qwertly
csendes
#5585
Itt van ami kiírt a parancsra.
[root@214-pc04 /]# readelf -d /opt/pt/bin/PacketTracer6Dynamic section at offset 0x3d7eeb0 contains 35 entries:
Tag Type Name/Value
0x00000001 (NEEDED) Shared library: [libcrypto.so.1.0.0]
0x00000001 (NEEDED) Shared library: [libQtWebKit.so.4]
0x00000001 (NEEDED) Shared library: [libQtScriptTools.so.4]
0x00000001 (NEEDED) Shared library: [libQtScript.so.4]
0x00000001 (NEEDED) Shared library: [libQtXml.so.4]
0x00000001 (NEEDED) Shared library: [libQtGui.so.4]
0x00000001 (NEEDED) Shared library: [libQtNetwork.so.4]
0x00000001 (NEEDED) Shared library: [libQtCore.so.4]
0x00000001 (NEEDED) Shared library: [libpthread.so.0]
0x00000001 (NEEDED) Shared library: [libstdc++.so.6]
0x00000001 (NEEDED) Shared library: [libm.so.6]
0x00000001 (NEEDED) Shared library: [libgcc_s.so.1]
0x00000001 (NEEDED) Shared library: [libc.so.6]
0x0000000f (RPATH) Library rpath: [/usr/local/Trolltech/Qt-4.8.2/lib]
0x0000000c (INIT) 0x80746e8
0x0000000d (FINI) 0xad96b7c
0x00000019 (INIT_ARRAY) 0xbdc5134
0x0000001b (INIT_ARRAYSZ) 7528 (bytes)
0x6ffffef5 (GNU_HASH) 0x80481ac
0x00000005 (STRTAB) 0x8054880
0x00000006 (SYMTAB) 0x8049770
0x0000000a (STRSZ) 102166 (bytes)
0x0000000b (SYMENT) 16 (bytes)
0x00000015 (DEBUG) 0x0
0x00000003 (PLTGOT) 0xbdc6ff4
0x00000002 (PLTRELSZ) 21472 (bytes)
0x00000014 (PLTREL) REL
0x00000017 (JMPREL) 0x806f308
0x00000011 (REL) 0x806ef08
0x00000012 (RELSZ) 1024 (bytes)
0x00000013 (RELENT) 8 (bytes)
0x6ffffffe (VERNEED) 0x806edb8
0x6fffffff (VERNEEDNUM) 6
0x6ffffff0 (VERSYM) 0x806d796
0x00000000 (NULL) 0x0
[root@214-pc04 /]# -
qwertly
csendes
#5583
Elsőnek is köszönöm a segítségedet
itt van a amit ki írt a sulix amikor kiadtam az általad javasolt parancsokat:
[root@214-pc04 /]# yum install glibc.i686
Betöltött bővítmények: langpacks, priorities, sulix
http://sulixupdate/SuliX.Professional.8/x86_64/repodata/repomd.xml: [Errno 14] HTTP Error 404 - Not Found
Próbálkozás másik tükörszerverről.
One of the configured repositories failed (SuliXerver - x86_64),
and yum doesn't have enough cached data to continue. At this point the only
safe thing yum can do is fail. There are a few ways to work "fix" this:1. Contact the upstream for the repository and get them to fix the problem.
2. Reconfigure the baseurl/etc. for the repository, to point to a working
upstream. This is most often useful if you are using a newer
distribution release than is supported by the repository (and the
packages for the previous distribution release still work).3. Disable the repository, so yum won't use it by default. Yum will then
just ignore the repository until you permanently enable it again or use
--enablerepo for temporary usage:yum-config-manager --disable sulixupdate-basearch
4. Configure the failing repository to be skipped, if it is unavailable.
Note that yum will try to contact the repo. when it runs most commands,
so will have to try and fail each time (and thus. yum will be be much
slower). If it is a very temporary problem though, this is often a nice
compromise:yum-config-manager --save --setopt=sulixupdate-basearch.skip_if_unavailable=true
failure: repodata/repomd.xml from sulixupdate-basearch: [Errno 256] No more mirrors to try.
readelf: Warning: Nothing to do.
