- G.SKILL Trident Z RGB 16GB (2x8GB) 3000MHz DDR4 kit/ BESZÁMÍTÁS OK!
- BONTATLAN Corsair Vengeance 32GB KIT (2x16GB) DDR5 7000MHz CL34 Black - 99 hó gari
- BONTATLAN Corsair Vengeance 32GB KIT (2x16GB) DDR4 3600MHz CL18 RGB PRO SL - 5 év gari
- ASUS ROG STRIX X870-A Gaming WIFI alaplap Bontatlan
- BONTATLAN Corsair Vengeance 32GB KIT (2x16GB) DDR5 7200MHz CL34 - 99 hó gari
