PlayStation 4 összefoglaló.
MIELŐTT KÉRDEZEL, OLVASD EL!
Aktuális:
Kölcsönjáték nyilvántartó
dilipok
Kicsikatona7
#83788
nem egeszen 3 mp gugli..
https://support.us.playstation.com/scea_searchresults?lang=en_US&selStr=ws-37397-9
WS-37397-9 Error Code:
Connection Error
Step 1: Turn off the PlayStation 4 by pressing the power button on the front panel. The power indicator will blink for a few moments before turning off.
Step 2: Once the PlayStation 4 is off, press and hold the power button. Release it after you've heard two beeps: one when you initially press, and another 7 seconds later.
Step 3: Connect the DualShock 4 controller with the provided USB cable and press the PS button on the controller.
Step 4: From the list of options select Rebuild Database and press “X”. Once the process is complete the PS4 will restart.
Step 5: Run the Internet connection test at [Settings] > [Network] > [Test Internet Connection] and make sure you can connect to the network.Illetve a masikra router restartot javasolnak.
dilipok
veeeegre hazaertem
Faxan nez ki a steelbuk
dilipok
FuRiONight
#83420
beta alapjan pc. (en csak azt probaltam mondjuk, de az itt leirtak alapjan nekem egyertelmuve valt
dilipok
donceleger8
#82769
erre gondoltam: Now with the Guest Play option to compete with friends. De ha nem, hat nem
dilipok
donceleger8
#82766
szerintem valamit elnezel, vagyezek kozul egyik sem az amit keresel? (foleg bold)
Other modes/features in FIFA 15 include:
FIFA Ultimate Team
Match Day – jump straight in to play head-to-head offline against a friend or the AI
Tournament Mode – returns to FIFA 15 with all new tournaments
Online Seasons – compete online in a season format. Now with the Guest Play option to compete with friends
Online friendlies – compete online against your friends
Co-Op Seasons – compete online with a friend in 2v2 matches
Skill Games – 26 new Skill Games added to the popular practice mode including four new games that cover the basics – dribbling, shooting, passing, defending
Practice Arena – practice in a 1v1 situation against the all new Next Gen Goalkeeper
Match Day Live
EA SPORTS Football Club -
dilipok
Sirandrish
#82238
szamomra akkor is gagyin nez ki
szep az anyanyelvunk, de a mai globalis vilagban legalabb 1 (de inkabb 2 ) masik nyelv eleg jo szintu ismerete nelkulozhetetlen -
dilipok
azert itt egy picit tul van reagalva a dolog... Bar en az ubercsalok
kozott jatszok (pc), de meg haxor nyomival is nehanyszor talalkoztam csak. Tehat a megkeseritik az eletet masoknak nem annyira fedi a valosagot. Nyugodtan lehet tisztessegesen jatszani, nem csorbul a jatekelmeny illetve a challenge mod "nehezsege" es a diadal, mikor sikerul megcsinalni. Ha valaki hasznalja a glitcheket, utana ne rinyaljon, h nincs a jatekban semmi nehezseg, meg elfogy a tartalom 2 ora alatt
dilipok
gabee369
#80911
a legelso talalat guglirol...
Connection Error
Step 5: Run the Internet connection test at [Settings] > [Network] > [Test Internet Connection] and make sure you can connect to the network. -
dilipok
kovimester
#79534
osszefoglalo?
dilipok
andro93
#77914
no offense, de en nem a promo video es a jelenlegi grafika kozti kulonbseget vitattam... direkt megneztem, hatha nem jol emlekszem, de nekem meg az addonokkal turbozott verzio sincs kozel grafikailag (csak h ne a levegobe beszeljek [link])
Es igen, pont azert mondtam, h mutass hasonlot, mert nem sok van. Igy nem is tudom, h mire a nagy felhaborodas
(csak az igert vs valos gameplay miatt lehet itt felhaborodni, de azt meg mint mondtam, eddig sem vitattam, es egyetertek a velemenyeddel)Ahha, igy mar mas
bar butasag lenne egy-egy reszletet csak kiragadni az osszkepbol. Nem emiatt az egy-ket gyengebb minosegu textura miatt nem latszik bevaltani az igereteket a jatek
dilipok
marilllyo
#77912
de az egy "evekkel ezelotti" jatek?
(nem mellesleg egyetertek, raadasul a pc verziohoz volt mindkettobol szerencsem, ultra beallitason
)most komolyan, mint mondtam, nagyjabol egyetertek a velemennyel, a mocskos kapitalizmus mar csak ilyen
csak a szerintem eros tulzasra kaptam fel a fejem. De aztan lehet majd mindjart kiszurjak a szemem egy evekkel ezelotti szebb jatekkal. Ez is benne van a pakliban. -
dilipok
andro93
#77910
igen, igazad van, de tovabbra is tartom, h tulzas amit irsz. Evekkel ezelotti jatek... mindjart kiderul, h egy c64-es jatek is jobb grafikaval rendelkezett
(ha gonosz lennek, megkernelek, h mutass mar egy evekkel ezelotti jatekot, ami hasonlo felepitesu, es igy (ha nem jobban) nezett ki...
dilipok
Osiris
#76906
nem, a sony biztos lenyulja, mocskos egy ceg ez...
na de komolyan, a psn oldalon meg live chat is van... vagyis en lattam, gondolom mukodik is
vagyis megsem, az a us oldalon volt
na mindjart kutakodok meg egy kicsitna csak megvan, nem olyan nehez az [link]
EczkE: support mit mondott? ketlem, hogy ne segitenenek (idestova 7 eve van meg az accountom, eleg sokat vasaroltam is, a sony is eleg nagy ceg....)
dilipok
aprofeta86
#76817
ha nem mukodik, ami van, akkor megveszed a masikat (vagy en ertettem felre valamit?
