peterattila
CPT.Pirk
#73008
Ez pedig a vdpau:
vdpauinfodisplay: :0 screen: 0API version: 1Information string: G3DVL VDPAU Driver Shared Library version 1.0Video surface:name width height types-------------------------------------------420 16384 16384 NV12 YV12422 16384 16384 UYVY YUYV444 16384 16384 Y8U8V8A8 V8U8Y8A8Decoder capabilities:name level macbs width height----------------------------------------------------MPEG1 --- not supported ---MPEG2_SIMPLE 3 65536 4096 4096MPEG2_MAIN 3 65536 4096 4096H264_BASELINE 52 65536 4096 4096H264_MAIN 52 65536 4096 4096H264_HIGH 52 65536 4096 4096VC1_SIMPLE 1 65536 4096 4096VC1_MAIN 2 65536 4096 4096VC1_ADVANCED 4 65536 4096 4096MPEG4_PART2_SP 3 65536 4096 4096MPEG4_PART2_ASP 5 65536 4096 4096DIVX4_QMOBILE --- not supported ---DIVX4_MOBILE --- not supported ---DIVX4_HOME_THEATER --- not supported ---DIVX4_HD_1080P --- not supported ---DIVX5_QMOBILE --- not supported ---DIVX5_MOBILE --- not supported ---DIVX5_HOME_THEATER --- not supported ---DIVX5_HD_1080P --- not supported ---H264_CONSTRAINED_BASELINE 0 65536 4096 4096H264_EXTENDED --- not supported ---H264_PROGRESSIVE_HIGH --- not supported ---H264_CONSTRAINED_HIGH --- not supported ---H264_HIGH_444_PREDICTIVE --- not supported ---HEVC_MAIN 186 65536 4096 4096HEVC_MAIN_10 186 65536 4096 4096HEVC_MAIN_STILL --- not supported ---HEVC_MAIN_12 --- not supported ---HEVC_MAIN_444 --- not supported ---Output surface:name width height nat types----------------------------------------------------B8G8R8A8 16384 16384 y NV12 YV12 UYVY YUYV Y8U8V8A8 V8U8Y8A8 A8I8 I8A8R8G8B8A8 16384 16384 y NV12 YV12 UYVY YUYV Y8U8V8A8 V8U8Y8A8 A8I8 I8A8R10G10B10A2 16384 16384 y NV12 YV12 UYVY YUYV Y8U8V8A8 V8U8Y8A8 A8I8 I8A8B10G10R10A2 16384 16384 y NV12 YV12 UYVY YUYV Y8U8V8A8 V8U8Y8A8 A8I8 I8A8Bitmap surface:name width height------------------------------B8G8R8A8 16384 16384R8G8B8A8 16384 16384R10G10B10A2 16384 16384B10G10R10A2 16384 16384A8 16384 16384Video mixer:feature name sup------------------------------------DEINTERLACE_TEMPORAL yDEINTERLACE_TEMPORAL_SPATIAL -INVERSE_TELECINE -NOISE_REDUCTION ySHARPNESS yLUMA_KEY yHIGH QUALITY SCALING - L1 yHIGH QUALITY SCALING - L2 -HIGH QUALITY SCALING - L3 -HIGH QUALITY SCALING - L4 -HIGH QUALITY SCALING - L5 -HIGH QUALITY SCALING - L6 -HIGH QUALITY SCALING - L7 -HIGH QUALITY SCALING - L8 -HIGH QUALITY SCALING - L9 -parameter name sup min max-----------------------------------------------------VIDEO_SURFACE_WIDTH y 48 4096VIDEO_SURFACE_HEIGHT y 48 4096CHROMA_TYPE yLAYERS y 0 4attribute name sup min max-----------------------------------------------------BACKGROUND_COLOR yCSC_MATRIX yNOISE_REDUCTION_LEVEL y 0.00 1.00SHARPNESS_LEVEL y -1.00 1.00LUMA_KEY_MIN_LUMA yLUMA_KEY_MAX_LUMA y -
peterattila
CPT.Pirk
#73008
Íme:
vainfolibva info: VA-API version 1.1.0libva info: va_getDriverName() returns 0libva info: Trying to open /usr/lib/x86_64-linux-gnu/dri/radeonsi_drv_video.solibva info: Found init function __vaDriverInit_1_1libva info: va_openDriver() returns 0vainfo: VA-API version: 1.1 (libva 2.1.0)vainfo: Driver version: Mesa Gallium driver 20.2.0-devel for AMD Radeon (TM) RX 460 Graphics (POLARIS11, DRM 3.33.0, 5.3.0-51-generic, LLVM 9.0.1)vainfo: Supported profile and entrypointsVAProfileMPEG2Simple : VAEntrypointVLDVAProfileMPEG2Main : VAEntrypointVLDVAProfileVC1Simple : VAEntrypointVLDVAProfileVC1Main : VAEntrypointVLDVAProfileVC1Advanced : VAEntrypointVLDVAProfileH264ConstrainedBaseline: VAEntrypointVLDVAProfileH264ConstrainedBaseline: VAEntrypointEncSliceVAProfileH264Main : VAEntrypointVLDVAProfileH264Main : VAEntrypointEncSliceVAProfileH264High : VAEntrypointVLDVAProfileH264High : VAEntrypointEncSliceVAProfileHEVCMain : VAEntrypointVLDVAProfileHEVCMain : VAEntrypointEncSliceVAProfileHEVCMain10 : VAEntrypointVLDVAProfileJPEGBaseline : VAEntrypointVLDVAProfileNone : VAEntrypointVideoProc -
hódmaci
CPT.Pirk
#72967
Sajnos a libre. nem nyerő, és egyébb alternatíva sem.
Akárhogyan nézem ismerősöknek, munkatársaknak tulnyomó részben még mindig msoffice van.
Amenyiben megnyitok egy ilyen dokumentumot (pl excel) tuti valami másképpen jelenik meg vagy teljesen szétesve indul.Vagyis marad a msoffice.
Tul. Képpen egész ügyesen kitalálta a nagy Windows. Tuti maradj nála
hódmaci
CPT.Pirk
#72965
Az az......................
Itt volt a hiba.
CPT.Pirk ; lev258 Köszönöm nektek.
Már csak arra a nyamvadt MS officera kell valami értelmes megoldást találnom.
Ez az egy program amit még nem tudtam értelmesen kiváltani egy pár wines játékon kívül
Bár már a játékok amik érdekelnek úgy néz ki megoldásra kerülnek. -
hódmaci
CPT.Pirk
#72908
Igazából egy steam-es játékot szeretnék elindítani amit még anno Windowsra vettem meg.
A Lutrison "keresztül" mi a módja az elindításának?
Van esetleg valami kis videó ami alapján elindulhatok?
Profil, Game library-ban beléptem a steam-be. beállítottam a leírás alapján a steam fiókomat, na de innen hogyan tovább?Vagy félre értek valamit?
lev258
CPT.Pirk
#72908
Csak annyival egészíteném ki, hogy a felső bekezdést a Lutris-ra is rá lehet akasztani, kivéve a bash-t. Mivel saját script nyelve van.
Nekem az utóbbi időben az a benyomásom, hogy a Lutris mögötti közösség aktívabb, gyakrabban frissítik, bővítik a script-eket és tesztelnek.
Bár én csak Wine-t tisztán és Steam-et (benne Proton) használok. -
peterattila
CPT.Pirk
#72791
Izé, gond van...
. Hozzáadtam az Oracle VirtualBox repository-t, telepítettem. Próbaképp létre akartam hozni egy Win10 telepítést, de kizárólag 32 bites Windows verziókat enged. A 6.1-es verziót telepítettem fel, évekkel ezelőtti emlékem szerint kellett vmi guest-csomag is, amit utólag telepítve javult pl a grafikus teljesítmény. OK, mondom felrakom ezt is, erre közli, hogy nagyon szívesen felrakja, ámde leszedné egyúttal az előbb telepített virtualbox-6.1-et. Mi van?! Most én vagyok villamos? -
Laszlo733
CPT.Pirk
#72717
A /run/media helyén a Win particiója van, valamiért azzal lehet valami baja. Korábban kézzel felcsatoltam, de már nem aktív a kérelem.