Usage: readelf <option(s)> elf-file(s)
Display information about the contents of ELF format files
Options are:
-a --all Equivalent to: -h -l -S -s -r -d -V -A -I
-h --file-header Display the ELF file header
-l --program-headers Display the program headers
--segments An alias for --program-headers
-S --section-headers Display the sections' header
--sections An alias for --section-headers
-g --section-groups Display the section groups
-t --section-details Display the section details
-e --headers Equivalent to: -h -l -S
-s --syms Display the symbol table
--symbols An alias for --syms
--dyn-syms Display the dynamic symbol table
-n --notes Display the core notes (if present)
-r --relocs Display the relocations (if present)
-u --unwind Display the unwind info (if present)
-d --dynamic Display the dynamic section (if present)
-V --version-info Display the version sections (if present)
-A --arch-specific Display architecture specific information (if any)
-c --archive-index Display the symbol/file index in an archive
-D --use-dynamic Use the dynamic section info when displaying symbols
-x --hex-dump=<number|name>
Dump the contents of section <number|name> as bytes
-p --string-dump=<number|name>
Dump the contents of section <number|name> as strings
-R --relocated-dump=<number|name>
Dump the contents of section <number|name> as relocated bytes
-w[lLiaprmfFsoRt] or
--debug-dump[=rawline,=decodedline,=info,=abbrev,=pubnames,=aranges,=macro,=frames,
=frames-interp,=str,=loc,=Ranges,=pubtypes,
=gdb_index,=trace_info,=trace_abbrev,=trace_aranges,
=addr,=cu_index]
Display the contents of DWARF2 debug sections
--dwarf-depth=N Do not display DIEs at depth N or greater
--dwarf-start=N Display DIEs starting with N, at the same depth
or deeper
-I --histogram Display histogram of bucket list lengths
-W --wide Allow output width to exceed 80 characters
@<file> Read options from <file>
-H --help Display this information
-v --version Display the version number of readelf
[root@214-pc04 /]#Kicsit sokk lett
soldi3r
csendes
#5557
Chrome volt, nem chromium. Kesobb kiderul a video lejatszas sem ment. Ezt lefuttattam es minden megoldodott:
sudo dnf install gstreamer-plugins-bad gstreamer-plugins-bad-free-extras gstreamer-plugins-bad-nonfree gstreamer-plugins-ugly gstreamer-ffmpeg gstreamer1-libav gstreamer1-plugins-bad-free-extras gstreamer1-plugins-bad-freeworld gstreamer1-plugins-base-tools gstreamer1-plugins-good-extras gstreamer1-plugins-ugly gstreamer1-plugins-bad-free gstreamer1-plugins-good gstreamer1-plugins-base gstreamer1
agy73p
csendes
#5532
És nincs igaza?
Szeretnék segítséget kérni.
1. Valahogy "elromlott" a képernyő kikapcsolás pár perc tétlenség után. Hiába állítok be bármit az energiakezelőben (laptop egyébként), nem változik semmi, marad folyamatosan bekapcsolva a képernyő.
Újratelepítés után is ugyanaz a helyzet, gondolom, vhol a home könyvtárban van ez a beállítás elmentve.2. Lassan bootol be a gép, b + 40 mp az eredetihez képest. Ezért.....
3. lementeném a home-ot és csak azokat a dolgokat tenném vissza, ami szükséges később. Hogy fussak neki? Van egy másik partíció, amin van hely....
BeeNiTTo
csendes
#5472
megnéztem sysmonitorral és Firfefoxnak futott egy csomo folyamata pedig be volt zárva,kilöttem ezeket most jó! felteszem helyette a chromiumot hátha jobblesz .
de nemertem miert futott a firefox bezaras utan . es hogy pörgette fel enyire mert nem volt egyfolytában ilyen nagy memorihasználata csak x idő után -
agy73p
csendes
#5468
Elvileg fent van, de nem tudom, h mindegyik-e:
[adam@localhost ~]$ sudo dnf install gstreamer1-plugins-good gstreamer1-plugins-ugly gstreamer1-plugins-bad-free gstreamer1-plugins-bad-free-extras gstreamer1-plugins-bad-freeworld gstreamer-plugin-crystalhd gstreamer-ffmpeg gstreamer-plugins-good gstreamer-plugins-ugly gstreamer-plugins-bad gstreamer-plugins-bad-extras gstreamer-plugins-bad-free gstreamer-plugins-bad-free-extras gstreamer-plugins-bad-nonfree gstreamer-plugins-bad-extras libmpg123 lame-lib
Last metadata expiration check performed 0:02:08 ago on Thu Jan 21 16:38:09 2016.