) Szerintem amugy a hdcp kell hozza. -
dilipok
Petya2900XT
#76439
akkor van
de mire fel volt akkor a kerdes?
Megvan a jatek? Van rajta angol? Ha nincs meg, rendelj olyat, amiben biztos van angol (i.e. ne lokalizalt kiadast) -
dilipok
Petya2900XT
#76434
nincs
dilipok
Amadako
#76325
3 mp guglizas utan talaltam:
EASY SOLUTION:
To adjust FIFA 15 on PS4 if it is too "zoomed in" and appears to go off your screen...Just go into the PS4 MAIN MENU area (NOT the FIFA menus)..then go to--SETTINGS--SOUND AND SCREEN--DISPLAY AREA SETTINGS and "Shrink" the display area down to the minimum size allowed using the left stick or down button on the left D-pad. Then press 'X' to save it.
FIFA should work perfectly after this--and will take only 10 seconds to change. Now I can't guarantee this with every game, but changing this setting hasn't affected any other game that I've tried. They still look normal and fill the entire screen as they should (but some TVs may be different). But even if you do need to change it back for any reason, again, it will take just 10 seconds and you don't need to quit a game to do it. So Good luck!
dilipok
IMIIKE1998
#75550
akkor minek kerdezel, h ugyis megvan a valaszod?
Amugy meg jol megfer egymas mellett a konzol es a pc, asszem ennek en vagyok az egyik jo peldaja
dilipok
laragirl83
#75532
ha esetleg ezt nem lattad volna (en is majdnem kihagytam, hirtelen sok volt az uj hsz
dilipok
ha mar itt szo volt mostansag a driveclubrol, van valami ph club? Alternativakent, barmilyen mas club amihez csatlakozhatnek? Neztem h kell par dologhoz, nem lenne rossz
dilipok
ez igy van, az ow, az ow marad
Viszont a w3 egyike azon keves jatekoknak, amit a dlc befejezese es az osszes armor craftolasa utan is el-elinditok, csak h kicsit lovagoljak, kardozgassak
Pedig megvan az MGS is, de azt meg vegig sem toltam (ami nem azt jelenti, hogy nem jo, csak kicsit lassabban haladok vele). Szoval tolem +1 a witcherre
dilipok
foxymaci
#74597
If you are experiencing this ce-34878-0 error code, please close the application and then install the latest system software and game patch.
You can also try deleting and reinstalling the game or application that's affected.
If the error occurs again, initialise the PS4 system after back-up of the save data and please also submit any crash reports after re-booting your console when the error occurs.
dilipok
soha nem lesz ezekkel az alapokkal jo jatekra. Gondolj bele, 100/200 hzes frissitest ugy "gyart" a tv, hogy 1/3 kepkockat interpolal a valosak koze (vagy feketek illeszt be), innentol fogva, addig aranylag jol is fog mukodni, amig nem tul valtozo sebesseggel, egy iranyba mozog valami es hatvanyozottan romlik az eredmeny, minel inkabb nonek a kulonbsegek ket valodi kepkocka kozott. A hangsuly a fokozatossagon van es ha hirtelen tortennek az esemenyek, az erosen tudja rontani az osszkepet. (de mint mar annyiszor bebizonyosodott, van akit ez egyaltalan nem zavar, igy en azt is el tudom fogadni, ha valaki ezt isteniti. Nekem nem gyere be, ennyi
dilipok
na megvan a kicsike
Eddig nagyon tetszik.Kerdeznek is rogton egy hulyeseget. Ertelem szeruen megtartottam a ps3as id-mat, de itt kiirja a teljes nevem. Amit en nem feltetlenul akarok, eleg lenne a dilipok mint ezelott. Azt hogy csinalom meg? Csak first/last(/middle) name valtoztatast talaltam, de kotelezo a first+last ezert hulyen nez ki a dilipok dilipok
Ezt meg lehet csinalni? Lattam a privacy settingsnel, hogy kivel oszthatom meg a real nevem, de attol meg a profil a valodi nevemet illetve dilipok dilipokot mutat. -
dilipok
- HP ProBook 650 G5 - i5 8265U, 8-16GB RAM, SSD, jó akku, számla, 6 hó gar
- ÚJ AKCIÓS HP EliteBook 6 G1a Ryzen 5 PRO 230 16GB DDR5 512GB FHD+ 16:10 már jobbik kijelző, gar 2028
- Samsung Galaxy S20 Ultra / 12/128GB / Kártyafüggetlen / 12Hó Garancia
- 206 - Lenovo Legion Slim 7 (16IRH8) - Intel Core i7-13700H, RTX 4060 (ELKELT)
- S22 Ultra 256/12 Dobozában
hogy nem lehet arra emlekezni? ![;]](http://cdn.rios.hu/dl/s/v1.gif)
kisertetiesen hasonlit az boxos live goldos nyavajgashoz...
(soha nem voltam erintett, csak a ps3 miatt gondoltam, h must have
Kendek
