t-bali3
válasz bkercso #19014 üzenetére
Most néztem meg ott ohm van, csak a bemásolás "k"-ra változtatta a jelet.
Ezek alapján ott 30 ohm szerepel.
Unbalanced Analog Outputs:
RCA outputs will conform to the –10 dBV convention for consumer grade equipment. The output impedance at
the RCA jacks is 30 Ohm and is low enough to allow for the use of high or low capacitance cable and the common
high capacitance of consumer receiver/amplifier inputs. Mono summing with a “Y” cable is not recommended as
this will cause high amounts of distortion. Mono summing with a “Y” cable can be accomplished with the use of a
modified cable by implementing a 1.25kOhm series resistor.
- Amazon Kindle
- Nyíregyháza és környéke adok-veszek-beszélgetek
- A régi node-okra koncentrál a szankciók miatt Kína
- Windows 11
- Facebook és Messenger
- The Last of Us Part I Ps5