A(z) gstreamer1-plugins-good-1.6.2-1.fc23.i686 nevű csomag már telepítve van, átugrás.
A(z) gstreamer1-plugins-ugly-1.6.2-1.fc23.i686 nevű csomag már telepítve van, átugrás.
A(z) gstreamer1-plugins-bad-free-1.6.2-1.fc23.i686 nevű csomag már telepítve van, átugrás.
A(z) gstreamer1-plugins-bad-freeworld-1.6.2-1.fc23.i686 nevű csomag már telepítve van, átugrás.
A(z) gstreamer-plugin-crystalhd-3.10.0-11.fc23.i686 nevű csomag már telepítve van, átugrás.
A(z) gstreamer-ffmpeg-0.10.13-15.fc22.i686 nevű csomag már telepítve van, átugrás.
A(z) gstreamer-plugins-good-0.10.31-15.fc23.i686 nevű csomag már telepítve van, átugrás.
A(z) gstreamer-plugins-ugly-0.10.19-18.fc23.i686 nevű csomag már telepítve van, átugrás.
A(z) gstreamer-plugins-bad-0.10.23-7.fc22.i686 nevű csomag már telepítve van, átugrás.
A(z) gstreamer-plugins-bad-free-0.10.23-28.fc23.i686 nevű csomag már telepítve van, átugrás.
A(z) gstreamer-plugins-bad-nonfree-0.10.23-3.fc22.i686 nevű csomag már telepítve van, átugrás.
A(z) libmpg123-1.22.4-1.fc23.i686 nevű csomag már telepítve van, átugrás.
Nincs ilyen csomag: lame-lib.
Hiba: Unable to find a match.
[adam@localhost ~]$ -
Fenyő
csendes
#5459
Ezek az észrevételek mind le vannak írva a fentebbi linkben is (bootolj be live médiáról, mountold be a külsős vinyót, de a forrásmeghajtót semmiképp stb), a forrás-cél meghajtók megadásánál meg tényleg figyelni kell (érdemes akár többször is ellenőrizni, ha bizonytalanok vagyunk van rá jópár módszer), de kb ennyi, viszont garantáltan működni fog, sok rendszeres vinyó esetében is...
inf3rno: A cél természetes a célmeghajtón megadott tetszőleges nevű képfájl nem az egész meghajtó (tehát pl /mnt/külsővinyólabel/mentes/mentes.img), a klónozandó vinyónak, tehát a forrásnak kell megadni a teljes vinyót vagy egy partíciót, tehát pl ált sda/sdax.
inf3rno
csendes
#5459
A célnak muszáj partíciót megadni? Nem lehet iso fájlba menteni? Ha LUKS-al titkosított a partíció, akkor mountolás nélkül hogyan másolja le? Nem kell ahhoz kikódolni?
Közben megjött a video kártya, kíváncsi leszek, hogy sikerül e megtartani a rendszert a cseréjénél. Gondolom Kapásból az összes 340-es nvidia csomag törlésével kell kezdeni.
inf3rno
csendes
#5439
Hmm van lehetőség olyasmire, hogy másik Linux-ról bootolva töröljünk dnf package-eket a rendszerből? Konkrétan az összes fent levő video kártya drivert akarom törölni, aztán elindítani CLI-vel a rendszert, és onnan telepíteni újat. Nem szívesen raknám újra teljesen a rendszert, baromi lassú az install menü.
