- ROG STRIX B660-F GAMING WIFI
- GIGABYTE B760 GAMING X AX WIFI - Garancia 2027.09.06.
- Apple iPhone 13 256GB / Kártyafüggetlen / 12Hó Garancia / 100% Akku
- HP 14 Elitebook 640 G9 FHD IPS i5-1235U 4.4Ghz 10mag 16GB 256GB Intel Iris XE Win11 Pro Garancia
- BESZÁMÍTÁS! ASRockB450M R5 5600X 16GB DDR4 512GB SSD STRIX RTX 2070 SUPER 8GB GameMax Aero Mini 700W
- LG 27UN880-B - 27" IPS ERGO - 3840x2160 4K - 60Hz - DisplayHDR 400 - USB Type-C - AMD FreeSync - Mac
- Bomba ár! Lenovo ThinkPad Yoga 12 - i5-G5 I 8GB I 128SSD I 12,5" FHD Touch I Cam I W10 I Garancia!
