már sokszor használtam Linuxot nagyon alap felhasználói szinten. Most a Mint tesztként van fent, hogy a jelenleg fontos dolgokat mennyire tudom linuxon csinálni. Egyelőre minden megy ami kell, úgy ahogy kell. A héten telepítem a Fedora KDE-t (nekem KDE a best) és akkor már mélyebben belemegyek a dolgokba.Ja és a hóesés is megy
ubyegon2 #87436 üzenetére
Az az abroot elég érdekes egy valami, nem nagyon hallottam még ilyenről...
abrootnak két állapota van - a jelen és a jövő. Amikor először van a Vanilla OS telepítésében, a jelenlegi állapot az A. Amikor újraindítja a rendszert, az állapot automatikusan átvált B-re. Amikor egy csomagot telepít az abroot segítségével, az a jövőbeli gyökérpartícióra települ, és újraindításkor szinkronizálódik a jelenlegi gyökérpartícióval.
CPT.Pirk
ubyegon2 #87266 üzenetére
Én most a Manjaro utódját keresem... Mivel német cég akik terméket is adnak el, így most ők is kivágták a mesa-ból a teljes x264/x265 kodek készletet, nehogy a jövőben valaki beperelje őket a licenc használata miatt... Miután már a jó ég tudja hány éve részei ezek a kodekek a mesa-nak és sosem érdekelt senkit... Mindeközben még az ilyesmire nagyon érzékeny Debian sem szedte ki a mesa-ból ezeket.
More Linux Distros Break H264 GPU Acceleration
Röviden összefoglalva, hogyha nincs legalább 5000-es sorozatú AMD kártyád (Navi), akkor AMD-n szinte semmilyen hardveres gyorsítást nem kapsz azokban a disztrókban, amik meglépték ezt a váltást. Márpedig például csaknem minden letöltött film x264 vagy x265 kódolású...
Lehet, hogy eljön nálam az Arch-ra váltás pillanata.
CPT.Pirk
ubyegon2 #87262 üzenetére
Nem csak h. nem volt gyors a netinstall, jellemzően előjött pl. a driver hiánya probléma a net elérésénél. Ugyan be lehetett neki kézzel adni drivert, de kb. annyira volt jó megoldás, mint anno az XP-n a sata driverek betallózása... Szóval egy idő után már biztosra mész Debiannal és csak a non-free telepítőt fogod, ami működik offline.
Aztán végiggondolod, hogy a csomagok régiek, ha van benne bug akkor az sokára kerül javításra meg hasonlók és nézel inkább másik disztrót.
ubeygon2: tedd el a linket: https://cdimage.debian.org/cdimage/unofficial/non-free/cd-including-firmware/
ubyegon2 #87172 üzenetére
Egy újszülöttnek minden vicc új, el is szomorodtam kicsit hogy a brilliáns ötleteimet már régesrégen mások megvalósították csak én nem tudtam róla.
Lásd Ventoy projektem, ezt hittem ez az én zseniális mármár brilliáns elmémbe született meg, erre csixy kolléga közli hogy ő ezt már régesrégen megcsinálta.
Nembaj nem csüggedek, talán egyszer tényleg egy korszakalkotó ötletem lesz ami előtt tátott szájjal áll az IT világ és veregetik a vállam hogy eeez igen, ez már döfi!
Addig is, jól fogalmaztál, tényleg nagy lendülettel vetem bele megamat ezekbe a kis agytornákba, ami viszont nem baj.
Milyen program ami... [link]
- Vélemény Ubuntu 20.04 LTS
- Vélemény Linux Mint Debian Edition 4
- Tudástár MX-Linux 19
- Bemutató Linux a mindennapokban: Manjaro KDE
- Hír A Steam Play hozza el a Windowsra írt játékokat Linuxra
- Hír Hova jut a világ? Linuxot kínál a Windows Store!
- Eladó Steam kulcsok kedvező áron!
- Kaspersky, McAfee, Norton, Avast és egyéb vírusírtó licencek a legolcsóbban, egyenesen a gyártóktól!
- ROBUX ÁRON ALUL - VÁSÁROLJ ROBLOX ROBUXOT MÉG MA, ELKÉPESZTŐ KEDVEZMÉNNYEL (Bármilyen platformra)
- Microsoft licencek KIVÉTELES ÁRON AZONNAL - UTALÁSSAL IS AUTOMATIKUS KÉZBESÍTÉS - Windows és Office
- Bontatlan - BATTLEFIELD 1 Collectors Edition - Játékszoftver nélkül
- DELL PowerEdge R730xd 26SFF rack szerver - 2xE5-2680v3 (24c/48t, 2.5/3.3GHz), 64GB RAM, 10G, H730p
- Bowers/Wilkins Px7 S2 fejhallgatók
- Samsung Galaxy S21 Ultra , 12GB , 128 GB , Kártyafüggetlen
- AKCIÓ! Dell Optiplex 5050 SFF asztali számítógép - i5 7500 8GB DDR4 256GB SSD HD630 Win10
Cég: CAMERA-PRO Hungary Kft