inf3rno
csendes
#5433
Váltok Linux-ra, a Fedora tetszik. Ezen kívül veszek egy új video kártyát, mert a régit már gyengének érzem a gép többi részéhez képest. Agyaltam rajta, hogy amd-t vegyek e, mert hogy azzal kevesebb a szívás driver téren, de látva ezeket a siralmas teljesítmény adatokat az nvidia-hoz képest, inkább maradok az nvidia-nál. Nagyjából ennyi a történet. Egyébként én sem tudom hogy jutottunk ide, már tényleg nagyon off. :-)
Fedora-hoz tudtok javasolni valamilyen full system backup megoldást? Szeretnék kísérletezgetni olyan dolgokkal, amik tönkrevághatják teljesen a rendszert, és nem szeretném hatodszor is újrarakni, és mindent nulláról beállítani, ha nem muszáj...
inf3rno
csendes
#5430
Nem akarom nagyon offolni a topic-ot, de ha már így alakult... A linkeden csak annyit bizonyít, hogy bizonyos benchmarkoknál bizonyos kártyákkal az opensource driver jobban teljesít. Ezt el tudom fogadni, mert írták is, hogy nagy különbség nincs AMD terén a catalyst meg az opensource között. Azt mire alapozod, hogy Linux alatt is ugyanolyan teljesítményt nyújtanak ezek a kártyák, mint Windows alatt? Amit előzőleg linkeltem az pont az ellenkezőjét támasztja alá. Az nvidia-hoz képest a Windows-on hasonló teljesítményt nyújtó amd pocsékul teljesített Linux alatt. Fele meg harmad pontokat hozott...
@Vladi :
Nyilván a játék egy mércéje a dolognak, hogy mennyire gyorsan fut. Ezen kívül pl videokat is szoktunk nézni, ahhoz is kell a GPU. Aztán bele szeretnék kóstolni WebGL programozásba, amihez szintén kell. De legyen, a játék miatt kell. Azért fura azt hallani egy Linux-os topic-ban, hogyha játszani akarsz, akkor használj inkább Windows-t...
inf3rno
csendes
#5427
Nálam nem feltétlen a játék a szempont, inkább az, hogy ugyanazért a teljesítményért nem szívesen fizetek kétszer annyit, csak hogy elmondhassam, hogy opensource drivereket használok. Ha hasonlót hozna az AMD Linux-on, mint Windows-on, akkor egyértelműen azt választanám én is. Integrált kártya nem jön szóba, az alaplap már megvan jópár éve.
Közben kiderült, hogy az új telepítéssel gond nélkül felmennek a gnome shell extension-ök, úgyhogy az a gondom is megoldódott. Találtam egy tök jót: https://extensions.gnome.org/extension/898/mmod-panel/. Megszoktam már nagyon a Win7-es indítómenüt, és ez gyakorlatilag ugyanazt be tudja lőni nekem pillanatok alatt. Szóval most teljesen elégedett vagyok. :-)
Shrike7973
csendes
#5373
We will change GDM to use wayland by default for GNOME. The code will automatically fall back to Xorg in cases where wayland is unavailable (like nvidia). Users will be able to disable wayland by setting WaylandEnable=false in /etc/gdm/custom.conf but there will no longer be two separate menu items for GNOME on Wayland and GNOME on X11 (forrás).
Ebben az olvasatban kicsit megnyugtatóbb a helyzet. Amúgy abszolút támogatom a Wayland projektet, de sajnos csak dedikált Nvidia GPU van a szeretett Elitebook-omban, a Nouveau képességeivel meg nem igazán vagyok megelégedve. Hirtelen azt hittem, hogy a Fedora rákényszeríti az összes felhasználóra a Wayland-et, és az X11-et meg teljes egészében dobja (amit egyébként nyugodtan megtehetne, mert hivatalosan ők csak a nyílt meghajtókat támogatják, amikkel meg nincs gond...).
papasoft80
csendes
#5348
Nade most lehet, hogy én vagyok a gyengeelméjű, de itt is arról van szó, hogy 512-nek látja a rendszer, holott valójában 4k-s.
Nekem pont az a gondom, hogy 4/4k-nak látja a rendszer és szerintem ezért nem tudja megfelelően kezelni.
Korábban linkeltem egy oldalt, ahol a srác pont azt írta le, hogy az USB-s kapcsolat befolyásolta, hogy a rendszer milyen sector méreteket érzékel. A korábbi HSZ-eimben bemásoltam a terminal képeket, melyben látszik, hogy 4/4-nek érzékeli, a neten meg csak olyat látni, hogy 4096/512 vagy 512/512, olyat sehol nem találtam, hogy 4096/4096. Na mindegy, majd összerakok egy gépet linux-al és kipróbálom SATA-n.
