- Bomba ár! Dell Latitude E5450 - i5-5GEN I 8GB I 128SSD I 14" FHD I HDMI I Cam I W10 I Gari!
- Samsung Galaxy Watch FE / 16GB / Bluetooth / Wi-fi / GPS / 1 Hónap garancia
- LG 27GR95QE - 27" OLED / QHD 2K / 240Hz & 0.03ms / NVIDIA G-Sync / FreeSync Premium / HDMI 2.1
- Geforce GTX 1050, 1050 Ti, 1060, 1650, 1660 - GT 1030 - Low profile is (LP)
