- G.SKILL Trident Z5 Royal NEO RGB 32GB (2x16GB) DDR5 6000MHz CL28
- Új, bontatlan G.SKILL 32GB (2x16GB) KIT DDR5 6000MHz CL36 Ripjaws M5 Neo RGB White EXPO - 10 év gari
- Új, bontatlan ADATA XPG 32GB (2x16GB) KIT DDR5 6000MHz CL30 Lancer Blade Black XMP/EXPO - 10 év gari
- Új, bontatlan ADATA XPG 48GB (2x24GB) KIT DDR5 6000MHz CL30 Lancer Blade RGB Black - 10 év garival!
- Patriot Viper RGB Elite 5 Ultra - 48GB (2x24) DDR5 6000MHz CL28 - 10 év garancia
- HP ProBook 650 G8 Intel i5-1145G7 16GB 512GB magyarbill 1 év garancia
- Bomba ár! Asus Vivobook X411UA - i3-7GEN I 8GB I 128SSD I HDMI I 14" HD I Cam I W11 I Garancia!
- 184 - Lenovo Legion Pro 7 (16IAX10H) - Intel Core U9 275HX, RTX 5090
- LG 27UL500P-W - 27" IPS - 3840x2160 4K - 60Hz 5ms - HDR10 - AMD FreeSync - 300 Nits - sRGB 99%