Köszönöm a segítségeteket! -
papasoft80
csendes
#5341
Az normális, hogy a maximum filesystem blocks az jóval kisebb, mint a létrehozott partícióé?
[root@vmh boot]# fdisk -cu /dev/sdc
Note: sector size is 4096 (not 512)
Command (m for help): p
Disk /dev/sdc: 2000.4 GB, 2000398934016 bytes
228 heads, 37 sectors/track, 57892 cylinders, total 488378646 sectors
Units = sectors of 1 * 4096 = 4096 bytes
Sector size (logical/physical): 4096 bytes / 4096 bytes
I/O size (minimum/optimal): 4096 bytes / 4096 bytes
Disk identifier: 0x2cf0279a
Device Boot Start End Blocks Id System
Command (m for help): n
Command action
e extended
p primary partition (1-4)
p
Partition number (1-4): 1
First sector (256-488378645, default 256): 4096
Last sector, +sectors or +size{K,M,G} (4096-488378645, default 488378645): 488374272
/dev/sdc1 4096 488374272 1953480708 83 Linux
Command (m for help): W
The partition table has been altered!
Calling ioctl() to re-read partition table.
Syncing disks.
[root@vmh boot]# mkfs.ext4 -b 4096 /dev/sdc1
mke2fs 1.41.12 (17-May-2010)
Filesystem label=
OS type: Linux
Block size=4096 (log=2)
Fragment size=4096 (log=2)
Stride=1 blocks, Stripe width=0 blocks
122093568 inodes, 488370177 blocks
24418508 blocks (5.00%) reserved for the super user
First data block=0
Maximum filesystem blocks=4294967296
14904 block groups
32768 blocks per group, 32768 fragments per group
8192 inodes per group
Superblock backups stored on blocks:
32768, 98304, 163840, 229376, 294912, 819200, 884736, 1605632, 2654208,
4096000, 7962624, 11239424, 20480000, 23887872, 71663616, 78675968,
102400000, 214990848
Writing inode tables: 1777/14904 -
agy73p
csendes
#5308
Ezeket ismerem, mindegyiket többször megpróbáltam, de nem jártam sikerrel.
Másik topicban is írtam róla, de nem még nem tudtam megoldani. Meg ezzel is gond van.
csendes
csendes
#5282
A végén csak sikerült frissíteni Fedora 23-ra
. Sikeresen beleütköztem ebbe a bug-ba: [link]. Ha valaki dnf system-upgrade download --releasever=23 paranccsal akar váltani, véletlenül se használja a --distro-sync opciót. Ha mégis megteszi, akkor a dnf system-upgrade reboot után újraindított rendszer megpróbálja törölni az éppen futó kernel-t is, ezért el sem indul a frissítés, csak néhány másodperc után újraindul. Ezt eljátszottam háromszor, amíg megtaláltam a fenti bug-ot.
Amikor már fent van az új rendszer az új kernellel, akkor már működik a distro-sync is. Még arra érdemes figyelni, hogy a dnf autoremove által felajánlott csomagok közül mindegyik olyan volt, amit nem célszerű törölni, tehát csak megnézni érdemes, elfogadni nem.
Egyébként hihetetlen nagy újdonságok vannak, például új háttérkép. habár az is kék, mint az előző. Nekem az ilyen gnome mintás terítő helyett jobban bejöttek a régiek, mint a Verne, Goddard, Cambridge. -
agy73p
csendes
#4969
1. Az alapból be volt pipálva, hogy kis méretűre állítás a tálca aktív ikonjai közé, de így sem teszi.
2. Megtettem, remélem, h működni fog.
3. Tényleg, igazad van, ezt benéztem. Köszönöm.
4. Köszönöm.5. Chrome tegnapi frissítése óta indításkor jelez a SElinux, hogy
- r n g d - execmod
- chrome-sandbox - write.
