kismokesz
CPT.Pirk
#63560
kismokesz@kismokesz-Aspire-E5-511G ~ $ cd Letöltések
kismokesz@kismokesz-Aspire-E5-511G ~/Letöltések $ wine mtasa-1.5.6.exe
err:winediag:SECUR32_initNTLMSP ntlm_auth was not found or is outdated. Make sure that ntlm_auth >= 3.0.25 is in your path. Usually, you can find it in the winbind package of your distribution.ezt irja felraktam a winbind-et
utána ezt írjafixme:shell
rsFolder_OnCreate flags BIF_NEWDIALOGSTYLE partially implemented
fixme:shell:SHAutoComplete stub
err:setupapi:do_file_copyW Unsupported style(s) 0x144
fixme:inseng
llGetClassObject {6e449686-c509-11cf-aafa-00aa00b6015c} {00000001-0000-0000-c000-000000000046} 0x33d0c8
err
le:apartment_getclassobject DllGetClassObject returned error 0x80040111
err
le:create_server class {6e449686-c509-11cf-aafa-00aa00b6015c} not registered
err
le
oGetClassObject no class object {6e449686-c509-11cf-aafa-00aa00b6015c} could be created for context 0x5
fixme:inseng
err
err
err
le
fixme
le
oInitializeSecurity ((nil),-1,(nil),(nil),0,3,(nil),0,(nil)) - stub!
fixme:wbemprox:client_security_SetBlanket 0x7d7892c4, 0x165680, 10, 0, (null), 3, 3, (nil), 0x00000000
fixme:wbemprox:client_security_Release 0x7d7892c4
fixme:service:SERV_QueryServiceObjectSecurity 0x1ee718 4 0x33f440 0 0x33f434 - semi-stub
fixme:service:SERV_QueryServiceObjectSecurity 0x1ee718 4 0x1c60c8 28 0x33f434 - semi-stub
fixme:service:SetServiceObjectSecurity 0x1ee718 4 0x33f40c
wine: Unhandled page fault on read access to 0xfffff78000000320 at address 0x457034 (thread 003a), starting debugger...
fixme:service:SERV_QueryServiceObjectSecurity 0x1c6018 4 0x33f708 0 0x33f6fc - semi-stub
fixme:service:SERV_QueryServiceObjectSecurity 0x1c6018 4 0x1b1248 28 0x33f6fc - semi-stub
fixme:service:SetServiceObjectSecurity 0x1c6018 4 0x33f6d4
wine: Unhandled page fault on read access to 0xfffff78000000320 at address 0x457034 (thread 001e), starting debugger...
kismokesz@kismokesz-Aspire-E5-511G ~/Letöltések $ fixme
le
fixme:wbemprox:client_security_SetBlanket 0x7d7842c4, 0x15c658, 10, 0, (null), 3, 3, (nil), 0x00000000
fixme:wbemprox:client_security_Release 0x7d7842c4
fixme:service:SERV_QueryServiceObjectSecurity 0x108e808 4 0x33f530 0 0x33f524 - semi-stub
fixme:service:SERV_QueryServiceObjectSecurity 0x108e808 4 0x1b2d70 28 0x33f524 - semi-stub
fixme:service:SetServiceObjectSecurity 0x108e808 4 0x33f4fc
fixme:service:SERV_QueryServiceObjectSecurity 0x1c6920 4 0x33f440 0 0x33f434 - semi-stub
fixme:service:SERV_QueryServiceObjectSecurity 0x1c6920 4 0x1c6370 28 0x33f434 - semi-stub
fixme:service:SetServiceObjectSecurity 0x1c6920 4 0x33f40c
wine: Unhandled page fault on read access to 0xfffff78000000320 at address 0x457034 (thread 0039), starting debugger...
wine: Unhandled page fault on read access to 0xfffff78000000320 at address 0x457034 (thread 002e), starting debugger...
fixme:service:SERV_QueryServiceObjectSecurity 0x10b1fc0 4 0x33f268 0 0x33f25c - semi-stub
fixme:service:SERV_QueryServiceObjectSecurity 0x10b1fc0 4 0x1fca98 28 0x33f25c - semi-stub
fixme:service:SetServiceObjectSecurity 0x10b1fc0 4 0x33f234
wine: Unhandled page fault on read access to 0xfffff78000000320 at address 0x457034 (thread 0035), starting debugger...
