- KINGSTON FURY 32GB Beast DDR5 5200MHz CL40 KIT KF552C40BBK2-32
- Új, bontatlan Kingston FURY 32GB (2x16GB) DDR5 6000MHz CL36 Beast XMP/EXPO - 2 év bolti garival! -
- ASUS Prime B550M-K alaplap 24 hó gari
- Alienware 17r4 olvass
- AKCIÓ! HP EliteBook x360 830 G7 i5-10210U 16GB 512GB 1 év garancia
- LG 50QNED85T3A / QNED / 50" - 127 cm / 4K UHD / 120Hz / HDR Dolby Vision / FreeSync Premium / VRR
- Xiaomi Redmi Note 11 Pro / 6/128GB / Kártyafüggetlen / 12Hó Garancia