Az fstab tartalma pedig:UUID=BA3A-351B /boot/efi vfat umask=0077 0 2
UUID=1da9d838-e923-421e-9cbb-262a39790555 swap swap defaults,noatime,discard 0 2
UUID=5ee468cd-1289-4271-a8e7-4732e2b4ec88 / ext4 defaults,noatime,discard 0 1
tmpfs /tmp tmpfs defaults,noatime,mode=1777 0 0 -
cigam
CPT.Pirk
#72698
Naaa smbv1-et visszakapcsolni olyan, mint töltött pisztolyt adni a gyereknek. Ha másik gépről elérik, akkor a mint-ben van a hiba.
Karmko
Tűzfal hogy néz ki a gépen?
smbclient -L windowsgépneve
parancsra mi a válasz?A sudo mount.cifs //gépneve/megosztás /mnt/cifs -o username=felhasználó,password=jelszó parancs sem csatolja fel?
peterattila
CPT.Pirk
#72279
Ennek alapnak kellene lennie, nem tudom a technikai hátterét, hogy miért olyan hatalmas/megoldhatatlan meló lenne ennek a lefejlesztése. Egy öreg masinámon (Q9550) win7 alatt a FF 1-3% CPU-t pörget, linux alatt 15-20%
. Windows alatt gyakorlatilag nem mérhető terhelés böngészés közben. -
anorche1
CPT.Pirk
#72201
Vlc. Es talan a qbittorent, de az nem biztos, mert a kovi rendszer inditaskor nem indult el. (csak akkor indul a rendszerrel, ha leallitaskor is futott, de az eroszakos kikapcsolas miatt nem tudom).
De leirom a teljes sztorit, hogy mit csinalt a geppel az elott, hogy ez a problema elojott:
Korabban is jeleztem, hogy van egy olyan problemam, hogy merevlemezre masolaskor a 80-90MB/s rol 3-4-5-6-ra lassul. Ilyenkor az olvasas is dog lassu, jegyzekek megnyitasakor mp -eket kell varni.
Ha a sync parancsot kiadom, akkor percekig tokol.
HDD sentinel szerint 100/100 a winyo, ext4 fajlrendszerrel. Fajlrendszer hiba keresest csinaltam, semmi talalt.
Mondom nem baj, lementem a tartalmat, es ujraparticionalom, hatha segit valamit. Illetve a tartalma mentesekor azt is teszteltem, hogy nem e odd helyen levo hdd cady szarakodik, ezert oda egy masik winyot tettem, es lementeskor es visszamasolaskor kulso hdd -kent hasznaltam.
Minden rendben ment, vissza masolaskor is tartotta a sebesseget.Utana viszont tobbszor csak ugy megfagyott a gepem. 10-20 perc varakozas utan ujra elindult, mintha mi sem tortent volna.
Volt frissites ezutan, es ujrainditas is. De ennek ellenere este lefagyott, orak alatt sem jott helyre. De cserebe szerintem a procit vegig maxon terhelte, had melegedjen.Most egy wine -os aida64 streszt tesztet elinditottam, de nem fagyott meg (csak akadt az eger. Az eger mozgas igazan mehetne realtime prioritassal)
herdsman12
szucstom
CPT.Pirk
#72158
parancsolj
Graphics: Device-1: Intel UHD Graphics vendor: Acer Incorporated ALI driver: i915 v: kernel bus ID: 00:02.0
chip ID: 8086:9b41
Device-2: NVIDIA GP108M [GeForce MX250] vendor: Acer Incorporated ALI driver: nvidia v: 440.64 bus ID: 02:00.0
chip ID: 10de:1d13
Display: server: X.Org 1.20.8 driver: modesetting,nvidia unloaded: intel,nouveau alternate: fbdev,nv,vesa
compositor: kwin_x11 resolution: 1920x1080~60Hz
OpenGL: renderer: Mesa DRI Intel UHD Graphics (Comet Lake 3x8 GT2) v: 4.6 Mesa 19.3.5 compat-v: 3.0
direct render: Yes -
szucstom
CPT.Pirk
#72131
no, itten van-e a kimenet
LC media player 3.0.8 Vetinari (revision 3.0.8-0-gf350b6b5a7)
[00005602927075b0] main libvlc: A VLC futtatása az alapértelmezett felülettel
. A VLC felület nélküli használatához használja a „cvlc” parancsot.