fixme
le
fixme
le
fixme:service:SERV_QueryServiceObjectSecurity 0x1c7c60 4 0x33f4e4 0 0x33f4d8 - semi-stub
fixme:service:SERV_QueryServiceObjectSecurity 0x1c7c60 4 0x1ed998 28 0x33f4d8 - semi-stub
fixme:service:SetServiceObjectSecurity 0x1c7c60 4 0x33f4b0
wine: Unhandled page fault on read access to 0xfffff78000000320 at address 0x457034 (thread 0018), starting debugger...
fixme:service:SERV_QueryServiceObjectSecurity 0x109c7b0 4 0x33f21c 0 0x33f210 - semi-stub
fixme:service:SERV_QueryServiceObjectSecurity 0x109c7b0 4 0x167538 28 0x33f210 - semi-stub
fixme:service:SetServiceObjectSecurity 0x109c7b0 4 0x33f1e8
wine: Unhandled page fault on read access to 0xfffff78000000320 at address 0x457034 (thread 0025), starting debugger...
fixme:win:EnumDisplayDevicesW ((null),0,0x33efd4,0x00000000), stub!a végén bejön az ablak mint ha indítaná közbe meg nem hanem CL25-hibát ír
Információ(CL25)
GTA: San Andreas nem indult el megfelelően. Szeretnéd ezt megszüntetni?ha arra nyomok hogy igen akkor bezárja a Wine-t ha meg arra hogy nem akkor megnyitva hagyja a Wine-t
Frawly
CPT.Pirk
#63459
Az „újabb” inteles GPU-kat úgy kell érteni, hogy i965 és attól újabb, azok azért már jó pár évesek. Ennek az az oka, hogy a Xorg Intel drivert már alig fejlesztik egy ideje, majdnem teljesen magára hagyott projekt, csak némi folt készül hozzá, minden fejlesztő az Intel modesetting kerneldriver fejlesztésére állt át.
Gond úgy szokott lenni belőle, hogy a Xorg Intel driverrel elkezd a kernel ilyen atomic DRM helper/flipping lófütyi hibákat dobni, meg a login manager vagy a Xorg fagyni. Random. Van, akiknek bizonyos nem használt GPU csatlakozók (S-VIDEO, HDMI, stb.) letiltása segít, nálam Intel HD3000-en nem segített.
tonyrulez
CPT.Pirk
#63443
Intel-microcode telepítésre jelzi hogy a legfrissebb már fent van.
Ha terminálban a fájlt is megadom smplayer-nek, akkor sem ír ki semmit, ugyanazt mint az előző hosszászólásomban is
vdpauinfo kimenet:
tonyrulez@acerpc:~$ vdpauinfo
display: :0.0 screen: 0
Failed to open VDPAU backend libvdpau_i965.so: cannot open shared object file: No such file or directory
Error creating VDPAU device: 1smplayer-ben video kimeneti meghajtónak vdpau-t választva ugyanúgy szaggat a videó, ha nem rosszabban.
Még mplayer és smplayer üzenetnaplóval tudok szolgálni amit smplayer GUI-ban leltem.
tonyrulez
CPT.Pirk
#63434
Feltettem az Ubuntu MATE-et. Ugyanúgy szaggat a videó, pontosabban alig megy. A beépített "További ilesztőprogramok" app szerint "Nincsenek elérhető illesztőprogramok."
Feltettem a vainfo-t, itt a kimenet. Terminálból indított smplayer semmit nem ír ki, ez is szerepel a fenti paste-ben.vdpau-ból fent van: libvdpau1, mesa-vdpau-drivers, vdpau-driver-all
vaapi-ból pedig: gstreamer1.0-vaapi, i965-va-driverPlusz info:
tonyrulez@acerpc:~$ lspci -nnk | grep -i VGA -A2
00:02.0 VGA compatible controller [0300]: Intel Corporation Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Integrated Graphics Controller [8086:22b1] (rev 21)
Subsystem: Acer Incorporated [ALI] Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Integrated Graphics Controller [1025:100f]
Kernel driver in use: i915Mi lenne a következő lépés?
Sajnos így használhatatlan a gép videonézésre, pedig Win10-en simán menne.
tonyrulez
CPT.Pirk
#63432
Igen, így már végigment. TLP system startup/shutdown-on túljutottunk, most az azt követő "Started Load/Save RF Kill Switch Status"-nál állt meg a boot
És a következő újraindításnál megint a TLP-nél... Szerintem ennek itt véget vetek, és felteszem holnap az Ubuntu Mate-et. Neked pedig köszönöm a kitartó segítséget
tonyrulez
CPT.Pirk
#63427
Haladok, első kettőt sikerült lefuttatni, majd
sudo mkinitcpio -p linuxután kijött ez a hiba:/usr/bin/mkinitcpio: line 261: /etc/mkinitcpio.d/linux.preset: No such file or directory
==> ERROR: Failed to load preset: '/etc/mkinitcpio.d/linux.preset'ubyegon2 Szeretek szenvedni
Bár nem tudom mi volt az én hibám, fogtam a Manjaro beépített kernel letöltőjét, listában rányomtam adott kernelnél letöltésre, majd grub-ban kiválasztottam, nem ment, akkor vissza az eredetire, és már az sem. Még egy ideig próbálkozok, különben reinstall, de azt már csak holnap -
tonyrulez
anorche1
CPT.Pirk
#63406
Ja igen, bocs, lemaradt.
