HookR
zed1983
#63201
AMD reportedly delays B840 and B850 motherboards to early 2025 — only X870 and X870E will launch in September - tomshardware.com
"The new B850 and B840 release date also confirms why there have been very few (if any) B850 or B840 chipset motherboards displayed at Gamescom 2024. With a
The release date is set for 2025, and AMD's partners are most likely waiting to showcase their new B850 and B840 motherboards at CES 2025."
- Vállalom telefonok,tabletek javítását ,(szoftveres hibát is,frp lock-ot is)márkától fügetlenűl
- BESZÁMÍTÁS! ASUS A320M R3 1200 8GB DDR4 370GB SSD GTX 1050Ti 4GB Zalman T3 Plus DeepCool 400W
- Bomba ár! HP Zbook 15u G5 - i7-8GEN I 16GB I 256-512SSD I 15,6" FHD I Cam I W11 I Garancia!
- Törött, Hibás iPhone felvásárlás!!
- REFURBISHED és ÚJ - HP Thunderbolt Dock G2 230W with combo cable (3TR87AA)