[00005602927a8570] main playlist: playlist is empty
kf5.kio.core: We got some errors while running testparm "Error loading services."
kf5.kio.core: We got some errors while running 'net usershare info'
kf5.kio.core: "Can't load /etc/samba/smb.conf - run testparm to debug it\n"
libva error: /usr/lib/dri/i965_drv_video.so init failed
[00007ff7e8001f50] glconv_vaapi_x11 gl error: vaInitialize: unknown libva error
uint DBusMenuExporterDBus::GetLayout(int, int, const QStringList&, DBusMenuLayoutItem&): Co
ndition failed: menu
ndition failed: menu -
CPT.Pirk
#72094
Én csak tippeltem a szűrőkondira. Aki szétszedte azt mondta, hogy a kondinak nincs baja, hanem valami egyéb alkatrész romolhatott el benne, de mérhető 10 voltos nagyságrendű kilengéseket regisztrálgattak benne, vagy rajta , nem tudom pontosan. Engem csípett az biztos. Amit adtak helyette azzal jól működik, csak kb 60°C a tápegység üzemi hőmérséklete. Lehet hogy ez a meleg normális persze.
CPT.Pirk
#72028
A táp volt a ludas. Úgy jöttem rá, hogy a meztelen talpam a kőpadlón volt és az ujjam vége hozzáért az egér USB-adó meztelen burkolatához (a számígép laptop GND-hez) és csípte az ujjam a kapcsolóüzemű tápegység szűretlen nagyfrekvenciás bizserája.
Kaptam hozzá egy javított 20Volt 4,5Amperes tápot. Ezzel most teljesen jól működik. Levizsgálattam vele a vinyót, nem talált hibát. Felfrissítette magát. Többször újraindítottam .... hiba nélkül újraindult. Jó lett. A táp elég meleg , olyan 60°C körül van. A fene se gondolta volna, hogy a táp az ok. Ha a talpam nincs akkor a kőpadlón és az ujjam nem ér a testhez, akkor nem jöttem volna rá sosem. -
Pano
CPT.Pirk
#72053
Köszi.
Feltettem a Manjaro Gnome-ot, ez részben megoldotta a problémát. Sokkal tűrhetőbbek a fontok. Még így is vannak eltérések (főleg pl twitchen), de talán szokható.
Én szeretem a gnome-ot, csak kevés distron tud normálisan futni. Pl fedorán tök jó, úgy néz ki manjaro is elég jó,Már csak arra kell rájönnöm, hogy linuxon miért nyújtanak ilyen tré teljesítményt a böngészők. Az Intel 520-nak azért még bírnia kéne ilyeneket, de chromiumben/chrome-ban, Firefox-ban (itt még a layer.acceleration bekapcsolásával javítható valamit, de messze nem végelges megoldás) pl a finomgörgetés is darabos, ha háttérben megy egy youtube videó akkor kb isten kegyelmezzen.
Plusz ha Chromiumot/Chrome-ot kell használnom a notim ventije szinte folyamatosan jár
Pedig sajnos nagyrészt rá vagyok erre a böngészőre kényszerülve, mert a cég Gsuite alapokon működik. -
Pano
CPT.Pirk
#72049
Jó neked, eléggé szembeötlő (nem csak szerintem, ismerősöm is majdnem elsírta magát amikor mutattam neki. Jó, mondjuk ő webdesigner, jobban rááll a szeme).
Prohardver nekem is jól jelenik meg. De sok oldal nem, vagy csak részben. Teljesen mindegy melyik disztróról van szó.
CPT.Pirk
#71987
A Debian nem szorította be magát, ez igaz, szoktak is néha csúszni. Régen talán jó ötlet volt Ubuntutól ez a naptárhoz kötés, de egyre inkább csapda. Egyszer talán próbáltam xorg-ot felrakni újabbat vagy Debianra vagy Ubialapúra.....mesa-t lehetett, de xorg-ot nagyon nem. (remélem nem pont fordítva írom)
(#71988) Brambka
Remélem azért nem vettük el a kedved egyik kiszemeltedtől sem!
Slownz
Horvi
CPT.Pirk
#71855
Áhh értem, és akkor sem fog sírni a linux ha vissza akarom dd-zni a 320GB-s img fájlt a 298GB-s lemezre?
