sg22
Most of the actions we tested have a fairly low parallel efficiency (below .7 or 70%). They still benefit from having more cores, but in most situations a CPU with a lower core count but higher operating frequency will give you the best performance. However, exporting images - which pretty much any Lightroom user is going to do - has a very high parallel efficiency which means a CPU with a high core count will allow you to export images faster. This means that the best CPU for you is going to depend on exactly what actions in Lightroom you regularly find yourself waiting on.
azt irjak h magasabb freki jobb mint a tobb mag ehhez a progihoz (lightroom). megoldas lett volna egy tobb magos xeon proci alacsonyabb frekivel ezaltal alacsonyabb tdp-vel. de mivel magas freki kell ezert a tdp is magas lesz
- Milyen házat vegyek?
- Nagyrobogósok baráti topikja
- Gyúrósok ide!
- RAM topik
- Cyberpunk 2077
- Hegesztés topic
- MacBook Air M4 24GB 512GB Garancia! Starlight / SKY / SILVER
- Apple iPhone XR 128GB, Kártyafüggetlen, 1 Év Garanciával
- ÁRGARANCIA!Épített KomPhone Ryzen 5 5600X 16/32/64GB RAM RX 9060 XT 8GB GAMER PC termékbeszámítással
- RÉSZLETRE .OPCIONÁLIS. G.SKILL Trident Z5 Neo RGB 96GB (2x48GB) DDR5 6000MHz
- Apple Watch Series 11 46mm GPS+Cellular , Újszerű, 1 Év Garanciával
