Samsung LCD és LED TV-k
ρσгτσ
Balázs6 #159314 üzenetére
Low-Quality Content Smoothing: Whereas sharpness and upscaling look at a TV's ability to scale a lower-resolution image and display it cleanly, smoothing looks at how well a TV can process that image to smooth out rough areas of the content and reduce banding and macro-blocking caused by a low-bitrate signal. Whereas upscaling is mainly important for low-resolution content, smoothing is mainly important for low-bitrate content. Although many people believe that streaming services are generally high-quality, they usually aren't. Even if you have the highest tier available with your streaming platform, and even if it's still sending a 4k signal, almost all streaming services use compression algorithms to reduce the amount of bandwidth used, as bandwidth is expensive. This results in noticeable compression artifacts, such as black blocks in near-black scenes.
- Nyíregyháza és környéke adok-veszek-beszélgetek
- ASUS ROG Ally
- Bomba ár! Dell Vostro 15 3558 - i5-5GEN I 4GB I 500GB I 15,6" HD I HDMI I Cam I W10 I Garancia!
- Telefon felvásárlás!! iPhone 14/iPhone 14 Plus/iPhone 14 Pro/iPhone 14 Pro Max
- AKCIÓ! Sony PlayStation 5 Slim 1TB SSD lemezes konzol + fejhallgató garanciával hibátlan működés
- IPhone 16 256GB!!! Bontatlan! One függő! Jótállás: 2028.04.04.-ig
- Panasonic CF-XZ6 AIO all-in-one laptop tablet 2k touch i5-7300u speciális ütésálló