Illetve másik kérdés, hogy ha simán felmountolom azt az img fájlt akkor azon tudok futtatni adatmentést vagy azt csak fizikai disken lehet tolni?A photorec elvileg tud olyat hogy dd-zett raw img-ből állít helyre adatot.
vadkörte
CPT.Pirk
#71846
Viszonylag rendszeresen kapok kollégáktól adatmentésre 3,5"-est. Nemrég egy napnyi molyolással sikerült is lementeni vagy 30db-ról kőkemény 19MB-ot...
5 döglött volt, a legrégebbi 1997-es és tökéletesen működött.
Pár hete az egyik mazsom hozott egy 5,25"-ost. Na erre már azt mondam, hogy helyezze fel és forogjon rajta... -
CPT.Pirk
#71797
Akkor határoztam el, hogy mindenképp a végére járok, amikor egy másik gépen, másik AMD VGA-val belefutottam ebbe. És itt meglett a megoldás is. Szintén az 5.5 kernel óta kell ez a két kapcsoló.
Mivel ez is AMD GPU, megkockáztattam, hogy összefügg (hasonló hiba). Ha a másik hiba és a megoldása nem lett volna, akkor feladtam volna ezt is.
#92691712
CPT.Pirk
#71629
Mkvmerge, ilyen van a desktopon, bár nekem mindig külön van az srt, gondolom nem eredeti nyelven nézem, amitt is. A kollégának viszont lehet hasznos lesz az infó! Alapból mindent meg lehet oldani Linuxon, csak ha nem a legegyszerűbb, legelterjedtebb módszer kell, akkor tenni kell bele kis energiát. Szerintem SMplayerrel is meg lehet oldani a dolgot, ha már a VLC-vel gondok vannak felirat terén.
CPT.Pirk
#71516
Az, szerintem, lev258 ft ugyan nyíltan mondta, hogy azt ne, mert innen senki nem használja, de látva milyen katyvasz a sources.list, talán nem véletlen.
Legalapvetőbb dolog, hogy minden desktop disztrót szuperül testre lehet szabni a nagyobb DE-kkel főleg, így talán emiatt is javaslunk minenkinek elterjedt disztrókat. Sajnos a Manjaro effektus a legújabb Zorinnál is megvan, a telepítési kinézete tetszetős.
(#71529) szucstom
Mi baj van a TW-vel, teljesen jól működik mindkét rendszeren és roppant egyszerű, még nekem is elsőre ment, mikor valami miatt alkalmaznom kellett.
Linux Mint új verzióját úgy érdemes várni, hogy májusban kijön és pár hetet mindig rá kell még hagyni, igaz utóbbi verzióval nem voltak stabilitási gondok, de totál kezdőnél ha kijön egy könnyen kezelhető bug, már az is kellemetlen lehet. (6 éves tapasztalat, persze mindenki azt tesz fel, amit akar) Nekem az Ubuntu 20.04 elég stabil egy hónapja, így az erre épülő Mint is stabil lehet.......
Storms
CPT.Pirk
#71527
Köszi. Végigcsináltam. Ez lett belőle:
$ sudo apt update && sudo apt install --install-recommends winehq-stable
Találat:1 http://ppa.launchpad.net/cybermax-dexter/sdl2-backport/ubuntu bionic InRelease
Találat:2 http://hu.archive.ubuntu.com/ubuntu bionic InRelease
Találat:3 https://dl.winehq.org/wine-builds/ubuntu bionic InRelease
Mellőz:4 http://ppa.launchpad.net/wine/wine-builds/ubuntu bionic InRelease
Találat:5 http://hu.archive.ubuntu.com/ubuntu bionic-security InRelease
Találat:6 http://hu.archive.ubuntu.com/ubuntu bionic-updates InRelease
Találat:7 http://hu.archive.ubuntu.com/ubuntu bionic-backports InRelease
Hiba:8 http://ppa.launchpad.net/wine/wine-builds/ubuntu bionic Release
404 Not Found [IP: 2001:67c:1560:8008::15 80]
Csomaglisták olvasása... Kész
E: A(z) „http://ppa.launchpad.net/wine/wine-builds/ubuntu bionic Release” tárolónak nincs Release fájlja.
N: Az ilyen tárolóból való frissítés nem végezhető el biztonságosan, így alapesetben ki van kapcsolva.
N: Lásd az apt-secure(8) kézikönyvoldalt a tárolólétrehozással és felhasználói beállításokkal kapcsolatos részletekért.