A gep egy dell E6440, integralt gpu val (hd4600).
Es igen, csak teamviewer alatt jon elo (de lehet, hogy pl. kepernyo video rogzitesnel is elojonne, meg nem probaltam).Szerk.: Nem igazan toredezes, inkabb ablak reszletek eltunese, felvillanasa. Olyan szinten, hogy ha le van zarva a gep, teamviewerrel akkor is be lehet latni a gepbe
CPT.Pirk
#63326
nincs vele baj, úgy a programod saját library készlettel tud működni, nem fog függni a rendszerben meglévőktől.
Akkor rakj fel egy Ubuntut!
A Flatpak a Mint-en is elérhető, de aki nem használ Szoftverközpontot, nem is találkozik vele, nem ügyködik a rendszerben, ellentétben a snap-pal.
(#63328) Shyciii
Ez a leírása az egésznek viszont érdekel, átküldheted emailben. (priv go now)
cattus
CPT.Pirk
#63319
20% max, de nyitva van mellette jópár böngésző tab, a memóriafogyasztás is azért annyi, amennyi.
ubuntu-driverscsomaggal próbáltam keresni hátha van amit nem rakott fel, de szerinte minden up-to-date.A hálózattal bitzos nincs semmi gond és nem is az a bottleneck, mert szimmetrikus gigabites.
CPT.Pirk
#63319
vazze, inkább igyál. A sörben legalább van vitamin és nem büdös.
Igazad van, akkor legalább kába leszek, fel sem tűnik, ha megfulladok a jó városi levegőtől!
amúgy ezek micsodák? A snap csinálja?
/dev/loop0 196M 196M 0 100% /snap/vlc/555
/dev/loop1 88M 88M 0 100% /snap/core/5742Amúgy nem hiszem, hogy networkmanager probléma lenne a kollégánál, de elég harapófogós nála a hw-környezet/terhelés, az is fura, hogy 4GB-ot mi eszi meg nála.
ez viszont kemény: - feltöltés 900Mbit
cattus
CPT.Pirk
#63316
Partíciók:
Filesystem Size Used Avail Use% Mounted on
udev 3,9G 0 3,9G 0% /dev
tmpfs 786M 1,6M 785M 1% /run
/dev/sda2 234G 18G 204G 8% /
tmpfs 3,9G 222M 3,7G 6% /dev/shm
tmpfs 5,0M 4,0K 5,0M 1% /run/lock
tmpfs 3,9G 0 3,9G 0% /sys/fs/cgroup
/dev/sda1 511M 6,1M 505M 2% /boot/efi
tmpfs 786M 44K 786M 1% /run/user/1000Ezt a Xubuntu telepítője csinálta magának ilyenre.
1db 256-os M.2-es SSD van benne. RAM-ból van 8GB össz, szabadon 4GB volt.
CPT.Pirk
#63312
Lehet, hogy ez is számít, de amúgy az Infinality viszont nagyon tetszett, az pengeéles volt. Elképzelhető, hogy a 20"-os monitoron nem jött át a képed. Abból is gondolom ezt, hogy KDE-n általában alapból jók a betűk, emlékeim szerint sokkal jobban tetszettek, mint máshol. (ha nem utálna a KDE, már rég megkedveltem volna én is)
(lehet, hogy cigifüstös a monitorom.....)
Cifu
CPT.Pirk
#63275
A Bionic kiadásra akarod a Cosmic csomagjait felrakni, azokból is a git-es úgymond nem végleges csomagokat. Biztos ezt szeretnéd?
Én feltelepítettem a Steam-et. Ő szeretné frissíteni a csomagokat, nem én. Én csak próbálom ezt a kulimászt összelapátolni, ha már a Steam telepítője képtelen erre.
Cosmic alatt 18.2-es Mesa van, ami már bőven jó hozzá és akkor nem kell kézzel összeborítanod a csomagadatbázist.