Még nem vagyok szokva az ilyenekhez.... mit kell tenni? Visszavonni a frissítést? -
Tamy
csendes
#4952
Igen, minden stimmel, amit leírtál. Lehet támogatást kérni, csupán az a baj vele, hogy nem mondják meg mit csinálj, hanem megcsinálják helyetted. Persze ez egyfelől baromi kényelmes, de én jobban szeretem magam belakni, kialakítani az általam használt rendszert, így legalább tanulok is valamit. Másfelől nem hiszem, hogy a kedvemért egyből belepakolják, esetleg a következő verzióba majd bekerül.
Tamy
csendes
#4949
Tegnap este rájöttem mi a gond, csak már nem volt erőm tovább keresgélni. Mint említettem a szerver RHEL 6 alapú, de nem mezei RHEL, hanem Sulixerver, így csak a saját repojuk szerepel benne, amiből valamiért kihagyták. Megpróbálom hozzáadni a hivatalos repot, és abból felrakni. Azt hol tudom megnézni, hogy milyen csomagok vannak a hivatalos repoban? Mármint neten, még mielőtt hozzáadnám, nem a "yum list all" parancsra gondolok.
Mod.: Jobban belegondolva, akkor a hivatalos repoból se biztos, hogy fel tudom rakni, mivel az előfizetés nem arra szól?
Fenyő
csendes
#4936
Köszi, most még csak úgyis ilyen tesztelős gépen van majd meglátjuk hogy működik élesben, CentOs-el is szemezgettem, csak nincs hozzá xfce spin (a gnome3 nem igazán bejövős), epel repóból kéne utólag hozzáadni gondolom minimal install után, de annyira még nem voltam bátor, hogy bele is vágjak, pedig jól hangzik a 10 év támogatás.
qisqaqas
csendes
#4931
20 és 21 között nagyon sok részproject volt amit meg kellett csinálni. Még a fedora 18 után(asszem) határozták el a fedora.next projectet, egyeztek meg benne ami rengeteg stuktúrális átalakítást igényelt. Ezt az egy esetet leszámítva félévente jelentkeztek új verzióval.
cigam
csendes
csendes
#4843
Linux Deploy és gnome-shell (GS) androidos okostelefonon llvmpipe driverrel fejlemények:
Fedora 21: gnome-classic módban a nautilus elindul, programok indíthatók, de a WM nem megy
Debian Wheezy: GS 3.4 csak fallback módban megy (akkor is, ha az llvmpipe-ot whitelist-elem), ami nem lenne még baj, viszont a caribou indítás után azonnal elszáll, nincs képernyős billentyűzet.
Arch Linux: Kapásból elindult rajta a GS 3.14.2, megy a képernyőn a billentyűzet is, de 1920x1200 felbontással megy és ezért (és a szoftver renderelés miatt) nagyon lassú. GS-ben hiába vettem lejjebb a felbontást, nem reagált rá. Ezt próbáltam beírni az xorg.conf-ba, de erre el sem indult:
Section "Monitor"
Identifier "Monitor0"
Option "PreferredMode" "1280x720"
EndSection
Lehet, hogy a "Screen"-ben is definiálni kellett volna a Monitor0-t? Vagy alapból nincs 1280x720 mód? (a GS viszont felajánlotta, csak utána mégis maradt az 1920x1200 felbontás)
Még próbálkoztam E19-cel Arch Linux-szal, de kiderült, hogy a mobil felülethez szükséges "illume2" modul annyira ingatag, hogy bele sem fordították a bináris csomagba, aki forráskódból ABS-sel fordította, annak pedig nem működött. -
csendes
#4792
Igen erre emlékszem (már arra, h csak suspend volt és alt-al kellett előhozni a kikapcsot). De egy extension-al ezt meg lehetett fordítani. Arra meg nem is gondoltam, h most megpróbáljam az alt-os módszert
Na majd otthon megnézem... Nameg a systemctl módszert is, köszi
csendes
#4727
Eddig jó volt. Eddig támogatta? Mostmár nem? És mint írtam próbáltam rpm-fusion-ból (és máshonnan is) bevált (működő) módszerekkel (olyan F17 óta ezt a lapost használom, mindig gond nélkül települt a zárt NV driver). És nincs szükségem több DE-re - hamár fedorát telepítek - így nem vigasztal, h a többi működőképes...