Függőségi fa építése
Állapotinformációk olvasása... Kész
Néhány csomagot nem lehetett telepíteni. Ez azt jelentheti, hogy
egy lehetetlen állapotot kért, vagy ha az unstable disztribúciót
használja, akkor néhány igényelt csomag még nem készült el vagy ki
lett mozdítva az Incoming-ból.
Az alábbi információk segíthetnek megoldani a problémát:
Az alábbi csomagoknak teljesítetlen függőségei vannak:
winehq-stable : Függ ettől: wine-stable (= 5.0.0~bionic)
E: A problémák nem javíthatók, sérült csomagokat fogott vissza. -
Storms
CPT.Pirk
#71523
sudo apt install -f
0 frissített, 0 újonnan telepített, 0 eltávolítandó és 0 nem frissített.Pfff. Azt hiszem ebből majd Linux újratelepítés lesz. De lehet megvárom a Linux Mint új verzióját. Hihetetlen, hogy nem lehet a wine-t felrakni,
Storms
CPT.Pirk
#71518
Kész. restart után próbálom telepíteni a wine-t. Ezt írja mindig most is.:
sudo apt-get install wine32
wine32:i386 : Függ ettől: libwine:i386 (= 3.0-1ubuntu1) de az nincs telepítésre megjelölve
Ajánlja: wine-stable:i386 (= 3.0-1ubuntu1)
Storms
CPT.Pirk
#71496
# deb cdrom:[Zorin-OS 15.1 Ultimate 64bit]/ bionic main restricted
# See http://help.ubuntu.com/community/UpgradeNotes for how to upgrade to
# newer versions of the distribution.
deb http://hu.archive.ubuntu.com/ubuntu/ bionic main restricted
# deb-src http://hu.archive.ubuntu.com/ubuntu/ bionic main restricted
## Major bug fix updates produced after the final release of the
## distribution.
deb http://hu.archive.ubuntu.com/ubuntu/ bionic-updates main restricted
# deb-src http://hu.archive.ubuntu.com/ubuntu/ bionic-updates main restricted
## N.B. software from this repository is ENTIRELY UNSUPPORTED by the Ubuntu
## team. Also, please note that software in universe WILL NOT receive any
## review or updates from the Ubuntu security team.
deb http://hu.archive.ubuntu.com/ubuntu/ bionic universe
# deb-src http://hu.archive.ubuntu.com/ubuntu/ bionic universe
deb http://hu.archive.ubuntu.com/ubuntu/ bionic-updates universe
# deb-src http://hu.archive.ubuntu.com/ubuntu/ bionic-updates universe
## team, and may not be under a free licence. Please satisfy yourself as to
## your rights to use the software. Also, please note that software in
## multiverse WILL NOT receive any review or updates from the Ubuntu
## security team.
deb http://hu.archive.ubuntu.com/ubuntu/ bionic multiverse
# deb-src http://hu.archive.ubuntu.com/ubuntu/ bionic multiverse
deb http://hu.archive.ubuntu.com/ubuntu/ bionic-updates multiverse
# deb-src http://hu.archive.ubuntu.com/ubuntu/ bionic-updates multiverse
## N.B. software from this repository may not have been tested as
## extensively as that contained in the main release, although it includes
## newer versions of some applications which may provide useful features.
## Also, please note that software in backports WILL NOT receive any review
## or updates from the Ubuntu security team.
deb http://hu.archive.ubuntu.com/ubuntu/ bionic-backports main restricted universe multiverse