Ó, miután önmagától nem képes a Steam megoldani a problémát, illetve a különféle próbálkozásaim az apt-get-el sem vezettek eredményre, gondoltam majd google hoz valami eredményt. Hát találtam egy fórumbejegyzést, ahol egy nagy tudású azt mondta, hogy semmi gond, törölni kell a lib32stdc++, aztán letölti magának, és az jó lesz.
Én marha meg követtem, és rögtön utána szembesültem vele, hogy a lib32stdc++ nélkül nagyjából semmi sem működik. Még újraindítani se lehetett GUI-ból a gépet, nem megy az apt-get, sőt, még a Konsole (a kubuntu konzolja) se futtatható. Szerencsére a böngésző, az X console és a dpkg működött, így sikerült végbéltükrözéssel visszavarázsolnom a lib32stdc++ fájlt a gépemre, alig fél óra szenvedés árán.
CPT.Pirk
#63261
Ez a frissítés service inkáb azoknak jó, akik nem terminalból intézik a frissítéseket, de ugye az Ubuntu ebbe az irányba megy értelemszerűen, hogy a totál laikus is ellegyen a desktop Linuxon.
A gyakorlottabbak meg ki tudják kapcsolni, amire nincs szükségük, akár GUI-ból is.A gyors FF is azt igazolja, hogy nem csak az számít a rendszernél, hogy milyen proci, mennyi memória, milyen VGA, sokszor gyengébb gép is pörgősen megy, ha szerencséje van az embernek, az általad említett optimalizálás miatt.
Sokszor olvasom még most is, hogy úgy tudják, az AMD nem túl szerencsés Linuxon, közben meg utóbbi időben rendkívül jó lett a nyílt driver.
(#63260) Shyciii
Az a külön nVidia nem szerencsés szerintem, főleg olcsóbb gépekben.
CPT.Pirk
#63249
Tudja a manó, de szerintem először lefut és a nulla órai időzítés miatt és utána aznap már nem fut le a daily cron. Ezek időzítését még soha nem baráltam(vagyis de, viszont már nem emlékszem miért), de gondolom lehet ezt finomítani, ha hourly, weekly, etc. cron-okba ki/berakosgatod őket.
(#63258) Shyciii
11.5sec !? Az még elmegy. Tegnap a HP8570p-n ki akartam próbálni egy Antergos OB-t, milyen gyors lesz.....hát ugye a szokásos. Arch klónok, azóta se kép se hang, még csak a meghajtót se akarja látni a laptop, pedig volt már pár Ubuntu alapú rajta gond nélkül. Szerencsére nincs időm most a HP-vel vacakolni......de a gyors bootidő nem jött be!
Silεncε
Frawly
CPT.Pirk
#63159
Ezt igazából a driver okozza, nem az S-video kimenet. Az Intel driverek egyre x@rabbak sajnos. A Xorg-Intel drivert nem nagyon gondozzák. A kernel modesetting drivert meg nem szereti a Xorg újabban. Én is ezért váltottam Waylandra, abból is a Gnome tűnt a legműködött alternatívának, de talonban van tartva a Sway (i3wm-klón Waylandre). A Wayland teljesen jól elvan a kernel modesetting driverrel.
Nálam a Wayland is szórakozik egy ideje, néha nem áll le a GDM, 1 perc 39 másodpercig tart, mire leálláskor néha lelövi a rendszer, ilyen A stop job is running jeligével számol vissza. Ezt sajnos meggyorsítani sem tudom, pedig átírtam a systemd konfigjában (DefaultTimeoutStopSec értékét levettem az /etc/systemd/system.conf-ban), de nem segít, állítólag ezt csak a systemd újrafordításával lehet rövidíteni. Be kéne vezetniük erre egy billkombót, aminek a lenyomása után azonnal lelőlné az adott folyamatot. Mert így is kilövi, szabálytalan leállítással (sigterm helyett sigkill), csak sokat kell rá várni. Pöcstering dolgozhatna még ezen.
Még az is lehet, hogy a GDM Xorg-emulációt használ, nem Waylandet, és ez amiatt van. Az biztos, hogy driver gond, de más baj nincs vele, a képi megjelenés tökéletes, fagyások sincsenek, sem más anomália, csak néha leragad ennél leállításkor.
cigam
CPT.Pirk
#63137
Már nem elég egy mezei "Escape"-et nyomni?