Vladi
Vladi
csendes
#4571
Lényegében csináltak egy platformot, hogy a kutatók egységes szoftverkörnyezetet használjanak. Erről ír.
(#4572) cigam:
Azért, mert más a cél. Maga a linux csak eszköz. A fedora fejleszteni akar, oda kerülnek mindig az új cuccok. Ezeket tesztelik, terjesztik. Könyebb úgy fájlrendszert csinálni, ha van egy komplett disztró alattad. Meg egy bazi nagy közösség. Meg Mivel van fedora és az szabad, így lehet oda csábítani önkénteseket. Cégeket, akárkit.
De szerverre meg fizetős szolgáltatás alá pont ezért nem jó. Oda kell egy stabil rendszer. Ez a red hat enterprise linux. Namármost ennek 99%-a szabad szoftver. Azt nem zárhatod csak úgy be. Ki kell adni.
Akkor már van egy forrás állapotú, komplett disztrónk. Csak le kéne fordítani és akkor van egy ingyenes red hatunk.
Ezt csinálta a centos. Majd jött a red hat és felvette a listájára a komplett centet. Igaza van, ha azt írja, hogy piacot vett magának.Nekik ez jó, mert inkább az ő felügyeletük alatt legyen.
Az oracle ugyan ezt csinálja, csak pénzért.
A scientific meg akart egy egységes tudományos szoftver platformot. Összeválogatta a programjait. Egységesíteni meg úgy megint egyszerűbb, ha van egy komplett disztród.
kovaax
whbear
csendes
#4369
Nem csináltam vele semmit és magától megjavult mindkét gépen. Nem is frissített. Örülök neki hogy most minden jó, kicsit unalmas is ☺. Kipróbáltam az OpenMandrivát, először tetszett is, de napi használat során derülnek ki a dolgok. Egyenlőre úgy látom, hogy a Fedora az ideális számomra.
Fedy és yumex aztán megy minden gyönyörűen.
Szerk : A hibernálás továbbra sem megy de nem is kell. -
whbear
csendes
#4366
Amikor belassul a jelszó beírása után, hiába lépek át konzolra ctrl+alt +F2-vel, csak a fekete képernyő van meg egy ilyen kurzor villog_. Semmit nem lehet csinálni vele, nem tudom kiadni a top parancsot. 3.15.10.201 kernel van, a régieket kitöröltem. Hogy tudok másik kernelt felrakni? A Fedy-vel csak leszedni tudtam.
csendes
#4297
A fedorás disks (lemezek) nevű progival néztem, azt írja, h nem tudja kiolvasni a smart adatokat. Majd megnézem hdsentinel-el is. Nincs telerakva, csak a gép és a tv között viszem a filmeket 1-2 db vagy ahogy kedvem tartja. Ezt pendrive helyet használom, nem tárolok rajta semmit, csak az utóbbi időben megszaporodott rajta a "hibás" film azért kérdezem.
(#4299) Vladi: Úgy nem mai darab, h vettem vagy 2 éve, használtan
Sajna ntfs, a tv csak ilyen b.zi vindózer file rendszereket eszik
- MasterDeeJay: Egy nem átlagos Asus videókártya (GTX950M 2GB GDDR3)
- Milyen monitort vegyek?
- Hobby elektronika
- Nem követi az NVIDIA dupla pontosságra kialakított modelljét az AMD
- E-roller topik
- Az aktuális Xbox konzolokon is megfogja majd a játékos kezét a Copilot
- áthajtós érintős 360 szinteÚJ Dell 16 Plus 2-in-1 Ultra 7 258V INTEL Arc 140V 32GB 1TB SSD 16QHD+
- Samsung Galaxy Z Flip6 12/512GB - ÚJSZERŰ, Kártyafüggetlen, Kék - 1 év garancia
- Beszámítás! MSI Gaming Cyborg A15 FHD Gamer notebook - R5 240 16GB DDR5 512GB SSD RTX 5050 8GB
- GYÖNYÖRŰ iPhone 13 Mini 256GB Midnight -1 ÉV GARANCIA - Kártyafüggetlen, MS4426, 100% AKKSI
De ha a verziószámot nézem, akkor ez még a yumos, nem a dnf-es változat, mert az 4.akármi.