# deb-src http://hu.archive.ubuntu.com/ubuntu/ bionic-backports main restricted universe multiverse
## Uncomment the following two lines to add software from Canonical's
## 'partner' repository.
## This software is not part of Ubuntu, but is offered by Canonical and the
## respective vendors as a service to Ubuntu users.
# deb http://archive.canonical.com/ubuntu bionic partner
# deb-src http://archive.canonical.com/ubuntu bionic partner
deb http://security.ubuntu.com/ubuntu bionic-security main restricted
# deb-src http://security.ubuntu.com/ubuntu bionic-security main restricted
deb http://security.ubuntu.com/ubuntu bionic-security universe
# deb-src http://security.ubuntu.com/ubuntu bionic-security universe
deb http://security.ubuntu.com/ubuntu bionic-security multiverse
# deb-src http://security.ubuntu.com/ubuntu bionic-security multiverse
deb https://dl.winehq.org/wine-builds/ubuntu/ bionic main
# deb-src https://dl.winehq.org/wine-builds/ubuntu/ bionic main
deb https://download.opensuse.org/repositories/Emulators:/Wine:/Debian/xUbuntu_18.04/ ./
# deb-src https://download.opensuse.org/repositories/Emulators:/Wine:/Debian/xUbuntu_18.04/ ./
# deb-src https://download.opensuse.org/repositories/Emulators:/Wine:/Debian/xUbuntu_18.04/ ./ -
Storms
CPT.Pirk
#71485
Ezt írta:
wine Setup.exe
it looks like wine32-development is missing, you should install it.
as root, please execute "apt-get install wine32-development"
wine: Rossz EXE formátum D:\Setup.exe.
Storms
CPT.Pirk
#71460
Például a szoftver letöltő áruházban elég sokszor. De egyéb műveleteknél is sokszor bejön egy kis ablak , hogy hitelesítés szükséges. Illetve ha hagyom a gépet pár percig és nem csinálok rajta semmit akkor megint kér jelszót úgy enged vissza a rendszerhez. (Zorin OS 15.2)
nonsen5e
CPT.Pirk
#71297
Naccerű.
Amúgy erre lehet tudni mi a magyarázat?
Mármint, ha ez így van "normál esetben", akkor hogyhogy nem lett még javítva?
Értem én, winen jóó sok év alatt amíg OC-val játszogattam, biztosan rákapcsoltam a gépre szumma 1000+ az áramot a tápegységen, amikor kifagyott és unreszponzív volt az egész.Ez meg 100%-os pontossággal, elmegy az áram, elmegy a bootloader.
Nem hiszem, hogy annyira normál eset lenne, sokkal többet találnék róla a neten. -
nonsen5e
CPT.Pirk
#71293
2015-ös laptop, de az akkumulátor elég gyenge már benne, tehát 0-70% között véletlenszerűen csak kikapcsol, és nem szépen szoftverből, hanem mint amikor az asztali gépből kitépem a kábelt / rákapcsolom a villanyóraszekrényt.
Dual-boot van rajta, de GRUB-ból indítom a WBM-et is.
Ugyanígy elszáll, ha Linux, vagy ha Win alatt merül le. -
ooszi
CPT.Pirk
#71223
Szia nekem egy Asus R9 290X-em, sajnos már megérett amúgy is a cserére 2016 os vásárlás kopp-kopp még működik de a venti már csörög.
De térjünk a lényegre, tegyük fel én a gépemre fel rakom az Ubuntu Mate-t, kell-e bármit is csinálnom hogy megfelelően működjön, értsd: Win-Fos-AMD DRiver -
ooszi
CPT.Pirk
#71157
szia köszönöm válaszod, a gép egy i3 9100F-16 gb memória-256 gb nvme ssd, szívesen meg hallgatnám hogy te hogy osztanád fel a 256 gb os nvme ssd-t. Gondolom te nem raknál Swap-ot?
1., 100 mb fat32 bios-group - ez kell-e egyáltalán?
2., 100 mb fat32 efi
3., 50 gb ext4 root
4., maradék ext4 /home
Köszönöm válaszod
Milyen program ami... [link]
- Teszt [Linux] A Flatpak
- Bambu Lab 3D nyomtatók
- Google Pixel 10 Pro XL – tíz kicsi Pixel
- Azonnali játékos kérdések órája
- Digitális Állampolgárság Program DÁP
- Milyen Android TV boxot vegyek?
- The Crew sorozat
- LicencAruhaz.hu OLCSÓ, LEGÁLIS SZOFTVEREK AZONNAL - Windows - Office - Win Server - ÖRÖK GARANCIÁVAL
- GYÖNYÖRŰ iPhone 12 mini 128GB Blue-1 ÉV GARANCIA - Kártyafüggetlen, MS3415 94% Akkumulátor
- MacBook Pro 14 2024 M4 Pro, 24 GB RAM, 1 TB SSD Space Black 27% Áfás
- Új! AKRacing Premium Master gamer szék
- Apple iPhone 15 Pro Max 256 GB Natural Titanium 1 év Garancia Beszámítás Házhozszállítás
Ha ezt tudom nem szopok annyit a nemzetközivel
