Hardtech
válasz ReFleXx #55537 üzenetére
Nekem is ezt az ip-t írta a Blizzard hogy ott a gond. Irtam a diginek semmi valasz.
" I checked and found that the issue seems to lie with your internet service provider (at the ip of 10.1.127.5)!
If you actually show that winMTR to your ISP they'll be able to see that they are not only having packetloss on their servers but also high latency (often caused by packetloss). They can then look let you know when the
issue will be fixed if they're able to identify it!"Itt egy mostani teszt:
Ping statistics for 10.1.127.5:
Packets: Sent = 30, Received = 24, Lost = 6 (20% loss),
Olvasd el az összefoglalót!
Társtopikok:
● DIGI kábel TV
● DIGI Mobil
● DIGI műholdas TV
● DIGI vezetékes telefon
● Milyen routert?
● Router gondok
- DuckDuckGo böngésző
- Melyik tápegységet vegyem?
- Poco X3 Pro - hardverfrissítés
- Call of Duty: Warzone
