gabross
Zenehallgatás közben nem melegszik windows-zal sem. Kevin Halverson (HRT, CTO) írta, hogy így viselkedik. Eleinte azt hittem, hogy csak az enyém szar.
If the temperature is actually elevated, the headphone amplifier will shutdown. In this condition, the line output would still be active as this is a separate path. With in specification voltage on the bus, it would not be likely that the amplifier could overheat, so if this is an actual over temperature induced shutdown of the headphone amplifier, it would be wise to check the host's USB supply for an over voltage condition.
Mac-en nem melegszik fel soha, igaz 1 perc idle után sleep-el a gépem és akkor automatikusan mute-ra állítja az amp részt.