ubyegon2
A Mint sem különb a többinél. Pl. az Intel VGA driver hibám (drm timed out) is ugyanúgy előjön vele. Nem csoda, hiszen ugyanazt a kernelt, és driver-t használja, mint az összes többi, és ugyanazt az XFCE-t mint az összes többi, csak másképpen van feltupírozva(háttérkép, színek, és pár program). -
JetiRulez
CPT.Pirk
#63130
Beírtam a parancsokat. Itt van rá a válasz, amit kiadott nekem a terminal. Nekem nem mondanak sokat ezek a sorok. Azt látom, hogy ott van az "1 min", de a 3,5 perces "semmit" nem listázza. [link]
Ez pedig a "journalctl -b"-re adott eredmény: [link]
ubyegon2: Ez a cikk adott nekem motivációt ismét nyitni a Linux világa felé. A cikkíró kezdőknek a Xubuntut ajánlotta leginkább a könnyebb disztribúciók közül. [link]
Pano
CPT.Pirk
#63106
Linux Mint 19 xfce
Linux PSystem-PC-Linux 4.15.0-38-generic #41-Ubuntu SMP Wed Oct 10 10:59:38 UTC 2018 x86_64 x86_64 x86_64 GNU/Linux
OpenGL version string: 3.0 Mesa 18.0.5
Kompozitorban melyiket érdemes használni? Szabad stabilitás ügyileg foglalkozni még a compizzal?
Jelenleg xfwm4+Compositing van beállítva, de nem az igazi (pl.: ha teljes méretűre nyitva zárom be a firefoxot, másnap bekapcsolom a gépet és elindítom a firefoxot a képernyő fele feketén, üresen nyílik meg, másik felén meg a firefox. De ez előfordul más programmal is). Compoton se, de compiz sokkal jobbnak tűnik (animációkat nem használok). -
Shyciii
CPT.Pirk
#63056
Nekemaz Intel HD620-as is rak ki "képet" boot közben, persze a kernel paraméterek közül ki kell venni a quiet-et
amúgy most Openboxos archnál nekem is nagyban mutatja, majd normális méretben, a kde-s archnál végig normális méretben, de engem nem zavar. Főleg, hogy olyan gyorsan pörög át rajta, hogy feleszmélni sincs ideje az embernek
Norbi887
CPT.Pirk
#63049
Igen ezen az EDID Chip-es dolgom filóztam énis, hogy az lehet, mert ha pedig a Main monitoromat kötöm be, ami mellesleg HDMI-ről megy, (Egy FullHD Phillips monitor), ott gond nélkül felismeri név szerint, és natív felbontással dolgozik is szépen.
DVI-al sajna nem tudom megoldani, úgyhogy ki kelett kötnöm! Köszi a választ!
Mostmárcsak az utóbbi dolog volna amire kiváncsi volnék, meg lehetne e oldani valahogy, az pedig ugye - mint írtam is, a plymouth-nak az alacsony felbontása boot során. Van erre egyáltalán megoldás, vagy egyszerűen felejtsem el inkább? Annyit tudok hogy azért alacsony még boot alatt mert ott még nem töltődik be a driver telejesen.
Norbi887
CPT.Pirk
#63047
Ubuntu 18.10-ről vagyok.
Kipróbáltam úgy is a dolgot, hogy csak is egyedül az 1280x1024-es Dell-t dugtam rá a gépre, igen VGA-ról.
Az eszközöknél "Ismeretlen"-címszóval jelezte ki a monitort még mindig, ugyancsak max 1024x768-as felbontással. Pedig ezúttal mondom csak ő volt egyedül bedugva a vga-ba.
Lehetséges hogy mivel nagyon régi monitor, így azt nem támogatja már az OS?
+Másik gyors kérdésem lenne még, hogy azt semmiképpen nem lehet megoldani, hogy NVIDIA driverekkel a boot képernyő ne 800x600-as legyen, hanem az is natív (1920x1080)-as képfelbontással jelenjen meg?
Nem nagy cucc, csak azért ha valahogy meglehet oldani, nem lenne rossz
southernsun
CPT.Pirk
#63022
A script indítópultban való automatikus elindítása nem elég, azonosítani kell az USB portot, amin az MCE infra vevő van, gondolom, így bekapcsolt állapotban is működik, meg alvó állapotból is fel tudom ébreszteni vele a gépet.
lsusb-re ezt dobta, ez a vevőre vonatkozó sor:
Bus 003 Device 003: ID 1934:5168 Feature Integration Technology Inc. (Fintek) F7
Nekem ezt kellett Mint 17- nél /etc/rc.local -ban rögzítenem rendszergzdai jogokkal:
script neve 1934:5168 (exit 0 feletti sorba).
Most az a kérdés ezt hogyan tudom megoldani?
Amit ubyegon2 írt, mint lehetséges beillesztési helyet (rc.local.service), az nekem nem működik, vagy valamit nem jól csinálok. -
MuldR
CPT.Pirk
#62876
Mint a windows terminal server services.
