sg22
sad_Vamp
#30530
Practical drive limits for drive controller chipsets & BIOSes were effectively eliminated way back in 2003 with the introduction of the ATA-6 standard. Allows for hard drives up to 128 PiB in size. Meaning that WD Black you are planning on (or any other drive 2TB or smaller) will not be a problem.
More important these days for hard drives over 2TB is what OS you will be running. You haven't said, so: to use a disk over 2TB, your operating system needs GPT support.
Windows XP 32-bit can only see up to 2TB disks maximum, whether the OS is on it or its a data drive. If you buy a 3TB (or larger) disk, you'll only get 2TB of capacity out of it.
XP 64-bit can use a data disk larger than 2TB (one other than the OS is on/booting from), but cannot create such a disk (in the "GPT" format).
Vista & 7 (& 8, but no one uses that) in both 32-bit & 64-bit can all use and format drives in the GPT format (over 2TB). But...only 64-bit versions of those OSes on UEFI-based systems (which yours is not) can boot from over-2TB GPT drives. Meaning using such drives on older motherboards such as yours means they can only be used as data drives (ones the OS is not installed on/booting from).
http://www.howtogeek.com/193669/whats-the-difference-between-gpt-and-mbr-when-partitioning-a-drive/
- Beszámítás! VALVE Steam Deck OLED 512GB SSD kézikonzol garanciával hibátlan működéssel
- Legjobb kijelzős!!! HP ZBook Power 15 G8 i7-11850H 32GB 1000GB Nvidia RTX A2000 1 év garancia
- Eredeti Lenovo 90W szögletes (téglalap) notebook táp + kerek átalakító egyben eladó
- AKCIÓ! LENOVO ThinkPad P15 Gen1 munkaállomás - i7 10875H 16GB DDR4 512GB SSD Quadro T1000 4GB W
- SzoftverPremium.hu
