- Új, bontatlan Corsair 32GB (2x16GB) KIT DDR5 6000MHz CL36 Vengeance White XMP - 10 év bolti gari!
- Kingston FURY 64GB (2x32GB) KIT DDR5 6000MHz CL36 Beast Black XMP/EXPO - 1 év bolti garival! -
- Asus H110-PLUS/ i3 6100/ ingyen foxpost/ garancia
- Lexar Ares RGB 32GB (2x16GB) DDR5 6000MHz CL28 - Élettartam garancia
- Kingston Fury Beast 32GB DDR5 5600MHz CL32 RAM