A kliens egy rendes full HD grafikus felületet lát, de nem azért mert a konzolt átveszi, hanem mert a szerverről kapja a szolgáltatást.
Pl Windowsnál asszem 32 klienst tud így kiszolgálni. Nekem csak 2 kellene és Linux alapon. De ez gyorsan látható is, hogy 2 ember nem tud egyszerre egy kliensen dolgozni. Vagyis tud, csak nem túl hatékony. -
lukaszokni
CPT.Pirk
#62851
Köszönöm!
Alapvetően ágyban filmezésre szoktam használni hálózatról, a netezés csak egy plusz luxusfunkció lenne, ha esetleg odaadnám szüleimnek, hogy használják.
Most win10 van rajta, mert legálisan felfrissíthettem anno, el tudod képzelni mennyire hasít.
Bekapcsolás után fél óra jó esetben, mire a háttérben a karbantartó, az antimalware, a wsappx és egyéb processzek lefutnak kötelezően, ha a frissítés is terítéken van, akkor két óráig kb használhatatlan a masina.
Az ablakkezelő néha megeszik 15-20%-ot a processzorteljesítményből - nonsense.
Szóval ha ennek, amit linkeltél, csak a fele vagy kétharmada az erőforrásigénye, már sokkal jobb a helyzet.Ezt a kört másodjára probálom futni, jó 5-6 éve már egyszer felheggesztettem rá egy linuxot, de pont azért szedtem le, mert egy driver problémát terminállal kellett volna megoldani és sok-sok óra próbálkozás árán sem ment nekem.
Akkor ránézek erre a Mint XFCE-re, egy VLC-t tennék fel rá, ha kész, és mehet a mozi remélem.
Shyciii
CPT.Pirk
#62823
Fstab mountolta be. Manjaro KDE alatt sem megy, pedig friss telepítés. Amúgy ez a probléma hivatalos bug-ként fel van véve, szal nem egyedi gond. Viszont...Egy idióta gondolattól vezérelve felraktam a gvfs-mtp -t. Mert bár ez gnome-osoknak van tehát Thunar, Nautilus, illetve inkább GTK-soknak, de mondom amilyen idiótaságok vannak most ki tudja. Hátha a Double Commander QT5-ös is szeretni fogja. És lőn bakker. Felrakva már látszik a Double COmmanderben újra az MTP-s kapcsolat, és szépen másolja is. Lassan sikítani fogok
Persze ettől még az FT-s képek másolása hogy elbassza a képeket még megvan, tehát mindenképp el kell hagynom a pure Arch + KDE kombót. Ha lesz sok időm (bár most lenne mert betegszabin vagyok, de ma is, meg holnap is kell távoliznom munka céljából), akkor egy Arch + Cinnamon-t megpróbálnék. Hátha tud mindent ami nekem kell, és nincsenek ilyen alapvető hibák.Viszont azon kezdtem gondolkodni, hogy nekem van olyan vágyan, hogy le lehessen zárolni a gépet. Plusz lehessen a noti fedelét lehajtva is zárolni. XFCE alatt egyáltalán nem volt ilyen funkció. Viszont felvetődött bennem, hogy ez a zárolás funkció ez egyáltalán az ablakezelő dolga? Nem a DM dolga? Tehát a LightDM, GDM, SDDM dolga lenne? Mert ha igen, akkor lehet hogy mégiscsak XFCE jó nekem, csak nem LightDM-el, hanem GDM-el, vagy SDDM-el.
Shyciii
CPT.Pirk
#62767
No most már tuti, hogy a WesternDigital My Passport 2TB-os winyó a ludas. Kicsit pofátlan voltam, és ha már betegszabin vagyok átmentem a szomszédba, bemutatkoztam, és megkérdeztem, hogy van-e számítógépük és külsős winyójuk
Van nekik egy még régi szögletes Toshiba winyójuk, és lőn azt felismeri, és stabilan 110MB/sec-el olvas és 94MB/sec-el ír, tehát annak USB3.0-ásnak kell lennie ekkora sebességgel. Szal ez a mocsadék WD My Passport winyó nem tetszik a Linuxoknak. Közben dd-vel már írom ki a WIndows-t, és utána megy a telepítés, és megnézem hdsentinel alatt. -
leviske
CPT.Pirk
#62724
Igen, sajnos azzal mutatkozott be, hogy a fájlok visszamásolása (azaz pendrive to SSD) közben a panel az alkalmazás menüvel (vagy mi az ami a Kubuntu jelre kattintva jön elő) együtt csontra fagyott és akkor gyógyult csak ki, mikor a másolás véget ért, 0,5-1 perc múlva. Ilyesmi Neon-on sosem volt, sőt azzal még kevesebb gondom volt, mint a Windows 10-el.
