sg22
Most of the actions we tested have a fairly low parallel efficiency (below .7 or 70%). They still benefit from having more cores, but in most situations a CPU with a lower core count but higher operating frequency will give you the best performance. However, exporting images - which pretty much any Lightroom user is going to do - has a very high parallel efficiency which means a CPU with a high core count will allow you to export images faster. This means that the best CPU for you is going to depend on exactly what actions in Lightroom you regularly find yourself waiting on.
azt irjak h magasabb freki jobb mint a tobb mag ehhez a progihoz (lightroom). megoldas lett volna egy tobb magos xeon proci alacsonyabb frekivel ezaltal alacsonyabb tdp-vel. de mivel magas freki kell ezert a tdp is magas lesz
- Bambu Lab 3D nyomtatók
- Crimson Desert
- ThinkPad (NEM IdeaPad)
- Futás, futópályák
- Kingston HyperX és FURY 16Gb (20-22k) és 32GB DDR4 (47k) laptop ramok párban is 2666Mhz/3200Mhz
