sg22
sad_Vamp
#30530
Practical drive limits for drive controller chipsets & BIOSes were effectively eliminated way back in 2003 with the introduction of the ATA-6 standard. Allows for hard drives up to 128 PiB in size. Meaning that WD Black you are planning on (or any other drive 2TB or smaller) will not be a problem.
More important these days for hard drives over 2TB is what OS you will be running. You haven't said, so: to use a disk over 2TB, your operating system needs GPT support.
Windows XP 32-bit can only see up to 2TB disks maximum, whether the OS is on it or its a data drive. If you buy a 3TB (or larger) disk, you'll only get 2TB of capacity out of it.
XP 64-bit can use a data disk larger than 2TB (one other than the OS is on/booting from), but cannot create such a disk (in the "GPT" format).
Vista & 7 (& 8, but no one uses that) in both 32-bit & 64-bit can all use and format drives in the GPT format (over 2TB). But...only 64-bit versions of those OSes on UEFI-based systems (which yours is not) can boot from over-2TB GPT drives. Meaning using such drives on older motherboards such as yours means they can only be used as data drives (ones the OS is not installed on/booting from).
http://www.howtogeek.com/193669/whats-the-difference-between-gpt-and-mbr-when-partitioning-a-drive/
- Ubuntu Linux
- Győr és környéke adok-veszek-beszélgetek
- Óra topik
- Kaspersky Antivirus és Internet Security Fórum
- Hibátlan - CORSAIR Vengeance LPX 16GB (2x8GB) 3200MHz DDR4 CL16 memória kit
- 16GB ( 2x8GB ) DDR4 2666MHz Notebook SODIMM Ram Memória
- ASUS ROG STRIX B550-F GAMING Eladó!
- Telefon felvásárlás!! Samsung Galaxy A20e/Samsung Galaxy A40/Samsung Galaxy A04s/Samsung Galaxy A03s
- Prémium minőségű HOFI üvegfóliák Tech Protect tokok és 20W Adapterek iPhone 13 14 15 16 17 szériához
- Apple iPhone 15 Pro 256GB Új akku 12hó jótállás!
- Samsung Enterprise PM893 1,92TB/ SATA 2,5" SSD- 6db/ számla-garancia
- Apple iPhone 14 / 128GB / Kártyafüggetlen / 12Hó Garancia / Akku: 87%