Lehet, hogy csak kell neki egy kis idő, de a Neonnak nem kellett.
(#62725) Dave™: Azt vágom, hogy a Neon-on a KDE rolling release alapon fut és a lehető legkorábban jön ki rá minden. Csak arra lennék kíváncsi, hogy az Ubuntu alapba bele szoktak-e nyúlni, vagy csak a KDE-s szoftvereket finomítják ahhoz, hogy helyén legyen a felhasználói élmény. Ha utóbbi, akkor nagyon veszélyes Neon-féle KDE repóra átállni Kubuntu 18.04 LTS-en? Egyáltalán lehetséges?
(#62727) sh4d0w: A korábbi próbálkozásaim során a rendszer nem volt mindig ennyire megtörhetetlen.
Anaren91
CPT.Pirk
#62722
Ok szerintem megvan a baj... Valószínűleg nem tetszik neki a 8 gigás ram modul amit bele tettek... Próbáltam windows 10 et feltenni, de a logo után újra indult a gép, és csinált egy diagnosztikat ( kikapcsoltam a quick bootot) 8 ból 2 giga átmenet a diagnosztikán majd ott megfagyott a gép.
Quick bootra kapcsolva ugyan azt a bootloopot produkálja mint haver ryzen gépe ami nem szerette a ramkitet amit vett. Fasza holnap mehetek vissza a boltba... -
CPT.Pirk
#62718
Persze, reklám pendrive-ok, amire 64GB van írva. Ne nevettess, mert ki van repedve a szám!
Egy vadiúj laptop közelébe se engednék egy ilyen reklámszemetet.(van itthon 6 db ilyen céges pen, direkt tesztelni hoztam anno - alapból csak 4-et tudtam megírni)
Mondjuk ezek a pendrive-ok akkorák is, amekkorának írva vannak.64gigás reklámpendrive!!!! wooooow -
CPT.Pirk
#62710
Esetleg ha telepítek egy windowst, ott nem lehet elindítani a telepítést és a Windowst legyalulva felrakni ezt a szutykot?
vs
akkor Windows alól írod ki a telepítő médiát. Honnan máshonnan?
(#62711) Anaren91
Másik pendrive-ról meg kéne próbálnod, mert a live-nak futnia kéne, tök mindegy, van-e bármilyen meghajtó a gépben. (épp ez a lényeg, mert live-ból a inicializálatlan meghajtót kell esetenként kezelned)
Van néhány egzotikus pendrive, aminél anno olvastam ilyet, hogy nem nagyon szereti a Linux iso-kat. -
Anaren91
CPT.Pirk
#62706
Még arra adj nekem választ kérlek, hogy az nem lehet e, hogy tekintve az ssdre semmi nem volt még telepítve, valahogy particionalnom kellene és akkor ki tudná rá csomagolni a telepítő fájlokat. Mert ha jól kaptam el, akkor valami olyasmit írt ki az egyik ujraindítás előtt, hogy nem tudt kicsomagolni valami csomagot.
Codecoolnál kezdek és ha jól látom elég sok mindenbe bele fogunk kóstolni. Programozni sose programoztam nem is nagyon értek még hozzá, de ezért megyek tanulni 🙂
CPT.Pirk
#62706
Szerintem, ha ez valami komolyabb képzés, akkor direkt írtak elő core 2-es gépet és 18.04.1-et, aki kiszúrja mi az idiótaság a követelményeknél, abból még lehet bármi is. (ha viszont nem direkt írták így, akkor valami nagyon nem kerek)
Ha mondjuk még a Linux telepítést is Win alól akarja csinálni az ember......fene tudja, programozóknak kell minimális türelem amúgy?
(#62681) Anaren91
A 64 gigás pendriveot meg nem is látja.
Ezt a mondatot nem értem a kezdő hsz-edben. Mi nem látja a pendrive-ot? Egy elindult(majd megállt)telepítési folyamat közben vagy végén honnan gondolod, hogy bármi is látja vagy nem látja a pendrive-ot? Addig nem arról ment a folyamat?
