  • CounterBoci
    válasz sz_abika #10380 üzenetére
    Igen.
    Mit akarsz rákötni? Alább az USB porton folyó áramerősségekről szóló szösszenet:
    "Power
    The USB 1.x and 2.0 specifications provide a 5 V supply on a single wire from which connected USB devices may draw power. The specification provides for no more than 5.25 V and no less than 4.75 V (5 V±5%) between the positive and negative bus power lines. For USB 2.0, the voltage supplied by low-powered hub ports is 4.4–5.25 V.[34]
    A unit load is defined as 100 mA in USB 2.0, and was raised to 150 mA in USB 3.0. A maximum of 5 unit loads (500 mA) can be drawn from a port in USB 2.0, which was raised to 6 (900 mA) in USB 3.0. There are two types of devices: low-power and high-power. Low-power devices draw at most 1 unit load, with minimum operating voltage of 4.4 V in USB 2.0, and 4 V in USB 3.0. High-power devices draw the maximum number of unit loads supported by the standard. All devices default as low-power but the device's software may request high-power as long as the power is available on the providing bus.[35]
    Some devices like high-speed external disk drives may require more than 500 mA of current[36] and therefore cannot be powered from one USB 2.0 port. Such devices usually come with Y-shaped cable that has two USB connectors to be inserted into a computer. With such a cable a device can draw power from two USB ports simultaneously.[37]
    A bus-powered hub is initialized at 1 unit load and transitions to maximum unit loads after hub configuration is obtained. Any device connected to the hub will draw 1 unit load regardless of the current draw of devices connected to other ports of the hub (i.e. one device connected on a four-port hub will only draw 1 unit load despite the fact that all unit loads are being supplied to the hub).[35]
    A self-powered hub will supply maximum supported unit loads to any device connected to it. An externally-powered hub (battery or DC converter) may supply maximum unit loads to ports. In addition, the VBUS will supply 1 unit load upstream for communication if parts of the Hub are powered down.[35]
    In Battery Charging Specification,[38] new powering modes are added to the USB specification. A host or hub Charging Downstream Port can supply a maximum of 1.5 A when communicating at low-bandwidth or full-bandwidth, a maximum of 900 mA when communicating at high-bandwidth, and as much current as the connector will safely handle when no communication is taking place; USB 2.0 standard-A connectors are rated at 1.5 A by default. A Dedicated Charging Port can supply a maximum of 1.8 A of current at 5.25 V. A portable device can draw up to 1.8 A from a Dedicated Charging Port. The Dedicated Charging Port shorts the D+ and D- pins with a resistance of at most 200 Ω. The short disables data transfer, but allows devices to detect the Dedicated Charging Port and allows very simple, high current chargers to be manufactured. The increased current (faster, 9 W charging) will occur once both the host/hub and devices support the new charging specification."
    forrás: [link]