Anaren91
CPT.Pirk
#62706
Én elhiszem neked, hogy 16.4 re is felmegy minden tekintve életembe csak videóban láttam Linuxot, de ha azt írják nekem emailben, hogy mindenki a 18.04.1 et telepítse, akkor nem fogok odamenni 16.4 el, mert nem azt kérték. Ennyire egyszerű. ISO módban írtam ki de akkor még egy próbát adok neki, bár legutóbb etcherrel írtam ki és ott nincs lehetőség a kettő közül választani és úgy se működött
Anaren91
CPT.Pirk
#62704
Hétfőn kezdek programozó képzésen és 18.04.1 kell... Nem hiszem el hogy nem lehet telepíteni egy i5 ös laposra, mikor neten egy szaros core 2 van megadva követelménynek
Esetleg ha telepítek egy windowst, ott nem lehet elindítani a telepítést és a Windowst legyalulva felrakni ezt a szutykot? -
carrilboy
CPT.Pirk
#62698
18.3 elindult.
Köszönöm mindenkinek!Most a partíciókkal vagyok gondban.
2 partíciót akarok a Linuxnak,egy rootot meg egy swapot. Meg is csináltam őket.
De a win10-nek eleve van 4 partíciója (wtf?)
És asszem van vmi olyan hogy max 4 elsődleges partíció lehet. Ilyenkor mi van?Bocs,életemben most először telepítek Linuxot.
Alább a kép.A rootnak szánom az 48.83 gigás partíciót, a swapnak a 7.79 gigásat.
Lemez0-ról beszélünk. -
CPT.Pirk
#62648
Linux programok topic - (Milyen program, ami..? Linux verzio)
Ugye nem oly rég ez is született. Anno volt is ilyen terv, hogy a kezdő topikok összevonásra kerülnek és lesz pluszban egy Linuxos programok, játékok topik is.
Ha nem is külön, de a fentibe be lehetne integrálni, a névváltoztatást egyszerűen megoldják a negybetűsök. (te fogod kérni majd)
Ahogy haladnak a dolgok jó irányba Linuxos játékok terén, célszerű lenne elkülönítve kezelni, mert itt csak elvész a rengetegben az azzal kapcsolatos hsz.
leviske
CPT.Pirk
#62646
Ha már másik topic. Az már felmerült korábban, hogy esetleg a kezdők meg haladók topicok mellé becsatlakozzon egy "Linux Gaming" is natív portok, DXVK/Lutris/Wine stb fókusszal? vagy a témával nem foglalkozik annyi ember erre, hogy pásztorolni tudja a kezdők ezen csoportját?
Erwinke
CPT.Pirk
#62579
Kicsit probalkoztam vele, ha mar sosem volt meg szerencsem ilyen rendszerhez.
Ilyesmi,h frissites v,h milyen verzio van rajta sehol nem talalni... xD eleg szorakoztato,h meg veletlen se lehessen belenyulni. Viszont van lehetoseg az automat frissitesre ami aktiv is volt.(de,h mikor frissitett utoljara v h van e frissites arrol semmi info )
Szerencsere a szentharomsag mukodik(ctrl,alt,del) ugyh a teljesitmenyt megtudtam nezni. O Chromet hasznal es azalatt teszteltem(allitolag Neki beszokott akadni a FB meg a youtube). Nah en megnyitottam 10 ablakot(fb, 2 youtube 1 sima vidi + zene ment, 9gag es egyeb ilyen terhelos oldalakat) proci 20%on ment(uresben2%). A ram meg 2.5gb a 3.7bol.
Teny es valo,h hosszas gorgetes utan a fb nehol megakadt, de am szerintem egy ilyen geptol tobbet nem igazan lehet elvarni : )
Reszemrol oke. Csak kivancsi voltam,h tudtok e valami okosat hozza, mert nekem nagyon uj ez.Koszonom! Szep estet.
teleahocipöm
Milyen program ami... [link]
- Teszt [Linux] A Flatpak
- Milyen asztali médialejátszót?
- Gitáros topic
- Gumi és felni topik
- E-roller topik
- Elemlámpa, zseblámpa
- Red Dead Redemption 2 (PC)
- Mini PC
- Keresem a Barkács Balázs Játékokat
- ÚJ Razer Kraken V4 Pro gamer fejhallgató
- Apple iPhone 14 Pro 256GB,Újszerű,Dobozával,12 hónap garanciával
- Játékra vagy Munkára! Csere-Beszámítás! I7 3930K / Nvida GTX Titan B / 16GB DDR3 / 500GB SSD!
- Apple iPhone 13 128GB,Átlagos,12 hónap garanciával
- ÁRGARANCIA! Épített KomPhone Ultra 7 265KF 32/64GB RAM RTX 5070 12GB GAMER PC termékbeszámítással
Komoly hogy ennyit kell csak beállítani "ne legyen szar a videó?" "légyszi"
Az aztán a provokenkodás!
(no meg, hogy a kolléga ne szívjon el féldoboz cigit a próbálkozások miatt)
